If a dead NVMe drive holds data you need, stop applying power to it. Each retry pushes current through whatever is shorted on the board, so a single failed rail can spread to neighboring components. If the controller is partly alive, repeated power-ups also risk it completing queued TRIM or UNMAP (Deallocate) commands. Pull the drive & call (512) 212-9111 for a free evaluation.
Why Is My NVMe Not Detected in BIOS?
There is a line worth drawing first. A drive that shows in BIOS but not in Windows is a logical problem, a dropped partition or a file system the operating system won't mount, and consumer software can sometimes reach it. A drive absent from BIOS is physical: the controller never came up, so there is no block device for any tool to scan.
That distinction decides the whole job. Recovery software like R-Studio or DMDE works on a healthy drive the operating system can see. It has no path to a controller that never powered its PCIe link, which is why an electrically dead NVMe drive is a bench job, not a software job.
Why a Dead NVMe Can Stop Your PC From Booting
The difference is the data path. SATA drives reach the system through a host bus adapter that speaks AHCI, an electrical buffer between the drive & the rest of the board. NVMe removes that layer for speed, wiring the controller's PCIe lanes straight to the CPU.
That direct link is why a dead NVMe drive can take the whole boot down with it, & why the recovery access point is different. The fix is to reach the controller over a controlled PCIe link, not over a SATA channel.
| Electrical behavior | NVMe (PCIe) | SATA SSD |
| Host connection | Direct to the CPU over PCIe lanes, no intermediating bridge | Through a SATA host bus adapter that speaks AHCI |
| When the drive shorts | Can pull down the PCIe bus & hang host POST | Isolated behind the bridge; the PC still boots |
| Becoming visible to BIOS | Controller must train the PCIe link before BIOS enumerates it | Negotiation handled by the host adapter |
| Lab access point | Stabilize a controlled PCIe link with a PC-3000 Portable III | Reach the controller over the SATA channel |
How Much Does Dead NVMe Recovery Cost?
The tier follows the fault. Most electrically dead drives are a board repair: we revive the power tree or rebuild a broken differential pair, then image through the original controller, which is the tier that preserves the encryption key. When the link trains but the controller never finishes its NVMe handshake, the work moves to firmware-side system-area reconstruction with PC-3000 SSD.
NAND transplant is the last resort, used only when the original PCB is too damaged to repair. It requires a 50% deposit because donor parts are consumed in the attempt, and the donor cost is additional. A donor drive is a matching SSD used for its circuit board. Typical donor cost: $40–$100 for common models, $150–$300 for discontinued or rare controllers. No data recovered means no charge. +$100 rush fee to move to the front of the queue.
The full failure-class breakdown & the M.2 and U.2 form factors we work on live on the NVMe recovery overview. Published pricing, free diagnostics, & 4.9 stars across 1,837+ Google reviews back the work, all of it done in-house at a single Austin lab since 2008.
PMIC & Power-Tree Failures: 3.3V to Secondary Rails
The power tree is the first thing that dies in a surge or a hard power loss. The controller is a complex chip with several core domains, & none of them come up without their rail. A single shorted ceramic capacitor can drag a rail to ground, & from the outside the drive looks completely dead.
- PMIC (Power Management IC)
- The chip that converts the M.2 slot's 3.3V into the lower secondary rails the controller & NAND need. A shorted PMIC pulls excess current & runs hot, which is exactly what a thermal camera catches.
- Secondary rail short
- A failed ceramic capacitor on one of those rails drags it to ground. The controller domain it feeds never powers, so link training never starts.
- Dead-short signature
- A drive that draws zero or pulls a hard short on first power is a power-tree fault, not a NAND fault. The fix is on the board, not in the data.
The bench sequence localizes the fault before anything gets desoldered:
- Current-limited power-up. Apply 3.3V through a bench supply with a current limit so a dead short can't spread, & read the draw. A hard short shows immediately.
- Thermal localization. With injection current on the shorted rail, a FLIR thermal camera shows the failed part as a hot spot, the PMIC or a specific capacitor.
- Component replacement. Replace the shorted PMIC or capacitor with a Hakko FM-2032 on its FM-203 base, with an Atten 862 hot air station for the surrounding parts.
- Rail verification. Confirm each secondary rail reads its target voltage, then retry the link. A revived controller trains & enumerates with its keys intact.
None of this is platter work, so none of it needs a cleanroom. NVMe recovery is electronics on an ESD-safe bench: microsoldering, BGA rework with a Zhuo Mao station, & thermal fault-finding. Board repair on an encrypted NVMe drive is the recovery, because only the original controller can decrypt its own NAND.
PCIe Differential-Pair Damage From ESD & PCB Flex
The PCIe link rides on differential pairs: matched trace pairs that carry the high-speed TX & RX signals between the controller & the host. They are tuned to tight tolerances, & they are fragile. Bend an M.2 board over a misplaced standoff, or hit it with static during a careless install, & you can sever a pair.
When a pair opens, link training fails at the physical layer. The controller can be perfectly healthy, the power tree intact, & the drive still vanishes from BIOS because one signal path is broken. This is an electrical break, not a logic fault, so no firmware tool will see it.
The repair is microscope work: trace the broken pair, rebuild the open conductor, & restore the matched geometry as closely as the board allows. Then retry the link.
Reading exactly where the link stalls, in Detect, Polling, or a Recovery loop, is a separate diagnostic discipline. That state-machine analysis is covered in depth on our NVMe PCIe lane diagnostics page. This page stays on the hardware fault that causes those stalls.
How the PC-3000 Portable III Images a Degraded Controller
Once the board is repaired, the drive still has to be imaged without re-stressing a controller that just came back from the dead. A motherboard slot is the wrong tool for that: it forces the fastest link the drive advertises & gives a fixed power feed.
The PC-3000 Portable III takes the drive on a diagnostic port instead of a production slot, so every attempt happens under bench control & can be repeated after each board-level repair step.
Once the controller answers on that port, the lab reads its identity, confirms the NAND geometry, & images sector by sector through the original silicon. Because the original controller is doing the reading, it decrypts & descrambles its own NAND on the way out. Imaging coverage on NVMe spans the Silicon Motion, Phison, & Marvell controller families that PC-3000 SSD supports, with examples including the Silicon Motion SM2262EN. Coverage varies by exact controller, so we confirm it during the free evaluation.
The full LTSSM stall analysis, in Detect, Polling, or a Recovery loop, is detailed on the PCIe lane diagnostics page.
Why Does a Marginal NVMe Drive Train at Gen 3 but Fail at Gen 4 or Gen 5?
PCIe raises its per-lane data rate by roughly double each generation: Gen 3 runs at 8 GT/s, Gen 4 at 16 GT/s, & Gen 5 at 32 GT/s. Every doubling halves the unit interval, the sliver of time the receiver has to sample each bit, & that shrinks the eye, the margin the link has for trace loss, reflection, & connector wear.
So the same physical defect behaves differently by generation. A marginal M.2 trace, or an oxidized gold edge-connector contact, can keep enough margin to train & hold at Gen 3, then blow past the insertion-loss & reflection budget at Gen 4 or Gen 5. The link either fails to train outright, or the LTSSM trains & then down-trains & drops, so the drive presents as unstable or intermittent rather than cleanly dead.
This is where the lab access point diverges from a motherboard slot. The drive is enumerated on a dedicated PCIe diagnostic port on the PC-3000 Portable III rather than in a production slot, so each attempt happens under bench control & can be repeated after each board-level repair step.
If your drive drops in & out of BIOS or benchmarks far below its rating on one board but not another, treat it as a signal-integrity fault, not a healthy drive, & get it onto the bench before it stops enumerating for good. That bench imaging is the core of our NVMe recovery service.
Why Does a Damaged x4 NVMe Drive Show Up Intermittently or at Reduced Speed?
An M.2 x4 NVMe drive carries four PCIe lanes, & each lane is a TX pair & an RX pair, so eight high-speed differential pairs run between the controller & the host. Link-width negotiation in the LTSSM Configuration state supports operating at a narrower width than the maximum the drive advertises.
That fallback is why partial damage looks the way it does. When one or two lanes have a severed or shorted differential pair but lane 0 still trains, the controller can negotiate a degraded x1 or x2 link instead of the full x4. The drive then shows in BIOS intermittently, or at reduced width & lower reported speed, rather than being wholly absent.
The dependency is lane 0: if lane 0 is dead, the link never trains, & no amount of retrying brings the drive up.
A hairline break in a trace widens with thermal expansion as the board heats under load, so a drive that enumerated cold at reduced width can drop entirely once it warms. That reduced-width window is the recovery window: it is the interval in which the lab can force a controlled low-width link & image the drive. Repeated power cycling risks losing that window before imaging, which is another reason not to keep re-powering a failing NVMe drive.
Reading where training stalls, in Detect, Polling, Configuration, or a Recovery loop, is a separate discipline, detailed in our LTSSM link-training analysis. The wider set of connector, trace, & component faults that produce these symptoms is covered on the SSD physical-damage classes page.
Can a Dead NVMe Controller Be Replaced to Recover Data?
Controller failure & NAND failure are different problems. A dead controller, killed by a shorted rail or a fried core, is a board-repair job: bring the original silicon back so it can read its own NAND. NAND failure, where the cells themselves degrade past the error-correction threshold, is a different path entirely.
Not every consumer NVMe drive runs hardware AES. Many budget DRAM-less drives don't encrypt at all. Even on those, reading the raw NAND off-chip means undoing the controller's XOR data scrambling & its LDPC error correction, which is its own wall. Either way, the original controller is the key, & reviving it beats chip-off.
When the controller die really is destroyed & the part is old enough to be unencrypted, chip-off onto a donor PCB is the last resort. That deeper treatment is on the chip-off NAND recovery page, & the broader physical-damage failure classes are on the SSD physical damage page.
Why You Must Stop Powering a Dead NVMe Drive
TRIM is a logical deallocate, not an instant physical erase. The operating system tells the controller which blocks are no longer needed; the controller unmaps them from its translation table. On a drive failing on the host link, those queued operations can still run when power returns, which is how a recoverable drive becomes an unrecoverable one.
The electrical risk compounds it. A board with a shorted rail draws fault current every time it powers, & that current can carry a single failure into nearby components. The safe move is to stop, pull the drive, & let the first power applied at the bench be current-limited, with the link coaxed up by a PC-3000 Portable III rather than a motherboard chasing the fastest negotiation.
The Lab Sequence for an Electrically Dead NVMe Drive
The sequence runs electrical-first, cheapest test before anything irreversible. Every step happens on an ESD-safe bench with the drive off any production host.
- Power-tree triage. Apply 3.3V through a current-limited supply & read the draw. Zero draw or a hard short points at a dead PMIC or a shorted rail before any link attempt.
- Thermal fault localization. Inject current on the shorted rail & find the hot component with a FLIR thermal camera, the PMIC or a specific capacitor.
- Differential-pair inspection. Where the rails are healthy, inspect the PCIe TX & RX pairs under a microscope for a sever from PCB flex or ESD.
- Board repair. Replace the shorted PMIC or capacitor & rebuild any broken pair with a Hakko FM-2032, Atten 862 hot air, & Zhuo Mao BGA rework, then verify the rails.
- Controlled-link imaging. Connect a PC-3000 Portable III, step the link down to a stable state, read the controller identity, & image through the original silicon so it decrypts its own NAND.
- Firmware path if the handshake fails. If the link trains but the controller never asserts ready, reconstruct the system area with PC-3000 SSD before imaging.
Why is my M.2 NVMe not detected in BIOS after a power outage?
Does a shorted NVMe drive stop the whole PC from booting?
Can I recover data from an NVMe drive with a cracked or bent PCB?
Can a dead NVMe controller be replaced to recover the data?
How much does dead NVMe board-level recovery cost?
What is the PC-3000 Portable III and how does it differ from a motherboard slot?
Can chip-off read the NAND and skip a dead NVMe controller?
What does the free NVMe evaluation cover?
NVMe drive dead or missing from BIOS?
Free evaluation. We localize the shorted PMIC or severed lane with a FLIR camera, repair the board, then image through the original controller with a PC-3000 Portable III. Board-level recovery from $900–$1,200. No data, no fee.
