WD My Cloud Home Data Recovery
The WD My Cloud Home is not a standard NAS. When the enclosure dies, pulling the drive and mounting it on a PC returns thousands of randomly named files with no folder structure. We recover the original file tree by extracting the SQLite index.db database and cross-referencing every content ID to its real filename. No data = no charge.
Original folders and names live in a separate SQLite database (index.db). Standard NAS recovery tools that read raw ext4 return unusable hex blobs without that database.
Why the My Cloud Home Is Not a Standard NAS
The standard WD My Cloud EX2 Ultra, PR2100, and PR4100 run embedded Linux with EXT4 filesystems and mdadm software RAID. Remove a drive from one of those units and you can mount it on any Linux system to see your original files and folders. The My Cloud Home is architecturally different.
How the WD My Cloud Home Stores Your Data
- When you upload a file, the system strips the original filename and stores the file under an opaque content ID. The file lives under
/restsdk/data/files/using this content ID as the filename, with no file extension. - A proprietary SQLite database located at
/restsdk/data/db/index.dbmaps each content ID back to the original filename, folder path, MIME type, and upload timestamp. - If the NAS enclosure fails but the drive is physically healthy, extracting the drive and mounting the EXT4 partition reveals only the obfuscated hex-named files. The original directory structure is invisible without the index.db database.
- Recovery requires extracting both the hex-named files and the index.db database, then parsing the SQLite tables to reconstruct the original file tree with real filenames and folders.
Enclosure Hardware and the Data Drive
The My Cloud Home enclosure board runs the Android kernel and manages the REST SDK layer. We do not try to log into it. Our NAS recovery work on these units starts at the drive, not at the enclosure.
When the enclosure board fails, the SATA data drive is unaffected. We disconnect the drive from the dead board, connect it directly to PC-3000, and image it at the sector level.
Do not run recovery software. Consumer tools like Disk Drill, Recuva, and EaseUS do not understand the My Cloud Home REST SDK architecture. They will scan the EXT4 partition and return thousands of content-ID-named files without any usable organization.
My Cloud Home vs. My Cloud EX2: Side-by-Side Comparison
The two product lines share the WD My Cloud brand but use completely different storage architectures. The table below summarizes the recovery-relevant differences.
| Attribute | My Cloud Home / Home Duo | My Cloud EX2 Ultra / PR2100 / PR4100 |
| Operating System | Embedded Linux (Debian-derived) | |
| File Storage | Hex content IDs in /restsdk/data/files/, no extensions | Standard filenames in user shares on ext4 |
| Filename Mapping | SQLite index.db at /restsdk/data/db/ | None required; filenames stored natively |
| RAID Implementation | Home Duo: Linux mdadm, Mirror (RAID 1) by default, user-selectable Max Capacity (JBOD) | mdadm RAID 0, 1, 5, 10 depending on model |
| Mount on Linux (Drive Pull) | Mounts ext4, shows hex blobs only | Mounts ext4, shows real files and folders |
| Recovery Workflow | Image drive, parse index.db, rebuild file tree | Image drive, assemble mdadm, copy ext4 directly |
| Affected by April 2022 OS 3 Cutoff | No (separate product line) | Yes (legacy EX2 only); data on drives is intact regardless |
The single-drive My Cloud Home (WDBVXC series, 2-8TB) holds one SATA drive on ext4 with no RAID. The My Cloud Home Duo (WDBMUT series, 4-20TB) holds two drives in Linux mdadm and ships in Mirror (RAID 1). A Duo switched to Max Capacity (JBOD) needs both drives. Both share the same content-ID architecture.
My Cloud Home vs. My Cloud Home Duo
My Cloud Home (Single Drive)
- Models: WDBVXC0020HWT, WDBVXC0040HWT, WDBVXC0060HWT, WDBVXC0080HWT. Capacities from 2TB to 8TB.
- Storage: Single SATA drive, no RAID. Data is stored on one EXT4 partition with the REST SDK file obfuscation layer.
- Recovery: Image the single drive through a write-blocker, extract the index.db, and reconstruct the file tree from the SQLite mapping tables.
My Cloud Home Duo (Two Drives)
- Models: WDBMUT0040JWT, WDBMUT0060JWT, WDBMUT0080JWT, WDBMUT0120JWT, WDBMUT0160JWT, WDBMUT0200JWT. Capacities from 4TB to 20TB (total, across two drives).
- Storage: Two SATA drives, Mirror (RAID 1) by default. A Duo the owner switched to Max Capacity (JBOD) requires both drives.
- Recovery: Image both drives through a write-blocker. Same SQLite reconstruction workflow as the single-drive model.
Duo Mirror Implementation: Linux mdadm RAID 1
In its default configuration the My Cloud Home Duo uses standard Linux software RAID (mdadm) to maintain a RAID 1 mirror, assembled as a standard md array. This is not a proprietary mirror format.
We connect one healthy drive to PC-3000, assemble the mdadm array offline, and access the ext4 data partition containing the REST SDK file tree. If both drives have degraded sectors, we image both & combine the best sectors from each mirror member before extracting the index.db database.
Confirming the Duo Mirror with mdadm --examine
Before assembling anything, we inspect a single member drive to confirm it really is a Duo RAID 1 mirror & not some other layout. Running mdadm --examine /dev/sdX on a member partition reads the Linux software RAID superblock and prints the array metadata stored on that disk. The v1.x superblock starts with the magic number 0xa92b4efc, and the metadata version field tells us where on the disk that superblock lives:
- Version 1.0: superblock at the end of the device.
- Version 1.1: superblock at the start of the device.
- Version 1.2: superblock 4 KiB after the start of the device. This is the typical embedded-Linux NAS layout, though we read the field rather than assume it.
Five fields in the --examine output confirm a two-disk Duo mirror: Raid Level reads raid1, Raid Devices reads 2, the Array UUID ties the two members together, and Device Role plus Array State show which slot the disk holds & whether it was in sync. Those fields are how we tell a Duo RAID 1 mirror apart from the EX2 Ultra mdadm layout, which can be RAID 0, RAID 1, or JBOD depending on how the owner set it up.
Offline Assembly Off a Dead Enclosure
Once the superblock is confirmed and both members are imaged, assembly off a dead enclosure is a stock Linux operation. We run mdadm --assemble --scan --verbose to bring the array up from the metadata on the images, or assemble the named array by listing its members explicitly, then mount the ext4 data partition read-only. Because RAID 1 is a direct mirror, each member already holds a complete copy of the filesystem.
This is the same mdadm superblock and array reconstruction workflow we use on any Linux software RAID set, applied here to a two-disk plaintext ext4 mirror.
Never run mdadm --create on a live Duo member drive. The --create mode writes a fresh superblock to the disk and immediately starts a resync, which overwrites the original array metadata and destroys the mirror copy. Forum threads that tell you to "recreate" the array to get it back are describing the one command that can turn a recoverable mirror into an unrecoverable one. We image both member drives at the block level with ddrescue or PC-3000 before any assembly or mount attempt, so the original metadata always survives on the source disk.
My Cloud Home failures fall into two buckets: a dead enclosure board, where the drive is intact and the recovery happens offline, and SMR translator failures on a WD Red WDx0EFAX drive, which require PC-3000 firmware-level repair before imaging.
WD My Cloud Home Failure Modes
Enclosure and Firmware Failures
- Solid white LED, no network access: The unit powered on but never came up on the network. Where the fault is in the enclosure rather than the drive, removing the drive and imaging it through a write-blocker recovers the data, provided the index.db is intact.
- Red LED on front panel: Do not factory reset, as this erases the index.db database and makes filename reconstruction impossible.
- WD Discovery app shows device offline: The My Cloud Home relies on WD cloud services for initial setup and remote access. If the cloud relay fails or WD discontinues the service, local network access may also break. Your files remain on the physical drive regardless of cloud service status.
What a Dead Enclosure Board Leaves on the Drive
An SoC or firmware failure in the enclosure does not touch the data partition. The ext4 volume containing /restsdk/data/ and the index.db SQLite database stays intact on the SATA drive.
We remove the drive, connect it to a write-blocker, and perform the same offline SQLite reconstruction as any other My Cloud Home recovery. This is a standard NAS extraction, not a drive repair.
Hardware Failures: SMR Drives and Translator Corruption
When a My Cloud Home holds a WD Red WDx0EFAX-series drive, that drive is drive-managed Shingled Magnetic Recording (SMR). SMR writes data in overlapping tracks to increase density, managed by an internal translator table that maps logical block addresses to physical track locations.
- Translator corruption: When an SMR drive experiences media degradation, the translator table that tracks where data resides on the overlapping tracks can become inconsistent. The drive mounts but returns incorrect data, or hangs during reads. PC-3000 firmware-level access is required to repair the translator before any data can be extracted.
- Media cache overflow: SMR drives buffer writes to a conventional recording zone (the media cache) before reorganizing them into shingled tracks. If the cache fills and the firmware cannot complete the reorganization, the drive becomes unresponsive. Power cycling repeatedly worsens the condition.
- Mechanical failure in aging units: SMART errors, clicking, and slow response mean the drive is degrading, and what is degrading comes from the bench. These drives need professional imaging with retry control on PC-3000 or DeepSpar before any SQLite extraction can begin.
Do not run chkdsk or fsck on a failing SMR drive. These tools place heavy read/write stress on the translator layer. On a degraded SMR drive, this accelerates logical corruption and can make recovery harder or impossible.
The internal drive carries several partitions; Windows can't read ext4 and prompts to format. Linux mounts the data partition, and the user files there are a flood of content-ID names with no extensions. That's expected REST SDK obfuscation, not corruption. Don't format, rename, or move anything; the index.db reconstruction needs every byte intact.
USB Dock Connection: Expected Hex Filenames and Format Prompts
The most common DIY mistake: pull the drive from the dead enclosure, plug it into a USB-to-SATA dock, and see either a Windows "Format Disk" prompt or a Linux file manager full of hex-named blobs. That's expected behavior, not corruption.
The internal drive carries several partitions: small system partitions plus the ext4 data partition. Windows can't read ext4 at all and prompts to format. Linux mounts the data partition, where the user files sit inside the /restsdk/data/files/ directory.
Every file there is a content ID with no extension. Formatting any partition destroys the SQLite index.db needed to restore real filenames.
If you've already connected the drive and see hex files, stop. Don't rename, move, or delete anything.
CVE-2025-30247 is bounded to the My Cloud OS 5 firmware line on the EX, PR, DL, and Mirror units, patched in firmware 5.31.108. The My Cloud Home is not on Western Digital's affected-device list. Check the model badge on your unit before you act on the advisory.
Is the My Cloud Home Affected by CVE-2025-30247?
No. The My Cloud Home does not appear on Western Digital's affected-device list for CVE-2025-30247. Advisory WDC-25006 names the My Cloud PR2100, PR4100, EX4100, EX2 Ultra, Mirror Gen 2, DL2100, EX2100, DL4100, WDBCTLxxxxxx-10, and the single-bay My Cloud, with 5.31.108 as the patched firmware. Neither the My Cloud Home nor the My Cloud Home Duo is among them.
The flaw is an OS command injection in the My Cloud OS 5 user interface, reachable by a remote attacker through a specially crafted HTTP POST. It carries a base score of 9.3 and was published on 2025-09-29. That management interface belongs to OS 5. The My Cloud Home has never run My Cloud OS 3 or OS 5; it runs its own REST SDK firmware, so the vulnerable OS 5 web interface is not present on it.
- My Cloud OS 5 line, listed in WDC-25006
- PR2100, PR4100, EX4100, EX2 Ultra, EX2100, DL2100, DL4100, Mirror Gen 2, WDBCTLxxxxxx-10, and the single-bay My Cloud. These units run the My Cloud OS 5 web management interface. Fixed in firmware 5.31.108.
- My Cloud Home line, absent from that list
- My Cloud Home and My Cloud Home Duo. These run REST SDK firmware, with user data on a plaintext ext4 partition wired by native SATA off the SoC. No OS 5 interface, and no entry in WDC-25006.
If the badge on your unit reads EX2 Ultra, EX2100, EX4100, PR2100, PR4100, DL2100, DL4100, or Mirror Gen 2, you are on the OS 5 line, and the advisory applies if the unit is still running firmware older than 5.31.108. That case has its own writeup: CVE-2025-30247 recovery. Enclosure and array failures on the same hardware are covered under WD My Cloud recovery.
The common NAS ransomware families encrypt file payloads one at a time on an ext4 volume. The partition structure survives, which is why neither a firmware update nor a factory reset decrypts anything. On a My Cloud Home the reset is worse than useless: it destroys the index.db mapping that turns content IDs back into real filenames, so even files the attacker never touched come back as unnamed blobs. Our ransomware recovery work follows the same imaging-first order as the rest of our NAS recovery casework: image the drive offline first, then read anything.
Recovery runs in two phases. First, image the SATA drive offline via write-blocker, repairing SMR translator damage in firmware or performing a head swap in the clean bench if the drive is mechanically failed. Second, extract index.db and run a parser that joins each hex content ID to its real filename and folder path.
How We Recover Data from a WD My Cloud Home
Recovery follows a two-phase approach: first image the drive and address any hardware or firmware issues, then reconstruct the original file tree from the SQLite database.
- Free evaluation: We identify your My Cloud Home model (single or Duo), confirm the Android REST SDK architecture, and assess the physical condition of the drive(s). No charge for this step.
- Drive imaging: The SATA drive is removed from the enclosure and connected to PC-3000 or DeepSpar through a hardware write-blocker. If the drive has SMR translator issues, we repair the translator in firmware before imaging. If the bench finds mechanical damage in the head stack, we perform a head swap in our 0.02µm ULPA-filtered clean bench.
- SMR translator stabilization (if needed): My Cloud Home units with WD Red WDx0EFAX drives use drive-managed SMR. The Second Level Translator (T2), stored in Service Area Module 190, maps logical block addresses to physical shingle bands. If Module 190 corrupts, the drive returns all zeros or hangs mid-read. We connect the drive via PC-3000 using the WDC Marvell utility, back up the corrupted Module 190, and enable the "Lock User Area writing" command. This prevents background garbage collection from reorganizing shingle bands during imaging, preserving the T2 state. We then image at the physical block level before any SMR translator repair.
- SQLite database extraction: From the disk image, we locate
/restsdk/data/db/index.dband extract the SQLite mapping tables. If index.db is damaged, we attempt SQLite repair before falling back to file carving. - File tree reconstruction: A parsing script cross-references each hex content ID in
/restsdk/data/files/against the index.db records. Original filenames, folder paths, and file extensions are restored. The complete directory tree is rebuilt on the target media. - Verification and delivery: We verify file integrity, copy recovered data to your target media, and ship it back. Working copies are purged on request.
For business-critical My Cloud Home cases, typical recovery turnaround is 5 to 10 business days from drive arrival for logical-only cases, and 10 to 15 business days when a head swap or SMR translator repair is required. We run every case through a write-blocker, log intake on a serialized evidence ledger, and purge working copies on request after delivery. NDAs are available before drive intake; sign and return prior to shipping. See hard drive recovery for the underlying imaging workflow that applies to the SATA drive inside.
Business Recovery: Turnaround, Chain of Custody, NDA
A My Cloud Home that holds business files (client deliverables, accounting archives, design assets, legal documents) needs more than a recovered file tree. It needs predictable turnaround, a documented handling process, and a confidentiality posture you can show a client or compliance reviewer.
The following describes how we handle these cases. It is operational practice, not a certification claim.
Typical Recovery Turnaround (RTO Context)
Turnaround depends on the failure mode and the drive condition. The ranges below are typical estimates from drive arrival to delivery of recovered data on your target media. They exclude inbound and outbound shipping.
- Logical only (healthy drive, dead enclosure): 5 to 10 business days. Image the drive, locate index.db, run the SQLite parser, and copy the reconstructed tree.
- SMR translator repair before imaging: 10 to 15 business days. Translator stabilization on PC-3000 adds time before extraction.
- Mechanical failure with head swap: 10 to 15 business days. Donor sourcing, clean-bench head swap, and slow read-with-retries imaging.
- Ransomware-encrypted partition: Variable. Plaintext residual extraction depends on how much of the ext4 volume the attacker overwrote.
RPO Context for NAS-Only Users
A My Cloud Home with no offsite backup has an effective Recovery Point Objective equal to the last write to the device. If the SoC failed and the drive is healthy, the RPO is zero; we recover the state as of the last successful write. If the drive itself has bad sectors or SMR translator corruption, the RPO depends on which sectors are readable.
We image at the physical block level so partial reads are preserved instead of being dropped by the host OS. This is the same NAS imaging workflow we use for Synology, QNAP, and multi-drive RAID cases.
Chain of Custody on Sensitive Data
For business cases we treat the inbound drive as evidence. The intake workflow:
- Drive logged on arrival with serial number, model, photographed condition, and case ID.
- All reads performed through a hardware write-blocker. The original drive receives no writes.
- Working copies stored on internal lab storage tied to the case ID. No cloud upload. No external network access during recovery.
- Recovered data delivered on your supplied target media or a fresh drive we provide.
- On request, working copies are purged and the original drive is returned or destroyed per your written instruction.
This is the operational handling we use. We do not claim a SOC 2, ISO 27001, or HIPAA certification. If your compliance program requires one, tell us before shipping so you can decide whether this workflow meets your internal review.
NDA Availability
A mutual NDA is available on request before drive intake. Send your preferred template or ask us to provide one. Signature happens before you ship; we do not start work on a business case without the NDA in place when one has been requested.
Single Austin, TX lab location, no outsourcing, no franchises. The technician handling your case is the same person every step.
My Cloud Home recovery prices match standard hard drive recovery tiers; logical-only cases (healthy drive, just SQLite reconstruction) start at Tier 2. The Duo is billed as a single-drive case when one mirror is sufficient for full extraction. Free evaluation, no diagnostic fees, no charge if no data is recovered.
WD My Cloud Home Recovery Pricing
My Cloud Home recovery is priced based on the condition of the internal drive. Logical recoveries (healthy drive, just need file tree reconstruction) start at Tier 2. Drives with firmware or mechanical issues follow our standard hard drive recovery pricing tiers. The My Cloud Home Duo is priced as a single-drive case when only one mirror needs imaging.
- Low complexity
- Low complexity
- Medium complexity
- High complexity
- High complexity
No Data = No Charge. If we cannot recover usable data from your WD My Cloud Home, you owe nothing. Free evaluation on every case.
REST SDK is WD's mobile-first storage layer for the My Cloud Home. It puts opaque content IDs in /restsdk/data/files/ and keeps a SQLite index.db at /restsdk/data/db/index.db that maps each ID to filename, MIME type, parent folder, and timestamp. Without that database, the files come back unnamed.
Technical Methodology: REST SDK Architecture
The My Cloud Home uses what WD internally calls the REST SDK architecture. This system was designed around mobile app access and cloud synchronization, not local file serving. Understanding this architecture is the difference between recovering organized data and recovering a pile of unnamed blobs.
Partition Layout
The internal drive contains multiple EXT4 partitions. The system partition holds the Android OS and firmware. The data partition contains the REST SDK directory tree:
/restsdk/data/files/stores every user file as a hex content ID with no extension/restsdk/data/db/index.dbis the SQLite database mapping content IDs to real filenames, MIME types, parent folder relationships, and timestamps
Why Standard Recovery Tools Fail
Standard data recovery software treats the My Cloud Home like any EXT4 volume. It finds the hex-named files and attempts to recover them as-is, returning thousands of files named a1b2c3d4e5f6... with no extensions, no folders, and no way to identify what each file contains without opening it individually.
The software has no awareness of the REST SDK layer or the index.db database. Even if the drive is physically healthy and every file is intact, the output is unusable without the SQLite cross-reference step.
Cloud Service Dependency and Discontinuation Risk
The My Cloud Home requires WD's cloud relay for initial setup and remote access. If WD discontinues this service (as they did for legacy My Cloud OS 3 devices), local network access can break even though your files are physically intact on the drive.
This isn't a drive failure; it's a vendor lock-in problem. We disconnect from the dead enclosure: remove the SATA drive, image it through a write-blocker, and extract data without needing any WD cloud service. See our full NAS data recovery page for how we handle vendor-locked NAS enclosures across all brands.
PCB and Board Considerations
Do not swap the PCB from another WD drive onto a My Cloud Home drive. Modern Western Digital drives store adaptive parameters and ROM data on the PCB.
A straight board swap without transferring the ROM chip or reading the adaptive data via PC-3000 will result in a drive that powers on but cannot access the platters correctly. The My Cloud Home enclosure board (the NAS controller) is separate from the drive PCB. A dead NAS controller does not mean the drive PCB needs replacement.
The most common questions: hex filenames are content IDs, not corruption. The Home Duo defaults to a Linux mdadm RAID 1 mirror, where one drive recovers the full set, and a Duo switched to Max Capacity (JBOD) needs both drives. Files on the ext4 partition aren't encrypted; the obfuscation is the REST SDK stripping names. WD's OS 3 cloud cutoff didn't affect the Home line. Don't run consumer recovery software.
WD My Cloud Home Recovery FAQ
Why are my WD My Cloud Home files renamed to random hex strings?
What is the difference between WD My Cloud Home and WD My Cloud EX2?
Can you recover data from a dead WD My Cloud Home Duo?
What happens if the index.db database is corrupted or missing?
Should I run recovery software on my My Cloud Home drive?
Does the WD My Cloud Home use SMR drives?
Why doesn't an Ubuntu Live CD or standard recovery software show my folder structure?
Which WD My Cloud Home capacities use SMR drives?
Are files on the WD My Cloud Home hardware encrypted?
Did WD's April 2022 OS 3 cloud shutdown affect My Cloud Home devices?
Related Recovery Services
EX2 Ultra, PR2100, PR4100, and single-bay My Cloud units running Linux with mdadm RAID.
All WD drives: Red, Blue, Black, Purple, Gold, Ultrastar.
Synology, QNAP, Buffalo, ASUSTOR, TerraMaster, Drobo, and all Linux-based NAS.
WD My Passport, My Book, Elements, and other USB enclosures.
Full HDD recovery service: head swaps, firmware repair, platter transplants.
WD SMR translator corruption diagnosis and PC-3000 firmware repair.
Recovery for orphaned Drobo units. BeyondRAID metadata parsed directly from member drives.
My Cloud Home showing hex filenames or not booting?
Free evaluation. No data = no charge. Ship your drive from anywhere in the U.S.
