Board-Level Microsoldering | Austin, TX Lab | From $500 | No Data, No Fee
Samsung Galaxy S23 Data Recovery
An S23 gets measured rather than matched against a pattern borrowed from another generation. Two things decide the job: which circuit failed, and what was already done to the board before it reached us.
An S23 Board Gets Measured Instead of Matched to a Pattern
Board-repair benches wrote a temperature-correlated boot-loop class for the Galaxy S22 Ultra, where thermal stress fractures joints under the processor and a cold phone briefly re-bridges them. They wrote a sudden-death class for the Galaxy S24 Ultra, where the board goes cold, refuses a known-good charger, and never reaches Download Mode.
Those are S22 and S24 Ultra patterns. A shop that quotes your S23 off an S22 pattern is selling you a diagnosis it hasn't made.
What stays constant is where the data lives. A Galaxy that stopped starting has almost always kept its files: the encrypted payload sits in the UFS package while a power, charging, or corrosion fault upstream of it blocks boot. The states with no recovery answer get named further down this page, and there are five of them.
So the first hour of an S23 job is measurement, not theory. Free evaluation, no diagnostic charge, and the number you get afterward is the number.
Diode-Mode Triage Decides Where an S23 Fault Sits
Every dead-board job starts at the port. A known-good cable and a current meter answer one question before any tool touches the board: does this phone accept current, accept a little and collapse, or pull a hard short the moment it is plugged in.
Diode mode answers the next one. We probe each rail to ground with a multimeter and hold the reading against the same point on a working board of the same model. A reading at or near zero is a hard short sitting on that line. A healthy line answers back in the hundreds of millivolts.
Where that short lands is the whole prognosis. A board drawing near zero from a charger points first at the charging and USB path, and a failure there leaves the processor and the UFS package electrically untouched, which is the outcome you want: one part on the input side, the encrypted payload intact behind it.
A short on a core rail is the other branch. Those rails feed the processor, the RAM, and the storage, and a short there implicates the processor package itself. That matters more than the repair difficulty, because the keys that decrypt your files live in secure hardware inside that processor.
Localization comes from heat rather than from a schematic guess. A current-limited DC supply feeds the board at battery voltage while a FLIR thermal camera watches which part turns that current into warmth, and a stereo microscope confirms what the camera found before anything is removed.
Corroded boards break that order. Liquid still on the board reads as shorts everywhere, so those go through the ultrasonic cleaner first and get measured second. The chemistry behind that sequence is on Samsung water damage recovery, and the no-power presentation across the rest of the line is mapped on Samsung won't turn on recovery.
What Does Reballing an S23 Processor Package Involve?
The processor on a Galaxy board does not sit alone. Its RAM is stacked directly on top of it as a package-on-package assembly, so the two come off and go back on as one piece. That pairing is thermal and mechanical rather than cryptographic; separating them adds reballing risk and buys nothing.
Joints under that stack are a real fault site. A drop, a crush, or years of thermal cycling can fracture the solder connections between the package and the board, which cuts the electrical path without damaging a single stored byte. Reballing those joints restores continuity. Reflowing them alone isn't the repair, and the data was never missing in the first place.
Underfill Removal Comes Before Any Reballing
Samsung packs heavy underfill under these packages, and getting it out is slow, mechanical work under magnification. It has to come out before the package will lift cleanly.
After the lift, residual solder and resin come off both the package and the board pads. New balls go on through a precision stencil, the package is aligned and reflowed on a Zhuo Mao station, and discrete parts around it go back with a Hakko FM-2032 on an FM-203 or FX-951 base station. Atten 862 hot air handles the package removals.
Which Parts Cross to a Donor Board Together?
When the board itself is fractured past repair, we use the same rework skill to do a transplant. Three original components cross to the donor as a set.
- The processor with its stacked RAM, lifted and replaced as the single assembly it already is.
- The UFS storage package, whose Replay Protected Memory Block is bound to that processor, which is why a cloned or substituted storage chip is rejected outright.
- The discrete Knox Vault secure element, the small part the bench calls the EEPROM or Pin Code IC. Flagships from the S21 generation forward carry it, and the S23 is one of them.
Leave the secure element behind and the repaired phone boots normally, then refuses the correct PIN. That failure is the one shops discover after the reballing is finished, which is late.
A transplant bills out of the same flat range as a charging-path repair. There is no per-model tier here and no transplant surcharge; bench hours are what separate one job from another.
What Changes When Another Shop Worked on the Board First?
Second-opinion boards are ordinary work. A phone that spent a week at a screen-repair counter, went to a mail-in outfit, or got flashed by a relative with a laptop arrives with a history, and that history is diagnostic information rather than a reason to decline the job.
Damage caused by a repair attempt has a name in medicine, iatrogenic, and it behaves differently from the original fault. It is often invisible on the board and plain in the phone's behavior, which is why nobody should have to guess at it.
| What was already done | What it changed | What we ask you for |
| Firmware flashed to fix what turned out to be a hardware fault | Writing firmware onto a phone whose real problem is a failing storage device can finish off what was still readable. The flash never read anything out either, since Download Mode only writes | Which firmware went in, and whether the screen reported a storage read failure before or after |
| A non-matching or unsigned bootloader binary flashed | That trips the Knox warranty fuse, a one-way hardware fuse. Secure Folder and any Knox container lose their keys permanently, even after the phone is repaired and boots normally | Whether custom recovery or unofficial firmware was ever flashed, and whether the data you need lives inside Secure Folder |
| An attempt at removing the Google account lock | Every documented route past Factory Reset Protection ends with the userdata partition formatted, so making the phone usable again and keeping the files are mutually exclusive outcomes | Whether anyone tried to clear that lock, and whether the phone was reset at any point |
| A wet phone powered up or charged to test it | Liquid between points at different voltages forms a cell that dissolves metal off one pad and plates it out elsewhere. Applied current drives that reaction; an unpowered wet board corrodes slowly | When it got wet, what the liquid was, and roughly how many times it was plugged in afterward |
| The storage package lifted alone onto a donor board | That package cannot decrypt anywhere else: its protected memory block is bound to the original processor, and the secure element holding the PIN verification keys stayed behind on the old board | Every part that came back with the phone, including the original board and anything in a separate bag |
A finished factory reset ends recovery for every file on the phone. A tripped Knox fuse ends it only for Secure Folder and any Knox container. Neither one is damage, so no amount of bench time and no price will undo either.
The other three change sequence and cost. A corroded board with a long charging history needs cleaning before measurement means anything, and a job where the original processor and secure element still exist somewhere is a different job from one where they were discarded.
Tell Us What Was Already Tried
Nobody is grading the previous attempt. A disclosure at intake costs you nothing and saves an evaluation from starting on a false premise.
- Name every place the phone has been. A carrier counter, a mall kiosk, a mail-in lab, and a friend with a soldering iron each leave different work on a board, and knowing which one narrows the first measurement.
- Say whether anything was flashed. Official firmware at the same revision, a downgrade attempt, custom recovery, or an unsigned binary are four different consequences, and the last one is permanent for Secure Folder.
- Say whether the phone was ever reset. A factory reset destroys the key material for every file at once, so a reset that happened during a previous repair attempt is the single most useful thing you can tell us.
- Send the parts, not just the phone. If a board came back in pieces or a chip came back in a bag, those pieces carry the keys and the storage. Ship the bag.
- Photograph anything the screen still shows. Download Mode text, an error string, or a repeating boot animation each route the job differently, and a photograph beats a description from memory.
- Stop charging it now. If liquid was ever involved, every plug-in since has moved metal around under the packages, and stopping is free.
Capacity Decides Which UFS Part Sits on an S23 Board
Model name alone does not identify the storage on an S23. The split happens inside a single retail listing, so two phones with the same name on the back can carry different parts.
Silicon is the easy half of the intake question on these three models. The S23, S23+, and S23 Ultra all shipped Snapdragon worldwide, so on those the country of purchase does not change the processor family the way it does one generation later.
The Fan Edition is the exception in this generation. North American FE units carry the Snapdragon 8 Gen 1, and Exynos 2200 units shipped in other markets, so silicon becomes a live intake question on that model in a way it never is on the other three. Read it off the model number rather than off the country of sale, because a phone can be bought in one market and resold in another. A donor board for an FE has to match the variant, because the two builds are different boards rather than one board with a chip swapped: a different processor package means a different layout and a different power management family.
| What you tell us at intake | Storage on the board |
| Galaxy S23, 128GB | UFS 3.1 |
| Galaxy S23 or S23+, 256GB and larger | UFS 4.0 |
| Galaxy S23 Ultra, every capacity | UFS 4.0 |
S23-era boards still expose the service and test points that flashing and dead-boot repair tools reach for. That access matters less than it looks, because those points fed firmware tools rather than any path to your photos.
Read the physics rather than the marketing. UFS 3.1 and UFS 4.0 both ride differential serial lanes carrying a SCSI command model, so neither tolerates the hand-soldered fly-wire technique that worked on older parallel storage; in-system access on either is a specialist job on the transmit and receive pairs with purpose-built adapters, and a desoldered package needs a socket programmer built for it.
Then encryption ends the conversation anyway. A read through a test point or out of a socket returns ciphertext keyed to the original processor, so a successful read contains nothing you can open. Raw flash reconstruction rigs and forensic extraction suites are genuine industry equipment. None of them lives on this bench.
Older Galaxy generations are a different medium with a different answer. eMMC data recovery covers controller failure on the legacy boards where a parallel path exists.
Why Does a Repaired S23 Still Wake at Your Lock Screen?
An S23 carries Knox Vault, the discrete secure processor Samsung introduced on the S21 flagships, with its own isolated memory. Key material sits in there and in the processor's trusted execution environment, and it stays there. No lab extracts it, and no vendor selling that service extracts it either.
Guessing does not scale, by design. Gatekeeper and Weaver rate-limit wrong attempts inside secure hardware, failure counts survive a reboot, and the derivation is bound to on-device secrets, so nothing can be copied to a computer and worked through at speed there.
Device-encrypted storage is what mounts before you type anything. It holds the limited system data Direct Boot needs, and none of your photos, messages, or app data lives in it.
Biometrics change nothing about this. A broken fingerprint or face-unlock sensor never blocks recovery, because a phone that has not been unlocked since boot accepts only the credential anyway, and a stored template is not a substitute for one.
Lock removal is not work this bench takes, and the arithmetic explains why better than any policy would. Factory Reset Protection only appears after a reset already destroyed the keys, so no user data waits behind that screen for anybody to recover.
Secure Folder Keeps Its Own Keys and Its Own PIN
Secure Folder is an isolated Knox container running as a separate profile, not a folder inside your account. It does not open when the main profile decrypts, standard Smart Switch backups to a PC leave it out, and Samsung ended cloud backup for it.
Getting that content back needs a fully booting phone, your separate Secure Folder credential, and a direct device-to-device transfer while the container is open. A Knox warranty fuse tripped by an earlier flash withholds those keys for good.
Backup Software Needs a Booting, Unlocked S23
Consumer products advertising broken-Android extraction are not faking their demo scan. They are quiet about its requirements. What that scan enumerates is live files over MTP or ADB, cached thumbnails included, which is why images appear on screen without anything having been decrypted to put them there.
Three conditions separate that demo from a cold S23. Debugging over USB had to be turned on before the failure. An ADB session stays refused until its host key gets approved on screen, which needs an unlocked phone to begin with. And the credential-encrypted file keys exist in kernel memory only after somebody unlocks the phone once, so a locked device has no plaintext for any tool to read even with a cable that works.
Flashing modes are not a way around that. Odin and Download Mode write Samsung-signed firmware and have no documented path for reading data out, and Qualcomm's emergency download mode is a firmware-programming interface whose raw reads come back as ciphertext because the credential-derived keys never come into existence in such a session.
Deleted Files on Internal Storage Do Not Come Back
Each file on a modern Galaxy carries its own key. Deleting one destroys that key immediately, and discard plus a scheduled trim clear the blocks behind it, which puts deleted internal-storage data past the reach of any scan. A factory reset performs that operation on everything at once.
Copies That Live Off the Handset Survive the Board
Some of these hold items that were never actually deleted, and some are copies that never depended on the phone in the first place:
- Samsung Gallery Trash, which holds photos roughly 30 days
- the unified My Files trash, which from One UI 6 also holds recently deleted Gallery and Voice Recorder items
- Google Photos and OneDrive trash
- any Smart Switch backup already sitting on a computer
The trash folders still need a working, unlocked phone, since they live in credential-encrypted storage like everything else. Samsung Cloud backups come back without the handset, except that the end-to-end-encrypted ones need the recovery code you were issued at setup.
Which Galaxy S23 Failures Have No Recovery Answer?
Five conditions end the job regardless of budget, and a lab that will not name them in advance is the wrong one to hand a phone to. None of the five is an effort problem.
- A cracked or electrically destroyed processor. The hardware-backed keys died with it, so carrying the storage package anywhere else recovers nothing.
- A dead UFS controller. The host cannot even read the device descriptor, and what sits behind that controller is hardware encrypted, so there is no plaintext fallback of the kind an older eMMC board sometimes allowed.
- A factory reset that already ran. Key material for every file was destroyed in one pass, including the reset a wiping flash performs.
- A Knox container behind a tripped warranty fuse. Blowing that fuse is a one-way operation, and the container never releases its keys again.
- An end-to-end-encrypted Samsung Cloud backup with no recovery code. That code is the only thing that opens it.
Everything outside that list is a repair question, and repair questions are most of what arrives. Most boards that stopped starting still hold what they held the hour before they went quiet.
What Does Galaxy S23 Data Recovery Cost?
No data, no fee. Free evaluation. No diagnostic charges. An S23 needing one component on the charging path and an S23 Ultra needing a paired set carried to a donor both quote out of the same range, because parts cost is not what separates them.
A board that arrives after a previous repair attempt is priced the same way. Prior work changes what we have to figure out first. It doesn't add a surcharge. If the board turns out to be past recovery, you don't pay a recovery fee.
Every S23 that comes in gets opened at 2410 San Antonio Street in Austin, Texas, by the people who quoted it. The shop was founded in 2008. There's one location, and we don't subcontract anything, even when a job gets awkward.
Drop it off during business hours, or send it in from anywhere in the country. Evaluation runs before the quote and the quote runs before the work, so the decision stays yours at both steps; start it here. Full generation coverage sits on the Android and Samsung recovery hub.
See the particle counter test at the benchQuestions About Prior Repair Attempts on an S23
Another shop already opened my S23. Can you still work on it?
My S23 was flashed before it got to you. What did that change?
Does a Galaxy S23 have UFS 3.1 or UFS 4.0 storage?
Can a donor board bring my S23 data back?
Is the Galaxy S23 Snapdragon or Exynos?
Is there a known Galaxy S23 defect that kills the board?
My S23 got wet and someone kept charging it. Is it too late?
What does Galaxy S23 data recovery cost?
Related Samsung Recovery Pages
Every generation, the encryption reality, and the full fault catalog
Temperature-correlated boot loops and the cold-boot backup window
Sudden-death boards and the USB-C sub-board isolation test
A/B slot switching and why an Odin flash risks a wipe
Corrosion chemistry, ultrasonic cleaning, and shorted power paths
S23 dead, wet, or already opened once?
Keep it off the charger, keep the parts that came back with it, and tell us what was tried before. Evaluation is free, the quote is firm once the board has been read, and a recovery that produces nothing is not billed.
