Why Your Seagate External Hard Drive is Beeping
Most beeping external drives aren't getting enough power. Try a different cable, port, and power supply first. If power isn't the problem, we find the cause by opening the drive. In this video, a technician opens a LaCie Porsche Design enclosure with a Seagate Rosewood drive inside and finds the heads resting on the platter surface.
Video
Summary
The Rosewood Stiction Problem
Seagate's Rosewood family of slim 2.5-inch drives includes the ST1000LM035 and ST2000LM007. When one powers off with its heads stuck to the surface, it won't spin up the next time you turn it on. That's what the beeping was on the drive in this video.
You'll find these drives in Seagate Backup Plus Slim and LaCie Porsche Design enclosures. The LaCie name on the outside doesn't change the Seagate drive inside.
Summary
What the Video Demonstrates
The technician opens a LaCie Porsche Design enclosure and removes the Rosewood drive. You can see the heads stuck to the platters, and the drive lid is sealed by a label with no rubber gasket. This drive had already been recovered. On camera, the technician uses a screwdriver to turn the head stack back onto the ramp and show the fix. The video doesn't show the normal next steps, but it walks through them: checking the heads under a microscope, then swapping them for heads from a donor drive.
Summary
What Happens Where the Heads Were Stuck?
Moving stuck heads back often leaves bad sectors where they sat. Professional recovery tools struggle to read that spot. A regular Windows computer isn't the tool for it.
Get help
Beeping Drive? Put Down the Power Cable.
Our Austin lab has PC-3000 hardware, a laminar-flow clean bench, and a shelf of donor Rosewood drives. Free evaluation, no-data no-fee policy.
