Water Damaged Data Recovery
Salt Water, Fresh Water, & Flood Damage Specialists
Do not plug it in. Water and electricity destroy data. If your device was dropped in a pool, submerged in a flood, or spilled on with coffee, corrosion begins immediately. We use ultrasonic cleaning and board-level microsoldering to stabilize your device and recover your data.
Corrosion Removal & Board Repair
Updated September 2026
If your device is wet
Critical: If Your Device is Wet
  • 1.
    DO NOT power it on. This causes short circuits that burn traces and destroy chips.
  • 2.
    DO NOT use rice. Rice does not clean corrosion. It creates a humid “sauna” that accelerates rust.
  • 3.
    DO NOT dry it with heat. Hair dryers can warp sensitive components.
  • 4.
    DO ship it immediately. Corrosion is a chemical reaction that gets worse every hour.
How to ship a wet drive
How to Ship a Wet Hard Drive
Do not power a water-damaged drive on, and do not open it or try to clean it yourself. Seal it in a bag, pack it in a padded box, & ship it overnight to our Austin, TX lab. Tell us at intake what liquid it went into and how long it sat.
The drive is going onto a clean bench to be opened either way, so nothing you do to the outside of it helps. What does help is not powering it on and getting it here quickly.
    Leave the drive as you found it. Do not power it on, run recovery software, or open the case.
    Place it inside an anti-static bag or a ziplock bag and seal it.
    Pack the sealed bag inside a padded box with bubble wrap on all sides.
    Ship overnight to our Austin, TX lab. Use our mail-in form to safely package & mail your drive.
Every hour of delay gives corrosion more time to spread. For hard drive recovery after water exposure, the single most important variable is how quickly the drive reaches our ultrasonic cleaning bath.
Reviews
How we recover water damaged drives
How We Recover Water Damaged Drives
We recover water damaged hard drives in three steps. First, we remove the PCB & clean it in an ultrasonic bath with electronics-grade solution to strip corrosion. Second, we replace corroded ICs & jumper broken traces under a microscope. Third, we inspect the head disk assembly & image dry platters with PC-3000, or dry them to prevent stiction first.
1. Ultrasonic Cleaning
We remove the PCB (circuit board) and clean it in an ultrasonic cleaner with specialized electronics-grade solution to remove mineral deposits and corrosion from underneath chips.
2. Microsoldering Repair
Corroded resistors, capacitors, and ICs are replaced. Broken traces are jumpered under a microscope. We restore the electrical integrity of the drive's control board.
3. HDA Inspection
For hard drives, we check if water breached the seal. If the platters are dry, we proceed with PC-3000 imaging. If wet, we use specialized drying techniques to prevent stiction before spinning up.
Platter decontamination
Platter Decontamination & Pre-Amplifier Repair
Flooded platters are extracted on a ULPA-filtered clean bench & decontaminated with specialized platter cleaning techniques that remove crystallized salt, mud, & mineral residue. We then inspect the pre-amplifier chip under a microscope; if it's corroded, we perform a head swap with matched donor heads & transfer the adaptive ROM parameters to a donor PCB.
A drive that took on floodwater comes to the bench with residue inside the sealed chamber, and residue on a platter surface is not something the heads can fly over.
We extract the platter stack on our ULPA-filtered clean bench and remove caked residue using specialized platter cleaning techniques. After decontamination, we inspect the pre-amplifier chip under a microscope. If the pre-amp is corroded, we perform a full head swap with matched donor heads ($1,200–$1,500 + donor cost). Helium-sealed drives are quoted on a separate tier on the helium drive recovery page.
A simple PCB swap does not work on water-damaged drives. The original PCB stores adaptive ROM parameters (head calibration data unique to that specific drive). We transfer the ROM chip itself from the damaged board to the donor PCB before the replacement board can communicate with the drive's heads and platters.
Types of liquid damage
Types of Liquid Damage We Handle
Flood & Salt Water
Flood water often contains sewage, oil, and salt. Salt water is highly conductive and corrosive. These are critical emergencies requiring immediate attention.
Salt Water Warning: Corrosion can destroy traces in hours. Send immediately.
Coffee, Soda, and Wine Spills
Sugar and acids in drinks eat through copper traces and solder joints. As the liquid dries, it leaves a conductive residue that causes short circuits when powered on.
Sugar Warning: Sticky residue can seize hard drive motors.
Water damage on SSDs
Water Damage & SSDs: Removable vs. Soldered
SSD TypeStorage LocationWater Damage BehaviorRecovery Approach
PC Laptop M.2 NVMe SSDSeparate removable M.2 moduleSSD itself was not part of the shorted circuit; only the surrounding board was. Data often survives if removed quickly and left unpowered.Remove the M.2 module, do not plug it in while wet, then ship for imaging.
Soldered MacBook SSD (Touch Bar and Apple Silicon)NAND soldered directly to the logic boardWater damage to the board means the NAND storage is part of the shorted circuit.Repair the logic board to restore power to the NAND chips before any data extraction is possible.
Liquid-induced SSD firmware corruption
Liquid-Induced SSD Firmware Corruption
A water damaged SSD is often recoverable. Removable M.2 NVMe drives frequently survive if pulled quickly & left unpowered, since the SSD itself wasn't part of the shorted circuit. A liquid voltage spike can corrupt the controller's Flash Translation Layer, so we first replace the shorted power ICs, then rebuild the translator tables with PC-3000 SSD.
Liquid damage on an SSD doesn't just short the physical pathways. The resulting power anomaly frequently corrupts the controller's Flash Translation Layer (FTL), the firmware map that tracks which physical NAND cells hold which logical data blocks. Without a functioning FTL, the drive appears as 0 bytes or enumerates with a generic device name instead of its model number.
SATA SSD controllers are particularly susceptible. A voltage spike from liquid contact forces Phison S11 (PS3111) controllers into a firmware panic state where the drive reports as "SATAFIRM S11" with zero capacity. NVMe controllers like the Phison E12 react differently, dropping off the PCIe bus entirely.
Recovery requires two steps: first, replacing the shorted power management ICs via Hakko FM-2032 microsoldering to restore stable voltage to the controller. Second, using PC-3000 SSD in Technological Mode to access the controller directly, rebuild the corrupted translator tables, and extract raw NAND pages. For SSD recovery involving liquid damage, firmware repair starts at $600–$1,200.
Water Damage Recovery Questions
Someone told me to put my drive in rice. Did I make it worse?
Rice does not clean corrosion. It absorbs surface moisture while creating a humid environment that accelerates rust on PCB traces and connector pins. Time spent in rice is time corrosion keeps spreading. The real damage is microscopic corrosion under BGA chips and metal shields that rice cannot reach. Send the drive for ultrasonic cleaning as soon as possible.
My drive fell into salt water. Is that recoverable?
Often, yes, but salt water is the worst-case liquid exposure. Salt is highly conductive and causes rapid, aggressive corrosion that can destroy PCB traces in hours. Send the drive immediately without powering it on. The faster we get it into an ultrasonic cleaning bath, the better the recovery odds.
How does ultrasonic cleaning remove water damage from a PCB?
We remove the PCB from the drive and submerge it in an ultrasonic cleaner with electronics-grade solution. High-frequency sound waves create microscopic cavitation bubbles that dislodge mineral deposits and corrosion from underneath BGA chips and inside connector pins where a brush or cloth cannot reach. After cleaning, we inspect under a microscope and replace any damaged components via microsoldering.
Water got inside the hard drive itself. Is recovery possible?
It depends on how long the drive was submerged and whether it was powered on while wet. If the platters are dry or only briefly exposed, we use specialized drying techniques to prevent stiction (heads sticking to the platters) before spinning up. If the heads or platters show corrosion, we may need a head swap on our clean bench before imaging with PC-3000.
I powered it on after it got wet. Did I ruin my chances?
Powering on a wet device causes short circuits that burn PCB traces and destroy chips. It makes recovery harder and more expensive, but not always impossible. The extent of damage depends on how long it ran while wet and what components shorted. We can often repair the electrical damage through component-level microsoldering and PCB trace repair.
My MacBook got wet and the SSD is soldered. Can you still get my data?
Yes, but it requires repairing the logic board first. In Touch Bar MacBook Pro models and Apple Silicon MacBooks, the SSD NAND chips are soldered directly to the logic board. Water damage to the board means the storage is part of the affected circuit. We perform ultrasonic cleaning and component-level repair to restore power to the NAND, then extract the data.
Can you recover data from a water damaged iPhone?
Yes. iPhone data recovery after water damage requires board-level micro-soldering to repair corroded circuits on the logic board. The storage (NAND) is soldered to the board, so we must restore power to the board before extracting any data. We perform ultrasonic cleaning to remove mineral deposits from under BGA chips, then replace damaged power management ICs, capacitors, and trace jumpers under a microscope. iPhone water damage recovery costs $500 to $750 depending on the model and extent of corrosion. The faster you send it (without powering it on), the better the recovery odds.
Is water damage worse for phones or hard drives?
Both are vulnerable, but the failure modes differ. A hard drive's PCB corrodes and the internal platters can develop stiction if moisture enters the sealed chamber. An iPhone's logic board has hundreds of microscopic solder joints under BGA chips where water wicks in and corrodes traces within hours. Hard drives can often be saved if the platters stayed dry. iPhones require component-level board repair regardless of where the water entered.
My SSD was encrypted with BitLocker and the controller burned out from water. Is the data lost?
If the liquid damage is isolated to power management ICs or capacitors, we can repair those components via microsoldering to bring the drive back online with BitLocker decryption intact. The data reads out normally through the original controller. If the water surge destroyed the controller chip itself, raw NAND chip-off extraction is useless; the proprietary translator and scrambling patterns needed to reassemble those pages die with the controller. We focus microsoldering efforts on keeping the original controller alive. SSD circuit board repair starts at $450–$600.
Save Your Water-Damaged Data
Don't wait for corrosion to spread. Free evaluation. No data = no charge.
