WD My Cloud Data Recovery
WD My Cloud NAS data recovery for single-bay My Cloud, EX2 Ultra, EX4100, PR2100, and PR4100 units. We recover data from OS 5 firmware bricks, red LED failures, and inaccessible network shares. Single-bay units use a standard EXT4 drive; multi-bay units use Linux mdadm RAID with EXT4. Free evaluation. No diagnostic fees. All work performed in-house at our Austin, TX lab. Single location, no franchises, no outsourcing. No data = no charge.
Looking for WD My Cloud Home recovery? If your files appear as random hexadecimal strings, your device uses a proprietary SQLite-indexed architecture, not standard Linux RAID. See our WD My Cloud Home recovery page for the correct process.
WD My Cloud Recovery at a Glance
We recover WD My Cloud drives in-house at our Austin, TX lab: each disk imaged through a hardware write-blocker, then the mdadm array metadata parsed & the EXT4 volume reconstructed offline from the clones. Free evaluation, no diagnostic fee, no data no charge, nationwide mail-in, single location, no outsourcing.
- Single-bay My Cloud
- One disk, no RAID. We image the drive through a write-blocker & mount its EXT4 partition read-only from the clone. That is the short path.
- Multi-bay EX2 Ultra, EX4100, PR2100, PR4100
- We image every member drive, read the mdadm superblocks, reassemble the array read-only, then mount the EXT4 volume. It is the same imaging-first NAS data recovery workflow we run across Linux-based units.
- Commercial terms
- Free evaluation, no diagnostic fee, and no data means no charge. Every drive is imaged before any array is assembled, because a NAS array is availability, not a backup.
- How to start
- Start a case for a free evaluation, then ship the drives to the Austin lab through our nationwide mail-in service.
What Are the WD My Cloud Product Lines?
WD My Cloud splits into two architectures. Single-bay personal cloud units hold one WD drive on a standard EXT4 partition with no RAID. Multi-bay models (EX2 Ultra, EX4100, PR2100, PR4100) run Linux mdadm software RAID over EXT4. Recovery differs accordingly: single-drive imaging versus full array reconstruction.
| Models | Architecture | RAID | Recovery |
| Single-Bay My Cloud | A standard WD drive inside an enclosure with a network interface (not USB). The drive has a Linux partition layout with EXT4 data volumes. | No RAID. | Remove the drive, connect through a write-blocker, and mount the EXT4 partition. If the drive has mechanical issues, it follows our standard hard drive recovery workflow. |
| Multi-Bay My Cloud: EX2 Ultra, EX4100, PR2100, PR4100, DL2100, DL4100. 2-bay or 4-bay. | Filesystem is EXT4. | Linux mdadm software RAID. Every unit does JBOD, Spanning, RAID 0 & RAID 1. Only the 4-bay units add RAID 5 & RAID 10. | Image each member drive, reconstruct the mdadm array, and extract the EXT4 volume. Same workflow as other Linux-based NAS recoveries. |
What Are Common WD My Cloud Failure Modes?
WD My Cloud failures come in four kinds. An OS 5 firmware update can leave the firmware corrupted and the LED red. Drives in older units fail. mdadm drops SMR WD40EFAX members out of the RAID. And when WD ended support for OS 3, remote and app access ended with it.
| Failure Mode | What Happens | What It Means for the Data |
| OS 5 Firmware Brick | An OS 5 firmware update can corrupt the firmware. When it does, the dashboard reports Safe Mode and the front LED goes red. | Your files are on their own data partition, apart from the firmware. |
| Red LED on Front Panel | A red LED means a fault. WD's manual lists these as red-LED faults: a disk SMART failure, a missing data or system volume, and a thermal shutdown. | Don't run a Quick Restore or a Full Restore. WD's manuals say both erase your shares & files. |
| Drive Failure in Aging Units | Older units still run their original drives. When those drives fail, you see SMART errors, clicking, or slow response. | These drives need professional imaging with retry control before data extraction. |
| Network Inaccessible After Cloud Service Shutdown | WD discontinued My Cloud remote access for older OS 3 units. | If your My Cloud is not accessible on the local network, the data is still on the physical drive. It has not been erased by the service shutdown. |
Do not factory reset. Both a Quick Restore and a Full Restore erase your shares & files on a My Cloud. Remove the drive(s) and contact us.
What Do the My Cloud Restore to Default Options Do to Your Files?
Two of the three options erase your files. WD's own My Cloud user manuals list System Only, Quick Restore & Full Restore in the Restore to Default area of the dashboard's Utilities page. Only System Only keeps your data.
WD's manual for the multi-bay DL2100, DL4100, EX2100 & EX4100 doesn't word every option the same way as WD's single-bay My Cloud manual.
| Option | What WD Says It Does | What It Means for Your Files |
| System Only | Puts the settings back to their defaults. The multi-bay manual says it keeps user data & shares. The single-bay manual says your content stays untouched, but private shares become public & the admin password goes back to none. | Your files stay put. On a single-bay unit, shares you'd made private come back public. |
| Quick Restore | Puts the settings back to their defaults & erases user data & shares. The single-bay manual says it erases the drive. The DL2100, DL4100, EX2100 & EX4100 manual says it makes a new file table but doesn't fully overwrite or erase the drive. | The unit erases your shares & files. For those four multi-bay models, WD says data recovery programs can still restore user data & shares. |
| Full Restore | Puts the settings back to their defaults & permanently deletes user data & shares. The single-bay manual says it permanently overwrites or erases them & can take several hours. | WD says data recovery programs can't bring that data back. We won't promise you anything different. |
If your My Cloud won't show its shares & the files matter, don't run any of the three. WD's multi-bay manual also warns that importing a saved configuration after a factory restore doesn't bring back shares or users. Shut the unit down & get the drives to us through our mail-in service.
Already ran a Quick Restore? Stop using the unit. On the DL2100, DL4100, EX2100 & EX4100, WD's own manual says the drive wasn't fully overwritten. Then send us the drives.
Does WD My Cloud Use Hardware Encryption?
WD My Cloud NAS units store data as standard EXT4 or mdadm RAID without bridge-chip encryption. WD My Book and My Passport USB drives use JMicron JMS561, JMS538S, or Symwave SW6316 bridge chips that enforce hardware AES at the PCB level. It's on even if nobody set a password.
On WD My Book and My Passport USB external drives, the encryption happens on the PCB. The JMicron JMS561, JMS538S, or Symwave SW6316 bridge chip on that board enforces hardware AES encryption, and it's on even if you never set a password.
Removing a My Book drive and connecting it directly via SATA yields ciphertext, not readable data. This is different from WD My Cloud NAS units, which store data as standard EXT4 or mdadm RAID without bridge-chip encryption.
Recovery for My Book bridge failures requires either repairing the original bridge PCB or recovering the original encryption key material to decrypt the imaged drive.
How the Bridge Chip Encrypts Data Transparently
The USB-to-SATA bridge chip sits between the host controller and the physical hard drive. It generates a Data Encryption Key (DEK), typically stored redundantly in both the bridge board EEPROM and hidden sectors on the drive itself.
Every block written to the drive passes through the chip's AES-256 cipher. The user never sees the encryption because the bridge decrypts automatically on read. When the bridge fails, the drive looks unreadable rather than encrypted, which leads users to attempt destructive recovery steps.
- JMicron JMS561
- It's in WD external USB drives, and it does hardware AES. The wrapped key is held in more than one place, so a destroyed bridge board does not by itself take the decryption path with it. Not present in WD My Cloud NAS units.
- JMicron JMS538S
- Single-drive bridge used in WD My Book and My Passport USB external drives. Applies AES-256 transparently even with no user password. Shucking the drive yields ciphertext on every sector. Not present in WD My Cloud NAS units.
- Symwave SW6316
- Alternative bridge chip found in some WD enclosure generations. Same AES-256 behavior: encryption is on by default and direct SATA attachment produces ciphertext. On these designs the wrapped key is held in the drive's Service Area as well as the bridge EEPROM, which is where we read it from.
Recovery Path for Bridge-Encrypted Drives
For WD My Book and similar USB external drives with bridge-chip encryption, we address decryption at the board level. The first step is imaging the drive through a write-blocker to preserve the current sector state.
If the original bridge PCB is intact but the enclosure logic has failed, we repair the PCB using microsoldering equipment (Hakko FM-2032 on FM-203 or FX-951 base, Atten 862 hot air rework station) to restore the bridge chip's power and data paths.
If the PCB can't be repaired, it comes down to the key material. When nobody ever set a password, the key-encryption key is derived from a factory default.
We recover the key itself, either from the original bridge EEPROM or from the backup copy in Service Area modules on the drive. Then we decrypt the drive image with it. Possession of the correct key determines a readable result, not board parity.
3.3 V power-pin warning: WD drives pulled out of enclosures can use the SATA 3.3 V power disable (PWDIS) feature on Pin 3. If your power supply puts 3.3 V on that pin, the drive won't spin up.
WD My Cloud Hardware & Firmware Failure Details
WD My Cloud enclosures use logic boards that are separate from the internal hard drives. A failed enclosure board can block access to your data, the same way a firmware fault, drive failure, or thermal shutdown does. We bypass enclosure failures by extracting the drives and imaging them directly via PC-3000.
SMR Drive Complications in EX2 & EX4 Arrays
WD lists the WD Red WD40EFAX as a Drive-Managed Shingled Magnetic Recording (DM-SMR) drive. To change data inside a shingled band, the drive has to rewrite the band.
During an mdadm RAID rebuild, the heavy write load overwhelms the drive's SMR Translation Layer. Before we image an SMR drive, we use PC-3000 to lock its background firmware processes.
WD40EFAX Firmware: Module 190 T2 Translator Corruption
On a WD DM-SMR drive such as the WD40EFAX, the second-level (T2) translator lives in Service Area Module 190.
PC-3000's WDC Marvell utilities include T2 translator recovery, and it works by analyzing Module 190. This failure is specific to WD SMR translator corruption & doesn't affect CMR drives in the same enclosure.
JBOD to RAID Configuration Overwrites
Changing a multi-bay My Cloud from JBOD to RAID 1 (or vice versa) through the dashboard wipes it the moment you apply it. WD's manual warns that changing the RAID mode deletes all of your data and your user settings.
When a RAID 1 member drops out, its event count falls behind the other member's. We read the event count in each superblock to find the current member, and we pull data from that drive only.
How Are the Drives Partitioned?
On a single-bay My Cloud the drive has several small Linux partitions, including swap, plus one large EXT4 partition that holds your files. Your data lives on the big one, in its own region of the disk.
On an EX2 Ultra the firmware and its configuration live in the unit's onboard flash. The drives carry small partitions mirrored across the bays with mdadm RAID 1. Your data sits on a separate mdadm volume formatted EXT4, set up as JBOD, Spanning, RAID 0, or RAID 1, whichever you picked.
This is the same separation that lets us pull the drives and read the data volume even when the unit will not boot.
Why a Member Drive in a USB Enclosure Won't Mount
Pulling a My Cloud drive and plugging it into a USB-to-SATA dock on a Windows or Mac desktop does not show your files, and there are two distinct reasons depending on the unit.
First, the data partition is EXT4, the native Linux filesystem. Microsoft's own documentation says an Ext4-formatted drive can't be mounted on the Windows file system.
Second, on a multi-bay unit each drive is an mdadm component, not a plain partition. It carries its own mdadm superblock, and depending on the metadata version the EXT4 filesystem can be offset from the start of the partition rather than beginning at sector zero.
The correct path is to assemble the array with mdadm first, then mount the resulting data volume. On a striped or parity set a single member on its own is a fragment, not a mountable disk.
This is a different failure from the WD My Book bridge-chip case covered above. A My Book drive on SATA returns AES-256 ciphertext because the bridge was encrypting every block on its way to the platters. A My Cloud member returns readable EXT4 once the array is assembled; nothing on the platter is encrypted unless you enabled software volume encryption in the dashboard.
If Windows can't read the filesystem, that's a visibility problem. Ciphertext is an encryption problem, and you don't handle the two the same way.
Imaging First, Then mdadm Reconstruction From the Clones
We never assemble a My Cloud array on the original drives. We image every member first through a hardware write-blocker (PC-3000 Portable III, PC-3000 Express, or DeepSpar Disk Imager), so we read the source disks once and never write to them. All reconstruction happens against the clones.
From each clone we read the mdadm superblock to recover the parameters the array needs: the member's role in the set, the chunk size, and the data offset. Read-only, on the clones, never the originals:
# READ-ONLY. Run against sector clones, never the original drives.
# Read each member's superblock: role, chunk size, data offset
mdadm --examine /dev/loop0 /dev/loop1
# Assemble the array read-only from the CLONES
mdadm --assemble --readonly /dev/md0 /dev/loop0 /dev/loop1
# Mount the EXT4 data volume read-only
mount -o ro,noload /dev/md0 /mnt/mycloudThe two mdadm commands are not WD-specific: a multi-bay My Cloud stores its array on the same Linux software RAID a ReadyNAS or a TeraStation does, so mdadm superblock recovery & read-only assembly is the same work at the md layer on all three. They split at the mount step. A TeraStation mostly puts XFS over md, and some units use EXT4. A ReadyNAS puts either LVM and EXT4 or Btrfs over it, depending on the OS generation.
When superblocks are damaged or the JBOD-to-RAID overwrite destroyed the metadata, we reconstruct the array virtually in Data Extractor Express RAID Edition (the ACE Lab RAID software that runs on the PC-3000 Express), which destripes the member images and recovers the layout when mdadm alone can't assemble it.
Either path mounts the EXT4 volume read-only and copies your files off. The original drives stay untouched the entire time, because a NAS rebuild is availability, not a backup, and the imaging-first rule is what keeps a second mistake off the table.
How Does the My Cloud OS 3 vs OS 5 Firmware Split Change Recovery?
It doesn't change where your files live. WD no longer supports OS 3, and the upgrade from OS 3 to OS 5 is one-way. Your files are on their own EXT4 partition or mdadm data array, apart from the firmware.
A firmware failure isn't a disk failure. Your files are on the large EXT4 data volume, apart from the firmware.
That separation is what lets us pull the drives and read the data even when the firmware will not load.
How the Layers Map to Your Model and Firmware
- One disk with small Linux partitions, including swap, and one large EXT4 data partition. There's no RAID. We image the disk and mount the EXT4 partition from the clone.
- On an EX2 Ultra, mdadm RAID 1 mirrors small partitions across the bays, and your data lives on a separate mdadm volume formatted EXT4. On a striped or parity data volume (RAID 0, 5, or 10), one member on its own is a fragment. We have to rebuild the array from the imaged clones before the EXT4 volume mounts. A RAID 1 mirror is different: each member holds a complete EXT4 filesystem.
- My Cloud OS 3
- The older firmware generation, now end-of-support. Data still sits on the same EXT4 or mdadm layout, so an OS 3 unit that will not boot is recovered the same way as any other My Cloud: image the drives, mount the data volume offline.
- My Cloud OS 5
- The upgrade from OS 3 is one-way. If a unit bricked partway through the migration, you can't roll it back to OS 3 to get it working again.
If you are here because shucking a WD drive returned unreadable data rather than a boot problem, read our My Cloud hardware encryption breakdown on why a My Book or My Passport member yields AES-256 ciphertext over SATA while a My Cloud member does not.
A firmware-layer failure is not the same as a security exposure. If you landed on this page chasing a published vulnerability rather than a bricked unit, our CVE-2025-30247 advisory covers that flaw separately from the benign mount failure described above.
Where Does a My Cloud Store Its RAID Geometry?
On the member drives. A multi-bay My Cloud records how its array is put together in the mdadm superblock written to each disk, so member ordering, RAID level, chunk size, parity layout, array UUID, data offset, and the event counters that show which member dropped first all survive the enclosure. A dead main board takes away the machine that was reading that description; it does not take away the description.
A My Cloud EX2 Ultra, EX4100, PR2100, or PR4100 runs stock Linux software RAID under WD firmware, and Linux software RAID keeps its array description on the member disks. Reconstruction is a software problem once the members are imaged.
mdadm Superblock Fields That Define the Array
Reading the superblock read-only from each clone with mdadm --examine returns the parameters an assembly needs. Nothing in that list is held by the enclosure.
| Superblock field | What it settles during reconstruction |
| Array UUID | Which disks belong to the same set. Drives from two different My Cloud units mixed in one shipment sort themselves out on this field alone. |
| Device Role | Which slot a member occupied. Bay order written on the chassis label is not what the assembly trusts; the role recorded per member is. |
| RAID level and layout | Whether the volume is a mirror, a stripe, or parity, and for parity sets how the parity rotates across the members. |
| Chunk size | How many kilobytes land on one member before the write moves to the next. Get this wrong and the assembled volume produces files that decode partway and then turn to noise. |
| Data offset | Where the payload starts behind the metadata, which is the boundary the EXT4 filesystem is measured from. |
| Event counter | How current each member is. A member that dropped weeks before the array stopped carries a lower count, and that is the one we exclude from the assembly rather than let it overwrite current data. |
Where that superblock sits depends on the metadata version, which is why locating it is the first step rather than an assumption. Versions 0.90 and 1.0 are stored at the end of the device with the data payload at offset 0. Version 1.1 sits at the absolute start. The modern default, 1.2, sits 4 KiB from the start with the payload at a calculated offset.
Chassis Swap Rewrites the Array Metadata
The advice that circulates on support forums is to buy a working enclosure of the same model and move the drives across. That works when the only thing that failed was the chassis power supply. It goes badly when the original crash was logical, because the next step a NAS dashboard offers for an unfamiliar set of drives is a write.
If a dashboard step re-creates the array, it writes new md superblocks over the old ones. mdadm's documentation says a re-created array can get a different data offset, so the boundary the EXT4 filesystem was measured from can move. The original description of the array isn't on the disks anymore for anyone to read. An enclosure failure that would have been a straight imaging job becomes a hunt for filesystem structures with no map to check them against.
On our side the equivalent destructive Linux operation is mdadm --create, and it never runs against original media here. Assembly happens on clones, read-only, after the superblocks have been read and recorded. If the geometry has to be derived because the metadata is already gone, that derivation runs against images too.
Dead Board Cases and Failing Member Cases Diverge at Intake
Both start the same way, with a write-blocked sector image of every member, and only one of them ends there. A dead main board leaves healthy disks whose only problem is that nothing is assembling them, so imaging is a clean sequential pass on a PC-3000 Portable III, PC-3000 Express, or DeepSpar Disk Imager, and the work that matters happens afterward at the md layer.
A failing member is a media problem and gets handled as one. Read timeouts, retry limits, and pass ordering are set per drive before the imaging starts, weak areas are deferred rather than hammered, and array assembly waits until the image is complete enough to trust. Assembling first and imaging later is how a marginal drive turns into a mechanical case mid-job. Where superblock metadata was destroyed before the drives reached us, the geometry gets derived from the member images in Data Extractor Express RAID Edition instead of read from disk.
A third intake case is not a failure at all. Western Digital ended support for the pre-OS 5 My Cloud generations on April 15, 2022, which removed remote access and mobile app connectivity for those units. A My Cloud in that state looks dead from a phone while the hardware runs, the EXT4 volume is untouched, and the shares still answer on the local network. Check the unit by IP address before assuming the disks are the problem.
My Cloud Home Stores Files as Hex Content IDs
My Cloud Home and My Cloud Home Duo are a different architecture from the classic My Cloud NAS described above, and the difference shows up after the image is already in hand. User files are stored under machine-generated hexadecimal content identifiers with the original names, extensions, and folder hierarchy stripped out. The mapping back to real names and paths lives in a separate SQLite index database, index.db, on the drive itself.
So an image of a Home drive reads fine, but it's useless as it is: hex-named objects with no extensions and no directory tree. Making it usable means parsing that database and re-mapping the objects back to their names and parent folders. The Home Duo carries the same framework across two drives. It defaults to Mirror (RAID 1) with a Max Capacity (JBOD) option, so how many members the offline rebuild needs depends on which mode the owner picked.
That is a separate workflow from mdadm superblock reading, and it has its own writeup on the My Cloud Home recovery page. Multi-bay classic units stay on the array path shared with the rest of our Linux NAS recovery work.
How We Recover Data from a WD My Cloud
Recovery depends on the unit type. Single-bay My Cloud is a single-drive EXT4 case: we image the drive through a write-blocker and mount the partition read-only. Multi-bay units (EX2 Ultra, PR2100, PR4100) require imaging every member, capturing the mdadm superblocks, reconstructing the RAID array, and extracting the EXT4 volume from the virtual disk.
- Free evaluation: We identify your My Cloud model, check whether it's single-bay or multi-bay and whether it has a RAID configuration, and write down the failure symptoms.
- Drive removal and imaging: We remove the drive(s) from the enclosure and image through a hardware write-blocker using PC-3000 or DeepSpar. Single-bay drives with mechanical issues receive head swaps if needed.
- Array reconstruction (multi-bay only): For EX2 Ultra, PR2100, PR4100, and similar multi-bay units, we capture mdadm superblocks and reconstruct the RAID array from cloned images.
- EXT4 extraction: Mount the EXT4 data partition (single-bay) or the EXT4 volume from the reconstructed array (multi-bay). Extract files and verify.
- Delivery: Recovered data copied to target media and shipped. Working copies purged on request.
How Much Does WD My Cloud Data Recovery Cost?
Single-bay My Cloud recovery is priced as a standard single-drive case. Multi-bay units (EX2 Ultra, PR2100, PR4100) use two-tiered pricing: per-member drive imaging billed by drive condition, plus an array reconstruction fee for mdadm RAID rebuilding. No data = no charge.
Single-Bay / Logical
EXT4 extraction from a healthy or firmware-damaged drive
$250–$900
Multi-Bay Reconstruction
mdadm RAID + EXT4 extraction from EX2/PR series
$400-$800
Per-member drive imaging billed separately based on drive condition.
Mechanical (Head Swap)
Clean-bench donor transplant for clicking or non-spinning drives
No Data = No Charge. If we cannot recover usable data from your WD My Cloud, you owe nothing.
Donor drives & rush service: Mechanical recoveries (head swap) require a matching donor drive, billed separately at market value. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. Need it faster? A +$100 rush fee to move to the front of the queue.
My Cloud member drives are standard hard drives, so per-member-drive imaging follows the canonical HDD tiers below. On a multi-bay EX2 Ultra, PR2100, or PR4100, the array reconstruction fee is quoted on top of the per-disk imaging for each drive that needs it.
The same quote structure covers any multi-bay NAS we take in, so NAS data recovery cost on a Synology, QNAP, or Buffalo array moves with the number of drives that need imaging, the way an EX2 Ultra job does.
- Low complexity
- Low complexity
- Medium complexity
- High complexity
- High complexity
WD My Cloud Recovery FAQ
Can you recover data from a WD My Cloud?
Can you recover data from a WD My Cloud bricked by the OS 5 update?
What is the difference between single-bay and multi-bay My Cloud recovery?
What RAID configuration does the WD My Cloud EX2 Ultra use?
My Cloud remote access is down but my data was local. Is it still on the drive?
Why did my WD My Cloud EX2 fail during a RAID rebuild?
I switched my WD My Cloud from JBOD to RAID 1 and lost data. Can you recover it?
Does volume encryption on the EX2 Ultra affect data recovery?
Can recovery software help if my WD My Cloud is not accessible on the network?
Can I remove the drive from my WD My Cloud enclosure and read it directly via SATA?
Does my WD My Cloud have hardware encryption even though I never set a password?
What is the difference between WD My Cloud volume encryption and bridge-chip encryption?
My WD My Book bridge board is dead. Can the AES key still be recovered?
How do you reconstruct the mdadm array from a WD My Cloud EX2 or PR4100?
What is the difference between My Cloud OS 3 and OS 5 for data recovery?
Does my My Cloud model change how you recover the data?
My WD My Cloud enclosure is dead. Do I need an identical chassis to get the data back?
Why do my My Cloud Home files show up as hexadecimal names with no folders?
Related Recovery Services
My Cloud Home hex filename reconstruction from SQLite index.db.
Synology, QNAP, Buffalo, ASUSTOR, TerraMaster, Drobo, and all Linux-based NAS.
All WD drives: Red, Blue, Black, Purple, Gold, Ultrastar.
Full HDD recovery service: head swaps, firmware repair, platter transplants.
RAID 0, 1, 5, 6, 10 array reconstruction from mdadm, ZFS, and hardware controllers.
WD SMR translator corruption diagnosis and PC-3000 firmware repair.
BeyondRAID pooled arrays recovered from write-blocked drive images after Drobo's 2023 shutdown.
WD My Cloud showing a red LED or not booting?
Free evaluation. No data = no charge. Ship your drive from anywhere in the U.S.
