Board-Level Microsoldering | Austin, TX Lab | From $500 | No Data, No Fee
Dead & Boot-Looping Galaxy S22 Data Recovery
An S22 that starts when it is cold and quits once it warms up is describing a cracked solder joint, not corrupted firmware. We separate the mated board stack, measure the rails against a known-good board, and reball or transplant what the microscope finds. Your files never left the storage package. All of it happens at our Austin, TX lab, so drop the phone off in person or mail it in from any state.
Why an S22 Ultra Boots Cold and Dies Warm
Temperature is the diagnosis. A phone that starts after a night on a cold windowsill and quits a few minutes into a warm hand has a break in a solder ball, and that break is moving. No firmware fix closes that gap.
The board-repair community documents this class on the S22 Ultra across both builds, Snapdragon 8 Gen 1 and Exynos 2200 alike. The source is the repair bench rather than a Samsung defect notice: technicians opening these phones keep finding the same fracture.
Two responses to it destroy data. The first is flashing firmware into a phone whose fault is mechanical, which changes nothing about the joint & can wipe userdata depending on which package gets written. The second is treating the cold-boot window as a cure instead of spending it on a backup.
The permanent fix is mechanical: the stack comes apart, the fractured packages come off, & the processor and its stacked RAM go back down reballed. Where the board is past that, the job becomes a paired-set transplant. The Galaxy boot loop page carries the full fault-class treatment, including the loops that have nothing to do with temperature.
Copy Everything During the Cold Window
If your S22 still comes up cold, that boot is the cheapest recovery you will ever get. Plan it before the phone is running, because the window closes as the board warms and improvising costs most of it.
- Have the cable and the computer ready first. A laptop with a USB-C cable already plugged in, a folder already open, and the phone unlocked the instant it boots. Deciding where the files go while the phone is up wastes the part of the window that matters.
- Take the irreplaceable material first. Camera roll first, then voice recordings and documents. Anything that also sits in a cloud account or on a second device can wait for a boot that may never arrive.
- Keep the phone cool while it copies. Skip video playback and refuse the system update it offers you, because processor load turns into heat and heat is what reopens the fracture.
- Do not restart it to see whether it still works. Just because it came up once doesn't mean it'll come up again.
- Write the model number down. SM-S901x, SM-S906x, or SM-S908x with its suffix, plus the capacity. That string decides the processor variant and which donor board would match if the job ends in a transplant.
- Stop when it dies, and leave it alone. Ship it, or bring it by. Every time you chill it again, you add risk.
The freezer version of this advice has a real problem underneath it. Metal that has been chilled below room temperature collects condensation the moment it comes back out, and water sitting on a board that somebody then plugs in behaves as an electrolyte, bridging points at different potentials and dissolving metal at the anode.
That is the same chemistry as a spill, arriving by a route the owner did not expect. Getting a cold boot out of a phone you have already turned into a liquid-damage case is a poor trade.
How Does the Bench Decide Where an S22 Job Goes?
By behavior under a supply and a meter, in that order. Each observation below routes the job somewhere different, & the routing is what the quote is built from.
| What the bench finds | What that means | Where the job goes |
| Boots when cold, dies as it warms | A fractured joint under the processor, or inside the interposer stack, that contraction closes and heat reopens | Back up now while the window is open, then board separation and a reball |
| Near-zero current from a known-good charger, board stays cold | The first suspect is the charging path, meaning the charging IC that runs the USB port and charging. The processor and storage are untouched. | Diode-mode triage and a charging IC replacement, which is the best branch to land on |
| Hard short on a core rail in diode mode | The main PMIC, or the processor sitting on the load side of that rail | Worse prognosis. A destroyed processor on a file-based-encryption phone means destroyed keys |
| Liquid history, and shorts that move as the stack is split | Corrosion inside the interposer layer, invisible while the two boards are mated | Split the stack, ultrasonic clean, and probe between the boards before any power goes near it |
| Board past repair, processor and storage and secure element intact | The parts that hold and unlock your data survived what the board around them did not | Paired-set transplant onto a donor matched by model number and processor variant |
Near-Zero Current Draw Points at the Charging Path First
A meter in line with a known-good cable answers the first question before anything comes apart: does the board accept current, take a little and collapse, or sit at a hard short? An S22 drawing nothing points first at a fault upstream of the processor, which is the good news buried inside a phone that presents as dead.
Samsung splits power management into two jobs on its Exynos-architecture boards. The S2MPS main PMIC makes the core rails for the processor, RAM, and storage. The S2MU charging IC runs the USB port and charge control.
The Snapdragon 8 Gen 1 units carry a different power-management family, which is part of why the two S22 variants are separate boards rather than one board with a chip swapped into it. The triage is the same on either; the part numbers are not.
Triage runs in diode mode with a multimeter, shields off and probe to ground, each reading compared against a working board of the same model. At or near 0.000 V is a hard short sitting on that line, while a healthy one answers in the hundreds of millivolts.
A short on a core rail changes the conversation. If the fault is the processor rather than anything supplying it, that is the branch where the keys are at risk, & we say so before any money changes hands rather than after.
Where the fault turns out to be the charging path, the repair is a component swap: a Hakko FM-2032 on an FM-203 or FX-951 base station for the part itself, Atten 862 hot air to lift packages, a Zhuo Mao BGA station for reballing, and a FLIR thermal camera to watch which component turns a current-limited supply into heat. None of this needs a cleanroom, & any shop telling you a phone board does is selling scenery.
A phone that goes warm in one spot on the charger while the screen stays black is the owner feeling that heat from the outside. Current pushed into a shorted part leaves as heat, & the camera turns a warm phone in a hand into one component on a board under a current-limited supply.
A board that stays cold & takes near nothing reads the opposite way, and it routes the job differently: nothing is dissipating anything, so triage starts at the charging path rather than at a hunt for a hot spot.
Order matters once corrosion is involved. Shorts get localized after the ultrasonic cleaner rather than before it, because contamination still bridging pads moves the target between one look & the next. The camera narrows where to probe, and it does nothing beyond that: the diode-mode reading against a known-good board is what confirms the fault before any part comes off.
Splitting a Liquid-Damaged S22 Board Stack
Liquid damage is electrochemistry rather than dampness. Water on a powered board acts as an electrolyte between points held at different potentials, and the resulting cell dissolves metal at the anode & plates it back out as dendrites at the cathode, with the worst of it concentrated under the BGA packages where nothing is visible.
Two instructions follow from that, and both are about stopping. Stop powering the phone. Stop charging it. Power makes the corrosion go faster. It keeps going slowly with the phone off, but every time you check whether it still turns on, you lose more copper.
Rice does nothing here. The problem is not moisture trapped in an air gap that a desiccant could pull out; it is corrosion products growing underneath packages that a grain of rice has no route to.
On the S22 architecture the liquid case and the thermal case end up at the same bench step for the same reason. Shorts hide inside the interposer layer between the mated boards, invisible with the stack together, so the boards have to be separated before the assembly goes through the ultrasonic cleaner and the probing happens between the layers.
The encrypted payload is not what corrosion attacks first. Power and interface lines go long before a storage package does, which is why a phone pulled out of a sink and left alone usually still has everything on it.
Does an S22 That Won't Boot Still Hold Your Files?
Storage does not participate in this failure. The UFS package keeps what it was given whether or not the circuitry around it can start, so the blocks on an S22 that quit in January are the blocks it holds today.
Those blocks are encrypted, and that single fact rewrites what recovery can mean on this generation. Every S22 shipped with file-based encryption on by default. Each file carries its own key, the keys are released by secure hardware that belongs to this phone, and the S22 generation carries Knox Vault, a discrete secure processor with memory of its own.
Deriving those keys takes two things at once: the credential you set, and secrets only this phone's secure hardware will hand over. Gatekeeper and Weaver throttle wrong attempts inside that hardware with counts that survive a reboot. There is no version of this where a lab supplies the missing half, & screen-lock, Factory Reset Protection, and Knox fuse requests get declined at intake.
Which is why the job runs the direction it does. Repair restores the boot path, verified boot completes, & the phone wakes at its own lock screen waiting on you. Credential-encrypted storage is where your photos, messages, and app data sit. The device-encrypted tier that mounts before you type carries the limited system data Direct Boot needs and none of the rest.
Some states are past that, and they are physics and cryptography rather than effort levels. No price and no tool moves any of them:
- A cracked or electrically destroyed processor. The key custody lived there, so the keys went with the die.
- A dead UFS controller. The host cannot read the device descriptor, and the payload underneath is hardware encrypted.
- A factory reset that already ran. One pass destroys the key material for everything the phone held.
- A Knox container whose warranty fuse tripped. The e-fuse is one-way, and Secure Folder keys stay withheld even after the phone boots normally again.
- An end-to-end-encrypted Samsung Cloud backup with no recovery code. Backups made under Knox Matrix Enhanced Data Protection open with that code, or they do not open.
A corrupted /efs partition or a null IMEI belongs on neither list. That partition holds device identity and radio calibration while the encrypted user payload lives in /data, so a phone with wrecked cellular identity still boots, still decrypts, and still hands over every file. The Android and Samsung recovery hub walks the same reality generation by generation, including the older eMMC boards where the bench work changes and the ending does not.
Snapdragon 8 Gen 1 and Exynos 2200 Ship in the Same S22 Lineup
The usual shorthand for this generation is wrong, & it is wrong in a way that wastes donor boards. Snapdragon 8 Gen 1 units shipped in the Americas, South Korea, Japan, India, Southeast Asia, Oceania, South Africa, and the UAE. Exynos 2200 units shipped in Europe and the UK.
Several markets that took Exynos in earlier generations took Snapdragon for the S22, which is why regional habit is a bad way to guess. Read the silicon off the model string printed on the frame or shown in Download Mode.
- SM-S901x, Galaxy S22
- The base model. The suffix tells you which build it is.
- SM-S906x, Galaxy S22+
- Same split, same rule.
- SM-S908x, Galaxy S22 Ultra
- The model carrying the documented thermal boot-loop class, on both builds. B-suffix models denote Exynos; U, U1, W, and E class models denote Snapdragon.
Storage is the part that does not split. Every S22, S22+, and S22 Ultra ships UFS 3.1 at every capacity from 128GB through 1TB, with no UFS 3.0 or UFS 4.0 anywhere in the lineup. Anyone quoting a UFS 4.0 S22 is describing a different generation.
The two variants are separate boards rather than one design with a different chip dropped into it. They carry different PMIC families and different RF chains on a different layout. A donor has to match the processor variant and the model number, or the teardown is wasted work before it starts.
None of that changes the recovery answer. Each family holds its file keys in a trusted execution environment gated by the credential you set, so the silicon decides which donor is correct and decides nothing else.
Which Chips Travel in a Paired-Set Transplant?
Four parts, and they move together or the exercise fails. The shop pitch about moving your memory chip to a working board describes something that does not work on an encrypted Galaxy, & it is worth knowing why before you hand a phone to someone offering it.
- The processor. Key custody lives here, so nothing that leaves it behind decrypts anything.
- Its package-on-package RAM. Not cryptographically paired with anything; it travels for thermal and mechanical reasons, because it sits stacked on the processor.
- The UFS storage package. Bound to the original processor through its Replay Protected Memory Block. A cloned or substituted package is refused outright rather than merely read back as noise.
- The discrete secure element. On flagships from the S21 forward, including every S22, the Knox Vault part the bench calls the EEPROM or the Pin Code IC holds the PIN verification keys. Leave it on the old board & the repaired phone starts up, then turns down the right PIN.
Samsung underfills these boards heavily, which turns removal into the long part of the job. Underfill has to come off before any package lifts cleanly, & the reballing that follows is measured against how well that step went.
Nobody images one storage chip into a blank replacement and calls the result recovery. The set that leaves your board is the set that decrypts on the donor, & a transplant quotes out of the same flat range as a charging IC swap.
Replacing the board of a dead S22 gets you a working phone, not your files. A replacement board carries its own processor & its own storage, so the encrypted payload stays behind on the original package that gets discarded, bound through its protected memory block to the processor it shipped beside. A board swap ends that pairing; repair & the paired-set transplant are the two paths that keep it.
Service Points on an S22 Board Are Not a Data Path
S22 and S23 era boards still present the service points that flashing and dead-boot tools use. From the S24 generation, monolithic storage packaging stops exposing usable storage test points. That difference decides how storage-level work is attempted and decides nothing about your files.
None of them was ever a route to user files. File-based encryption ties the contents of that package to the processor beside it, so a probe that lands perfectly still returns scrambled blocks with no directory structure a carver can walk.
UFS is also the wrong shape for the technique people picture. The eMMC parallel bus gave way to MIPI M-PHY differential serial lanes carrying a SCSI command model, so fly-wires soldered by hand have nothing here they can carry a link over. Reading a UFS package in place is a specialist job on its differential transmit and receive pairs with adapters built for that purpose, & reading a removed one takes a socket programmer. Those are things the industry does; they are not tools sitting on this bench.
Legacy boards are another matter, & the packaging decides which conversation you are in. eMMC data recovery covers controller death and the parallel path that older packaging still allows.
For an S22 that lands in one place. A dead board is answered by repairing it, or by carrying the paired set to a donor; the storage package on its own answers nothing.
Will an Odin Flash Get Your S22 Files Back?
Download Mode is a write channel for firmware, with no documented path that reads user data out of it. Every claim built on top of it that promises extraction is describing firmware programming with a different word.
Which package gets flashed decides what survives. The CSC binary inside a firmware bundle is what wipes userdata or leaves it alone, and that decision is made in the download folder before anybody presses start. Verified-boot rollback protection is a separate check. The phone records a binary revision, and it refuses any image whose revision is lower than that.
There is also no wipe-then-recover sequence under file-based encryption. The wipe destroys key material, and nothing downstream of it reconstitutes what those keys protected. Flashing a phone whose storage is already degrading can finish off what was still readable, which is why it belongs after the hardware has been cleared instead of first.
Qualcomm EDL Is Not a Samsung Recovery Path
The tooling is not the obstacle, which is the part the advertising leaves out. Signed programmers for modern flagships have leaked, & a raw read taken with one still comes back as file-based-encryption ciphertext, because the keys for credential-encrypted storage are derived at unlock and never exist inside that kind of session.
There is a second wall behind the first. Plenty of vendor loaders refuse memory reads while Secure Boot or the OEM lock is enabled, so many attempts never produce even an unreadable image. A shop selling this mode as a Samsung unlocker is selling firmware-programming access under a borrowed name, and we neither perform it nor quote it.
Consumer Recovery Software Cannot Read a Locked S22
Software earns its keep on a phone that boots & unlocks. If yours still works & you can unlock it, make a backup with Smart Switch, Samsung Cloud, or Google backup. None of that reaches a board that will not start.
The vendors selling broken-Android extraction tell the truth about their demo scan and stay quiet about what it assumes. MTP and ADB expose files, not block devices, so a non-root scan enumerates what still exists and nothing underneath it. That is why the demo finds thumbnails on a working phone & the paid version never returns the file you actually lost.
A cold S22 misses every requirement that demo quietly assumes. USB debugging had to be switched on before the failure. ADB will not talk to a host until its key is approved on a screen somebody has already unlocked. And file keys live in kernel memory only once the owner has unlocked the phone, so a device sitting before its first unlock has nothing decrypted for a tool to look at.
Trash Folders and Cloud Copies Worth Checking First
Permanently deleted files on internal storage are gone. Deletion destroys the per-file key, and F2FS discard plus the scheduled trim clear the blocks behind it. What survives is what was never really deleted, or what was never only on the phone.
- Samsung Gallery Trash keeps photos roughly 30 days, because nothing was destroyed yet. It sits in credential-encrypted storage, so it needs a phone you can unlock.
- The unified My Files trash in One UI 6 and later also holds recently deleted Gallery and Voice Recorder items, so those deletions land there too. It wants the same thing: a phone that boots and opens.
- Google Photos and OneDrive trash sit on servers a browser reaches without the handset, so a dead S22 has no say in the matter.
- An existing Smart Switch backup is a file on a computer or a second phone, dated before the failure.
- Older Samsung Cloud backups come back without the handset when they were made without end-to-end encryption. From One UI 6.1, the ones protected by Knox Matrix need your recovery code.
The free evaluation tells you which of those applies to your phone before you owe anybody anything. Board work is the answer when none of them do.
How Much Does Galaxy S22 Data Recovery Cost?
No data, no fee. Free evaluation. No diagnostic charges. The number is firm once the board has been measured, so you authorize work against a price rather than an estimate, and the harder branches carry no surcharge on top of it.
We do the work in one building, at 2410 San Antonio Street in Austin, Texas. Single location. No franchise network behind the name, and no second lab quietly taking the awkward half of a job.
Drop it off during business hours, or ship it in from any state. The evaluation comes first and the firm number follows it, so nothing gets authorized against a guess. If we can't bring the board back, there's no recovery fee. We still bill you for return shipping.
See the particle counter test at the benchGalaxy S22 Intake Questions
Does the freezer trick fix an S22 bootloop?
Can a factory reset fix an S22 boot loop and keep my photos?
How do I tell whether my S22 is Snapdragon or Exynos?
My S22 loops after a drop. Is that the same fault?
My fingerprint sensor is broken. Does that block recovery?
Are photos I deleted from my S22 last month still recoverable?
What happens if my S22 board turns out to be past repair?
How much is Galaxy S22 data recovery?
Related Samsung Recovery Pages
Every generation, the encryption reality, and the full fault catalog
The full fault-class map behind a Galaxy stuck at the splash screen
What monolithic packaging changed on the Galaxy S24
Current draw at the port and the per-rail prognosis map
Corrosion chemistry, ultrasonic cleaning, and shorted power paths
Controller death on the legacy boards that still expose a parallel path
S22 only starting when it is cold?
Copy what you can during the next window, then send it in before anyone flashes it. The evaluation is free. Once we've measured the board, the quote is firm. If we don't get anything back, there's no recovery fee.
