Accidentally Rebuilt RAID Recovery
An accidental RAID rebuild, re-initialization, or re-create rarely erases your data. An mdadm --create --assume-clean with the wrong drive order rewrites only the superblock, and a rebuild onto a replacement member writes only to that member, so the surviving members are read rather than overwritten. The exception is a full initialization, which zero-fills the volume. We recover these arrays by imaging every member offline and destriping virtually on Data Extractor Express RAID Edition. The original chassis is never written to. Free evaluation. No data recovered means no charge. This is one of the array states our RAID data recovery service handles.
Crisis
Is Data Loss After a RAID Rebuild Permanent?
Usually not. Stop any running fsck, chkdsk, mdadm --create, or Force Online now. The source members typically still hold the file extents. Image every drive before another action, then we destripe it virtually.
Data loss after a RAID rebuild is rarely the irreversible event forums declare it to be. A re-create rewrites the superblock, and a rebuild onto a replacement member writes only to that member, so the surviving source members are read rather than overwritten. The one operation that genuinely destroys data is a full initialization that ran to completion. Until each member is imaged read-only, no one can call the array unrecoverable, and every additional write against the live controller narrows what our RAID recovery lab can carve back.
15 min read
First Action
Can You Recover Data After Accidentally Rebuilding a RAID?
Yes, in most cases, unless a full initialization zero-filled the volume. A background init overwrites only parity; an mdadm re-create rewrites only the superblock. The file extents survive on the source members. Power down now and image every drive before anything else.
Stop all writes. Do not start another rebuild. Do not click Repair in the NAS UI. Do not run fsck, chkdsk, or mdadm --create again. Do not Force Online or Import Foreign Configuration. Power the chassis down to freeze the current state of the member drives and their metadata.
The instinct after an accidental rebuild is to assume total loss, or to try to undo it by issuing the same command again. Both are wrong. The destructiveness of the operation depends entirely on which command ran and which firmware executed it.
A background initialization and a full initialization look similar in a menu and produce completely different outcomes on the platters. Until the drives are imaged, every additional operation against the live array narrows what is recoverable.
On Disk
What Actually Happens on the Disks During a Mistaken Rebuild?
A RAID rebuild or re-initialization is not a universal secure erase. What it writes to the platters depends on the exact command. The most important distinction is between an operation that touches only parity or the target member and an operation that zeros the whole volume.
Background initialization (BGI)
Broadcom documents BGI as establishing mirroring or parity for a RAID virtual drive while allowing full host access, and supports it only on RAID 5 and RAID 6. Broadcom does not publish what BGI leaves untouched, so what a BGI on a misconfigured array left behind is established from the member images, not assumed.
Full initialization
A full init explicitly overwrites every block of the logical volume with zeros. This is the catastrophic case. It destroys the allocated extents themselves, not just the parity. If the operation ran to completion across the full LBA range, the volume is a field of zeros and there is nothing to carve. A full init that was interrupted partway leaves data beyond the zero-fill point intact.
mdadm rebuild or resync
When mdadm resyncs a degraded RAID 5 or RAID 6, it reads the data and parity from the surviving members, recomputes the missing stripes via XOR, and writes the result only to the target (replacement) member. The surviving source members are read, not written, so their allocated extents stay intact. The target member is fully overwritten with regenerated, possibly polluted, stripe data.
This rewrites the mdadm superblock and skips the parity resync. For v1.2 metadata, the default, the superblock is written at the 4 KiB offset from the start of the device. It does not zero the drives and does not recompute parity, so the user data is intact. If the drive order, RAID level, or chunk size in the create call is wrong, the new superblock imposes an incorrect geometric map and the filesystem will not mount, but the data is still there to be destriped.
Parity Pollution
How Does Parity Pollution Corrupt a Forced Rebuild?
Parity pollution is when a controller recomputes new parity from stale or desynchronized member data. The XOR math is correct, the inputs are not, so the controller writes parity that is mathematically valid and logically invalid across the affected stripes. It silently corrupts files that span those stripes.
Parity arrays use XOR logic for fault tolerance. With data blocks A and B, parity P is computed as P = A XOR B. If a member is lost, the controller rebuilds it as B = A XOR P. The math is exact.
The danger is in the inputs. When an accidental rebuild is forced using a stale drive, a member that dropped out of the array days or weeks earlier, the controller computes new parity from outdated blocks. The XOR operation succeeds and writes parity that is internally consistent but logically wrong for the current data.
The result is not a zeroed drive. It is a set of stripes whose parity no longer describes the data, so any file that spans the polluted stripes reads back corrupt while the rest of the volume looks fine.
This is why forcing a rebuild with a previously dropped member reintroduced is so destructive: the array reports optimal, the volume mounts, and the corruption is invisible until specific files are opened. The defense is to image the members in their current state before any further rebuild, so destriping later works against the pre-pollution extents on the source drives rather than against recomputed parity.
This is the line that separates this scenario from a rebuild that failed partway through. A failed rebuild aborts and leaves the source members untouched. A forced or completed rebuild succeeds mechanically and writes new parity or new target data, so the array is logically wrong even though it reports healthy. It is also distinct from a double-member physical failure, where the problem is dead hardware rather than a destructive operation.
URE Math
Why Did the RAID 5 Rebuild Become Dangerous in the First Place?
A degraded RAID 5 rebuild is a full-surface stress test with zero remaining fault tolerance, which is why starting one by accident is so costly. To reconstruct the missing member the controller must read every sector of every surviving member.
Consumer and nearline SATA drives spec a worst-case unrecoverable read error (URE) rate of one error per 10^14 bits, which works out to roughly one unreadable sector per 12.5 TB of sequential reads. Enterprise drives spec one per 10^15 bits, about 125 TB.
A four-member RAID 5 of 16 TB drives, after losing one member, forces the controller to read roughly 48 TB sequentially from the survivors. That is a real risk scaling with array size and drive age rather than a certainty. What happens when a URE does land is controller-specific: modern Dell PERC and LSI/Broadcom MegaRAID puncture the affected stripe and complete the rebuild, Linux mdadm records the block in its Bad Block Log and continues, and HP Smart Array P-series and E-series and low-end consumer hardware such as Intel RST abort the rebuild and drop the array.
That spec is a warranty floor rather than a schedule, and many drives read well past it clean, but the only safe assumption for an array you care about is the worst case. That is exactly why the correct response to any accidental rebuild is to image member-by-member before another rebuild is attempted, rather than trusting the controller to read 48 TB without an error.
Single-parity RAID 5 on large drives runs on razor-thin margins. The parity math is covered in depth on our RAID 5 recovery page. Dual parity (RAID 6, RAIDZ2) is the sane minimum above roughly 12 TB of usable capacity precisely because it survives a URE during a rebuild instead of collapsing on one.
Rebuild Aborted
What Do I Do When a RAID 5 Rebuild Failed Midway?
A degraded RAID 5 rebuild that aborted leaves the array offline, and the next move is to do nothing to it. Do not retry the rebuild and do not Force Online or Make Optimal. Power the chassis down and image every member before any reconstruction is attempted.
When a RAID 5 rebuild aborts partway through, the array is offline and you stop touching it, because the surviving members hold an intact copy of your data and every further operation against the live array risks losing that. This is a different state from the accidentally-completed rebuild covered above. Here the rebuild started, hit a problem on a surviving member, and the controller dropped the array before the resync finished.
The rebuild aborted because a degraded RAID 5 has zero remaining fault tolerance. Reconstructing the missing member forces a full-surface read of every sector of every surviving member so the controller can XOR the missing block back into existence.
If an unrecoverable read error surfaces on one of those surviving members during that read pass, the controller cannot recalculate the missing block for that stripe from parity. On an HP Smart Array P-series or E-series card, or on low-end consumer hardware such as Intel RST, that aborts the rebuild and takes the array from degraded to offline. On a modern PERC or MegaRAID the stripe is punctured and the rebuild finishes with that stripe lost.
The chance of hitting at least one URE climbs with the total bytes the survivors must read, which is why arrays of large members are where this shows up.
The state the drives are in after the abort is the reason recovery is usually possible. A software resync reads the surviving source members and writes only to the target (replacement) member, so the source members were read, not written, and their allocated extents are intact on the platters.
Only the replacement member was being written, and an aborted mdadm resync leaves that target partially written with regenerated, possibly polluted, stripe data. The intact survivors are what we destripe from; the half-written target is treated as untrusted.
On hardware controllers the event is in the controller log rather than hidden, so pull the log before anything else touches the array; it is the record of what the card actually did and in what order.
The array geometry itself, a SNIA DDF variant, lives in the trailing sectors of the member drives, not in controller NVRAM, so the chunk size, member order, and parity rotation travel with the disks. A dead or replaced controller does not block reconstruction, and the original card is not required to reassemble the array on a forensic workstation.
Retrying the rebuild is the wrong move. It puts the already-marginal surviving members under another full-surface read load and raises the probability of another abort or an outright media failure on a head assembly that is already stressed.
Force Online or Make Optimal is worse: it flushes parity recomputed from stale and inconsistent blocks across the stripes and converts a frozen, recoverable state into an overwritten one. The correct first step is to image member-by-member with a write-blocked imager, PC-3000 Portable III or ddrescue behind a hardware write-blocker, and then reconstruct the array virtually in software from those images.
A rebuild that died mid-pass and left the array offline is one of the array states our RAID recovery service handles as a routine image-first case. The probability math behind why these single-parity rebuilds abort is worked through on our parity and URE rebuild-failure reference.
Metadata
How Do Forensic Engineers Bypass the Controller Metadata?
The original controller card is not required to recover the array. The metadata that defines array geometry lives on the member drives, not in controller NVRAM, so chunk size, member order, RAID level, and parity rotation are portable to a forensic workstation. Where that metadata sits depends on the controller family.
LSI MegaRAID and Dell PERC
Dell PERC is rebranded LSI/Broadcom MegaRAID silicon. Both store array geometry in SNIA Disk Data Format (DDF) metadata in the trailing sectors at the absolute end of each member. Because DDF sits at the end of the disk, it survives a partial filesystem format and records the RAID level, stripe size, drive order, and parity rotation. The DDF on the surviving members is the authoritative geometry source, so a dead or absent controller does not block reconstruction.
HP and HPE Smart Array
HP and HPE Smart Array controllers do not use DDF. They write RAID Information Sectors (RIS) to raw reserved physical sectors at the start of each member, below any OS partitioning scheme, recording the logical drive boundaries, stripe size (HP defaults to 256 KB), parity rotation, and epoch data. A rebuild writes only to the target disk and does not overwrite the RIS on surviving members, so the RIS remains the source of truth and completely bypasses the need for the original controller card.
Adaptec and Areca
Adaptec (aacraid) and Areca controllers maintain their own vendor configuration structures on the member drives. The geometry still lives on the disks, so we capture the vendor metadata offline and reconstruct with the detected rotation, which often differs from Linux mdadm defaults.
Linux mdadm
The mdadm v1.2 superblock sits 4 KiB into each member and records the array UUID, level, chunk size, member role, and event count. An accidental --create --assume-clean overwrites that superblock with new values but leaves the data extents alone. Read-only inspection with mdadm --assemble --readonly against cloned images is the safe path; when the create call used wrong parameters, we ignore the superblock entirely and destripe by signature analysis.
When a re-create scrambled the geometry and the metadata can no longer be trusted, the fallback is signature analysis. We locate known file headers, filesystem metadata records, database pages, and media file markers across the raw member images and measure the spacing between them. That spacing reveals the original chunk size and drive order, which lets us rebuild the correct geometry virtually and read the allocated extents back as valid files, bypassing the polluted parity entirely.
Hex Analysis
How Do You Read the Hex to Tell Overwritten Parity From Surviving Data?
Run mdadm --examine read-only against clones first to see whether a superblock survived and to compare event counts, then distinguish blocks by content: plaintext data carries filesystem signatures, recomputed parity is high-entropy XOR output with none.
Before any destriping, the first diagnostic read is mdadm --examine /dev/sdX, run read-only and ideally against the cloned images rather than the original members. It prints the v1.2 superblock: the array UUID, RAID level, chunk size, layout such as left-symmetric, the device role, and the event count. It serves three purposes here.
  • Confirm whether an md superblock exists at all. If --examine finds no superblock, the array was either hardware RAID carrying DDF or HP RIS metadata instead, or the mdadm superblock was overwritten or zeroed. That answer alone redirects the whole reconstruction path.
  • Compare event counts across members. A member with a lower event count is the stale one, and reintroducing it into a forced rebuild is exactly what pollutes parity across the affected stripes. Reading the counts read-only identifies that member without writing anything.
  • Read the chunk size and layout the last create imposed. This is a starting hypothesis, not ground truth. After an mdadm --create --assume-clean run with wrong parameters, --examine reports the geometry that the create call imposed, not the array's original geometry. Treat its output as a hypothesis that signature analysis then confirms or overrides; do not trust it to hand back the original layout after a re-create.
The hex-level distinction between overwritten parity and surviving data comes down to content. A RAID 5 data column is stored in plaintext, so at the hex level an allocated data block shows recognizable structure: filesystem metadata (for ext4, the superblock magic 0xEF53 at offset 0x438, inode tables, directory entries) and file header signatures. A recomputed parity block is the XOR of every data block in its stripe row, so it is high-entropy pseudo-random content with no filesystem signature and no readable file structure.
Measuring entropy and scanning for signatures across the members therefore reveals which column at each stripe offset is parity and which is data. That in turn reveals the rotating parity pattern and the chunk size, the two parameters a scrambled re-create destroyed. This is the hex-level forensic mechanism behind the parity math, not a drag-and-drop scan against the live drives.
Data Extractor Express RAID Edition performs this sector-by-sector entropy and signature scan across the cloned members, maps the parity rotation and chunk boundaries from the measured content, then virtually assembles the array from the deduced geometry. The PC-3000 hardware images the drives; the array itself is reconstructed in software from those images, never against the live members.
Parity pollution still leaves the data recoverable because RAID 5 keeps the data columns in plaintext and parity in a separate rotating block. Parity recalculation overwrites only the parity blocks, never the file bytes on the data members. A virtual destripe reads the plaintext data columns directly and only falls back to the (possibly polluted) parity for a member that is genuinely absent. So an accidental rebuild that recomputed parity did not touch the file extents on the members still present, and partial-to-full reconstruction stays possible from those surviving columns.
Banned Commands
Commands That Pollute Parity or Scramble Geometry
After an accidental rebuild: the commands below are the ones most often recommended on forums to "undo" the mistake. Every one of them writes to the member drives and narrows what can be recovered. Power down first; run none of them.
  • mdadm --create --assume-clean --level=5 --raid-devices=N ... run a second time with a different guess
    What it does: writes another new v1.2 superblock with new parameters. Why it hurts: if the new guess triggers a resync rather than assume-clean, parity is recomputed and written across the array, polluting stripes that were still clean.
  • "Force Online" or "Make Optimal" in LSI or PERC BIOS
    What it does: overrides the controller decision that the array is offline. Why it hurts: it flushes pending cache writes to the members even though data and parity are inconsistent, and lets the filesystem mount and truncate against polluted stripes.
  • Full initialization on a virtual disk that holds your data
    What it does: zero-fills every block of the logical volume. Why it hurts: it overwrites the allocated extents themselves, not just parity. This is the one operation that genuinely destroys the data rather than scrambling the map.
  • megacli -CfgForeign -Import or -Clear
    What it does: imports or discards the DDF the controller found on the drives. Why it hurts: importing can trigger an automatic rebuild; clearing discards the geometry. Either narrows the recovery before an image exists.
  • Synology DSM "Repair" or QNAP Recovery Wizard "initialize"
    What it does: runs vendor scripts that call mdadm and lvm or rewrite the storage pool database. Why it hurts: the scripts can overwrite md superblocks and pool metadata on the member partitions. Read-only inspection on a separate Linux workstation is the safe alternative.
  • fsck or chkdsk on the mounted array
    What it does: writes filesystem repairs to the volume. Why it hurts: on a parity-polluted array the filesystem is reading corrupted stripes, so the repair writes wrong structures over salvageable data.
Process
Our Image-First Forensic Destriping Process
We image every member of the array through hardware write-blockers, then reconstruct the array geometry virtually in software against the image files. The original chassis is never written to and no live rebuild is ever run on your drives.
  1. Free evaluation and documentation. Record the controller model, RAID level, member count, filesystem (ext4, XFS, Btrfs, ZFS, NTFS, VMFS), and the exact rebuild, re-init, or re-create command that ran, including any drive order and chunk size used. This step is free and tells us whether parity was polluted or geometry was scrambled.
  2. Label every drive bay. Each drive is marked with its physical slot number before removal and bagged individually. Slot order is needed to validate the reconstructed stripe layout.
  3. Capture metadata from each member. Metadata location varies: LSI MegaRAID and Dell PERC store DDF in the trailing sectors; HP and HPE Smart Array write RIS at the start of the drive; mdadm uses a v1.2 superblock at the 4 KiB offset. Capture runs against cloned images, not the originals, so an accidental superblock overwrite is never compounded.
  4. Write-blocked forensic imaging. Each member is imaged through a hardware write-blocker. PC-3000 Portable III reads and clones every member sector by sector with adaptive retry; a member that turns out to have mechanical damage receives a donor head transplant on the ULPA-filtered clean bench before imaging.
  5. Virtual reconstruction in software. The array geometry is reconstructed virtually in software against the image files, never against the live members. Data Extractor Express RAID Edition and mdadm --assemble --readonly assemble the array from the captured metadata; when a re-create scrambled the parameters, we ignore the superblock and destripe by signature analysis to recover the original chunk size and order.
  6. Extent extraction and filesystem repair. The reconstructed volume is mounted read-only and the allocated extents are extracted. R-Studio and UFS Explorer handle filesystem-level damage if the polluted parity corrupted directory structures.
  7. Delivery and secure purge. Recovered data is copied to your target media. After you confirm receipt, working copies are securely purged on request.
If a rebuild is still running: power the chassis down. A rebuild forced onto a stale member writes more polluted parity with every minute it runs. The drives can sit unpowered indefinitely with no further loss while you arrange evaluation.
How Much Does Accidentally Rebuilt RAID Recovery Cost?
Pricing is the aggregate of per-member imaging plus a flat array reconstruction fee of $400-$800. Each member drive is imaged and priced individually at the HDD tier matching its condition, then the array is reassembled virtually in software.
Per-Member Imaging
  • Logical or firmware-level issues: From $250 to $600–$900 per drive. Covers members that image cleanly, members with filesystem corruption from the polluted parity, and firmware module damage that blocks normal reads.
  • Mechanical failures (head swap, motor seizure): $1,200–$1,500 per drive with a 50% deposit. Donor parts are consumed during the transplant. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available.
  • Helium members (10 TB and above): $3,000–$4,500 per drive at the head-swap tier. Helium cost: $400-$800 additional for head swap and surface damage tiers. This covers the helium refill required after opening the sealed chamber.
Array Reconstruction
  • $400-$800 depending on member count, filesystem type, and whether geometry must be detected from raw data by signature analysis versus captured from surviving DDF, RIS, or mdadm superblocks.
  • Reconstruction is the software stage: mdadm, LVM, XFS, EXT4, Btrfs, or ZFS virtual reconstruction from cloned members. R-Studio and UFS Explorer handle filesystem-level extraction afterward.
No Data = No Charge: if we recover nothing from your array, you owe $0. Free evaluation, no diagnostic fee, no obligation.
Example: a four-member array where the re-create scrambled geometry but every member images cleanly costs roughly 4 × From $250 (logical imaging) plus $400-$800 for reconstruction and destriping. A mechanically damaged member raises that member to $1,200–$1,500.
+$100 rush fee to move to the front of the queue. Full HDD pricing is published at our HDD recovery service page.
Accidentally Rebuilt RAID Recovery Questions
Is data loss after a RAID rebuild permanent?
Usually not. An mdadm --create --assume-clean rewrites the v1.2 superblock at the 4 KiB offset, and an mdadm rebuild onto a replacement member writes only to that member, so the surviving source members are read rather than overwritten. The operation that genuinely destroys data is a full initialization that completed its zero-fill across the whole logical volume; what any other operation left behind is established from the member images, not assumed. The correct response to data loss after a rebuild is to stop, power the chassis down, and image every member read-only through a write-blocker before any further command runs. No one can call the array permanently lost until the members are imaged and inspected.
Forums say an accidentally rebuilt array is automatically unrecoverable. Is that true?
No. The blanket claim that any rebuild started with the wrong parameters wipes the data is wrong, and it is the most common myth on IT forums and software vendor pages. Unless a full initialization completed its zero-fill, the data extents are generally recoverable by a lab that can manually destripe the array. The real hazards come from the advice that follows that myth: running chkdsk or fsck on a mounted array writes filesystem repairs over salvageable data when the underlying geometry is wrong, and selecting Force Online or mdadm --assemble --force when event counts differ forces the array to operate on stale blocks and corrupts spanning files. The recoverable state is the frozen, powered-down one. Image first, do not repair in place.
Can you recover data after accidentally rebuilding a RAID?
Yes, in most cases, provided the array was not subjected to a full initialization (zero-fill). An mdadm re-create with --assume-clean rewrites the array metadata rather than the data area, and an mdadm rebuild onto a replacement member writes only to that member, so the surviving source members are read rather than overwritten. Recovery requires powering the array down, imaging every member through a write-blocker, and destriping the array virtually from the on-disk metadata (DDF, HP RIS, or the mdadm superblock) rather than from the live controller. The cost rises sharply if a full init or repeated rebuild passes have run, so the most useful thing you can do is stop now and power down.
What is the difference between a background init and a full init?
Broadcom documents a background initialization (BGI) as establishing parity for a virtual drive while allowing full host access, and supports it only on RAID 5 and RAID 6. A full initialization is documented as overwriting all blocks and destroying all data on the virtual drive; it is the catastrophic case because it overwrites the allocated extents themselves. On Dell PERC and LSI MegaRAID the BIOS and OpenManage both expose these as separate operations. If you triggered the fast option that returned the array to optimal in seconds and a background task continued afterward, that was a BGI. If the operation wiped the volume to zeros over many hours, that was a full init. Broadcom does not publish what a BGI leaves untouched, so what survived one is established from the member images, not assumed.
I ran mdadm --create --assume-clean with the wrong drive order. Is my data gone?
Probably not. mdadm --create --assume-clean writes a new v1.2 superblock at the 4 KiB offset and skips the parity resync. It does not zero the members and does not recalculate parity, so the allocated extents stay on the platters. The wrong drive order, wrong chunk size, or wrong RAID level imposes an incorrect geometric map, so the filesystem will not mount and the volume looks scrambled. We image each member read-only, ignore the new superblock, and mathematically destripe the raw images by locating file signatures across the disks to deduce the original chunk size and rotation. Do not run it again with a different guess; every create pass risks a resync that pollutes parity.
What is parity pollution?
Parity pollution is what happens when a controller recomputes new parity from stale or desynchronized member data. The XOR math is correct, but the inputs are wrong, so the controller writes parity that is mathematically valid and logically invalid across the affected stripes. This silently corrupts files that span the polluted stripes without zeroing the whole drive. It is the central hazard of forcing a rebuild with a stale drive reintroduced. The defense is to image the members in their current state first, so any later destriping works against the pre-pollution extents on the source drives rather than the corrupted parity.
How is this different from a rebuild that failed partway through?
A rebuild that aborted leaves the array degraded and the source members untouched, which is covered on our rebuild failure page. An accidentally completed rebuild or re-create is the opposite problem: the operation succeeded mechanically and wrote new metadata or new parity, so the array is logically wrong even though it reports optimal. A double-member physical failure is a third case, covered on our two drives failed page. This page is specifically for the case where you started or forced a rebuild, re-init, or re-create that finished onto the wrong, stale, or replaced member.
My RAID 5 rebuild failed and the array is now offline. What now?
Stop and power the chassis down. What a URE on a surviving member does next depends on the controller: modern Dell PERC and LSI/Broadcom MegaRAID puncture that stripe and finish the rebuild, Linux mdadm logs the block to its Bad Block Log and continues, and HP Smart Array P-series and E-series and low-end consumer hardware such as Intel RST abort the rebuild and drop the array. The surviving source members were only read during the resync, not written, so their allocated extents are intact; only the replacement member was being written and is partially regenerated. Do not retry the rebuild and do not Force Online or Make Optimal, because both load the marginal survivors again or flush parity recomputed from inconsistent blocks. We image every member behind a write-blocker, then reconstruct the geometry virtually from the SNIA DDF metadata on the trailing sectors, which means the original controller is not required.
Does forcing the array online destroy my parity data?
It can. Force Online or Make Optimal in the LSI or PERC BIOS overrides the controller decision that the array is offline and flushes pending cache writes to the members even though data and parity are inconsistent. If the array then mounts, the filesystem reads silently corrupted stripes and can truncate directory trees as it tries to reconcile them. Forcing online does not recover the array; it converts a frozen, recoverable state into a written-over one. Power down instead and image first.
Do I need the original controller card to recover the array?
No. LSI MegaRAID and Dell PERC store array geometry in SNIA DDF metadata in the trailing sectors of each member; HP and HPE Smart Array store RAID Information Sectors (RIS) at the start of each drive. Linux mdadm writes a v1.2 superblock at the 4 KiB offset. All of that lives on the drives, not in controller NVRAM, so chunk size, member order, and parity rotation are portable. We reconstruct the array geometry virtually from the member images. The original card is convenient but not required.
How do you tell surviving file data from overwritten parity?
We carve. After imaging every member, we ignore the new or polluted superblock and run signature analysis across the raw images, locating known file headers such as filesystem metadata records, database pages, and media file markers. The spacing of those signatures across the members reveals the original chunk size and drive order, which lets us rebuild the correct geometry virtually. Allocated extents read back as valid files; regions that were genuinely overwritten by parity recomputation or a target-member rewrite read back as the new content. This is hex-level forensic work, not a drag-and-drop scan against the live drives.
Why is a RAID 5 rebuild so risky in the first place?
A degraded RAID 5 rebuild has zero remaining fault tolerance and must read every sector of every surviving member. Consumer and nearline drives spec a worst-case unrecoverable read error rate of one URE per 10^14 bits, about one unreadable sector per 12.5 TB of sequential reads. A four-member array of 16 TB drives forces roughly 48 TB of reads on the survivors. That spec is a worst-case warranty floor rather than a schedule, and real drives often read far past it clean, but the risk scales with array size and drive age, and what a URE does when it lands depends on the controller: PERC and MegaRAID puncture the stripe and continue, mdadm logs it and continues, HP Smart Array P-series and E-series and Intel RST abort. That is why you image member-by-member before any rebuild instead of trusting the controller to read 48 TB clean. +$100 rush fee to move to the front of the queue.
What does mdadm --examine tell you after an accidental rebuild?
Run mdadm --examine /dev/sdX read-only, ideally against cloned images rather than the originals. It prints the v1.2 superblock: array UUID, RAID level, chunk size, layout such as left-symmetric, device role, and event count. It answers three things: whether an md superblock is present at all (absent means hardware-RAID DDF or HP RIS metadata, or an overwritten superblock), which member is stale by comparing event counts so you know which drive would pollute parity if a rebuild were forced, and what chunk size and layout the last create imposed. That last point carries a caveat: after an mdadm --create --assume-clean run with wrong parameters, --examine reports the geometry the create call imposed, not the original array geometry, so we treat it as a hypothesis that signature and entropy analysis then confirm or override. It does not hand back the original layout after a re-create.
What should I avoid doing right now?
Do not start another rebuild. Do not click Repair in the NAS UI. Do not run mdadm --create again with a different guess, do not run fsck or chkdsk, and do not Force Online or Import Foreign Configuration. Each of those writes to the members and can convert a recoverable state into parity pollution or a zero-filled volume. Power the chassis down, label every drive with its slot number, and arrange evaluation. The drives can sit unpowered indefinitely with no further loss.
How much does accidentally rebuilt RAID recovery cost?
Pricing is the aggregate of per-member imaging plus a flat array reconstruction fee of $400-$800. Each member drive is imaged and priced individually at the HDD tier matching its condition, then the array is reassembled virtually in software. Healthy members that only need imaging price at the lower tiers; mechanically damaged members price at the head-swap tier. +$100 rush fee to move to the front of the queue. No data recovered means no charge, and there is no diagnostic fee.
You rebuilt the wrong array. Power down before doing anything else.
