WD My Cloud CVE-2025-30247 Ransomware Recovery
CVE-2025-30247 is an unauthenticated OS command injection vulnerability in WD My Cloud OS 5 firmware prior to v5.31.108. Attackers exploit it via HTTP POST to deploy ransomware on the internal ext4 data partition. Updating firmware closes the hole but does not decrypt already-encrypted files. We recover data by imaging the internal SATA drives offline through PC-3000, reconstructing corrupted ext4 superblocks, and carving surviving plaintext from journal entries and unallocated space. No data = no charge.
Updated September 2026
10 min read
Not hit by ransomware? If your WD My Cloud has a red LED, is stuck in a boot loop, or was bricked by the OS 5 update, see our general WD My Cloud recovery page instead.
CVE Details
What Is CVE-2025-30247?
CVE-2025-30247 is an unauthenticated remote code execution flaw in the WD My Cloud OS 5 web management interface on firmware older than v5.31.108. A crafted request injects OS commands, which is how attackers deploy ransomware to the ext4 user data partition with no login required.
CVE-2025-30247 is a critical remote code execution (RCE) vulnerability in the web management interface of WD My Cloud OS 5 firmware versions prior to v5.31.108.
NVD classifies it as CWE-78, improper neutralization of special elements used in an OS command: a request reaching the management interface ends up in an OS command with those elements intact, so the attacker's commands run on the device.
No authentication or user interaction is required. Any My Cloud device with its management interface exposed to the internet is a target. Once inside, attackers download and execute ransomware payloads that encrypt the ext4 user data partition.
Affected Devices and Firmware
Western Digital released patched firmware v5.31.108 for My Cloud OS 5. All devices running My Cloud OS 5 firmware older than that version are vulnerable.
Multi-Bay Models
  • My Cloud PR2100 / PR4100
  • My Cloud EX2 Ultra / EX4100
  • My Cloud EX2100
  • My Cloud Mirror Gen 2
  • My Cloud DL2100 / DL4100
Single-Bay Models
  • My Cloud (WDBCTL series)
  • My Cloud single-bay (all generations running OS 5)
Firmware vs Ransomware
Why Don't Firmware Updates Decrypt Already-Encrypted Data?
Firmware v5.31.108 closes the command injection vector but never touches the data partition, so files already encrypted by the ransomware stay encrypted after the update. A factory reset is worse: it re-initializes the OS partitions and erases the GPT partition table while leaving the encrypted user data locked.
Updating to firmware v5.31.108 closes the OS command injection vector. Future exploitation through this path is blocked.
The patch does not interact with the data partition. If ransomware has already encrypted files on the ext4 volume (or encrypted the volume itself via LUKS/cryptsetup), those files remain encrypted after the firmware update. A factory reset also does not help; it re-initializes the OS partitions and erases the GPT partition table metadata, but the encrypted user data remains locked.
Do not factory reset. Factory reset erases the GPT layout and mdadm RAID metadata without decrypting any data. This destroys filesystem references needed for forensic extraction. Power off the NAS and remove the drives.
Hardware
WD My Cloud Internal Architecture
Understanding the hardware layout matters for recovery because the forensic approach differs between single-bay and multi-bay models, and the SoC dictates the partition structure. The architecture detailed below covers single-bay Gen2 units; multi-bay PR/EX/DL models use different SoCs and a different bring-up sequence, but the recovery workflow on the data partition is the same once the drives are imaged.
Single-Bay Storage Interface
  • Drive connection: The drive attaches natively to the SoC. There is no USB-to-SATA bridge in the data path, so the platters carry plaintext unless something on the device encrypted them
  • Consequence for recovery: A drive pulled from a single-bay My Cloud reads on a Linux workstation without any bridge board from the original enclosure
Partition Layout (GPT)
  • Boot partitions: Linux kernel, u-boot bootloader, and OS root filesystems (ext2/ext3) occupy the first several GPT partitions
  • User data: The largest partition (end of disk) is formatted ext4 and holds all user files
  • Multi-bay: The ext4 data partition sits on a Linux mdadm software RAID volume. RAID 0, 1, 5, or JBOD depending on configuration
Attack Patterns
What Ransomware Encryption Patterns Target WD My Cloud?
WD My Cloud ransomware falls into three patterns: file-level encryption (read, encrypt, delete the original), full-volume LUKS/cryptsetup encryption, and metadata destruction that wipes superblocks but leaves the data in plaintext. File-level and metadata-wiper cases are the most recoverable; full-volume LUKS without the key is not.
NAS ransomware payloads fall into three categories. The recovery path depends on which type encrypted the data.
1. File-Level Encryption
The ransomware traverses the mounted ext4 volume and encrypts individual files using AES-256 with RSA key exchange, usually appending its own extension to each file. The encryption process reads the original file, writes an encrypted copy, then deletes the original.
Deleted plaintext data may survive in ext4 unallocated space if the drive has not been heavily written to since the attack.
2. Volume-Level Encryption (LUKS/cryptsetup)
If an attacker encrypts the whole block device with LUKS, the volume becomes mathematically inaccessible without the passphrase.
If full-volume LUKS encryption occurred, recovery of the encrypted data is not possible without the key. We check whether the LUKS header was applied before or after user data was written, which occasionally reveals unencrypted sectors in the gap between the old ext4 boundary and the LUKS container.
3. Metadata Destruction (Wiper Behavior)
Some payloads destroy filesystem metadata (superblocks, group descriptors, inode tables) to render the partition raw and unmountable. The user data remains on the platters in plaintext, but the operating system cannot locate file boundaries or directory trees.
This pattern is the most recoverable in a lab setting because the data itself is not encrypted; only the map to the data is destroyed. We reconstruct from ext4 backup superblocks and journal entries.
Process
Forensic Recovery Procedure
We remove the drives, image every member sector-by-sector through a write-blocker with PC-3000, then work only on the clones. From there we virtually reassemble any mdadm array, restore corrupted ext4 superblocks from their backup copies, and carve surviving plaintext from the journal and unallocated space. The originals are never modified.
Every step operates on cloned images. The original customer drives are never modified. This workflow applies to both single-bay and multi-bay WD My Cloud devices.
  1. Drive removal and isolation: We remove the 3.5-inch SATA drive(s) from the NAS enclosure. The NAS is never powered on again; all subsequent work happens offline. Drives with mechanical symptoms (clicking, non-spinning) go through head swap or firmware repair in our 0.02 micron ULPA clean bench before imaging.
  2. Write-blocked forensic imaging via PC-3000: Each drive is connected to a hardware write-blocker and cloned sector-by-sector using PC-3000 Data Extractor. The write-blocker prevents any modification to the evidence drive. If the drive has bad sectors or read instability, PC-3000's adaptive retry algorithms map around damaged regions and capture maximum data.
  3. RAID reconstruction (multi-bay only): For EX2 Ultra, PR2100, PR4100, and other multi-bay units, we parse the mdadm superblocks from each member drive image to determine stripe size, disk order, and parity rotation. The RAID array is reassembled virtually from the cloned images without touching the originals.
  4. Ext4 superblock restoration: If ransomware corrupted the primary ext4 superblock, the filesystem will not mount (the drive reports "Bad magic number in super-block"). Ext4 stores the superblock signature 0xEF53 at offset 0x38 in the primary superblock. Backup copies exist at block numbers 32768, 98304, 163840, 229376, and 294912. We locate a valid backup using mke2fs -n (dry-run mode; writes nothing) and restore via e2fsck -b 32768 on the forensic clone.
  5. Journal carving and inode recovery: The ext4 journal records metadata changes before they are committed to the main filesystem. We parse uncommitted transactions and roll back recent journal entries to recover the filesystem state from immediately before the ransomware executed. This rescues deleted plaintext files from unallocated space when the ransomware used file-level encryption (read-encrypt-delete cycle).
  6. Bridge-chip encryption check during triage: Before assuming a recovered drive is unencrypted, we verify how it was wired. Single-bay My Cloud NAS units connect the drive natively to the SoC and write ext4 with no bridge chip in the way, so a clone reads back as plaintext ext4. WD My Book and other external-USB-enclosure models are the opposite case: those route the drive through a USB-to-SATA bridge that encrypts with hardware AES even when no password was ever set, so a shucked drive read on a plain SATA port returns ciphertext. Recovering that data means recovering the key material, which is stored redundantly in the bridge board and in Service Area modules on the drive itself, and decrypting the sector image with it. Possession of the key decides the outcome, not a matching donor board. That is why bridge status is part of triage rather than an assumption.
  7. Data extraction and verification: Recovered files are extracted, verified for integrity, and delivered on target media. We provide a file listing before shipping so you can confirm the recovery meets your needs.
Vanished shares are not always deleted data. Certain WD firmware updates have a documented history of resetting the auto-mount parameters for encrypted volumes. Network shares disappear after the update and owners conclude the data was wiped, when the volume is intact and simply no longer mounting. We check the auto-mount and encryption state during triage before treating a drive as erased.
Common Mistakes
Which Actions Destroy Recoverable Data on WD My Cloud?
The four actions that destroy recoverable data are connecting the drive to Windows and letting it initialize or format, running fsck on the live NAS, triggering a RAID rebuild while the infection is still active, and factory resetting. Each one overwrites the GPT layout, ext4 metadata, or RAID parity needed for forensic extraction.
Community forums show recurring patterns where users permanently destroy data that would otherwise be recoverable.
  • Connecting the drive to Windows: Windows cannot read ext4. When you connect the internal drive, Windows prompts to "Initialize" or "Format" the disk. Clicking either option overwrites the GPT partition table and destroys the ext4 superblock.
  • Running fsck on the live NAS: fsck is designed to make a filesystem consistent, not to preserve user data. On a ransomware-damaged filesystem, it orphans or deletes thousands of entries to restore mountability, permanently destroying the inode references needed for journal-based recovery.
  • Triggering a RAID rebuild while infected: On multi-bay units, swapping a drive or forcing a rebuild while ransomware is still active causes parity recalculations that embed the encrypted data across all surviving members. The pre-attack data is overwritten by parity writes.
  • Factory reset: Erases the GPT partition table and mdadm configuration. Does not decrypt anything. Destroys the filesystem metadata needed for forensic extraction.
How Much Does CVE-2025-30247 Recovery Cost?
Pricing follows our standard hard drive recovery tiers because the internal drives are standard 3.5-inch SATA HDDs. The complexity depends on the ransomware type (metadata destruction vs. file-level encryption vs. full-volume LUKS) and whether the drive has mechanical damage.
Metadata / Logical Recovery
Superblock restoration, ext4 journal carving, inode recovery from unallocated space
$250–$900
Multi-Bay Array + Forensics
mdadm RAID reconstruction from cloned images plus ext4 extraction
Mechanical + Ransomware
Head swap or firmware repair required before imaging the ransomware-affected volume
No Data = No Charge. If we cannot recover usable data, you pay nothing.
CVE-2025-30247 Recovery FAQ
Will updating my WD My Cloud firmware to v5.31.108 decrypt my files?
No. Firmware v5.31.108 patches the OS command injection vulnerability so attackers cannot re-enter through the same vector. It does not reverse encryption applied by the ransomware payload. Encrypted files remain encrypted after the update. A factory reset also does not decrypt files. A Quick Restore or Full Restore erases your shares and files, which makes recovery harder.
Is it safe to factory reset my hacked WD My Cloud?
No. A factory reset erases the GPT partition table and mdadm RAID configuration without touching the encrypted data. You lose the filesystem metadata needed to locate surviving unencrypted fragments. Remove the drives from the enclosure, leave them powered off, and ship them to the lab.
Can you recover data if only some files were encrypted?
File-level ransomware reads the original file, writes an encrypted copy, then deletes the original. The deleted plaintext data may still exist in ext4 unallocated space if the disk has not been heavily written to since the attack. We image the drive through a write-blocker using PC-3000, then carve deleted inodes from the ext4 journal and unallocated sectors. The earlier you power off the NAS after discovering the infection, the more unencrypted data survives.
My EX2 Ultra was in RAID 1. Can I recover from just one drive?
RAID 1 mirrors data across both drives. If ransomware encrypted both members identically, both mirrors contain the same encrypted data. If the attacker only encrypted the mounted volume (the logical mdadm array) but not the raw blocks underneath, we may recover pre-encryption data from raw sectors on either member. We image both drives and compare their unallocated regions for surviving plaintext fragments.
WD My Cloud hacked or encrypted?
Power off the NAS. Remove the drives. Ship them to our Austin lab. Free evaluation. No data = no charge.
