iPhone Error Code
iPhone Error 1110
We don't have a solution for this error code. Apple does not document this code anywhere in its update and restore error documentation, so there is no published cause to read off the number. A restore erases the device, so do not restore the phone.
What Does Apple Say About Error 1110?
Nothing. Apple's update and restore error article lists dozens of codes and sorts them into causes: computer software, server connections, security software, USB connections, hardware. Error 1110 is on none of those lists.
Why an iTunes Restore Erases Everything on the Phone
A standard iTunes or Finder restore wipes the storage and puts a fresh copy of iOS on the empty phone. It also destroys every photo, message, and contact that had not already been backed up, and nothing recovers them afterward.
The other button is Update, which Apple describes across its restore-error articles as reinstalling the software and keeping your personal data. On a phone where the files matter, that is the only button worth pressing.
If the phone boots again, it can decrypt your data. The original SoC and its Secure Enclave, together with the passcode you enter, unwrap the data in place. The passcode is mandatory and nothing substitutes for it. Desoldering the NAND or moving it to a donor board on an A7-and-later iPhone, meaning iPhone 5s and newer, returns only ciphertext, because the decryption keys are derived from a hardware UID fused into the original SoC that never leaves it.
Why Generic Software Cannot Help
Backup and sync software works on a phone that boots and whose passcode you know. iCloud and Finder can pull what is there. So can the reputable end of the recovery-app market, reading a healthy, running device.
None of that survives contact with a phone that will not start. Software needs a device that enumerates, boots iOS, and decrypts under a passcode before it can read a single photo. That is the wall Dr.Fone, UltData, and PhoneRescue hit on these phones too. If a forum comment points you at 4DDiG, the drive-recovery tool Tenorshare sells alongside UltData, check the 4DDiG comment pattern in r/datarecovery first.
Nobody's software reaches around a board that will not boot. That is the honest line between what an app can do and what a bench does, and it is why the work here is electrical rather than logical.
Do not attempt an iTunes restore. A restore erases the storage to install a fresh copy of iOS. If your data has not been copied off first, it is permanently lost, and no software or lab reverses it.
What is iPhone Error 1110?
Why would a phone restart instead of finishing an update?
Can I fix Error 1110 with software?
Is my data still on the phone?
Related iPhone Recovery Services
Hub page for all iPhone recovery services
The storage error Apple does document
iPhone stuck restarting on Apple logo
DFU mode and storage chip faults
Phone will not power on at all
How iPad board-level recovery works
Logic-board and storage recovery for Macs
View complete service catalog
