SK Hynix SSD Data Recovery
SK Hynix is the world's second-largest NAND manufacturer. The Platinum P41 uses 176-layer NAND with an in-house Gen4 controller. We recover SK Hynix consumer models through board-level electrical repair at our Austin lab.
SSD from $200 | No Data, No Fee | Free Evaluation | Since 2008
SK Hynix SSDs We Recover
NVMe Gen3
Gold P31 (128L TLC, power-efficient laptop SSD)
NVMe Gen4
Platinum P41 (176L TLC, high-performance Gen4)
SATA III
Gold S31 (72L TLC, older consumer SATA)
NVMe Gen3 (OEM)
BC711 (128L TLC, OEM laptop drive in Dell/Lenovo)
Board-level PMIC and voltage regulator repair for proprietary controllers
Updated September 2026
12 min read
SK Hynix SSD Recovery
How SK Hynix SSD Recovery Works
SK Hynix designs and fabricates its own NAND flash memory and builds its own controllers. Consumer recovery software and generic SSD tools cannot communicate with these controllers when they enter a fault state. Because these proprietary controllers are not supported by standard firmware repair utilities, recovery relies on board-level microsoldering to replace failed electrical components and revive the original controller.
Gold P31
SK Hynix Gold P31 In-House Controller Recovery
The Gold P31 was the first consumer NVMe SSD built on 128-layer TLC NAND. SK Hynix paired it with an in-house controller, an ARM-based design with onboard LPDDR4 DRAM and a 4-channel PCIe Gen3 x4 interface.
The P31's power efficiency came from tight integration between the in-house controller and SK Hynix's own NAND.
The P31's in-house controller uses an SLC write cache that absorbs incoming writes at high speed, then background-folds the data into TLC cells. Heavy sustained random write workloads (database journaling, virtual machine disk I/O, swap partitions) keep the SLC cache perpetually full.
The P31 shipped in capacities from 500GB to 2TB. OEM variants in Dell, HP, and Lenovo laptops may carry SK Hynix part numbers rather than the Gold P31 retail branding, but the internal hardware is the same in-house controller.
Platinum P41
SK Hynix Platinum P41: Gen4 Performance
The Platinum P41 is SK Hynix's flagship PCIe Gen4 consumer NVMe SSD. It uses the in-house Aries controller paired with 176-layer TLC NAND and a PCIe Gen4 x4 interface. Sequential read speeds reach 7,000 MB/s. SK Hynix includes onboard LPDDR4 DRAM for FTL caching and AES-256 hardware encryption.
When NAND blocks fail, the controller marks them as bad and remaps their data to spare blocks. If the spare pool is exhausted, the drive enters read-only mode or drops offline.
The P41 shipped in 500GB, 1TB, and 2TB capacities.
SSD Pricing
SK Hynix SSD Recovery Pricing
SSD Recovery Calculator
Estimate Your SK Hynix SSD Recovery Cost
Select your symptoms and drive type for a preliminary cost range.
What type of SSD do you have?
Shomari Hohn
Aravind Udayakumar
David Dachenhaus (DDock)
Ludwig Jonsson
LaCie
SK Hynix Controller Architecture
SK Hynix Controller Architecture and Recovery Methods
Gold P31 Controller
Gold P31 | NVMe Gen3 x4 | LPDDR4 DRAM
ARM-based 4-channel controller designed in-house. Paired with 128-layer TLC NAND and onboard LPDDR4 DRAM for FTL caching. It stores its FTL mapping tables in both DRAM (volatile) and NAND (persistent backup). Unexpected power loss during a NAND write can desynchronize the DRAM and NAND copies of the FTL, leaving the controller unable to locate user data blocks. Because standard firmware repair tools do not support this controller, recovery relies on board-level repair to restore power to the original controller.
Platinum P41 Aries Controller
Platinum P41 | NVMe Gen4 x4 | LPDDR4 DRAM
The P41's Aries controller is quad-core, with an 8-channel NAND interface & PCIe Gen4 x4. Paired with 176-layer TLC NAND and LPDDR4 DRAM. It handles higher throughput than the Gold P31 controller (7,000 MB/s vs 3,500 MB/s). Unexpected power loss or voltage rail instability during high-throughput operations can desynchronize the FTL. Recovery focuses on M.2 PCB electrical repair. FLIR thermal imaging locates shorted components, which are then replaced under microscope to restore the controller without risking the hardware-bound AES-256 encryption key.
Gold S31 SATA Controller
Gold S31 | SATA III | LPDDR3 DRAM
In-house SATA controller used in the Gold S31 (250GB, 500GB, 1TB). The Gold S31 pairs it with 72-layer TLC NAND and LPDDR3 DRAM. It is absent from ACE Lab's PC-3000 SSD supported list. Because standard utilities cannot communicate with it in a fault state, recovery focuses on circuit-level repair to restore native SATA communication.
BC711 OEM Variant
OEM NVMe Gen3 x4 | In-house controller | M.2 2230/2242/2280
The BC711 is SK Hynix's OEM NVMe drive, shipped in Dell Inspiron, Lenovo ThinkBook, & other thin laptops. It uses an SK Hynix in-house controller paired with 128-layer 4D TLC NAND. Board repair runs $900–$1,200 for PMIC failures on M.2 2230 & 2242 form factors.
SK Hynix vs Solidigm Distinction
SK Hynix vs. Solidigm: Two Different Product Lines
SK Hynix completed the first phase of its acquisition of Intel's NAND flash and SSD business in December 2021. The acquired division now operates as Solidigm, a wholly-owned SK Hynix subsidiary. Solidigm sells SSDs based on former Intel IP (like the 670p and P41 Plus) using Silicon Motion controllers, alongside newer flagship drives (like the P44 Pro) that run SK Hynix in-house controller silicon.
SK Hynix designed and built the Gold P31, Platinum P41, and Gold S31 itself. They use proprietary controllers that SK Hynix designed in-house.
The practical implication for recovery: an Intel 670p and an SK Hynix Gold P31 are both "SK Hynix products" at the corporate level, but they use different controllers, different firmware, different NAND configurations, and require entirely different recovery methodologies. Sending an SK Hynix SSD to a lab that only has firmware tools for Silicon Motion controllers will produce no result.
SK Hynix-branded
Gold P31, Platinum P41, Gold S31
Proprietary in-house controllers
SK Hynix NAND (128L, 176L, 72L TLC)
Intel/Solidigm
660p, 670p, P41 Plus
Diagnostic Symptom-to-Failure Table
What Does Your SK Hynix SSD Symptom Mean?
Not every symptom means data loss; some are configuration issues that don't require lab work at all.
SymptomLikely CauseDiagnosis MethodRecovery Tier
Drive not detected in BIOSFirmware corruption or a failed PMIC on the M.2 PCBFLIR thermal imaging to locate shorted componentBoard repair: $900–$1,200
P41 write speeds dropped to 1-2 GB/sSLC cache folding firmware bugCheck for a firmware update in SK Hynix Drive Manager; the update for this behavior resolves itUser fix (no lab work needed if drive is detected)
Not seen during Windows installMissing Intel RST / VMD drivers, or BIOS set to RAID mode instead of AHCICheck BIOS storage mode settingConfiguration fix (not a hardware failure)
Drive enters read-only modeNAND cell degradation past LDPC ECC correction threshold; spare block pool exhaustedBoard repair ($900–$1,200) if the controller is not electrically accessible
Two of these symptoms (P41 write speed drop & missing during Windows install) don't require professional recovery. We'll tell you that during the free evaluation rather than charge you for work you don't need. +$100 rush fee to move to the front of the queue.
Common Failure Modes
Common SK Hynix SSD Failure Patterns
Controller firmware lockout after power loss
A power loss during a NAND write operation corrupts the flash translation layer. The controller detects the inconsistency during boot and refuses to present the drive to the host system. The drive may appear briefly in BIOS during POST but disappears before the OS loads, or it may not enumerate at all.
NAND page read retry exhaustion
As NAND cells age, the voltage threshold windows narrow. The controller applies read retry sequences with adjusted voltage levels to extract data from marginal cells. When retries exceed the controller's programmed limit, the affected pages are marked as uncorrectable. If enough pages in a block become uncorrectable, the controller may panic and lock the drive.
PMIC and voltage regulator failure
Replacing a failed PMIC or voltage regulator is board repair, which runs $900–$1,200.
Chip-off and Encryption
Encryption and Why Chip-Off Does Not Work
The Platinum P41 has hardware AES-256 encryption built into the controller. The encryption key is generated on the controller and wrapped by a key tied to the controller's hardware-unique root, so it never leaves the original controller.
Without the key from the original controller, the data cannot be decrypted.
Board-level repair is the primary recovery path. Replacing a failed PMIC, voltage regulator, or passive component on the original M.2 PCB restores power to the original controller, which still holds the encryption key. Once the controller boots, the drive can be logically imaged using standard NVMe or SATA protocols. The NAND contents are decrypted transparently by the controller during read operations.
PC-3000 SSD Diagnostic Limitations for SK Hynix
How Does PC-3000 SSD Work with SK Hynix Controllers?
PC-3000 SSD cannot perform firmware-level repair on SK Hynix's proprietary controllers. PC-3000 SSD relies on vendor-specific utilities that push a controller into Technological Mode by injecting microcode loaders into the controller's RAM. No such loaders exist for SK Hynix's in-house ARM-based designs. PC-3000 SSD's role in SK Hynix recovery is post-repair imaging, not firmware manipulation.
PC-3000 SSD ships with firmware utilities for Silicon Motion (SM2259, SM2263, SM2269) & Phison (PS5012, PS5016, PS5018) controllers. Samsung's modern NVMe controllers are absent from that list too. SK Hynix's in-house controllers are absent from ACE Lab's PC-3000 SSD supported list, and Rossmann does not currently offer in-lab recovery for the SK Hynix in-house controllers at the firmware level.
Because firmware tools can't access the controller, the diagnostic workflow for a dead SK Hynix SSD is electrical rather than software-based. The M.2 PCB carries three critical voltage domains: the ARM core supply for the controller, the LPDDR4 SDRAM supply, & the NAND flash array voltage. Here's how it works in our lab:
  1. FLIR thermal scan of the M.2 PCB.
  2. Component replacement via Hakko FM-2032. The failed PMIC or voltage regulator is replaced under microscope using a Hakko FM-2032 microsoldering iron on an FM-203 base station. The original controller & NAND remain untouched on the PCB; only the power delivery component is swapped.
  3. Post-repair imaging via PC-3000 SSD. Once the controller boots, PC-3000 SSD images the drive through the native NVMe protocol. PC-3000 SSD handles the imaging stage: high-reliability sector-by-sector reads with configurable retry parameters for marginal NAND blocks.
Board repair for SK Hynix SSDs runs $900–$1,200. We replace the broken power delivery with board-level microsoldering. Once the original controller boots, the data comes off through standard NVMe commands.
OEM Variants
OEM Variants in Dell, HP, and Lenovo Laptops
SK Hynix supplies OEM versions of the Gold P31 and Platinum P41 to major laptop manufacturers. These drives carry SK Hynix part numbers (e.g., HFM512GD3JX013N for a 512GB OEM P31 variant) rather than the consumer retail branding. The internal hardware is the same SK Hynix controller and NAND.
Consumer vs OEM SK Hynix Comparison
Which SK Hynix SSD Is in Your System?
SK Hynix sells consumer retail SSDs under the Gold & Platinum brands, and ships OEM variants under model-number-only designations to laptop manufacturers.
ModelInterfaceControllerNANDCapacities
Gold P31NVMe Gen3 x4In-house controller128L TLC500GB, 1TB, 2TB
Platinum P41NVMe Gen4 x4Aries, in-house176L TLC500GB, 1TB, 2TB
BC711 (OEM)NVMe Gen3 x4In-house controller128L 4D TLC128GB, 256GB, 512GB, 1TB
Gold S31SATA IIIIn-house SATA controller72L TLC250GB, 500GB, 1TB
You can update the firmware on a retail Gold P31 or Platinum P41 with SK Hynix Drive Manager. OEM BC711 drives carry part numbers like HFM256GD3GX013N (256GB) or HFM512GD3HX015N (512GB). The SK Hynix Beetle X31 portable SSD also uses an SK Hynix in-house controller internally.
SK Hynix SSD Data Recovery FAQ
Can you recover data from an SK Hynix Gold P31 that is not detected?
Yes. The Gold P31 uses an SK Hynix in-house controller with 128-layer TLC NAND. Non-detection typically indicates firmware corruption or a failed PMIC on the M.2 PCB. Standard firmware repair tools don't support that controller. So we do board-level repair, replacing the PMIC or voltage regulator to get power back to the original controller. Board repair runs $900–$1,200.
Is the SK Hynix Platinum P41 recoverable after firmware failure?
The Platinum P41 uses the in-house Aries controller with 176-layer TLC NAND and PCIe Gen4 interface. Standard firmware repair tools do not support this proprietary controller. AES-256 hardware encryption means the original controller must be operational for data access. Board-level repair to fix failed voltage regulators preserves the encryption key. Chip-off is not viable on the P41.
How is SK Hynix SSD recovery different from Intel/Solidigm?
SK Hynix SSDs use proprietary in-house controllers that require board-level electrical repair rather than firmware utilities.
Is chip-off recovery possible on SK Hynix SSDs?
The Platinum P41 uses a proprietary controller with hardware AES-256 encryption. The encryption key is generated by and bound to the original controller silicon. Desoldering the NAND yields only ciphertext. Board-level repair to revive the original controller is the only path when the controller cannot be accessed through standard firmware recovery.
How much does SK Hynix SSD recovery cost?
SK Hynix SSD recovery is priced $200–$2,500. Simple data copies are $200. File system recovery is from $250. Circuit board repair (PMIC, voltage regulator replacement) runs $900–$1,200. Advanced NAND swap onto a donor PCB is $1,200–$2,500. Free evaluation with no diagnostic fees.
Do you recover the older SK Hynix Gold S31 SATA SSD?
Yes. The Gold S31 uses an SK Hynix in-house SATA controller with 72-layer TLC NAND over a SATA III interface. That controller is not used by any other brand, so consumer recovery software cannot communicate with it when it enters a fault state. Recovery focuses on board-level electrical repair to restore native SATA communication.
Can you recover data from an SK Hynix BC711 OEM drive?
Yes. The BC711 is SK Hynix's OEM NVMe drive found in Dell Inspiron, Lenovo ThinkBook, and similar laptops. It uses an SK Hynix in-house controller with 128-layer 4D TLC NAND. BC711 drives ship in M.2 2230, 2242, and 2280 form factors. Part numbers start with HFM (e.g., HFM512GD3HX015N). Recovery pricing starts at $200 for simple copies.
My Platinum P41 write speeds dropped after several months. Is my data at risk?
The P41 has a documented write speed degradation issue where sequential writes drop from roughly 6,500 MB/s to 1,000-2,000 MB/s over time. SK Hynix released a firmware update to address SLC cache folding behavior. If the underlying cause is an electrical fault on the M.2 PCB, board-level repair ($900–$1,200) can restore controller functionality.
How do I identify which SK Hynix SSD model is in my laptop?
Check the M.2 drive label for the part number. Retail drives show the product name (Gold P31, Platinum P41). OEM drives show a model number: HFM-prefix means NVMe (e.g., HFM512GD3HX015N is a 512GB BC711), HFS-prefix can be SATA or NVMe. The capacity code follows the prefix: 256 = 256GB, 512 = 512GB, 001T = 1TB, 002T = 2TB. On Windows, Device Manager lists the drive model under Disk Drives. On macOS, System Information shows the drive under NVMExpress or SATA.
Can PC-3000 SSD repair SK Hynix controller firmware?
No. PC-3000 SSD uses vendor-specific utilities to push drives into Technological Mode, which requires firmware loaders matched to the controller. SK Hynix's in-house controllers are proprietary ARM-based designs with no third-party firmware loader support. PC-3000 SSD's role in SK Hynix recovery is limited to post-repair imaging: once the controller is electrically revived through board-level repair, PC-3000 SSD images the drive over the native NVMe protocol. The firmware manipulation that PC-3000 performs on Phison or Silicon Motion controllers is not possible on SK Hynix silicon.
Why does my SK Hynix SSD show 0GB or RAW in BIOS?
A 0GB or RAW capacity reading means the controller booted but cannot read the flash translation layer (FTL) mapping table. The FTL maps logical addresses to physical NAND locations; without it, the controller doesn't know where data is stored. This typically follows a power loss during a NAND write that corrupted the FTL metadata. If the controller itself is dead (no BIOS detection at all), a failed PMIC or voltage regulator is the likely cause, and board-level repair ($900–$1,200) is needed first.
Send Us Your SK Hynix SSD
Free evaluation. No data, no fee. Ship your SK Hynix SSD to our Austin lab.
