Time-Critical Recovery
Emergency Data Recovery Services
When your data loss is urgent, every hour matters. Our Austin lab provides fast evaluation and priority processing for emergency hard drive data recovery, SSD recovery, and RAID recovery cases.
Fast Evaluation
No Data, No Charge
Direct Technician Access
Is This an Emergency?
Yes, if your drive is clicking, grinding, or making unusual sounds. Stop powering it on. Each power cycle can cause additional damage.
(512) 212-9111
Call for immediate guidance
Updated 2026-08-07
What Emergency Changes
What Is Emergency Data Recovery?
Emergency data recovery at Rossmann Repair Group is queue priority, not a different procedure. A flat $100 rush fee moves your drive to the front of the bench queue, & there's no diagnostic fee, rush or otherwise. Every recovery runs at the Austin, TX lab; nationwide service is mail-in.
Same technicians, same tiers, same $100–$2,000 range as standard intake. What changes is where your case sits in the day's work order & how fast you hear back with a failure mode. The entire emergency surcharge is the flat $100 rush fee: no after-hours markup, no expedited evaluation charge, no percentage of the recovery total.
Ship it or drop it off. Nationwide customers mail drives to 2410 San Antonio St, Austin, TX 78705, & every step from intake to imaging happens in that building. One location, no franchises, no outsourced partner lab handling your drive under our name.
What Makes It Emergency
When Is Data Recovery an Emergency?
Emergency data recovery services are appropriate when the cost of delay exceeds the cost of expedited service.
Business Operations Halted
Critical databases, accounting systems, or operational files needed to resume business.
Legal or Compliance Deadline
Court-ordered discovery, regulatory audits, or contractual obligations with hard deadlines.
Medical or Research Data
Patient records, clinical trial data, or irreplaceable research that cannot be reconstructed.
Active Physical Damage
Clicking or grinding drives where continued use risks total data loss.
Single Copy of Critical Files
No backup exists and the data is essential for personal or professional reasons.
Time-Sensitive Projects
Wedding photos before the event, project deliverables before deadline, etc.
What Customers Say
Andrew Hansen
Kyle Hartley (crazybangles)
Christopolis
Patrick Dughi
The First Hour
What Should You Do in the First Hour?
Cut power to the device & leave it off. On a mechanically failing hard drive, every power cycle, file system repair pass, & consumer recovery scan drives a degraded head back across the platters, & the damage accumulates. Nothing you run at home fixes a mechanical or firmware fault.
  1. Kill power now. If the drive is clicking or grinding, pull the plug instead of waiting for the operating system to finish a graceful shutdown. Every extra rotation with a damaged head is more contact with the recording surface.
  2. Leave it off. Don't re-power it to see whether it still works. A second spin-up buys no information we can't get on the bench with a PC-3000.
  3. Don't run CHKDSK, Disk Utility, or fsck. These utilities work at the file system layer over standard ATA. They can't reach the drive's firmware service area & they don't overwrite the translator, so the damage they do is mechanical: a repair pass hammers a degraded head with sustained read retries, & those retries score platters.
  4. Don't run consumer recovery software on a failing drive. Recuva, EaseUS, & Disk Drill assume healthy hardware underneath the file system. A full-surface scan is hours of continuous seeking across the exact zones that are already failing.
  5. Don't open the drive. Head work happens in a ULPA-filtered clean bench because ambient room air puts particulate between the head & the platter. That is how a $1,200–$1,500 head swap becomes a $2,000 surface-damage case.
  6. On an SSD, power off is still the answer. If files were deleted or a volume was formatted on a solid-state drive, cut power the same way. Garbage collection runs during idle time, so every minute the drive stays powered is more time for the controller to erase blocks that TRIM already unmapped.
  7. Call before you ship. We triage over the phone at (512) 212-9111 during lab hours (Mon-Fri, 10 AM - 6 PM CT) & tell you whether to ship overnight, drop off in Austin, or leave the device alone until Monday.
  8. Pack it box-in-box, then ship to Austin. Anti-static bag, two inches of bubble wrap on every face, a small inner box floated inside a larger outer box. No padded envelopes, no loose peanuts. The full protocol is on the mail-in page; the address is 2410 San Antonio St, Austin, TX 78705.
SSD Firmware Emergency Recovery
Emergency SSD Firmware Recovery: 0 Bytes, ROM Mode, & BIOS Dropouts
An SSD that suddenly reports 0 bytes or vanishes from BIOS isn't erased. Silicon Motion controllers (SM2258, SM2259) & Phison controllers enter a protective ROM mode when the Flash Translation Layer corrupts after a power loss.
The NAND chips still hold your data; the controller just can't map it. Consumer recovery software can't reach a drive in ROM mode.
Our Austin lab uses PC-3000 SSD with the Silicon Motion (SM) Utility or Phison Utility to inject volatile microcode into the controller's RAM, reconstructing the FTL logically without desoldering NAND chips. SSD firmware recovery starts at $600–$1,200.
Marvell 88SS1074 BSY State at Power-On
Marvell 88SS1074 controllers can fail to finish initialization. The drive powers on but never becomes ready. It's stuck in a BSY (busy) state. We use PC-3000's Marvell family active utility to access the controller's diagnostic mode and image the drive.
If your SSD needs emergency recovery, call us before powering the drive on again.
Emergency HDD Recovery
Emergency Hard Drive Recovery: Head Crashes & Seagate Rosewood Firmware Failures
A clicking hard drive risks destroying data with every power cycle. Where the heads are down on the platter surface, they drag across it, scoring the magnetic coating & embedding debris.
Power the drive off. Don't run CHKDSK, don't try Recuva, don't plug it into another computer. Each attempt grinds the platters further.
Head swap recovery starts at $1,200–$1,500 plus donor drive cost. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available.
We open the drive in our ULPA-filtered clean bench, match donor heads from our cataloged inventory by model, firmware revision, & head map, then image sector-by-sector using PC-3000 Express with selective read retries. A flat $100 rush fee moves emergency cases to the front of the queue.
Seagate Rosewood BSY Bug & Media Cache Corruption
The Seagate Rosewood family (ST1000LM035, ST2000LM007) is prone to BSY (Busy) state lockups & media cache corruption. The platters spin normally, but the drive's microprocessor hangs during initialization, blocking all host access. Consumer software can't reach the drive because the firmware never completes its boot sequence.
We connect PC-3000 to the drive's serial diagnostic terminal. Modern Rosewood drives ship the factory terminal locked, so PC-3000 first applies its technician-mode unlock before the drive will accept terminal commands.
Rosewood firmware recovery falls in our $600–$900 tier. If the heads are also damaged, the cost moves to $1,200–$1,500 plus donor.
PCB Damage: Why Simple Board Swaps Fail
If your drive suffered a power surge or electrical short, swapping the printed circuit board from a matching model won't work. Modern HDD PCBs contain a ROM chip storing adaptive calibration parameters that are specific to each individual drive, including head alignment data and servo tuning.
Without transferring the ROM chip from the original board to the donor, the drive can't align its heads or initialize. We desolder the original ROM, transplant it to a working donor PCB, & verify initialization before imaging. This falls under our $600–$900 recovery tier.
The walkthrough below is one of these recoveries, filmed in the Austin lab: clean bench disassembly, head inspection, donor matching, and PC-3000 imaging on a single clicking drive.
Our Emergency Process
Our Emergency Data Recovery Process
For urgent cases, we streamline our process to minimize time-to-recovery while maintaining our rigorous technical standards.
    Immediate Phone Consultation
    Call us directly. Describe your situation. We'll assess urgency and provide initial guidance immediately.
    Expedited Intake
    Ship overnight or drop off in Austin. We prioritize emergency cases for same-day or next-day evaluation.
    Priority Processing
    Emergency cases jump the queue. Our engineers focus on your drive with dedicated attention.
    Real-Time Updates
    Direct communication with the technician working your case. No phone trees, no waiting.
NAS Emergency
Emergency RAID & NAS Recovery: Array Degradation & SMR Risks
A multi-drive failure in a NAS or RAID array halts business operations instantly. Do not attempt a live rebuild with a replacement drive. A RAID rebuild has to recalculate parity, and that puts sustained read stress on the remaining aging members. That load can push a marginal drive into failure.
This risk is worse in modern consumer NAS devices loaded with Shingled Magnetic Recording (SMR) hard drives. SMR overlaps data tracks to increase density; rewriting data during a rebuild forces the drive to read, modify, & rewrite massive adjacent zones.
The severe performance bottleneck triggers controller timeouts, causing the RAID firmware to falsely flag healthy SMR members as dead. The logical volume collapses even though the physical drives are intact.
We never rebuild a degraded array. We remove the drives from the hardware controller, clone each member independently at the physical level using PC-3000, & virtually reconstruct the array geometry in software. This preserves every sector of data without stressing the original drives.
RAID recovery pricing depends on the number of member drives & their individual failure modes; each drive is assessed at our standard HDD recovery tiers ($100–$2,000 per drive). A $100 rush fee applies to the entire case, not per drive.
Priority Processing
What Does the Rush Fee Change?
The $100 rush fee buys queue position & nothing else. It reorders when your drive gets evaluated, when it gets bench time, & when the technician calls with a diagnosis. It doesn't change the tier price, doesn't add a diagnostic fee, & doesn't make a damaged head read faster.
Stage of the caseWhat the rush fee changesWhat sets the clock
Intake & evaluationYour drive is evaluated ahead of standard intake the day it landsLab hours: Mon-Fri, 10 AM - 6 PM CT
Diagnosis callYou hear the failure mode & the quote soonerWhether the drive stays stable long enough on the PC-3000 to identify the fault
Bench schedulingThe case takes the next open bench slot instead of queueing behind standard workHow much bench time is already committed to cases ahead of yours
Donor sourcingNothingWhether a matching donor is already in cataloged inventory
ImagingNothingHead condition, surface condition, & how many read passes each damaged zone needs
Price & published ETANothing. Firmware repair is $600–$900 & a head swap is $1,200–$1,500 with or without rushFailure class. Head swap stays 4-8 weeks; surface damage stays 4-8 weeks
The fee is flat, not a percentage: +$100 rush fee to move to the front of the queue. A rushed head swap costs the head swap tier plus the donor plus the rush fee, & nothing else gets added for urgency. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available.
What the fee can't buy is a technician who isn't in the building. The lab runs Mon-Fri, 10 AM - 6 PM CT, so a drive that lands Saturday goes to the front of Monday's queue. We'd rather publish that than sell a 24-hour promise a five-day lab can't keep, & if we recover nothing you pay no recovery fee either way.
Rate-Limited Failures
Which Failures Can't Be Compressed by Paying More?
Three failure classes resist scheduling pressure: surface damage, head swaps waiting on a donor, & SMR members that need a firmware-level write lock before imaging starts. In each case the clock belongs to the hardware. A scored surface gets read slowly because reading it any faster is what destroys the remaining data.
Imaging Rate on a Degrading Surface
Imaging is rate-limited by the drive. PC-3000 works at millisecond-level ATA timeouts, so a hung read aborts quickly instead of vanishing into the drive's own error-recovery loop with the head sitting over the damage. That is the safety margin. It doesn't make the platter hand over data any faster.
During imaging, bad-sector auto-relocation is turned off, so the remaining head life goes into reading your data instead of internal housekeeping. Every sector we have to attempt again costs at least one more rotation, & the sectors bordering a scored track are the ones that need the most attempts.
Where the signal is marginal rather than gone, PC-3000 retunes the read-channel adaptives: FIR equalizer taps, gain, target response, & retry behavior. Then we run the area again, head by head. That is why surface damage is our $2,000 tier with a published ETA of 4-8 weeks, & why the rush fee doesn't move that number.
Donor Matching and Sourcing
A head swap can't start until a donor exists. We match donors by model, firmware revision, & head map from cataloged inventory; when the model isn't on the shelf, the case waits on the market rather than on the bench. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available.
Head swap recovery runs $1,200–$1,500 plus donor cost with a published ETA of 4-8 weeks. Priority placement gets the drive opened & assessed first, which is what tells us which donor to buy. It does not shorten the shipping time on a donor we have to buy from someone else.
SMR Members and the Firmware Write Lock
SMR drives dictate their own imaging order. A SATA write-blocker stops host writes & nothing else; it can't stop the drive's internal background garbage collection or its media-cache flush, & both keep running on a powered idle drive. We command the PC-3000 firmware-level write lock first, then image on PC-3000.
That order isn't optional, & it isn't quick. Firmware repair splits by recording type: $600 for a CMR drive, $900 for an SMR drive, with a 3-6 weeks ETA. Array cases inherit the slowest member: an eight-bay NAS full of SMR drives is eight of these sequences, not one.
No data, no recovery fee covers every one of these. If the surface is gone, you don't pay for the attempt, & you hear that on the diagnosis call rather than after four weeks of imaging.
Services We Handle
What NOT to Do
What NOT to Do in a Data Emergency
If a drive is clicking, stop powering it on. A clicking drive has a hardware fault, & each power cycle re-attempts to load the heads across the platters, risking head-to-surface contact that scores the media & can make the data permanently unrecoverable. Which part failed is settled on the bench, & every retry before then costs you data surface.
  • Don't keep powering on a clicking drive
    Each power cycle can cause the heads to scrape the platters, destroying data permanently.
  • Don't run CHKDSK or Disk Utility on a failing drive
    These tools write to the drive and can overwrite recoverable data or cause further degradation.
  • Don't open the drive yourself
    Microscopic dust contamination can destroy platters. This requires a ULPA-filtered clean bench environment.
  • Don't freeze your hard drive
    This internet myth causes condensation damage and thermal shock. It does not help recovery.
  • Don't use consumer recovery software on a physically damaged drive
    Software cannot fix mechanical problems and will stress the drive further.
Contact
Need Emergency Data Recovery Now?
Call us directly for immediate guidance. We can assess your situation over the phone and advise on the safest next steps. For urgent cases, we offer priority processing with direct technician communication.
Lab Location
Nationwide Coverage
View All Locations
Emergency Data Recovery Pricing
Same tiers, same prices, plus a flat $100 rush fee for priority queue placement. No after-hours surcharge, no expedited diagnostic fee, no "emergency evaluation" markup. If we can't recover your data, you pay no recovery fee.
Emergency Data Recovery: Common Questions
How much does emergency data recovery cost?
Emergency recovery uses our standard tier pricing: $100–$2,000 for hard drives, $200–$1,500 for SATA SSDs. Rush processing uses +$100 rush fee to move to the front of the queue. No after-hours surcharge, no expedited diagnostic fee, and no diagnostic fee at all, rush or otherwise. If we can't recover your data, you don't pay a recovery fee.
Can you recover data from a clicking hard drive the same day?
Same-day evaluation is standard for emergency cases. Full recovery depends on the failure. A clicking drive is diagnosed first, because the sound does not name the part that failed. Where it is the head stack, we match a donor head assembly from our cataloged inventory and transplant it inside our ULPA-filtered clean bench. If the donor takes cleanly, imaging via PC-3000 Express can start within hours. Severely degraded platters require throttled read speeds on PC-3000 to prevent secondary head crashes; that process runs days, not hours. Head swap recovery costs $1,200–$1,500 plus donor drive cost. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available.
What should I do if my SSD suddenly shows 0 bytes or disappears from BIOS?
Power it off. An SSD reporting 0 bytes or dropping from BIOS is typically a firmware panic, not permanent data loss. Controllers from Silicon Motion (SM2258, SM2259) & Phison enter a protective ROM mode when the Flash Translation Layer corrupts after a power loss. Consumer recovery software can't reach a drive in ROM mode. Our lab uses PC-3000 SSD with the Silicon Motion (SM) Utility or Phison Utility to inject volatile microcode into the controller's RAM & rebuild the FTL without desoldering NAND chips. SSD firmware recovery starts at $600–$1,200.
Is the $100 rush fee a percentage of the total recovery cost?
No. The rush fee is a flat $100 regardless of recovery complexity. No percentage markups, no tiered emergency surcharges, and no expedited diagnostic fee. The fee moves your drive to the front of the diagnostic and recovery queue.
How fast can you evaluate an emergency drive that arrives by overnight shipping?
We open overnight packages the morning they arrive & begin evaluation the same day. For hard drives, we start on the PC-3000: we find the failure mode, check whether we can get into the firmware, and see whether the heads need replacing. We'll call you with a diagnosis & quote before starting any billable work. Ship to: 2410 San Antonio St, Austin, TX 78705. Customers pay shipping to the lab and are billed for return shipping.
Can you recover deleted files from a modern SSD in an emergency?
On modern SATA & NVMe SSDs, deleted file recovery is virtually impossible once TRIM has run. Windows 7 and later sends TRIM by default when you delete a file. macOS does it by default only on Apple-supplied SSDs. When that TRIM goes out, the SSD controller unmaps the logical addresses and schedules garbage collection. Once garbage collection erases the underlying NAND blocks, the data ceases to exist. No lab on earth can recover data after the controller has completed that background process. If you suspect accidental deletion on an SSD, power it off immediately; garbage collection runs during idle time, so the faster you cut power, the more blocks may survive. SSD firmware recovery starts at $600–$1,200.
Can you perform emergency data recovery remotely?
If your storage device has suffered a physical hardware failure, remote recovery is impossible. Software can't fix a seized spindle motor, crashed read/write heads, firmware panic, or a shorted power rail. For firmware panics, electrical shorts, or mechanical failures, the device must be physically connected to diagnostic hardware like the PC-3000 in our Austin lab. We don't offer remote recovery because we won't sell a service that can't deliver results on hardware failures.
Can you recover data from an Apple Silicon (M-series) or T2 MacBook?
Yes, but not by removing the storage chips. Modern Apple MacBooks with T2, M1, M2, M3, or M4 chips use hardware-level encryption tied to the logic board's Secure Enclave. Desoldering the NAND & reading it externally yields only encrypted ciphertext. Recovery requires board-level microsoldering to repair the logic board itself so the system can boot & decrypt its own storage. We perform this work in-house using Hakko FM-2032 microsoldering irons & hot air rework stations.
Can you start working on my drive tonight?
Our Austin lab operates Monday through Friday, 10am to 6pm Central. If you call before close, we can triage the case the same day and tell you whether to power the device down, ship overnight, or drop off locally. Drives shipped overnight that arrive the next business morning go into the emergency intake queue that day.
Do you work on weekends?
The lab is closed Saturday and Sunday. A clean-bench head swap requires a focused technician, donor matching, and controlled imaging time, so we do not sell weekend recovery work that cannot be performed properly. If a drive arrives late Friday, the +$100 rush fee to move to the front of the queue moves it to the front of the next business-day queue.
What counts as an emergency case vs. standard recovery?
An emergency is a case where delay creates real harm: a dead RAID array halting business operations, a court discovery deadline, a clicking drive that should not be powered again, or single-copy files needed before a fixed deadline. Standard recovery uses the same pricing tiers when a few extra business days do not change the outcome. The only emergency-specific charge is the +$100 rush fee to move to the front of the queue.
How fast can you ship a recovered drive back to me?
Once recovery is complete and you approve the file list, we ship the same business day when the case closes before the carrier cutoff. Time-critical returns can use overnight shipping at carrier cost. You can also pick up in person at 2410 San Antonio St, Austin, TX 78705 during business hours.
Do you offer same-day diagnostic evaluations?
Yes for Austin drop-offs and overnight shipments that arrive early enough in the business day. Hard drive diagnostics on PC-3000 usually identify the failure mode, firmware accessibility, and likely head-swap need within the first evaluation window. We call with a diagnosis and quote before billable recovery work begins.
What does the rush fee buy, and what does it not buy?
The flat $100 rush fee buys queue position. Your drive is evaluated ahead of standard intake, it takes the next open bench slot, & you hear the failure mode & the quote sooner. It doesn't change the tier price, doesn't add a diagnostic fee, and doesn't change the published tier ETAs: a head swap is still 4-8 weeks & surface damage is still 4-8 weeks. It also does not buy weekend labor. The lab runs Mon-Fri, 10 AM - 6 PM CT.
Why can't a surface-damage recovery go faster if I pay more?
The drive sets the pace. Imaging a scored platter means re-reading damaged zones until the data comes back, & PC-3000 works at millisecond-level ATA timeouts so a hung read aborts instead of sitting in the drive's own error-recovery loop with the head sitting over the damage. Faster settings mean more head contact & less recovered data. Surface damage is our $2,000 tier with a published ETA of 4-8 weeks, rush fee or not.
What should I do in the first hour before shipping the drive?
Cut power & leave it off. Don't re-power the drive to check whether it still works, don't run CHKDSK, Disk Utility, or fsck, and don't run consumer recovery software over a drive that's clicking. A file system repair pass hammers a degraded head with sustained read retries, & those retries score platters. Don't open the drive; head work belongs in a ULPA-filtered clean bench. Pack it box-in-box with an anti-static bag & bubble wrap, then ship to 2410 San Antonio St, Austin, TX 78705.
Have a question not listed here? Call us at (512) 212-9111 or visit our hard drive recovery & SSD recovery pages for detailed pricing & process information.
Data emergency? We're ready to help.
Call now for immediate guidance. Priority processing available.
