Are Seagate Hard Drives Good Quality?
A data recovery technician's honest assessment of Seagate Rosewood drives, with real lab footage of what failure looks like on these models.
Video
Summary
The Rosewood Problem
The Seagate Rosewood family of 2.5" drives (ST1000LM035, ST2000LM007, ST500LM030) are among the most common failed drives in data recovery labs. These slim 7mm drives ship inside Seagate Backup Plus and Expansion enclosures, LaCie Rugged and Porsche Design portable externals (Seagate acquired LaCie in 2012), and laptops from HP and Dell.
The read/write head sliders on these drives are fragile. When they make contact with the platter surface, the result is often catastrophic: the heads embed into the magnetic coating and destroy data in the contact zone. In the video, you can see a Rosewood drive so unstable it destroyed two sets of donor heads within two days during recovery attempts. That frequency points to a design problem, not isolated bad luck.
Summary
Three Failure Modes
Head/Preamp Failure
Drive spins up but clicks repeatedly, or spins down after failing to initialize. Usually recoverable with a head swap from a matching donor.
Stuck Heads (Stiction)
The heads have come to rest on the platters and bonded to the surface, so the platters cannot turn. Often recoverable with careful head unsticking. Do not power cycle repeatedly; each attempt can score the platter surface.
Platter Damage
Visible coating damage, debris on platters. Not recoverable. The head sliders gouge the magnetic coating, physically destroying data.
Summary
LaCie and Porsche Design: Seagate Inside
Since the 2012 acquisition, LaCie external drives use Seagate internals. LaCie Rugged Mini, Rugged USB-C, Porsche Design Mobile, and Mobile Drive all contain Seagate mobile mechanisms. The desktop d2 Professional uses larger 3.5" Seagate drives, not the Rosewood 2.5" family. If you bought a LaCie portable external, there is a high probability it contains a Rosewood drive.
Get help
Seagate Drive Failed?
Stop powering it on. Each power cycle on a Rosewood drive with stuck or damaged heads makes things worse. Our Austin lab handles these recoveries daily with PC-3000 tools and clean bench procedures.
