Fire Damaged Data Recovery
Recovery from Heat, Smoke, & Soot Damage
Fire damage looks catastrophic, but your data is often safe inside the platters. While high heat can demagnetize platters, the sealed chassis often protects data from brief exposure to high temperatures.
Fire & Smoke Remediation
Don't clean, power on, or remove the PCB from a fire-damaged hard drive. Soot is acidic & abrasive, so wiping it drives particles into the drive's breathing holes, & the electronics are likely shorted while the sealed drive body protects the platters. Handle it gently, since fire makes metal brittle, & pack it with extra cushioning.
Handling Fire Damaged Drives
- 1.DO NOT clean it. Soot is acidic and abrasive. Trying to wipe it off can drive particles into the breathing holes of the drive.
- 2.DO NOT power it on. The electronics are likely shorted or melted.
- 3.DO NOT remove the PCB. The seal between the board and the drive body protects the platters.
- 4.DO handle gently. Fire makes metal brittle and plastic seals fragile. Pack with extra cushioning.
Our Fire Recovery Process
First we remove external soot & melted plastic on the ULPA-filtered clean bench so no contaminants enter the drive. Next we source an exact-match donor board & move the unique ROM chip across, or rebuild adaptive parameters with PC-3000.
1. Decontamination
We carefully remove external soot and melted plastic in our ULPA-filtered clean bench to ensure no contaminants enter the drive assembly.
2. PCB Reconstruction
The electronics are usually destroyed. This is similar to PCB failure recovery: we source an exact-match donor board and move the unique ROM to it or rebuild adaptive parameters using PC-3000 if the ROM is damaged.
What Fire Damage Recovery Costs
Fire damage is priced by what the drive needs, not by how bad the outside looks. A melted board reads as firmware-tier board & ROM work. The quote after the free evaluation is the price you pay.
Fire damage prices the same way as any other hard drive failure: by what the drive actually needs, not by how bad the outside looks. A melted or shorted board reads as firmware-tier board & ROM work. The quote you get after the free evaluation is the price you pay.
- Low complexity
- Low complexity
- Medium complexity
- High complexity
- High complexity
Understanding Fire Damage
Heat & smoke damage the drive in different ways. Heat only erases data if it pushes the platters past their Curie point, & unless the drive sat in the heart of the fire for a long time, the platters often survive. Smoke particles are microscopic, & soot is acidic & corrosive, so we treat fire drives as liquid-damage cases too.
Heat Damage
Hard drives can lose data if heated above their Curie point (where magnetic properties change). However, unless the drive was directly in the heart of the fire for a long time, the platters often survive.
Smoke & Soot
Smoke particles are microscopic and can bypass some filters. Soot is acidic and corrosive. Water from fire hoses also complicates recovery. We treat fire drives as liquid damage cases too.
Recoverable vs Non-Recoverable Heat Exposure
Most fire-damaged drives that reach our bench survived, because the sealed head disk assembly & its internal air gap buffer the platters from short heat exposure. Two conditions can't be recovered: a recording layer heated past its Curie point, so the magnetic domains randomize, or platters that warped or delaminated under sustained heat & can't fly a head.
Most fire-damaged drives that reach our bench survived the heat. Not because the fire spared them, but because the sealed head disk assembly & its internal air gap buffer the platters from short exposure.
Soot & smoke stay on the outside of the aluminum casing. Most residential fires reach 600 to 800 degrees Celsius up at the ceiling, yet the enclosed chassis & that air gap keep the recording surface well under the outside temperature during brief exposure.
The failure line is the recording layer. Platters store data as magnetic orientation in a thin cobalt-based alloy with high coercivity. Heat that layer past its Curie point & the magnetic domains randomize; the data is demagnetized permanently, & no lab can bring it back.
Sustained direct flame does that. Brief exposure through a sealed chassis usually does not.
Two conditions we can't recover from: a recording layer heated past the Curie point, & platters that warped or delaminated under sustained heat. A warped platter can't fly a head at a stable clearance, so there is nothing to image.
We tell you which case you have at the free evaluation, before you pay anything. Everything short of that line we open on the ULPA-filtered clean bench.
The drive's unique ROM is read with a programmer and written to the donor board, or PC-3000 rebuilds its adaptive parameters.
A fire-destroyed board needs the drive's unique adaptive parameters, not just a new board. The 8-pin SPI NOR flash ROM carries calibration data specific to that drive.
We read that ROM with a programmer & write it to the matching donor PCB. If the ROM chip itself is incinerated past reading, we rebuild the adaptive parameters with PC-3000 before the donor board can talk to the heads.
Fire-hose water turns a heat case into a combined liquid case. We decontaminate & ultrasonically clean the board before any power is applied, then transfer the ROM.
FLIR thermal cameras flag short-circuit hotspots on the exposed PCB so we replace only the components that shorted. Then we image read-only with PC-3000, pulling data sector by sector. We're extracting your data, not returning the drive to service.
See the particle counter test at the benchFire Damage Recovery Questions
My drive looks charred. Is there any chance of recovery?
Why shouldn't I clean the soot off my fire-damaged drive?
The electronics are melted. Can you still get my data?
Water from fire hoses got on my drive. Does that make it worse?
How should I pack and ship a fire-damaged drive?
Related Recovery Services
Recover From Disaster
We have recovered data from drives that looked like charcoal briquettes. Don't give up.
