Kioxia SSD Data Recovery
Kioxia (formerly Toshiba Memory) is the world's third-largest NAND flash manufacturer. Their consumer Exceria lineup uses Phison controllers paired with Kioxia's own BiCS FLASH 3D TLC NAND. The Exceria Pro uses the Phison E18.
SSD from $200 | No Data, No Fee | Free Evaluation | Since 2008
Kioxia SSDs We Recover
Consumer NVMe Gen3
Exceria (TC58NC1202GST, BiCS TLC, DRAM)
Consumer NVMe Gen4
Exceria Pro (Phison E18, BiCS TLC, DRAM, AES-256), Exceria Plus G3 (Phison E21T, DRAMless HMB)
Enterprise SSDs
CM6 (U.2/E3.S NVMe, custom Kioxia controller), CD8 (NVMe, data center), PM7 (SAS-4, dual-port)
Legacy Toshiba SSDs
RC500, XG5/XG6 (Toshiba controller, OEM), OCZ RD400/VX500 (acquired brand)
PC-3000 SSD with Phison NVMe and Toshiba/Kioxia modules
9 min read
Kioxia SSD Recovery
How Kioxia SSD Recovery Works
Kioxia consumer SSDs use Phison controllers paired with Kioxia's own BiCS FLASH 3D TLC NAND. The Exceria uses the TC58NC1202GST. The Exceria Pro uses the Phison PS5018-E18. SSD data recovery on Kioxia drives requires identifying the controller, loading the correct PC-3000 SSD Phison module, and rebuilding the corrupted flash translation layer. We evaluate your drive for free and provide a firm quote.
Kioxia Exceria Gen3
Firmware Failures on the Kioxia Exceria
The Kioxia Exceria is a Gen3 NVMe SSD built around the TC58NC1202GST controller. The Exceria pairs this controller with Kioxia BiCS FLASH 3D TLC NAND in M.2 2280 form factor.
The most common failure is FTL corruption after power loss. The flash translation layer maps logical addresses to physical NAND locations. When an unexpected shutdown interrupts an FTL write, the mapping tables become inconsistent. The controller detects the corruption at next boot and enters a firmware diagnostic mode. The drive enumerates with a vendor-specific device string and reports 0MB capacity. SMART data becomes inaccessible.
The recovery workflow involves accessing the controller diagnostic interface, reading the NAND contents directly, and rebuilding the corrupted FTL tables. The Toshiba RC500 (the predecessor model sold under the old Toshiba branding) uses the same controller and the same recovery procedure.
Exceria Pro Gen4
Exceria Pro: Phison E18 Gen4 Recovery
The Kioxia Exceria Pro is the brand's flagship consumer SSD. It uses the Phison PS5018-E18 controller: triple ARM Cortex-R5 cores, 8-channel Gen4 NVMe, onboard DRAM, and AES-256 + TCG Opal 2.0 hardware encryption. Kioxia pairs this with their BiCS FLASH 3D TLC NAND for sequential reads up to 7,300 MB/s.
Sustained heavy writes push the E18 controller into thermal throttling. Under prolonged thermal stress, the PMIC (power management IC) on the M.2 PCB can degrade. A failed PMIC prevents the drive from powering on entirely. The drive appears completely dead to the host system: no enumeration, no BIOS detection, no activity LED.
AES-256 hardware encryption on the E18 makes chip-off unviable. The encryption key lives on the controller die. Board-level repair (replacing the failed PMIC or voltage regulators) is the recovery path because it preserves the original controller and its encryption key. PC-3000 SSD supports the E18 through its Phison NVMe module once the controller is operational again.
SSD Pricing
Kioxia SSD Recovery Pricing
SSD Recovery Calculator
Estimate Your Kioxia SSD Recovery Cost
What type of SSD do you have?
Shomari Hohn
Aravind Udayakumar
David Dachenhaus (DDock)
Ludwig Jonsson
LaCie
BiCS FLASH NAND Architecture
BiCS FLASH NAND and Recovery Implications
Kioxia (jointly with Western Digital/SanDisk) manufactures BiCS FLASH 3D TLC NAND at their Yokkaichi and Kitakami fabrication plants in Japan. BiCS FLASH uses charge-trap flash (CTF) architecture, the same fundamental cell type as Samsung V-NAND. The implementation details differ (vertical channel structure, word-line geometry, oxide layer composition), but both are charge-trap designs. Current consumer drives ship with 112-layer or 162-layer BiCS FLASH.
Charge-trap cell behavior affects read retry parameters during recovery. When NAND cells degrade past their programmed threshold voltages, PC-3000's read retry mechanism shifts voltage references to find the correct charge level. BiCS FLASH and Samsung V-NAND both use charge-trap cells, but their oxide stack compositions and manufacturing processes differ. This means the optimal read retry parameters differ between Kioxia and Samsung NAND even when the host controller is identical (e.g., both using a Phison E18).
Controller Architecture Grid
Kioxia SSD Controllers and Recovery Methods
TC58NC1202GST in the Kioxia Exceria
4-channel NVMe Gen3, onboard DRAM, AES-256 encryption. BiCS FLASH 3D TLC. Power loss during FTL flush corrupts the mapping tables, triggering firmware diagnostic mode (0MB capacity). PC-3000 SSD's Phison Utility accesses the controller diagnostic interface, reads NAND contents with proper descrambling, and rebuilds the flash translation layer. Shares the same firmware family and recovery workflow as the Toshiba RC500.
TC58NC1202GST recovery details
Phison PS5018-E18: Exceria Pro
Triple ARM Cortex-R5 cores, 12nm process, 8-channel NVMe Gen4 with onboard DRAM. Thermal stress from sustained writes can damage the PMIC, causing complete non-detection. Board-level repair (PMIC or voltage regulator replacement) preserves the encryption key. Once the controller is operational, PC-3000 SSD's Phison Utility handles firmware repair and data extraction.
Phison E18 recovery details
Phison E21T: Exceria Plus G3
DRAMless Gen4 NVMe controller using Host Memory Buffer (HMB) for FTL metadata. The Exceria Plus G3 is Kioxia's budget Gen4 option. DRAMless design makes FTL corruption from power loss more likely because the mapping data resides in NAND rather than dedicated DRAM. The E21T is on ACELab's PC-3000 SSD supported list for firmware-level FTL rebuild. Contact us for an honest assessment.
Custom Kioxia Controller for CM6, CD8, and PM7
Kioxia enterprise SSDs use in-house controllers (not Phison). The CM6 series ships in U.2 and E3.S form factors for data center NVMe deployments. The PM7 is a SAS-4 dual-port drive. Enterprise Kioxia controllers include hardware power loss protection (tantalum capacitors on the PCB), multi-namespace support, and enterprise-grade encryption. PC-3000 coverage for Kioxia's in-house controllers is limited to older Toshiba enterprise families. We evaluate each enterprise drive individually.
Legacy Toshiba SSDs: XG5, XG6, and RC500
The Toshiba RC500 is the direct predecessor to the Kioxia Exceria, using the same TC58NC1202GST controller. The XG5 and XG6 were OEM NVMe drives shipped in Lenovo, Dell, and HP laptops; they use Toshiba's in-house controller with BiCS FLASH NAND. Toshiba also acquired OCZ Technology in 2014. OCZ drives (RD400, VX500, Trion series) used a mix of Toshiba and Indilinx controllers. Recovery approach varies by the specific controller inside.
Toshiba drive recovery
Kioxia BiCS FLASH in Other Brands
Kioxia supplies BiCS FLASH NAND to other SSD manufacturers. Western Digital and SanDisk SSDs use Kioxia/WD jointly-produced BiCS FLASH. Some Kingston, PNY, and Corsair drives also use Kioxia NAND sourced from the Yokkaichi fab. The NAND manufacturer affects read retry parameters during recovery, but the host controller determines the primary recovery workflow. A Kingston KC3000 with Kioxia NAND still uses the Phison E18 recovery module, not a Kioxia-specific tool.
DRAMless vs DRAM-Equipped
DRAMless Kioxia SSDs and Power Loss Vulnerability
The Kioxia Exceria Plus G3 uses the Phison E21T, a DRAMless Gen4 controller that relies on Host Memory Buffer (HMB) for FTL metadata caching. In normal operation, the host system's RAM stores frequently accessed FTL entries, reducing latency. When the system loses power, HMB contents vanish. The controller must reconstruct FTL state from NAND on next boot.
This reconstruction fails when a write was in progress during the power loss. The FTL data stored in NAND becomes inconsistent because the write to update the mapping was interrupted mid-operation. DRAM-equipped drives (Exceria, Exceria Pro) also suffer from power loss corruption.
If your Kioxia SSD failed after a power loss event, note the circumstances when you contact us; it helps us determine the expected FTL damage scope.
Chip-off and Encryption
Chip-Off Recovery and Kioxia Encryption
All current Kioxia consumer NVMe SSDs use controllers with AES-256 hardware encryption. The Exceria's TC58NC1202GST, the Exceria Pro's PS5018-E18, and the Exceria Plus G3's E21T all generate unique encryption keys during manufacturing. These keys are bound to the controller silicon and never exposed to the host system.
Desoldering BiCS FLASH NAND packages from a dead Kioxia SSD yields only AES-256 ciphertext. Without the original controller's decryption key, the raw NAND data is mathematically unrecoverable. This is why board-level repair (not chip-off) is the primary recovery path for Kioxia NVMe drives.
Board-level repair replaces failed passive components (PMICs, voltage regulators, capacitors) on the original M.2 PCB while preserving the controller die and its encryption key. Our microsoldering workstations handle BGA rework on M.2 2280 form factors. Once the controller powers on and initializes, PC-3000 SSD accesses the firmware layer for data extraction.
Kioxia SSD Data Recovery FAQ
My Kioxia Exceria SSD shows 0MB in BIOS. Can you recover it?
The Exceria Gen3 uses the KIOXIA TC58NC1202GST controller. When firmware tables corrupt (typically after power loss), the controller enters a diagnostic mode and reports 0MB capacity. PC-3000 SSD's Phison Utility accesses the controller below the firmware layer to rebuild the flash translation layer and extract data. Firmware recovery is $900–$1,200.
Is the Kioxia Exceria Pro recoverable after firmware failure?
The Exceria Pro uses the Phison PS5018-E18, a Gen4 NVMe controller with AES-256 hardware encryption. ACE Lab lists the PS5018-E18 under its repair-only designation, so PC-3000 SSD does not rebuild the translator on this controller. Board-level repair (replacing failed PMICs or voltage regulators) preserves the encryption key when the controller cannot be accessed through standard tooling.
What is the difference between Kioxia and Toshiba SSDs?
Kioxia is the former Toshiba Memory Corporation, sold to a Bain Capital consortium in 2018 and renamed Kioxia in October 2019. Kioxia manufactures BiCS FLASH NAND and uses it in their own SSDs. Older drives sold under the Toshiba brand (RC500, XG5, XG6) use the same NAND technology. We recover both Kioxia-branded and legacy Toshiba-branded SSDs. The Toshiba RC500 uses the same TC58NC1202GST controller as the Kioxia Exceria.
Can you recover enterprise Kioxia SSDs like the CM6 or CD8?
Kioxia enterprise SSDs (CM6, CD8, PM7 SAS) use custom firmware with enterprise-specific features: power loss protection capacitors, enhanced encryption, and proprietary wear leveling. We evaluate each enterprise drive individually. The CM6 uses a custom Kioxia controller (not Phison), which limits PC-3000 coverage. Contact us with the specific model number for an honest assessment of recovery options.
How much does Kioxia SSD recovery cost?
Kioxia SSD recovery is priced $200–$2,500. Simple data copies are $200. File system recovery is from $250. Circuit board repair runs $900–$1,200. Firmware corruption is $900–$1,200. Advanced component repair requiring microsoldering is $1,200–$2,500. Free evaluation with no diagnostic fees.
Is chip-off recovery possible on Kioxia SSDs?
Kioxia consumer NVMe SSDs including the Exceria and the Exceria Pro use controllers with AES-256 hardware encryption. The encryption key is generated by and bound to the original controller silicon. Desoldering BiCS FLASH NAND chips yields only ciphertext. Board-level repair to revive the original controller is the only viable path when the controller fails on encrypted Kioxia drives.
Send Us Your Kioxia SSD
Free evaluation. Firm quote. No data, no fee. Ship your Kioxia or legacy Toshiba SSD to our Austin lab.
