Why Do External SSDs Fail?
External SSDs have a failure point that internal SSDs don't: the USB bridge controller. This chip translates between the USB protocol your computer speaks & the NVMe or SATA protocol the internal drive uses. Most external SSD failures happen at the bridge, not the NAND storage.
The bridge chip is vulnerable in ways internal SSDs aren't. Drop a Samsung T7 on concrete & the USB-C connector can shear off its PCB solder pads. Plug into a cheap USB hub with unstable 5V power & the bridge's voltage regulator can fry.
Leave it in a hot car & thermal cycling weakens the BGA solder joints under the bridge IC. The NAND flash inside doesn't care about any of this; it's solid-state with no moving parts.
When the bridge dies, the drive disappears. Your computer won't see it in File Explorer, Disk Management, or even BIOS. The data is still sitting on the NAND chips inside the enclosure, but there's no communication path to reach it without lab intervention. Bypassing or repairing the bridge to read that NAND is the core of our SSD data recovery service.
Common External SSD Failure Causes
- USB bridge controller failure: The ASMedia, JMicron, or Realtek bridge chip stops responding. The drive doesn't enumerate on any USB port or any computer.
- USB-C connector damage: Physical impact tears the USB-C port off the PCB. Visible as a loose or recessed connector, intermittent connection, or no connection at all.
- Bus-powered voltage damage: Erratic 5V from a failing laptop battery or cheap hub fries the bridge's power management circuit. The drive may get warm when plugged in but never shows up.
- Firmware corruption on the bridge: A sudden disconnect during a write can corrupt the bridge firmware. The drive may enumerate as an unknown USB device with 0 bytes capacity.
- Internal SSD failure: Less common, but the NVMe or SATA drive inside can suffer controller or firmware corruption independent of the bridge.
Does Recovery Software Work on a Dead External SSD?
Recovery software works when the external SSD is physically healthy but has a logical problem: accidentally deleted files, a corrupted partition table, or a formatted volume. Software can't fix a dead bridge controller because the drive doesn't appear to the operating system at all.
Tools like Disk Drill, EaseUS, PhotoRec, & R-Studio communicate with storage devices through the OS driver stack. If the bridge chip is dead, the OS never assigns a drive letter or device node. There's nothing for the software to talk to.
This isn't a limitation of the software; it's physics. A dead bridge means no USB enumeration, which means no data path.
One more factor specific to SSDs: if you deleted files and the drive was still working when you deleted them, TRIM likely already erased those blocks.
On a modern SSD with TRIM enabled (the default on Windows 7+ and, on macOS, for Apple-shipped SSDs), the controller unmaps the deleted logical blocks and schedules them for garbage collection. Subsequent software reads return zeroes through Deterministic Read Zero after TRIM before the NAND cells are physically erased. Once background garbage collection physically erases those cells, no software and no lab can reverse it.
Recovery is only possible if TRIM didn't execute on those specific blocks.
When the failure is physical, you need a lab with PC-3000 SSD & board-level repair capability. That's where professional recovery starts: bridge repair costs $450–$600 for SATA-based externals & $900–$1,200 for NVMe-based externals.
What Should You Do First When an External SSD Fails?
Stop using the external SSD after the first serious symptom: disappearing from Disk Management, reporting 0 bytes, disconnecting during transfers, or getting hot at the USB-C port. The first 10 minutes matter because repeated reconnects can trigger TRIM, corrupt bridge firmware, worsen NAND read errors, or push an unstable RTL9210 bridge into total failure.
- Unplug the drive once. Don't keep reconnecting a Samsung T7, SanDisk Extreme, WD My Passport SSD, or RTL9210 enclosure to see if it comes back. Repeated USB resets can turn an intermittent bridge problem into a firmware problem.
- Try one known-good cable and one direct USB port. Skip hubs, docks, front-panel ports, & bus-powered adapters. A healthy USB 3.0 port supplies 900mA at 5V; a weak cable or hub can make a good bridge board look dead.
- Check whether the computer sees a device, not just a drive letter. If Windows Device Manager sees a USB Mass Storage device but Disk Management shows 0 bytes, the bridge is talking but the internal SSD firmware or FTL may be stuck.
- Do not initialize, format, run CHKDSK, or update bridge firmware. If the external SSD is encrypted, consumer repair steps can break the bridge-controller relationship needed for hardware-encryption recovery.
- Send the drive before the symptoms change. Free evaluation at our Austin, TX lab separates bridge failure from SSD firmware corruption. If the internal drive is NVMe, the next step is direct NVMe PCIe data recovery with PC-3000 SSD.
How We Recover Data from External SSDs
External SSD recovery follows a four-step process: open the enclosure, diagnose whether the bridge or the internal drive failed, repair or bypass the failed component, then image the data using PC-3000. All work happens at our Austin, TX lab.
- 01
Open the enclosure and inspect
We disassemble the external housing & identify the internal drive type. SanDisk Extreme V2, WD My Passport SSD, & Crucial X8 use M.2 NVMe drives behind an ASMedia ASM2362 bridge. The Samsung T7 integrates the bridge, NVMe controller, & NAND onto a single custom PCB.
Older models like the Seagate One Touch SSD use a compact custom SATA PCB behind a JMicron JMS578 bridge.
The internal architecture determines the recovery path.
- 02
Diagnose bridge vs. internal drive failure
Using FLIR thermal imaging & multimeter probing, we determine whether the bridge chip, its power delivery circuit, or the internal SSD itself failed. If the bridge board shows a shorted voltage regulator (visible as a hot spot on thermal), the internal drive is likely fine. If the bridge passes diagnostics but the internal NVMe doesn't respond on a PCIe adapter, the failure is inside the SSD.
- 03
Repair or bypass the bridge
For non-encrypted drives, we can often remove the internal M.2 or SATA drive, connect it directly to PC-3000 SSD via a PCIe or SATA adapter, & image the data without touching the bridge.
- 04
Image and extract your data
With the data path restored, PC-3000 SSD or PC-3000 Portable III images the drive sector-by-sector. We verify file integrity, copy your data to a target drive, & ship it back. No data, no recovery fee.
How Much Does External SSD Recovery Cost?
External SSD recovery costs $200–$1,500 for SATA-based externals & $200–$2,500 for NVMe-based externals. The tier depends on the failure type: bridge bypass on a non-encrypted drive is the lowest tier, while encrypted bridge repair or NAND-level work is higher.
Most external SSDs manufactured after 2019 use NVMe drives internally (Samsung T7, T9, SanDisk Extreme V2, Crucial X8, WD My Passport SSD). Older models with SATA internals (Seagate One Touch SSD, older Samsung T5) fall under SATA SSD pricing. We'll identify the internal drive type during the free evaluation & give you a firm quote.
If the recovery requires a donor bridge board for component harvesting, the donor cost is additional. A donor drive is a matching SSD used for its circuit board. Typical donor cost: $40–$100 for common models, $150–$300 for discontinued or rare controllers. Rush service: +$100 rush fee to move to the front of the queue.
SATA External SSD Pricing (Older Models)
NVMe External SSD Pricing (Samsung T7/T9, SanDisk Extreme, WD, Crucial)
Which USB Bridge Controller Is Inside Your External SSD?
Most external SSDs contain a USB bridge controller that translates between USB 3.x & the internal storage protocol (NVMe or SATA). Some newer models use native USB SSD controllers instead. The bridge chip model determines the failure modes, encryption behavior, & recovery approach.
Knowing which bridge is inside your enclosure is the first diagnostic step.
| External SSD | Bridge Chip | Internal Protocol | Hardware Encryption |
| Samsung T7 / T7 Touch | ASMedia ASM2362 | NVMe to USB 3.2 Gen2 | Optional (T7 Touch fingerprint) |
| Samsung T9 | ASMedia ASM2364 | NVMe to USB 3.2 Gen2x2 | Optional (software password) |
| SanDisk Extreme V2 | ASMedia ASM2362 | NVMe to USB 3.2 Gen2 | AES-256 (internal NVMe controller) |
| WD My Passport SSD | ASMedia ASM2362 | NVMe to USB 3.2 Gen2 | AES-256 (internal NVMe controller) |
| Crucial X8 | ASMedia ASM2362 | NVMe to USB 3.2 Gen2 | None (standard bridge) |
| Seagate One Touch SSD | JMicron JMS578 | SATA to USB 3.1 Gen1 | None (standard bridge) |
| LaCie Rugged SSD | JMicron JMS583 | NVMe to USB 3.1 Gen2 | None (standard bridge) |
| Generic NVMe enclosures (Orico, Ugreen, Sabrent) | Realtek RTL9210 | NVMe to USB 3.2 Gen2 | None (standard bridge) |
| Generic dual-protocol enclosures (Orico, Ugreen, Sabrent) | Realtek RTL9210B | NVMe + SATA to USB 3.2 Gen2 | None (standard bridge) |
| Commodity 2.5" SATA SSD enclosures (Orico, Sabrent, Inateck, StarTech) | ASMedia ASM235CM | SATA to USB 3.2 Gen2 (UASP) | None (standard bridge) |
Identify Your Bridge Chip by USB VID/PID
Before opening the enclosure, you can identify the bridge chip from the USB Vendor ID & Product ID the drive advertises. On Linux or macOS Terminal: run lsusb (Linux) or system_profiler SPUSBDataType (macOS). On Windows: Device Manager > right-click the device > Properties > Details tab > Hardware Ids. Cross-reference against the table below.
Where the identifier does not pin down a chip revision, the markings on the PCB do. Opening the enclosure is the reliable answer.
| Bridge | VID:PID | Notes & Limitation |
| ASMedia ASM2362 | 174C:2362 | 10 Gbps USB-NVMe bridge; used in SanDisk Extreme V2, WD My Passport SSD, Samsung T7, Crucial X8. |
| ASMedia ASM2364 | 174C:2364 | 20 Gbps USB 3.2 Gen 2x2 bridge; used in Samsung T9 & SanDisk Extreme Pro V2. |
| JMicron JMS583 | 152D:0583 | USB 3.1 Gen 2 to PCIe Gen3x2 NVMe bridge; common in LaCie Rugged SSD & mid-tier NVMe enclosures. |
ASMedia ASM2362 Failure Patterns
The ASM2362 is the most common bridge chip in NVMe external SSDs. It handles USB Attached SCSI Protocol (UASP) translation for the NVMe command set. Two failure patterns dominate our bench.
First: enumeration without LUN exposure. The bridge enumerates on USB (the OS sees a device) but doesn't expose the Logical Unit Number. Disk Management shows nothing. Board-level rework at $900–$1,200 covers a bridge that has stopped responding.
Device Manager shows a "USB Mass Storage Device" with 0 bytes. This indicates bridge firmware corruption or a failed NVMe initialization handshake between the ASM2362 & the internal drive's controller.
On SanDisk Extreme V2 drives suffering the documented solder-joint fracture failure (Attingo Data Recovery; Krum v. Western Digital class action), Windows Device Manager enumerates the failing drive as a 55DD SCSI Disk Device with 0 bytes of capacity. On macOS, System Information shows the bridge on the USB bus at a 10 Gb/s link speed, but no /dev/diskX device is created & the drive never appears in Disk Utility. Both signatures point to the same root cause: the ASM2362 package was oversized for its PCB pad layout, sat raised on the outer edges, & the solder joints fractured under thermal cycling.
Linux dmesg signature (ASM2364)
On ASM2364-based enclosures (Samsung T9, SanDisk Extreme Pro V2), the kernel reports SCSI cache synchronization failures when the bridge drops mid-operation:
sd 0:0:0:0: [sda] Synchronizing SCSI cache
sd 0:0:0:0: [sda] Synchronize Cache(10) failed: Result: hostbyte=DID_ERROR driverbyte=DRIVER_OKJMicron JMS578/JMS583 Failure Patterns
JMicron bridges handle SATA-to-USB (JMS578) and NVMe-to-USB (JMS583) translation. The JMS578 is found in older SATA-based external SSDs like the Seagate One Touch SSD. These chips are less complex than the ASMedia NVMe bridges & tend to fail from voltage regulator burnout rather than firmware issues.
Recovery on a JMS578-based drive is often simpler: remove the internal SATA board, connect directly to PC-3000 SSD via SATA, & image. SATA SSD recovery starts at $200.
Linux dmesg signature (JMS583 TRIM/UNMAP firmware bug)
The JMS583 has a documented firmware bug in its TRIM/UNMAP handling on Linux, reproduced reliably on Proxmox + ZFS configurations. When the host issues a DISCARD command on an address near the end-of-device, the bridge returns Illegal Request & the kernel logs the following sequence:
sd 6:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
sd 6:0:0:0: [sda] tag#0 Sense Key : Illegal Request [current]
sd 6:0:0:0: [sda] tag#0 Add. Sense: Logical block address out of range
sd 6:0:0:0: [sda] tag#0 CDB: Unmap/Read sub-channel 42 00 00 00 00 00 00 00 18 00
critical target error, dev sda, sector 1116008816 op 0x3:(DISCARD) flags 0x0 phys_seg 1 prio class 0This signature indicates a JMS583 protocol-translation firmware bug, not NAND damage. The underlying SSD is healthy. Bypassing the bridge & imaging the M.2 drive directly over native PCIe avoids the failing UNMAP code path entirely.
Realtek RTL9210/RTL9210B Failure Patterns
The RTL9210 is the default bridge chip in budget NVMe enclosures from Orico, Ugreen, & Sabrent. It translates NVMe to USB 3.2 Gen2 at 10 Gbps. The RTL9210B adds dual-protocol support, handling both NVMe & SATA M.2 drives in the same enclosure.
Neither chip implements hardware encryption, which is good news for recovery: if the bridge dies, we remove the M.2 drive & connect directly to PC-3000 via a PCIe or SATA adapter, bypassing the dead bridge entirely.
The RTL9210's most common failure mode is thermal dropout during sustained writes. The chip runs hot under continuous load in an unventilated enclosure. When it hits its thermal limit, it disconnects from USB without warning.
The drive vanishes mid-transfer.
Repeated thermal disconnects stress the firmware state machine & can brick the bridge permanently. Users see this as a drive that worked for small files but disconnects during any transfer over a few gigabytes.
The second pattern: firmware bricking from failed updates. Realtek periodically releases firmware updates for the RTL9210, & some enclosure vendors provide flashing utilities. A power interruption or USB disconnect during the firmware flash leaves the chip unresponsive.
The bridge won't enumerate on USB at all. Since the RTL9210 doesn't encrypt, recovery is straightforward: pull the M.2 NVMe drive, connect to PC-3000 SSD via PCIe adapter, image the NAND. Bridge bypass on a non-encrypted drive starts at $200.
A third pattern: the documented aggressive idle-timeout firmware bug. The RTL9210 issues an unsolicited USB disconnect after roughly 10 minutes of presumed idle, even when the drive is mounted & in use by long-running processes. The behavior is particularly disruptive on Linux & Raspberry Pi hosts where the disconnect freezes the I/O scheduler. Later RTL9210 firmware revisions (documented as 1.33.44 improving stability) reduce the aggression, but the fix is firmware-level & many enclosure vendors never ship updates. If the drive is still partially responsive, we read it through the bridge in controlled passes between disconnects; if it has brick-flashed into a non-enumerating state, we bypass to native PCIe.
Linux dmesg signature (RTL9210 Read Capacity failure)
When an RTL9210 enumerates on USB but fails the SCSI Read Capacity handshake, the drive appears in lsusb & in dmesg as a storage device, but it never receives a block device node & will not mount:
sd 0:0:0:0: [sda] Read Capacity(10) failed: Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
sd 0:0:0:0: [sda] Sense Key : Illegal Request [current]
sd 0:0:0:0: [sda] Add. Sense: Invalid command operation code
sd 0:0:0:0: [sda] 0 512-byte logical blocks: (0 B/0 B)This is bridge enumeration without successful capacity negotiation. The host sees a device but the bridge cannot complete the LUN size handshake with the internal SSD. Bridge bypass to native PCIe sidesteps the broken handshake entirely.
ASMedia ASM235CM Failure Patterns
The ASM235CM is transparent; it does not implement hardware encryption, which simplifies recovery when the bridge itself fails.
Two ASM235CM failure patterns recur on our bench. First: 5V regulator burnout under bus power. The ASM235CM reference design uses a single 5V bus-powered rail feeding an onboard LDO that derives the 3.3V & 1.2V the bridge silicon needs.
Erratic 5V from a failing laptop port or an unpowered hub burns the LDO, the bridge never boots, & the enclosure enumerates as nothing on the host.
FLIR thermal imaging locates the shorted regulator; Hakko FM-2032 rework swaps it. For SATA externals with a dead ASM235CM board, bypass is usually faster than repair: remove the 2.5" SATA SSD, connect it directly to PC-3000 SSD via the SATA port, & image. Bypass recovery on a non-encrypted SATA external starts at $200; bridge board repair tier is $450–$600.
Second: TRIM passthrough stalls on specific host chipsets. The ASM235CM's UASP firmware can hang when TRIM commands interleave with queued reads on certain Intel & AMD USB host controllers, leaving the drive visible in Device Manager but unresponsive to reads. Power-cycling the enclosure clears the stall temporarily, but the underlying firmware bug is uncorrectable without a vendor firmware update that most enclosure manufacturers never ship.
When the stall coincides with an in-flight write, the on-drive FTL can end up in an inconsistent state; at that point the failure migrates from bridge-level to SSD controller firmware corruption & recovery moves to the firmware repair tier.
UASP Flaps & BOT Fallback During Imaging
UASP makes healthy external SSDs fast, but it is hostile to failing NAND. Queued USB commands are expected to complete on time; if the internal SSD pauses for LDPC error correction, the transfer can end in a USB reset mid-read.
Lab imaging removes that weak link. We bypass the bridge when the drive is not encrypted, connect the SATA or NVMe SSD to PC-3000 SSD, & image through a direct interface instead of the consumer UASP path. If the bridge must stay in circuit for encryption, we reduce command queue depth & image in controlled passes so the original controller stays online.
4Kn vs 512e Sector Translation Problems
Some USB bridge boards present the same SSD differently than a native SATA or PCIe adapter. A bridge may expose one logical sector size to the operating system while the internal SSD reports another geometry over its native interface, which makes file system offsets look wrong after a simple DIY enclosure swap.
PC-3000 SSD imaging lets us normalize the sector layout before file system extraction. That matters on exFAT, NTFS, & APFS volumes because one sector-size mismatch can shift every metadata structure. The drive may be readable at the block level but still look empty until the USB bridge translation is accounted for.
How Do We Image a Failing External SSD Without Triggering a USB Reset?
A failing external SSD pauses while its internal controller runs LDPC error correction. On a UASP link that pause can end in a USB reset mid-read, so the imaging job restarts & the weak NAND takes another beating. When we have to read through the bridge, we force the enclosure into legacy Bulk-Only Transport mode & pin the SCSI queue depth to 1 so one slow read never trips a bus reset.
Forcing BOT Mode & Queue Depth 1
UASP (USB Attached SCSI Protocol) keeps multiple commands in flight & expects each to finish on a deadline. That makes a healthy Samsung T7 or RTL9210 enclosure fast. On a drive with marginal NAND, a single read can stall for hundreds of milliseconds while the controller decodes a weak page, and a stall long enough to miss that deadline ends in a reset.
We disable UASP & force the enclosure to fall back to legacy Bulk-Only Transport, which sends one command at a time with no queue. On Linux that is theusb-storage.quirks flag carrying the device VID:PID with a u attribute; the controlled alternative is imaging through a USB 2.0 reader, which has no UASP path at all.
With queue depth pinned to 1 & no UASP deadline to miss, a read that pauses for LDPC correction simply waits instead of triggering a reset. Throughput drops, but the drive stays enumerated across a multi-hour pass instead of dropping off the bus every few minutes. This is slower than a direct PC-3000 SSD interface, so we only use it when the bridge must stay in the loop.
Multi-Bay Enclosures: One Cold Solder Joint Drops Every Drive
A multi-bay external enclosure does not use a simple bridge. It runs a multi-port PCIe-to-SATA controller or a port multiplier such as the JMicron JMB585 (5-port) or ASMedia ASM1166 (6-port) behind its USB bridge. These ICs sit in a thermally hostile box behind multiple spinning or solid-state drives, & the BGA solder joints under them fatigue from repeated heat-up & cool-down cycles.
When one of those joints goes cold, the symptom is distinct from a single portable SSD's dead bridge: every drive in the chassis disappears at once, even though the drives themselves are fine. The shared controller is the single point of failure for the whole array.
We locate the open joint with FLIR thermal imaging, then reflow or replace the controller on a Zhuo Mao BGA rework station & bring the whole bank of drives back online. Board repair on this class of enclosure falls in the $450–$600 (SATA) to $900–$1,200 (NVMe) bridge-repair range, with the internal drives imaged afterward.
ESD-Damaged Protection Array: A Bad Cable That Kills Enumeration
A bridge board carries a small ESD protection array on the USB data & power lines, usually a TVS diode network sitting between the USB-C connector & the bridge silicon. A cheap or damaged cable, a static discharge, or a hot-plug surge can blow one of those protection ICs.
Once it shorts or goes leaky, it clamps the data lines & the host never completes enumeration; the drive looks as dead as a failed bridge even though the bridge silicon is fine.
The diagnostic difference matters because the fix is cheaper than a bridge swap. We probe the protection array for a short, then replace the failed ESD ICs by microsoldering with a Hakko FM-2032 on its FM-203 base. With the clamp gone, the data lines swing clean again & the drive enumerates. From there the internal drive images normally. This is the lowest-effort case in the bridge-repair tier, $900–$1,200 on an NVMe external.
Other Bridges Seen on the Bench
ASMedia, JMicron, & Realtek cover most of what comes through, but older & white-label enclosures still arrive with bridges from Initio, VIA Labs, Cypress, & Genesys Logic. The recovery logic is the same regardless of vendor: identify the bridge, decide whether we can remove it to reach the internal drive, & if it must stay in circuit, image through it in BOT mode at queue depth 1. We identify the exact bridge during the free evaluation before quoting.
Native USB-NVMe Controllers (No Bridge to Bypass)
A 2023-2025 generation of portable SSDs replaces the two-chip bridge + NVMe SSD architecture with a single-chip native USB flash controller that talks USB on one side & NAND on the other. There is no internal NVMe drive to extract; the whole drive is one controller IC & bare NAND on a single PCB.
For recovery, this changes the math. Bridge bypass is not a thing here because there is no bridge to bypass. The USB protocol & the NAND interface terminate on the same die. Hardware encryption is integrated into that same die.
Chip-off yields ciphertext on any model that enables the integrated AES-256 engine. Recovery happens through the original controller, on the original PCB, via vendor-specific Technological Mode commands in PC-3000 SSD.
Silicon Motion SM2320
The SM2320 is a single-chip USB 3.2 Gen 2x2 (20 Gbps) flash controller with four NAND channels & an integrated AES-256 engine. Documented host devices include the Kingston XS2000, Lexar SL500, Crucial X9 Pro, & Biwin Amber PR2000.
There is no internal NVMe to pull. The SM2320 die manages the FTL, ECC, & AES engine directly against bare TLC NAND on the same PCB.
Rossmann does not currently offer in-lab recovery for the Silicon Motion SM2320. The SM2320 is a native single-chip USB controller with no SATA or NVMe host interface. With AES-256 integrated on the same die, chip-off yields ciphertext.
Phison U17
The U17 is a DRAM-less USB 3.2 Gen 2 (10 Gbps) flash controller from Phison's native portable line. Documented host devices include the Crucial X9 (non-Pro), the 4TB variant of the Crucial X6, & Inland Platinum portable SSDs.
Because it is DRAM-less, the U17 leans on Host Memory Buffer-equivalent caching for FTL pages, which means an interrupted write can leave the mapping table in an inconsistent state.
Rossmann does not currently offer in-lab recovery for the Phison U17. The U17 is a monolithic native USB controller with no SATA or NVMe host interface, so there is no internal drive to pull and read on its own.
Phison U18
The U18 is the USB 3.2 Gen 2x2 (20 Gbps) sibling to the U17. Documented host devices include the Sabrent Rocket Nano V2, PNY EliteX-PRO, & Corsair EX100U.
Rossmann does not currently offer in-lab recovery for the Phison U18. Like the U17, the U18 is a monolithic native USB controller with no SATA or NVMe host interface, so there is no internal drive to pull and read on its own.
InnoGrit IG5236
The IG5236 is an 8-channel PCIe 4.0 NVMe controller. Unlike the native USB chips above, the IG5236 is a traditional NVMe controller that sits behind a USB bridge when used in an external enclosure; it appears in DIY portable builds that pair an internal M.2 NVMe with a bridge IC rather than in true single-PCB native-USB designs.
InnoGrit is absent from the ACELab PC-3000 SSD supported vendor list, so the vendor command set required for Technological Mode boot, FTL reconstruction, & firmware module repair is not available to us. Hardware AES-256 binds the media encryption key to the IG5236 die. If your drive uses the IG5236, we will identify it during free evaluation & tell you before any work begins.
Documented Firmware Bugs in Portable SSDs
Two portable-SSD failures come into the lab often enough to call out by name. Each one looks like hardware death from the user side. Neither internal controller is on the ACELab PC-3000 SSD supported list.
SanDisk Extreme & Extreme Pro Portable SSD (2023) Scrambled Allocation Metadata
Affected models: 2TB & 4TB SanDisk Extreme & Extreme Pro portable SSDs from the 2023 production batch. Symptoms: files spontaneously disappear, the file system corrupts during normal use, & the drive mounts as Unrecognized or RAW.
Mechanism: teardown analyses attribute the failures to board-level hardware flaws, weak solder joints and oversized components. Those teardown reports do not isolate the defect to the internal NVMe board versus the bridge board, so we do not assume which one failed before the drive is on the bench.
Recovery implication: consumer recovery software fails because the drive reports corrupted geometry & the file system structure is fragmented across the wrong physical blocks. The internal NVMe controller is a WD/SanDisk in-house design, which has no PC-3000 SSD active utility for FTL reconstruction. Recovery relies on bridge bypass and direct imaging of the internal NVMe drive, or board-level repair so the controller mounts its own namespace and images through its native mapping. Typical tier: $900–$1,200.
InnoGrit IG5236 "MN-5236" 2.1 GB Panic State
Symptoms: the drive enumerates with model name reporting as "MN-5236" instead of its branded model, & capacity reporting as 2 MB or 2.1 GB instead of the actual TB-class capacity.
Mechanism: the IG5236 controller hits a NAND read exception or a thermal / diagnostic event, drops its programmed identity & firmware-resident model metadata, & reverts to its silicon factory ROM descriptor. The factory ROM advertises a generic "MN-5236" identity with a tiny placeholder capacity. The user data is still on the NAND, but the controller no longer knows where.
Hardware AES-256 binds the media encryption key to the IG5236 die, so recovery has to go through the original controller. InnoGrit is absent from the ACELab PC-3000 SSD supported vendor list, so the vendor command set needed to clear the panic state & rebuild the FTL is not available to us.
Can You Shuck a WD, SanDisk, or Seagate External SSD and Read the Drive Inside?
The practical question for any branded external SSD is whether you can shuck it & read the internal drive, or whether the original board has to be repaired first. On the WD My Passport SSD & SanDisk Extreme, that turns on whether hardware encryption is active on your unit, which is established at evaluation.
| External SSD | Internal Interface | Encryption Binding | Recovery Decision |
| WD My Passport SSD | NVMe, WD in-house SSD behind the bridge | Password enabled AES-256; state confirmed at evaluation | If encryption is active, repair the original board; shucking or chip-off then yields ciphertext |
| WD_BLACK P50 | NVMe, USB 3.2 Gen 2x2 bridge | Confirmed at evaluation | Identify the bridge & encryption state before any work |
| SanDisk Extreme / Extreme Pro | NVMe, in-house controller, USB 3.2 Gen 2 (Gen 2x2 on the Pro) | Hardware AES-256; active state confirmed at evaluation | If encryption is active, repair the original board; chip-off then yields ciphertext |
WD My Passport SSD & WD_BLACK P50
The WD My Passport SSD runs an in-house WD NVMe SSD behind its bridge. Western Digital describes the drive as carrying "password enabled 256-bit AES hardware encryption", and its own manual notes that not every Western Digital product ships with active encryption, so whether a given unit's data is locked to its original board is established on the bench rather than assumed.
Rossmann does not currently offer in-lab recovery for WD in-house NVMe silicon. That silicon is not on the ACELab PC-3000 SSD supported list, so the recovery path is board-level repair, not a controller utility & never chip-off.
We locate the failed component with FLIR thermal imaging, rework it with a Hakko FM-2032, & bring the original board back so the controller powers up in its trusted environment & decrypts its own namespace. Board repair on an NVMe external runs $900–$1,200.
The WD_BLACK P50 is a rugged portable NVMe SSD on a USB 3.2 Gen 2x2 interface. Its exact USB bridge part is not something we will name from memory; we identify it on the bench. Free evaluation confirms which bridge the P50 uses & whether its internal NVMe has hardware encryption active before any work or quote, because that single fact decides whether the internal drive can be read directly or the original board has to be repaired. A donor drive is a matching SSD used for its circuit board. Typical donor cost: $40–$100 for common models, $150–$300 for discontinued or rare controllers.
The SanDisk Extreme & Extreme Pro Portable run an in-house NVMe controller with hardware 256-bit AES. SanDisk lists the Extreme Portable SDSSDE61 as USB 3.2 Gen 2 and the Extreme PRO Portable SDSSDE81 as USB 3.2 Gen 2x2. The encryption decision is the same as WD: whether encryption is active on a given unit is established on the bench, and when it is, the key lives in the original controller.
Rossmann does not currently offer in-lab recovery for the SanDisk in-house NVMe controller. It is not on the ACELab PC-3000 SSD supported list, which is why the work is board-level microsoldering rather than a utility loader.
Drives hit by the documented 2023 SanDisk data-loss defect (covered in the firmware-bugs section above) come in unreadable or unmountable; the fault is inside the internal NVMe drive, not the USB bridge, & the recovery decision still comes down to hardware-encryption handling on the original board. NVMe board repair runs $900–$1,200.
Drop-induced USB-C shear is a general portable-SSD risk, not a SanDisk-specific defect, so we diagnose the connector on the bench rather than assume it.
Seagate Fast SSD
Seagate does not publish what is inside the Fast SSD, so we open it and read the board rather than working from a spec sheet. If the internal drive is a standard SATA or NVMe SSD that is not encryption-bound to the bridge, the first move is to connect it straight to PC-3000 SSD. Reading it directly starts at $200.
A drive that does not enumerate has a fault inside it, in the controller or the NAND. When the internal controller is one PC-3000 SSD supports, vendor-mode access can rebuild the FTL & system area & image through the controller's own mapping. That moves the job to the firmware tier at $600–$1,200. A severely damaged internal board can also be handled as a controller-level repair under our SSD data recovery service. Rush service: +$100 rush fee to move to the front of the queue.
How Does Hardware Encryption Change WD & SanDisk External SSD Recovery?
WD My Passport SSD & SanDisk Extreme carry password enabled AES-256 hardware encryption within the internal NVMe SSD, working in tandem with the bridge board. WD's own manual notes that not every Western Digital product ships with active encryption, so whether encryption is active on a given unit is established on the bench.
This creates a recovery problem that doesn't exist with non-encrypted external SSDs. On a Crucial X8, the internal M.2 NVMe drive stores plaintext. If the bridge dies, we remove the M.2 drive, plug it into a PCIe adapter, & image it with PC-3000 Portable III.
The bridge failure is irrelevant because neither the bridge nor the internal controller was encrypting anything.
Modern WD and SanDisk portable SSDs run proprietary in-house NVMe silicon; the older SATA SanDisk Extreme V1 used a Marvell 88SS1074 behind an ASM235CM bridge. AES-256 is implemented inside those proprietary controllers, and when encryption is active the key material stays with the original hardware, so chip-off of the NAND alone yields ciphertext.
Recovery Path for Encrypted WD/SanDisk External SSDs
If the failure is a blown voltage regulator, shorted capacitor, or damaged USB-C connector, we fix it with Hakko FM-2032 microsoldering & restore the bridge to operational state.
When bridge damage is severe (dead controller IC, lifted pads), component-level repair replaces the failed silicon. This falls into the circuit board repair tier at $900–$1,200 for NVMe-based WD/SanDisk models. A donor drive is a matching SSD used for its circuit board. Typical donor cost: $40–$100 for common models, $150–$300 for discontinued or rare controllers.
What Does Your External SSD Symptom Mean?
External SSD failures produce two distinct symptoms that point to different hardware problems & different recovery costs. A drive that isn't detected at all usually has a dead bridge controller. A drive that shows up with 0 bytes or "No Media" usually has an internal SSD firmware failure.
Distinguishing between the two during free evaluation determines your recovery tier.
| Symptom | Likely Cause | Recovery Approach | Typical Cost Tier |
| Drive not detected in Disk Management, Device Manager, or BIOS | Dead USB bridge controller or shorted PMIC on bridge board | Bypass bridge (non-encrypted) or repair bridge board with Hakko FM-2032 (encrypted WD/SanDisk) | $450–$600 (SATA) / $900–$1,200 (NVMe) |
| Shows in Device Manager as "USB Mass Storage" but 0 bytes / No Media | Bridge is alive but internal SSD controller firmware is corrupted; FTL mapping lost | Remove internal SSD, connect to PC-3000 SSD, reconstruct FTL & firmware modules | $600–$1,200 (SATA) / $900–$1,200 (NVMe) |
| Detected with wrong capacity (shows 8MB or 32MB instead of 500GB/1TB) | Internal SSD booted into safe mode; controller firmware partially corrupted | PC-3000 SSD firmware repair using controller-specific utility (Phison, Silicon Motion, Marvell) | $600–$1,200 (SATA) / $900–$1,200 (NVMe) |
| Intermittent disconnects during large file transfers | Bridge thermal throttling (RTL9210), cracked BGA solder joints, or failing USB-C connector | FLIR thermal diagnosis, Zhuo Mao BGA rework or USB-C connector replacement | $450–$600 (SATA) / $900–$1,200 (NVMe) |
| Drive gets warm when plugged in but never appears | Shorted voltage regulator on bridge board drawing current but not booting | FLIR thermal imaging to locate shorted component, Hakko FM-2032 replacement | $450–$600 (SATA) / $900–$1,200 (NVMe) |
| macOS "Disk you inserted was not readable" (mount failure) or Error 69760 on erase / format | Corrupted APFS or ExFAT partition table from unsafe eject or a bridge controller fault | PC-3000 SSD imaging with bridge bypass on non-encrypted models; bridge repair on WD/SanDisk encrypted models | $450–$600 (SATA) / $900–$1,200 (NVMe) |
| macOS fsck_exfat at 100% CPU after reconnecting an unsafely-ejected drive | ExFAT dirty bit triggers a macOS background repair pass that blocks the mount; the drive itself is not physically dead | Lab forces a clean image with PC-3000 SSD, then reconstructs the file system on the image instead of on the live drive | From $250 (SATA) / From $250 (NVMe) |
| Windows "A device which does not exist was specified" / RAW file system on the drive | Metadata damage on the internal SSD or partition table corruption | PC-3000 SSD vendor-mode imaging plus metadata reconstruction against the internal controller's FTL | $600–$1,200 (SATA) / $900–$1,200 (NVMe) |
Free evaluation determines which category your drive falls into. We diagnose using FLIR thermal imaging & multimeter probing at our Austin, TX lab. No diagnostic fee.
If we can't recover your data, you don't pay.
How Does Drop Damage Break an External SSD?
External SSDs survive drops better than external hard drives because they are solid-state devices with no moving parts. But the PCB, USB-C connector, & BGA solder joints under the bridge chip are still vulnerable to impact. Drop damage is a common cause of the physical SSD damage cases we see.
The most common drop failure: the USB-C connector shears off the PCB. The connector's surface-mount pads tear away from the board, sometimes lifting copper traces with them. The fix is Hakko FM-2032 microsoldering to run jumper wires from the surviving trace stubs to a replacement connector.
If traces are intact but the connector is physically broken, we desolder the damaged connector with Atten 862 hot air & solder a new one. Bridge board repair runs $450–$600 to $900–$1,200 depending on whether the internal drive is SATA or NVMe.
Less visible but equally damaging: BGA micro-fractures under the bridge chip. Thermal cycling from repeated heat/cool cycles (a drive that lives in a laptop bag, goes from 40C in a parked car to 20C indoors) weakens the solder balls connecting the ASM2362 to the PCB. A drop can crack these weakened joints.
The drive works intermittently or not at all. Diagnosis requires FLIR thermal imaging to locate the cold joint; repair requires Zhuo Mao precision BGA rework to reflow or reball the bridge IC.
Bus-Powered Voltage Instability
External SSDs draw power directly from the USB port. They don't have a separate power adapter. A healthy USB 3.0 port provides 900mA at 5V.
A failing laptop battery, a cheap unpowered USB hub, or a damaged cable can deliver erratic voltage that destroys the bridge's onboard voltage regulators. We locate the burned component using FLIR thermal imaging & replace it with a Hakko FM-2032.
The NAND and the internal SSD controller are almost always unaffected by bus voltage issues because the bridge's voltage regulators absorb the damage before it reaches the internal drive. This is good news for recovery: bridge failure from voltage damage usually means the data is intact on the NAND, waiting to be read once the power delivery is repaired.
How Does PC-3000 Image an External SSD After Bridge Bypass?
When the bridge is bypassed (non-encrypted drive) or repaired (encrypted drive), the internal SSD connects to PC-3000 via a direct interface. NVMe drives connect through a PCIe adapter. SATA drives connect through the PC-3000 SATA port.
From this point, recovery follows standard SSD data recovery procedures.
- Boot the controller into Technological Mode. PC-3000 SSD sends vendor-specific ATA or NVMe commands to put the internal SSD's controller into a diagnostic state. This bypasses the normal firmware boot sequence & allows direct access to NAND contents even when the FTL (Flash Translation Layer) is corrupted.
- Map NAND health. PC-3000 scans the NAND for bad blocks, read errors, & ECC failures. This map guides the imaging strategy: healthy regions image first, damaged regions get multiple read attempts at adjusted voltage thresholds.
- Image sector-by-sector. Full drive imaging proceeds from healthy to damaged areas. On drives with degraded 3D TLC or QLC NAND, read retry counts are adjusted to maximize yield before the cells degrade further from repeated read disturb.
- Reconstruct file system. The imaged data goes through file system analysis. NTFS, exFAT, APFS, or HFS+ structures are parsed. Files are verified for integrity and copied to a fresh target drive for return shipping.
Why Native NVMe PCIe Imaging Matters
A portable NVMe SSD behind USB is still an NVMe SSD. Once a non-encrypted bridge is out of the way, we treat the internal module like any other NVMe PCIe recovery target: controller identification, firmware access, NAND health map, then controlled imaging. The USB enclosure is only part of the failure if it changes power, protocol, or encryption behavior.
For drives where the internal SSD's controller is also damaged (rare, but possible with severe impact or electrical surge), the recovery moves into firmware repair at $600–$1,200 (SATA) or $900–$1,200 (NVMe). If both the bridge board & the internal drive's PCB are destroyed beyond repair, NAND swap to a donor PCB at $1,200–$1,500 (SATA) or $1,200–$2,500 (NVMe) is the last option. NAND swap requires a 50% deposit & works only on drives without hardware encryption (not WD My Passport SSD or SanDisk Extreme).
The PC-3000 Portable III workflow for external drives is an extension of the same controller-level methodology we apply across every solid state drive data recovery case at our Austin lab. Once the bridge is out of the data path (bypassed for non-encrypted drives, repaired for encrypted WD/SanDisk drives), the internal SATA or NVMe SSD is treated as a standalone target: vendor command set for Technological Mode, NAND health map, sector imaging, FTL reconstruction where needed, then file system extraction. Nothing about the USB enclosure changes the recovery physics past the bridge.
Why Does Bridge Board Microsoldering Matter for External SSD Recovery?
Most data recovery labs are equipped for firmware-level work with PC-3000 but not for component-level soldering. When an external SSD fails at the bridge hardware, those labs either outsource the board repair or declare the drive unrecoverable.
Board-level repair is the foundation of this shop, dating back to MacBook logic board repair since 2008.
For encrypted WD & SanDisk external SSDs, board repair IS data recovery.
FLIR thermal cameras locate the shorted or failed component. Hakko FM-2032 microsoldering irons on an FM-203 base station handle the precision work: replacing 0201-size capacitors, 0402 voltage regulators, & QFN package bridge chips.
Atten 862 hot air handles larger BGA rework. Zhuo Mao precision BGA rework stations handle bridge IC reballing when solder joints fail from thermal fatigue or drop impact.
This is the capability gap that separates Rossmann from firmware-only recovery labs. A dead ASM2362 with a shorted PMIC isn't a firmware problem. It's an electronics repair problem.
We fix the board, the bridge boots, the encryption chain activates, & PC-3000 images the data. Single location in Austin, TX. No outsourcing.
The tech who diagnoses your drive is the tech who solders the repair.
Why can't I just remove the internal SSD and plug it into my computer?
Some external SSDs use standard M.2 NVMe or 2.5-inch SATA drives internally, and removing them works if the bridge was the only failure point. Other models (Samsung T7) solder the bridge, controller, and NAND onto a single PCB, so physical removal is not possible.
How much does external SSD data recovery cost?
External SSDs with SATA internals: $200–$1,500 across five tiers. External SSDs with NVMe internals: $200–$2,500 across five tiers. The tier depends on the failure type: a simple bridge bypass is lower cost, while encrypted bridge repair or NAND-level recovery costs more. Free evaluation, firm quote before work begins. +$100 rush fee to move to the front of the queue.
Does recovery software work on external SSDs?
Only when the drive is physically healthy and recognized by the OS. Software like Disk Drill, EaseUS, or PhotoRec can recover accidentally deleted files if TRIM hasn't erased the blocks. When the bridge controller is dead, the drive doesn't appear in Disk Management or BIOS. Software can't communicate with a device the OS can't see. Lab recovery with PC-3000 is required for hardware failures.
What happens to encrypted data when the USB bridge dies?
On a drive with hardware encryption active (a WD My Passport SSD or SanDisk Extreme with password protection enabled), the internal NVMe controller encrypts the data. Whether encryption is active on your unit is confirmed during the free evaluation.
How long does external SSD recovery take?
Standard turnaround is 2-6 weeks depending on the failure type and parts availability. Simple bridge bypass on a non-encrypted drive can complete in under a week. Encrypted bridge repairs that require donor board sourcing take longer. Rush service is available: +$100 rush fee to move to the front of the queue.
Can a portable SSD be repaired?
Repair and recovery are different goals. Data recovery means extracting your files from a failed drive; we do this by repairing the bridge board or bypassing it to reach the NAND. The drive doesn't need to work long-term, just long enough to image the data with PC-3000. For continued use after a bridge failure, we'd recommend replacing the enclosure or drive entirely since the original failure point (voltage regulator, USB-C connector, bridge IC) is a reliability risk even after repair. Bridge repair for data recovery runs $450–$600 (SATA) to $900–$1,200 (NVMe).
Why does my external SSD keep disconnecting?
Intermittent disconnects on external SSDs usually point to one of three hardware problems: thermal throttling on the USB bridge chip (common on Realtek RTL9210-based enclosures that overheat during sustained transfers), a cracked solder joint under the bridge IC from drop damage or thermal cycling, or a damaged USB-C cable delivering inconsistent power. If disconnects happen under load (large file transfers), the bridge is overheating. If they happen randomly, suspect the cable first, then the USB-C connector solder joints. Intermittent disconnects often precede total bridge failure. If the drive has stopped connecting entirely, the bridge has likely died and lab recovery with PC-3000 is required.
Why is my external SSD not detected by my computer?
There are two distinct cases and they cost different amounts to recover. If the drive does not appear anywhere (Disk Management, Device Manager, BIOS, macOS System Information), the USB bridge controller is most likely dead: shorted PMIC, blown 5V regulator, cracked BGA, or sheared USB-C connector. If the drive appears as a USB Mass Storage device but no drive letter or volume mounts, the bridge is alive and the internal SSD firmware has failed (FTL corruption, controller panic, scrambled metadata). The symptom matrix on this page maps each pattern to its recovery path. Safe first steps: try exactly one known-good cable, one direct USB port (no hubs, no docks), do not initialize, do not format, do not run CHKDSK. Bridge repair or bypass starts at $450–$600 (SATA) / $900–$1,200 (NVMe). Internal SSD firmware repair starts at $600–$1,200 (SATA) / $900–$1,200 (NVMe). No diagnostic fee; we identify which case yours is during free evaluation.
What does "No Media" mean on my external SSD in Disk Management?
"No Media" means the bridge is alive (Windows sees the USB Mass Storage device, which is why an entry shows up at all) but the internal SSD controller cannot communicate with its NAND or has lost its Flash Translation Layer. The drive reports 0 bytes because the controller has no map of what is on the NAND. This pattern is common after a firmware panic, degraded NAND on the internal SSD, or an internal NVMe controller failure unrelated to the bridge. Consumer recovery software cannot help because there is no addressable storage for it to scan: the drive reports zero capacity at the OS level. The path here is PC-3000 SSD vendor-mode access to the internal controller, FTL reconstruction, and sector imaging. Typical tier: $900–$1,200 on NVMe-based externals.
Why doesn't my external SSD show up in Disk Utility on my Mac?
Three causes account for most cases. (1) Dead USB bridge: macOS may show the bridge on the USB bus at 10 Gb/s under System Information > USB, but no /dev/diskX device is created and the drive never appears in Disk Utility. This is the ASM2362 solder-fracture pattern on SanDisk Extreme V2. (2) Bridge alive, internal SSD firmware dead: the device appears as USB Mass Storage in System Information but Disk Utility shows zero capacity or "uninitialized." Do not click Initialize; that erases partition tables and makes recovery harder. (3) APFS container damage on an otherwise healthy drive: run "diskutil list" and "diskutil apfs list" from Terminal to inspect the container state, then "diskutil verifyVolume" against the affected identifier. The first two cases require lab recovery. Bridge bypass starts at $450–$600 (SATA) / $900–$1,200 (NVMe).
How do I identify which USB bridge chip my external SSD uses?
Read the USB Vendor ID and Product ID from your operating system. On Linux Terminal: lsusb prints VID:PID for every connected device. On macOS Terminal: system_profiler SPUSBDataType prints the same data plus link speed. On Windows: Device Manager > right-click the device > Properties > Details tab > Hardware Ids. Cross-reference VID:PID against the bridge identification table on this page. Where VID/PID does not pin down the revision, opening the enclosure and reading the chip markings does.
Related SSD Recovery Services
External SSD stopped working?
Bridge controller repair, encrypted drive recovery, drop damage repair. SATA: $450–$600+. NVMe: $900–$1,200+. Free evaluation, no data = no fee.
