Board-Level Microsoldering | Austin, TX Lab | From $500 | No Data, No Fee
Samsung Galaxy S24 Data Recovery
An S24 that went cold on the charger is a power-delivery failure until a meter says otherwise. We measure current at the port, isolate the USB-C sub-board from the main board, and hunt the short with diode mode and a thermal camera. The encrypted files stay where they were; the board is what has to come back.
Does a Dead Galaxy S24 Still Have Your Data?
Storage is a passive participant in this failure. The UFS package holds its contents with no help from the circuitry around it, so a phone that died on a nightstand in March holds the same blocks in August that it held that night.
Those blocks are encrypted, which is the fact that decides what recovery can mean here. Every file gets its own key, and those keys come from a master key that the secure hardware on this phone's original board protects. Put the storage package into a programmer and what comes back is unreadable noise with no directory structure inside it.
So the job runs backwards from what people expect. Bring the board far enough that verified boot finishes, hand you a phone sitting at its own lock screen, & let your PIN release the keys on the hardware that has been holding them the whole time.
That answer holds across the whole generation & does not soften on a budget board. The Android and Samsung recovery hub walks through it generation by generation, older eMMC boards included.
What a Sudden-Death S24 Ultra Looks Like on the Bench
Nothing warns the owner first. The board-repair community documents a class on the Galaxy S24 Ultra where a phone that was working, frequently while charging or partway through a video, stops answering anything and never comes back.
Four observations define it on a bench. The phone stays cold. It draws zero or near-zero current from a known-good charger, and it refuses both Download Mode and recovery mode, which matters because reaching either one needs a live power path.
Zero draw is the observation that clears away the easy explanations. A phone whose only problem is a flat cell answers a working charger with current, and a meter in line with the cable shows it. A board taking nothing has a fault upstream of any of that.
A dead panel is a different intake, because the board underneath a failed display keeps running and keeps the encrypted payload intact, waiting on its owner's credential the same as ever. Nothing about this class is a display symptom.
The documented causes fan out across three regions, & they carry different prognoses. One is the main PMIC. Another is the charging IC & the USB-C input path. When that fails, no power gets through, and the phone looks like a dead motherboard while the processor & the UFS package sit untouched. The third is shorted BGA joints under the processor or the storage package, which is the branch that can end in reballing or a transplant.
None of this comes from a Samsung-published defect notice. It is bench consensus, assembled by the technicians who take these boards apart, & nobody has published how often it happens. That is also why a number quoted over the phone off a symptom description is a guess: current draw alone cannot tell a failed charging IC apart from a shorted core rail.
Intake Protocol for a Cold Galaxy S24
Order decides how much of the board survives the diagnosis. Every step below runs before a single software tool is opened, because there is no software step available on a phone that will not enumerate.
- Stop cycling chargers and cables. Swapping bricks proves the charger, not the phone, & a board with a short on it spends every one of those attempts pushing current through the fault.
- Keep it away from Odin. Download Mode is unreachable on a board with no power, and a shop that gets there on a phone with degrading storage can finish the data off. Flashing is a last resort after the hardware is proven healthy.
- Write down the model number and the capacity. Those two tell us which processor variant & which UFS tier the phone has.
- Say what the phone was doing when it died. Charging overnight, playing video, dropped, or hot in a pocket. A drop points at the joints under the packages; a quiet death on a charger points at the input side first.
- Meter the port on the bench. A known-good cable and a current meter answer the first question: does the board accept anything at all, does it take a little and collapse, or does it take a hard short.
- Take the sub-board out of the circuit. The USB-C assembly sits on its own sub-board. With it out, we feed the main board straight from a current-limited DC supply at battery voltage. That tells us whether we're looking at an input-side fault or a dead main board.
- Measure in diode mode, rail by rail. Shields come off, the probe goes to ground, & every reading gets held against a working board of the same model. Near 0.000 V means a hard short sitting on that line, while a healthy one answers back in the hundreds of millivolts. That side-by-side is where the quote comes from.
What the meter reads in diode mode is a junction drop, & a junction drop carries no meaning by itself. It needs a working board of the same model sitting next to it, which is not the same thing as a table of values copied off a forum.
Finding out which branch your phone landed on costs you nothing, because evaluation is free & we bill no diagnostic charge. Knowing the answer commits you to no repair. Mail-in intake works from any state.
Is It the USB-C Sub-Board or the Main Board?
This is the split in the diagnosis that matters most. A failed charging IC blocks all power flow, and the result is a phone imitating a destroyed motherboard while its processor and its UFS package remain in perfect condition.
Isolation runs in a fixed order. We disconnect the cell first. Then the sub-board and its flex leave the assembly, & the main board is fed at the battery connector from a current-limited DC supply that caps whatever a remaining short is allowed to pull.
A FLIR thermal camera watches what happens next. A shorted part turns that current into heat and identifies itself on the image rather than being guessed at from a schematic, and the stereo microscope confirms what the camera pointed at.
Both outcomes are useful. If the main board powers up with the input side removed, the repair's on the sub-board, and your data was never in question. A main board that still takes nothing, or still shorts, moves the work onto the rails themselves.
Parts get changed with a Hakko FM-2032 driven from an FM-203 or FX-951 base station, packages lift under Atten 862 hot air, and reballing happens on a Zhuo Mao station. A board with liquid history goes through the ultrasonic cleaner before any of that starts. That last case has its own treatment on Samsung water damage recovery.
Symptom-to-Circuit Prognosis on an S24 Board
How the board behaves under a supply narrows the fault well before a soldering iron gets involved, & every one of these behaviours carries a different answer about the files.
| Bench behaviour | Circuit implicated | What it means for the data |
| Cold, zero draw at the port, no device on a PC | The USB-C sub-board, or the charging IC and the rest of the input path | Best case here. Nothing on the input side touches the processor or the UFS package, so a component swap is all that stands between you and the files |
| Main board still takes nothing with the sub-board removed | Main PMIC, or a shorted load on one of the core rails it generates for the processor, the RAM, and the storage | Whether the short sits on the supply side or the load side decides which part leaves the board |
| VDD_CORE reads at or near 0.000 V to ground | The processor itself, rather than anything supplying it | Worst case here. A cracked or electrically destroyed processor die takes the key set with it, and moving the storage to a donor board recovers nothing |
| Intermittent life, or death that arrived with a drop | Shorted or fractured BGA joints under the processor or under the UFS package | Mechanically repairable. Underfill removal and a reball restore continuity; a joint that cannot be recovered moves the job to a transplant |
| Download Mode works, then a storage read errors | The storage device itself rather than the power path, which is a different message from the OEM-unlocking refusal | Do not flash it. Writing firmware to a phone whose real fault is degrading storage can destroy what is still readable |
| Boots after board work, then rejects the correct PIN | A transplant that moved the processor and the storage but left the discrete Knox Vault secure element behind | Recoverable by moving the missing part. The secure element travels with the paired set on S21 and newer flagships |
What Monolithic Packaging Changed From the S24 Generation
This is the generation where test-point access to the storage went away. An S22 or S23 board still carries the service and test points that unbrick and flashing tools reach for; the S24 moved to a monolithic storage package that presents no usable ones.
Losing them costs less than it sounds like, since not one of those points was ever a route to your files. Anything read through them arrives encrypted under keys the original processor holds, so a tap that works perfectly still hands back noise.
UFS was never that job to begin with. Its parallel predecessor gave way to differential serial lanes carrying a SCSI command model, which is why hand-soldered wires that read an eMMC chip cannot carry a UFS link. Reading one in place is a specialist technique on the transmit and receive pairs with purpose-built adapters; reading a removed package needs a socket programmer built for it. Both are industry techniques, and neither is equipment on this bench.
Older packaging is a genuinely different situation, and it is worth knowing which one you are in. eMMC data recovery covers controller death and what sits behind it on the legacy boards where the parallel path still exists.
For an S24 the practical consequence is short. Dead-board work runs through repairing the board, or through a paired-set transplant, and never through the storage chip on its own.
UFS 3.1 and UFS 4.0 Ship in the Same S24 Lineup
Capacity picks the storage version on this generation, so the name on the box tells you nothing. Any sentence assigning one UFS version to the whole S24 line is wrong about part of it.
- 128GB Galaxy S24
- UFS 3.1. The base capacity of the S23, S24, and S25 all sit on this tier, so an S24 and the S23 next to it in a drawer can carry the same storage generation.
- 256GB and larger S24 and S24+
- UFS 4.0, so one retail listing covers two storage generations.
- Galaxy S24 Ultra
- UFS 4.0 across the Ultra models. This is also the model carrying the documented sudden-death class.
The version number changes nothing about recovery. Both tiers run over the same differential signalling, so neither offers a parallel way in, & both hold blocks encrypted under keys that belong to the processor beside them.
Which Donor Board Matches an S24?
Market allocation on this generation is split rather than uniform. The Snapdragon 8 Gen 3 went to the S24 and S24+ in the US, Canada, China, Taiwan, and Hong Kong; the Exynos 2400 went to the UK, Europe, India, and other international markets. The Ultra skipped the split and shipped Snapdragon everywhere.
Neither family is a way around anything. Both keep the file keys inside a trusted execution environment behind the owner's credential, so the silicon changes which donor board is correct & changes nothing about what the recovery requires.
Read the silicon off the model number printed on the device rather than off what a country usually got. A phone bought abroad, imported, or replaced under warranty does not owe its board to regional habit.
A board past repair moves to a transplant, & the real procedure is narrower than the one shops usually describe. Nobody moves the storage chip by itself. What crosses to the donor is a set: the processor with the RAM stacked on top of it, the UFS package, and on flagships from the S21 forward the discrete Knox Vault secure element, the part technicians name the EEPROM or the Pin Code IC.
The stacked RAM is not itself cryptographically paired; it travels for thermal and mechanical reasons. The secure element is another matter, and a set that arrives without it produces a phone that boots normally and then refuses the correct PIN.
Substitution is not on the table either. UFS storage is bound to its original processor through the Replay Protected Memory Block, so a cloned or replacement package is rejected outright rather than merely coming back unreadable. Samsung underfills these boards heavily, which turns the removal into a long job before any reballing begins, and it is quoted from the same flat range as a charging-circuit repair.
Download Mode, CSC, and Rollback Index on an S24
Odin writes Samsung-signed firmware and does nothing else. No documented path reads user data out of it, and a hypothetical raw dump taken through it would be ciphertext, so a reflash is never the data-safe first step somebody on a forum says it is.
Three separate mechanisms decide what a flash costs you on this generation.
- The CSC binary decides userdata. Standard CSC and repair firmware wipe it. That choice is made inside the firmware package before anyone presses start, which is why the wrong download destroys a phone that was otherwise intact.
- Rollback protection decides direction. Verified boot refuses to flash or boot any image whose rollback index, the binary revision counter the bench reads as BIT or SW REV, sits below what the device recorded. Same-revision flashes stay routine, and there is no way back down once that counter has advanced.
- The error message decides the route. "Only official released binaries are allowed to be flashed" means OEM Unlocking is switched off, which is a settings problem. A storage read failure is a different animal and points at the storage device itself.
Reflashing a phone whose real fault is degrading storage can finish off what was still readable, so flashing belongs after the hardware has been cleared rather than before. There is no wipe-then-recover sequence under file-based encryption; a wipe destroys key material and nothing on the far side brings it back.
On the sudden-death class none of this is even reachable, since a board taking no current never gets to Download Mode. The Galaxy boot loop page covers the phones that do get there & loop anyway.
Does Qualcomm EDL Get Data Off an SM-S928B?
Emergency download mode is a firmware-programming interface. It loads a signed programmer that can implement raw memory access, which is a real capability & a different thing from decryption.
The credential-derived keys for credential-encrypted storage never materialize in such a session. They come into existence when the owner unlocks the phone through the normal boot path, so an image pulled from underneath the operating system is byte-exact ciphertext no matter how clean the read was.
A second obstacle sits on top of the first. Plenty of vendor loaders decline memory reads while Secure Boot or the OEM lock is on, so many attempts never even get as far as producing an unreadable image.
Shops advertising this mode as a Samsung unlocker are selling flash-programming access described as decryption. We do not perform it, quote it, or route around it, and a job arriving with that request gets declined at intake.
What Encryption Requires From You on a Repaired S24
One thing, & it happens to be the one thing no lab can hand over. Credential-encrypted storage derives its keys from what you know, your PIN or pattern or password, mixed with secrets that only this phone's secure hardware will release, and only on this phone.
Knox Vault handles that on an S24: a separate secure processor with memory of its own, standard on Samsung flagships since the S21 generation. Guessing is throttled where it happens, by Gatekeeper and Weaver, with failure counts that survive a reboot. None of that can be copied to a PC and worked on there.
Device-encrypted storage is what mounts before you type. It carries the limited system data Direct Boot needs & holds none of your photos, messages, or app data, which is why a phone sitting at a lock screen has nothing readable on it yet.
Lock removal is not work this bench does, and the reason is not squeamishness. Factory Reset Protection only appears after a reset already destroyed the keys, so there is no user data sitting behind that screen for anyone to recover, & every documented route past it ends with the userdata partition formatted. The Knox warranty fuse is one-way and stays that way.
Entering Your PIN Into a Phone With No Screen
A board that works behind a broken display is a different job from a board that will not power, and it often does not need us. Galaxy models supporting DisplayPort Alt Mode over USB-C will drive a hub with HDMI out, so a monitor and a USB keyboard put the lock screen in front of you.
Blind-entering your own PIN there satisfies Gatekeeper and Weaver the same way typing it on the phone would, moves the device into its after-first-unlock state, and brings up desktop mode or mirroring so files copy off with Smart Switch or over MTP. That path enters your credential; it does not work around it.
Two settings can close that door. Auto Blocker refuses commands arriving over the cable when it is switched on. Maintenance Mode boots an empty profile and keeps your real data walled off until you leave the mode from a working display. Either one turns the job back into a temporary donor screen, or board repair, so you can unlock the phone the ordinary way.
What Can Recovery Software Do for a Galaxy S24?
The paid products advertising broken-Android extraction are not lying about their demo; they are quiet about its requirements. A scan listing your photos is listing files that still exist, over MTP or ADB, on a phone somebody already unlocked.
Three requirements stand between that demo and a cold S24, and a dead board fails all three. Debugging over USB had to be turned on ahead of the failure. An ADB session wants its host key approved in a dialog that only appears on an unlocked screen. And file keys live in kernel memory only after somebody unlocks the phone once, so nothing is decrypted for a tool to read even when the cable behaves.
Deleted files carry the harder answer. Destroying a file destroys its key, and discard plus a scheduled trim clear the physical blocks behind it, which puts permanently deleted internal-storage data past the reach of any scan on a modern Galaxy. A factory reset performs that operation on everything the phone held, in one pass.
Copies do survive elsewhere, in app-level holding areas or off the handset, & every one of these is worth checking before a board ships anywhere:
- Samsung Gallery Trash holds photos for roughly 30 days after you delete them, since nothing was destroyed yet. Reaching it takes a phone you can unlock.
- One UI 6 unified the My Files trash, which from that release also catches Gallery and Voice Recorder deletions. Same requirement: the phone has to boot and open.
- Google Photos and OneDrive trash sit on somebody else's servers, which means a dead S24 gets no vote in whether you can open them.
- Smart Switch backups already made are files on a computer or a second phone, written before any of this happened.
- Samsung Cloud backups come back without the handset, subject to one condition. From One UI 6.1, backups protected by Knox Matrix Enhanced Data Protection are end-to-end encrypted, and without the recovery code you were issued at setup, a dead phone's backups can't be restored.
- Secure Folder contents are excluded from standard Smart Switch backups and sit under their own separate credential, so they need a booting phone and a device-to-device transfer while the container is open.
If one of those already has what you lost, you will hear it during the free evaluation and it costs you nothing. Board work is what is left over when none of them do.
What Does Galaxy S24 Data Recovery Cost?
No data, no fee. Free evaluation. No diagnostic charges. That figure is firm once measurement is done, so you never authorize work against an estimate, & a transplant adds no surcharge to it.
Work stays in one building, at 2410 San Antonio Street in Austin, Texas, where board-level repair has been the trade since 2008. There is no franchise network behind that address and no outside lab handling the awkward half of a job. A board that turns out to be past saving leaves you owing nothing.
Bring it by during business hours, or ship it in from any state. The free evaluation comes first, then a firm number, then your call.
See the particle counter test at the benchQuestions About Galaxy S24 Board Failures
Does a forced restart fix a Galaxy S24 with a black screen?
Does a Galaxy S24 that won't turn on still have my data?
Why did my S24 Ultra die overnight while it was charging?
Will flashing firmware in Odin get my files back?
Can you get files off an S24 whose screen is dead but boots?
Can you take the storage chip off an S24 and read it?
Do you need my PIN, pattern, or password?
What does Galaxy S24 data recovery cost?
Related Samsung Recovery Pages
Every generation, the encryption reality, and the full fault catalog
Temperature-correlated boot loops and the cold-boot backup window
Diode-mode triage, processor reballing, and boards another shop already opened
A/B slot-switch soft-bricks and power-delivery triage
Two processor builds, UFS 4.0 at every capacity, and blind PIN entry
Hinge flex faults that mimic a dead board, and a black inner screen
Current draw at the port and the per-rail prognosis map
Thermal fracture, interposer cracking, and Odin flash semantics
Corrosion chemistry, ultrasonic cleaning, and shorted power paths
Controller death on the legacy boards that still expose a parallel path
What happens when a recovery does not produce data
S24 went cold and stayed cold?
Take it off the charger and send it in before anyone flashes it. Evaluation is free, the quote is firm once the board has been measured, and a recovery that produces nothing is not billed.
