iPad intake status
iPad Data Recovery
We are not accepting iPads for repair or data recovery. Device volume is the reason: the lab is at capacity with the devices it already handles. This page covers where to send an iPad instead, and what is actually recoverable from one.
Board-level microsoldering work on an Apple logic board under magnification
8 min read
Are You Accepting iPads?
No. Rossmann Repair Group is not accepting iPads for repair or data recovery. Device volume is the reason: the lab is at capacity with the devices it already handles, and iPads are not part of that intake. We are not holding a waitlist, so there is nothing to sign up for. If an iPad has data on it that matters, send it to a lab that does this work rather than waiting on us. The rest of this page is the part that does not change: what can be recovered from an iPad, what cannot, and why.
Where to Send an iPad for Data Recovery
Two independent labs do board-level Apple work, and both are reputable businesses. For the longer list of labs we recommend and the reasoning behind it, see the data recovery companies we recommend.
iPad Rehab
Jessa Jones · Honeoye Falls, New York
iPad Rehab is the iPad specialist. Jessa Jones and her team do iPhone and iPad data recovery through board-level microsoldering, and they take mail-in board repair work. Send the iPad here first.
Disclosure: Jessa Jones is a long-time collaborator of Louis Rossmann and a fellow Right to Repair advocate. That relationship is documented on our editorial standards page.
Visit ipadrehab.com
iBoard Repair
Aaron Harrington · San Jacinto, California
iBoard Repair is a board-level microsoldering lab. The advertised service is nationwide mail-in iPhone logic board repair and data recovery, on a no data, no fee basis. We know Aaron Harrington, we have sent customers there when our own bench was backed up, and the work those customers got back was good.
Check one thing before shipping: iBoard Repair's site describes iPhone logic board work, not iPad work. Ask whether they will take the iPad before you send it.
Visit iboardrepair.com
Why NAND Chip-Off Recovery Does Not Work on iPads
Every iPad manufactured since late 2013 (iPad Air and later) uses hardware-level encryption tied to the Secure Enclave coprocessor inside the A-series or M-series CPU. The NAND flash storage is AES encrypted, and the encryption keys are generated and stored exclusively within the Secure Enclave. These keys never leave the processor die.
Desoldering the NAND chips and reading them in an external programmer (the technique called "chip-off") produces encrypted data that cannot be decrypted without the original CPU. This is not a limitation of current tools; it is a cryptographic guarantee enforced by the hardware. No lab, regardless of equipment or claims, can read raw iPad NAND externally and produce usable files.
Because the NAND is locked to the original processor and EEPROM rather than to the fiberglass board itself, recovery means repairing the original logic board so the CPU, Secure Enclave, and NAND can work together to decrypt the data, or, if the board is too damaged to repair, transplanting that entire paired set of chips together to a donor board. Moving the NAND alone never works. Both paths require microsoldering to diagnose and replace failed power management components, shorted capacitors, or corroded traces.
How iPads Fail and What Happens to the Data
Four failures account for most iPads that arrive at a board repair lab with data on them. In all four, the storage itself is intact and the board is what broke.
Dead iPad With No Power
The tablet shows no signs of life when pressing the power button or connecting to a charger. This is typically caused by a failed PMIC (power management IC), a shorted ceramic capacitor on the VDD_MAIN rail, or a fractured solder joint under the CPU. The bench procedure is to inject current-limited voltage into the shorted rail, find the thermal signature of the short, and replace the failed component to restore the boot sequence. The data was never gone; the board could not boot.
Liquid Damage
Water or coffee exposure causes corrosion on the logic board, particularly around the charging port connector and power rail components. The repair is to remove EMI shielding, clean the board ultrasonically, then diagnose and repair corroded traces and failed components. Time is critical: corrosion spreads every hour the board sits wet. Do not attempt to charge or power on a wet iPad, and do not wait to send it out.
Boot Loop
The iPad repeatedly restarts or shows the Apple logo and then shuts off. A standard iTunes or Finder restore will erase all user data, which is why it is the wrong first move.
Cracked Screen With No Display
A cracked iPad screen does not destroy data, but it can prevent passcode entry, and the passcode is what decrypts the storage. If the digitizer still registers touch, a replacement display assembly is enough to enter the passcode and copy the data off. If the impact also damaged the logic board, that gets repaired first.
Related iPhone recovery pages:
Deleted Files on an iPad
Deleted Files Cannot Be Recovered from iPads
iPadOS uses APFS with file-based encryption. When you delete a file, the per-file encryption key is discarded and the underlying blocks hold nothing but ciphertext from that moment on, before TRIM has even queued them for erasure. No software tool or hardware lab can reverse this, ours included. Recovery is only possible when the data still exists on the device but the device itself is physically broken. Any company that quotes you a price to undelete iPad photos is selling something that does not exist.
How Board-Level iPad Recovery Is Done
This is the sequence a competent board repair lab follows on an iPad that will not boot. It is worth knowing so you can tell whether the shop you are talking to actually does this work.
  1. Visual inspection and board isolation. Remove the display assembly, disconnect the battery, and examine the logic board under magnification for visible damage, burnt components, or corrosion.
  2. Power rail measurements in diode mode. Measure VDD_MAIN and PP3V0_NAND power rails to identify shorts. A reading well below the expected value indicates a shorted component pulling the rail down.
  3. Thermal imaging to locate the short. Inject a controlled voltage into the shorted rail and use a FLIR thermal camera to identify which component is heating up. The hot spot reveals the failed part.
  4. Component-level repair. Replace the failed capacitor, PMIC, or other component using a Hakko microsoldering station and hot air rework. Reflow or rebuild damaged solder connections.
  5. Boot, authenticate, and copy. Reconnect the display and battery. Boot the iPad, have the owner enter the passcode, and copy the user data (photos, documents, app data, messages) to an external drive.
iPad Models and Storage Architecture
Recovery approach varies by iPad generation because Apple changed the storage architecture and encryption model across product lines.
iPad ModelProcessorSecure EnclaveRecovery Path
iPad 1-4, iPad mini 1A4-A6XNoBoard repair or NAND read (no hardware encryption on pre-Touch ID models without passcode set)
iPad Air, iPad mini 2-3A7Yes (first generation)Board repair mandatory. NAND encrypted to Secure Enclave.
iPad Air 2, iPad mini 4, iPad Pro 9.7/12.9 (1st gen)A8-A9XYesBoard repair mandatory. Chip-off not viable.
iPad Pro (2018+), iPad Air (M1/M2)A12X-M2Yes (enhanced)Board repair mandatory. Face ID models add complexity. M-series boards share MacBook architecture.
iPad Pro M4 (2024+)M4Yes (latest)Board repair mandatory. Tandem OLED display adds reassembly complexity but does not affect data access.
Why Recovery Software Does Not Work on a Dead iPad
Consumer recovery tools like Dr.Fone, EaseUS MobiSaver, and UltData require a functioning USB connection and an iPad that powers on. They communicate with the iPad's operating system through the Lightning or USB-C port. If the iPad is dead, has a shorted power rail, or will not boot past the Apple logo, no software can reach the encrypted storage.
Repeatedly connecting a physically damaged iPad to a computer and running recovery scans pushes current through potentially shorted circuits. Each attempt risks further damage to the logic board and can convert a repairable board failure into a permanent one. If your iPad is physically damaged, do not run software tools. Send it to a board-level repair lab. When a forum comment recommends one of these tools instead, weigh it against the 4DDiG comment pattern in r/datarecovery.
Board-Level Repair in Action
iPad data recovery uses the microsoldering techniques shown in this filmed logic board repair. The board layout differs from iPhones and MacBooks, but the diagnostic methodology and tooling are the same.
iPad Data Recovery Questions
Are you accepting iPads for repair or data recovery?
No. Rossmann Repair Group is not accepting iPads for repair or data recovery. Device volume is the reason: the lab is at capacity with the devices it already handles. We are not holding a waitlist for iPad work. Send the iPad to a lab that does this work instead.
Where should I send an iPad for data recovery?
iPad Rehab in Honeoye Falls, New York, run by Jessa Jones, does iPhone and iPad data recovery and mail-in board repair. That is the first place to send an iPad. iBoard Repair in San Jacinto, California, run by Aaron Harrington, is a board-level microsoldering lab that advertises nationwide mail-in iPhone logic board repair and data recovery on a no data, no fee basis; ask whether they will take an iPad before shipping one. Both are reputable businesses.
Can you recover data from a dead iPad?
We are not taking iPads, so the answer for our lab is no. The data itself is usually recoverable by a lab that does this work. A dead iPad typically has a failed power circuit, a shorted capacitor, or a corroded trace on the logic board, and the NAND storage and CPU survive intact. The repair is board-level microsoldering: fix the board, boot the device, enter the passcode, copy the data off.
Can you remove the storage chip and read it directly?
No. Every iPad since the iPad Air (A7, 2013) encrypts all user data using AES keys bound to the Secure Enclave coprocessor inside the CPU. The NAND is cryptographically paired to the original processor. Desoldering the NAND and reading it externally produces encrypted data that cannot be decrypted. Repairing the original logic board is the only viable recovery path.
Do I need my iPad passcode for data recovery?
Yes. iPad data is encrypted with keys derived from the Secure Enclave and your passcode. Without the correct passcode, the data cannot be decrypted even on a fully working device. No commercial tool can bypass this encryption.
Can you recover deleted photos or files from an iPad?
No, and neither can anyone else. iPadOS uses APFS with file-based encryption. When a file is deleted, its per-file encryption key is discarded and the underlying blocks become ciphertext, and TRIM then queues those blocks for erasure. No software or hardware tool can recover deleted data from a modern iPad. Recovery is only possible from a physically damaged device where the data was never deleted.
My iPad is stuck in a boot loop. Can the data be recovered?
Usually, by a lab that does board-level iPad work. A boot loop can follow a failed software update, and it can follow NAND degradation; Error 1110 is one code these iPads report, and Apple documents no cause for it. A restore through iTunes or Finder erases user data, so it is the wrong first move on a device that holds the only copy of something. A board-level lab diagnoses the fault and repairs the board instead, then copies the data off.
How much does iPad data recovery cost?
We are not accepting iPads, so we do not quote iPad work and publish no iPad pricing. The price comes from the lab that takes the job. iPad Rehab publishes per-service pricing on its own site. Get a written quote before shipping the device to anyone.
