Toshiba Data Recovery
Recovery for the full Toshiba hard drive lineup: MQ laptop drives, DT desktops, MG enterprise helium drives, N300 NAS drives, and Canvio external portables. All work performed in our Austin, TX lab on PC-3000 hardware.
Standard drives $100–$2,000 | No Data, No Fee | Free Evaluation
How Toshiba Drive Recovery Works
Our hard drive data recovery page covers the full range of brands & failure types we handle.
We evaluate your drive for free and give you a firm quote. If we can't recover your data, there's no recovery fee. All recovery work happens in our Austin lab on PC-3000 Portable III and PC-3000 Express hardware with a ULPA-filtered clean bench for mechanical work.
Laptop / Portable
MQ Series Laptop Drive Recovery
The MQ01 and MQ04 are Toshiba's 2.5-inch laptop drives.
External / Portable
Canvio External Drive Recovery
The Canvio Basics, Canvio Advance, Canvio Ready, and Canvio Slim are Toshiba's portable external drives. Some Canvio drives, such as the MQ04UBB400 and MQ01UBD100, are native-USB. On those, the USB connector is part of the drive's own PCB, and there's no SATA edge connector.
Canvio model-specific recovery detailsDT01/DT02 Desktop Drive Recovery
DT01/DT02 model-specific recovery detailsEnterprise / Datacenter
MG Enterprise Drive Recovery
Helium-sealed Toshiba MG enterprise drives have laser-welded enclosures. We repair firmware failures without breaking the seal. A mechanical failure means opening the drive and refilling it with helium during the head swap. The helium refill adds to the base recovery cost.
The MG series is Toshiba's enterprise line, deployed in data centers, NAS arrays, and servers.
We repair firmware and electronic failures on helium-sealed MG drives without breaking the seal. The PC-3000 connects through the drive's diagnostic interface to access the service area, rebuild translator tables, and patch corrupted firmware modules. Mechanical failures on helium drives are more complex. The heads fly at a height calibrated for helium's density, and if the drive runs in atmospheric air, the heads contact the platters.
N300 NAS Recovery
When an N300 fails inside a NAS array, we image every member drive, then rebuild the array from those images.
Toshiba Recovery Pricing
Air-filled MQ, DT, and Canvio drives use the standard HDD tiers. Helium-sealed MG enterprise drives use the helium HDD tiers when firmware complexity or sealed-chamber mechanical work is involved. Free evaluation. No data, no recovery fee.
Air-filled Toshiba HDD pricing
- Low complexity
- Low complexity
- Medium complexity
- High complexity
- High complexity
Helium-sealed Toshiba MG pricing
From $600
$3,000–$4,500
$4,000–$5,000
- Helium cost
- Helium cost: $400-$800 additional for head swap and surface damage tiers. This covers the helium refill required after opening the sealed chamber.
- Helium donor drives must be an exact match. Typical donor cost: $200–$600 depending on model and availability, plus helium refill cost ($400–$800) required after opening the sealed chamber.
Rush service available: +$100 rush fee to move to the front of the queue.
Donor drive costs: Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available. Head swap & surface damage tiers require donor parts. For helium-sealed MG series drives, refer to helium drive pricing ($200–$5,000+, plus helium cost: $400-$800 additional for head swap and surface damage tiers. this covers the helium refill required after opening the sealed chamber.).
Technical Methodology
Toshiba PCB ROM Architecture
A simple PCB swap on a Toshiba drive (replacing a burnt board with an identical one) does not work because the ROM chip on the original board contains unique calibration data & adaptive parameters specific to that individual drive.
For MQ01 drives, firmware repair means moving the original ROM contents onto the replacement board so the adaptives stay with the drive they were calibrated for.
Helium Seal Considerations for MG Enterprise Drives
The heads fly at a height calibrated for helium's lower density. Firmware repairs, translator rebuilding, and electronic component replacement on the PCB all proceed without disturbing the helium seal. Mechanical failures that require opening the drive are handled in-house at our Austin lab. We perform the head swap on our ULPA-filtered clean bench and refill the drive with helium before imaging with PC-3000.
As helium escapes and heavier atmospheric air ingresses, the gas density inside the drive rises and the heads deviate from the fly height the firmware was calibrated for. Heads can no longer maintain stable flight, particulate from head-platter contact begins to circulate, and the case transitions from a recoverable mechanical case to a surface-damage case.
Once helium pressure has dropped, no field procedure can re-inject helium without opening the laser-welded enclosure. We open the drive on the ULPA-filtered clean bench, swap in the head-stack assembly from a model-matched donor, refill the chamber with helium, and image the recovered drive. That's billed on the helium head-swap tier, $3,000–$4,500. If the heads have already touched the platters, it moves to the helium surface-damage tier, $4,000–$5,000.
DIY Imagers on a Clicking Toshiba: How Additional Damage Occurs
Running ddrescue, HDDSuperClone, or any other OS-level imager on a clicking drive won't get your data back. It keeps weak heads working across the platters, and that can destroy the surface.
How We Recover Toshiba Drives
Image and Extract
Firmware repairs restore logical access. Head swaps are performed on our ULPA-filtered clean bench with model-matched donors. PC-3000 for degraded media.
See the particle counter test at the benchToshiba Recovery Questions
How much does Toshiba data recovery cost?
My Toshiba Canvio external drive stopped working. Can you recover the data?
Can you recover data from a Toshiba MG08 enterprise helium drive?
Can a Toshiba PCB be swapped from a donor without ROM transfer?
Related Recovery Services
All HDD brands and failure types
MG enterprise helium-sealed drives
N300 NAS and multi-drive arrays
Canvio and other USB enclosures
Head failure symptoms and diagnosis
HDD recovery pricing tiers explained
Mail-in HDD recovery to the Austin TX lab
Choosing an honest HDD recovery lab
Toshiba Drive Failing?
Send us the model number from the drive label. We'll confirm the controller architecture and give you a firm quote. If we don't recover your data, there's no recovery fee.
