SSD Not Detected in BIOS: Data Recovery
An SSD that won't show up in BIOS or UEFI hasn't lost your data. The controller can no longer present the drive to your computer. We recover SSDs that fail to enumerate at the hardware layer at our Austin, TX lab, using PC-3000 SSD direct-NAND read and board-level microsoldering. Before you do anything else, stop power-cycling the drive. Free evaluation, no diagnostic fee, no charge if there's no data.
An SSD missing from BIOS or UEFI signals a controller firmware panic, a degraded NAND service area, or an electrical failure on the board, not a file system problem. Software can't read a drive that never enumerates at the SATA or NVMe protocol layer, so recovery needs hardware-level tools. We use PC-3000 SSD to inject a volatile loader into the controller and read the NAND directly, and board-level microsoldering to revive a dead controller. Stop power-cycling the drive first.
Updated July 2026
11 min read
The first 60 seconds: stop write activity
The most damaging thing you can do to a failing SSD is keep applying power to it. The dead state is safe. Re-detection is the hazard. If the controller comes back to the host even for a moment, the operating system can issue TRIM and the controller can resume garbage collection, and either one finalizes the mapping data a recovery depends on.
Most people respond to a missing drive by rebooting again and again, hoping it shows up. On a healthy drive that's harmless. On a drive that is intermittently failing, every reboot is a chance for the controller to re-enumerate, and that brief window is exactly when TRIM commands and background garbage collection can run.
The result is the same whether it happens once or ten times: the logical-to-physical mappings that point at your files get unmapped or rewritten, and what was recoverable an hour ago no longer is.
The right move takes four steps. Power down the machine fully. Disconnect the SSD so it draws no power. Do not run recovery software against it, do not plug it into a USB enclosure to "check if it still works," and do not let Windows or macOS mount it. Then send it in for evaluation.
A drive that sat untouched after the first failure is the best version of itself a lab will ever see.
Why "just plug it in to test it" backfires: a USB-to-SATA or USB-to-NVMe bridge presents the drive to the operating system as a normal disk. If the controller answers for even a second, the OS sees a mountable volume and can issue TRIM against blocks it thinks are free. Those are often the exact blocks holding deleted or recently moved files.
Dead controller or corrupted file system? Two different problems
A drive that's missing from BIOS is a hardware-layer failure. A drive that appears in BIOS but won't mount in your operating system is a logical failure. These present differently and take completely different recovery paths. Knowing which one you have decides whether software can help at all.
The deciding question is where the drive disappears. BIOS and UEFI enumerate storage before any operating system loads. If the drive is absent there, the controller never answered the host, and no software running inside an OS can reach it. If the drive is present in BIOS but absent in Windows Disk Management or macOS Disk Utility, the hardware works and the problem is logical.
PresentationDead-controller SSDCorrupted file system
Visible in BIOS / UEFINo, or shows a 0GB / factory string, or hangs POSTYes, correct model name and full capacity
Visible to recovery softwareNo, there is no addressable block deviceYes, software can scan it for files
Failure layerController firmware or board electronicsPartition table or file system metadata
Recovery pathPC-3000 SSD loader injection or board repairFile system rebuild on a healthy drive
Pricing tier$600–$1,200 firmware / $450–$600 boardFrom $250 file system recovery
The flagship SSD data recovery overview breaks down every failure family we handle in-house. This page focuses on the hardware-layer column: the drive that won't enumerate.
What does my SSD look like in Windows Device Manager when it fails?
The layer where the drive disappears tells you what failed. If it's gone from BIOS it never enumerated. If it reaches Windows but shows 0 bytes or won't respond, the controller answered the host but its translator or NAND did not. Three OS-surface presentations, three failure families.
A drive that vanished from BIOS never handed a block device to the operating system, so Windows has nothing to show. But not every failing SSD dies that far down the stack. Some make it into Device Manager, and a few even into Disk Management, before something in the controller's logic gives out. Where the drive stops on its way to a mountable volume tells you how deep the fault is and which recovery path it routes to.
What you see in WindowsWhat actually failedWhat NOT to doRecovery path
Absent from Device Manager and Disk Management entirelyThe controller never enumerated: a dead PMIC or voltage rail, or the drive never completed the host handshake. Same class as a BIOS-absent drive.Do not keep power-cycling it hoping it reappearsBoard-level microsoldering ($450–$600 SATA / $900–$1,200 NVMe) if it draws no power, or PC-3000 SSD diagnostic-mode access ($600–$1,200 SATA / $900–$1,200 NVMe firmware) if it powers up but won't answer; the intake test routes by whether it draws power
Listed in Device Manager as a disk, but Disk Management shows 0 bytes, "Not Initialized," a prompt to initialize, or RAWThe controller powered up and answered Identify, but the Flash Translation Layer is torn, so it reports zero usable capacityDo not click "Initialize Disk"PC-3000 SSD diagnostic-mode access and FTL rebuild in RAM on the drive itself ($600–$1,200 SATA / $900–$1,200 NVMe firmware)
Detected in Device Manager but unresponsive: reads hang, Explorer freezes, Disk Management takes minutes or says "device is not ready"The controller is answering the bus but hanging on I/O, typically worn service-area or NAND cells whose raw bit error rate exceeds the ECC/LDPC limit, or a controller locking up under loadDo not run a full read or a benchmark against itRaw-NAND read with read-retry voltage shifts and maximum-strength ECC decoding; degraded cells may image imperfectly
One safety rule is specific to this OS layer. When Windows pops "You must initialize a disk before Logical Disk Manager can access it," do not click Initialize. Initializing writes a fresh partition table to the drive; for MBR that write lands at the first sector, LBA 0, and for GPT it's written at both the start and the end of the disk. That write overwrites the existing MBR or GPT partition metadata, the index a logical recovery uses to reconstruct partition and file-system boundaries. It does not reach the firmware, and it does not erase the NAND or the FTL; formatting, a separate later step, is what writes over your file data. What initialization destroys is the partition index, and on a drive that only detects intermittently it's one more host write you don't want. If a drive is showing up as uninitialized or 0 bytes, pull it and read how we reach a controller that reports zero capacity before you let Windows touch it.
Is my SSD controller dead or is the NAND worn out?
An SSD that vanishes from BIOS has one of three hardware causes: a temporary firmware hang that clears after a power cycle, a permanent controller death that stays invisible and fails link training, or a NAND-layer failure where the worn service area can no longer pass error correction. Each one behaves differently at intake and routes to a different recovery path.
The hard part for a searcher is that two of these can look identical from the front of the machine. A drive that comes back after a reboot and a drive that is one bad read away from never coming back both "sometimes show up." What separates them is the controller. A firmware hang means the on-NAND boot code is logically torn but the cells are fine; a NAND-layer failure means the cells holding that boot code are worn past the controller's LDPC correction limit. Telling them apart is a lab job, which is why the full SSD recovery workflow starts by reading the bus, not by guessing from the symptom.
SignalTemporary firmware hangPermanent controller deathNAND-layer / service-area failure
What you observeDrops off the bus or freezes POST, then returnsStays completely invisible, slot reads emptyIntermittent, capacity drops to 0GB, factory string, init loop
What a power cycle doesOften re-detects for a window, then fails againNothing, the controller never powers up to answerRe-detects unreliably; each failed read degrades marginal service-area cells further
Bus behavior at lab intakeEnumerates, then an uncorrectable read or torn FTL metadata hangs the controllerNo link training; dead PMIC, shorted caps, fried controllerDraws normal power, hangs or times out reading its own microcode
Recovery pathPC-3000 SSD loader injection, FTL rebuild in RAMBoard-level microsoldering to revive the original controllerRead the service area below the dead init with read-retry voltage shifts; degraded cells image imperfectly and may not be recoverable
Pricing tier$600–$1,200 firmware (SATA)$450–$600 board (SATA)$600–$1,200 firmware service-area work
Intermittent detection is usually the last warning a drive gives before its error correction fails for good. Every time the controller re-reads a marginal service-area cell, the raw bit error rate creeps closer to the LDPC ceiling, and the boot that worked today may not work tomorrow. That is exactly why power-cycling an intermittently-detecting SSD is the worst move: you are spending the drive's remaining good reads on reboots instead of on a one-shot lab image. The deeper mechanics of cells aging past their correction threshold live on our firmware panics and ROM mode page.
Why does re-detection, not the dead state, destroy SSD data?
TRIM is a host command issued at the ATA or NVMe layer that tells the controller which logical blocks the file system no longer needs. The controller unmaps those blocks from its translation table. On an intermittently failing drive, the dangerous moment is when it re-detects, because that is when the OS can issue TRIM against the very blocks holding your files.
TRIM is a logical deallocate, not an instant physical wipe. When the operating system decides a block is free (after a delete, a format, or a move), it sends a TRIM command. The controller marks that logical block as unmapped in its Flash Translation Layer.
The unmap is what ends recoverability. Once the controller stops pointing a logical block at its data, no lab can ask it to point back.
This is why the power-cycling habit is so destructive. A drive sitting unpowered cannot run TRIM or garbage collection. A drive that re-enumerates can.
Every reboot that briefly brings the controller back to the host is an opportunity for the OS to flush queued TRIM commands and for the controller to resume the housekeeping it paused when it failed. The drive does not have to stay alive long. A few seconds of re-detection is enough to finalize unmaps that were pending.
On modern Windows (7 and later), TRIM is on by default; on macOS it is on by default for Apple-supplied SSDs since 10.6.8, while third-party SSDs require enabling it with trimforce. This is the normal behavior, not an edge case. Recovery of deleted or moved files from an SSD is only possible when TRIM never executed against those blocks: the drive was pulled immediately, TRIM was disabled, or the file system doesn't support it. For a drive that won't enumerate at all, keeping it powered off protects whatever unmaps were still pending when it died.
How does PC-3000 SSD read a drive the BIOS can't see?
PC-3000 SSD does not run through the operating system storage driver. It acts as a surrogate controller, connecting to the drive over a native SATA or NVMe port with vendor-command access, coordinating diagnostic-mode entry, injecting a volatile microcode loader into the controller, and reading the raw NAND. The Flash Translation Layer is then reconstructed in RAM on the drive itself, and the source NAND is imaged strictly read-only. The workflow runs in five stages.
  1. 01
    Native vendor-command access, never a USB bridge
    The drive connects to a PC-3000 SSD port directly over SATA or, for NVMe, over a native M.2 PCIe adapter. A USB-to-SATA or USB-to-NVMe bridge strips the vendor-specific command opcodes the active utility needs, so a drive that looks completely dead through an enclosure can still respond on a direct connection. The utility issues an identity probe to classify the failure before any intervention.
  2. 02
    Test-pad short to enter Technological Mode
    To stop the controller from loading its corrupted on-NAND firmware, a technician locates the ROM_CS test pad on the PCB under a microscope and shorts it to ground at power-on. The controller then stays in its read-only bootloader rather than crashing on the bad firmware.
  3. 03
    Volatile loader microcode injection
    PC-3000 SSD selects a microcode loader matched to the controller silicon revision and the exact NAND geometry, then injects it into the controller's volatile memory through vendor commands. The loader runs only from volatile memory and never writes to the NAND. A mismatched loader produces an ECC storm because its descrambler and error-correction tables don't match the physical NAND, so the geometry has to be read off the dies first.
  4. 04
    FTL / translator reconstruction in RAM on the drive itself
    With the loader live and the controller's garbage collection and TRIM muted, the utility scans the spare-area metadata of every physical NAND page (logical page number, block sequence number, program counter, validity bitmap) and rebuilds the logical-to-physical translator in RAM on the drive itself. This software step is what reconstructs the map. The imaging hardware reads NAND; it does not rebuild anything on the drive.
  5. 05
    Read-only sector-by-sector imaging
    The rebuilt translator drives a sector-by-sector image to a separate destination drive. The source NAND stays strictly read-only throughout. If a destination fills or a pass aborts, the source is exactly where it started and a second pass can run against the same translator. Nothing in this workflow modifies the failed SSD.
PC-3000 SSD coverage spans the Phison (including the PS3111-S11), Silicon Motion (SM2258, SM2259, SM2259XT), and Marvell (88SS1074 and related) controller families. For the deeper ROM-mode and firmware-panic mechanics, see our firmware panics and ROM mode page.
Why a dead NVMe SSD often needs board repair before it can be read
An NVMe SSD that draws no power, or that the motherboard never lists at all, frequently has an electrical fault rather than a firmware one. NVMe drives rely on PCIe Gen3, Gen4, or Gen5 lanes, and the controller cannot complete PCIe link training until its power rails are clean. A dead PMIC or voltage regulator stops the controller before it ever gets to enumerate.
An NVMe controller has to negotiate the PCIe link with the host before it presents itself as a storage device. That negotiation, link training, needs the controller fully powered. The board steps the incoming rail down to the controller's core voltages through a power-management IC and discrete regulators.
If one of those is shorted, often from an over-voltage event or a failed coupling capacitor, the controller never powers up and link training never starts. To the motherboard, the slot is empty.
The fix is board-level microsoldering, not software. We locate the fault with FLIR thermal imaging: a shorted PMIC or regulator shows up as a hot spot within seconds of applying bench power. The failed component is replaced with a Hakko FM-2032 on an FX-951 base station, and where a controller or other BGA package needs reflow, a Zhuo Mao precision BGA rework station handles the thermal profile. Once the rails are clean, the controller completes link training, enumerates, and PC-3000 SSD can interface with it.
Reviving the original controller matters for one more reason. On modern always-on AES NVMe drives, the decryption key lives inside the original controller. Board repair that brings that controller back is not a side service; for an encrypted drive it is the recovery. NVMe board-level repair is $900–$1,200. NVMe firmware recovery, when the board is healthy but the controller refuses to mount its translator, is $900–$1,200.
Why does my motherboard say no NVMe device found?
No NVMe device found and NVMe not detected are PCIe enumeration failures: the drive never asserted its presence on the PCIe bus, so UEFI has nothing to list.
That can mean a misconfigured motherboard on a healthy drive, or a genuinely dead drive that lost the ability to power up its controller. The way to tell them apart is to rule out the board's M.2 configuration first, then treat a drive that stays invisible across known-good slots and adapters as a hardware failure.
Start at the motherboard. A new build or a freshly moved drive is far more often a configuration problem than a dead drive, and five at-home checks rule out the common causes before you assume the worst.
  1. M.2 slot mode. Some M.2 slots are PCIe-only and will not show a SATA M.2 drive; others are SATA-only and will not show an NVMe drive. Confirm in the manual that the slot matches the drive's interface.
  2. Shared-lane behavior. Populating one M.2 port can disable a shared SATA port or a second M.2 slot, because they share the same PCIe lanes. A drive that vanished right after you added another drive is usually a lane-sharing conflict.
  3. Hidden in EZ Mode. Older BIOS frameworks list NVMe M.2 drives only in the Advanced or NVMe Configuration menus, not on the EZ Mode storage summary. Switch to Advanced Mode before you conclude the drive is gone.
  4. Overclock in the picture. If the drive stopped appearing after a CPU or memory overclock, clear CMOS back to stock and retest before going further.
  5. Adapter in the path. USB-to-M.2 enclosures can block proper NVMe recognition because the bridge chip hides the native NVMe endpoint. Test the drive in a native M.2 slot before you judge it dead.
When the drive stays invisible in a known-good native slot and the configuration is ruled out, the failure is in the drive. NVMe drives fail to enumerate in three hardware ways, and all three differ from the SATA BSY hang.
The first is a PCIe link training failure. The controller's PHY negotiates the link through the Link Training and Status State Machine before it can present itself to the host. A damaged PHY fails that negotiation outright, so the drive never enumerates, or it drops to a degraded Gen1 link that a torn FTL then hangs during init.
The second is PMIC or power-rail death. The power-management IC and discrete regulators step the incoming rail down to the controller's core voltages. If one is shorted, the controller receives no power and cannot assert presence on the PCIe bus. There is nothing for link training to negotiate with.
The third is a controller firmware panic, the NVMe form of ROM-recovery mode. The controller powers up, fails to load or validate its firmware from the NAND, and drops into a read-only recovery state where it refuses to initialize its NVMe namespaces.
This is where NVMe diverges from SATA. A SATA SSD that hangs completes the ATA handshake first, then holds the bus busy on a bad command; the drive is electrically present but frozen. An NVMe controller that lost power never reaches the handshake. It cannot assert presence on the PCIe bus, so the motherboard reports an empty slot rather than a hung one.
The protocol detail underneath this is worth knowing. At reset an NVMe controller brings up only its admin submission and completion queues, then uses admin commands to expose its namespaces, the logical volumes that hold your data. A panicked controller never gets past admin-queue initialization, so it never presents a namespace and UEFI sees nothing.
DRAM-less NVMe drives add one more failure path: they borrow a slice of system RAM through the Host Memory Buffer to hold the FTL, and a corrupt FTL can hang the drive during that init handshake.
The lab path splits on which of these it is. A firmware panic or namespace-init failure on a Phison, Silicon Motion, or Marvell NVMe controller takes the same PC-3000 SSD workflow described above: enter the controller's diagnostic mode through a test-pad short, inject a volatile loader into its volatile memory, rebuild the FTL in RAM on the drive itself, and image the NAND read-only.
A PMIC or power-rail fault has to be fixed first, because there is no live controller to talk to until the rails are clean. We localize the short with FLIR thermal imaging, replace the failed component with a Hakko FM-2032, and reflow a BGA package on a Zhuo Mao station when one is needed. Only then can the firmware-level work begin.
NVMe firmware recovery, when the board is healthy but the controller won't present a namespace, is priced in the $900–$1,200 tier; board-level repair on a dead PMIC or voltage rail is the $900–$1,200 tier. The full set of failure families we handle, and where each one routes, is laid out on the flagship SSD data recovery overview, and the ROM-mode mechanics behind a namespace-init failure are detailed on our firmware panics and ROM mode page.
Which PCIe link-training stall is hiding your NVMe drive?
Almost every "NVMe not detected in BIOS" case maps to one of three regions of the PCIe Link Training and Status State Machine: a Detect or Polling stall where no electrical link forms, a Recovery.Equalization stall at Gen3/Gen4/Gen5 where the link forms then collapses under a speed step-up, or an L0-reached firmware panic where the link is healthy but the controller never answers NVMe Identify Controller. Each region routes to a different lab intervention, and the PCIe Configuration Space registers say which one it is in the first seconds of a bench session.
The LTSSM negotiates bit-lock, symbol-lock, lane numbering, and link width by exchanging training ordered sets at 2.5 GT/s before any NVMe command is sent. A drive that never reaches L0 has a physical-layer or PHY fault, so board repair comes first. A drive that reaches L0 and then drops back to Recovery in a loop has a signal-integrity or thermal fault: the classic cracked-BGA signature is a link that works cold, opens a microfracture under thermal expansion, drops, then reforms once the controller cools. A drive that sits at L0 but never presents a namespace has a controller or FTL fault, which is firmware-side work, not board work.
The negotiated state is observable, not guessed. The Link Status Register at PCIe Configuration Space offset 12h reports the width and speed the link actually came up at; the Link Capabilities Register at offset 0Ch reports the maximum the hardware supports. A mismatch, for example a maximum of x4 running at a negotiated x1, is direct evidence of physical-layer damage on at least one differential lane rather than a firmware problem. A drive in that state is imaged from a PC-3000 Portable III diagnostic port, off any production host, rather than from a host BIOS that gives up after its standard timeout.
SymptomPHY / LTSSM-side causeController / firmware-side causeFirst PC-3000 diagnostic
Absent from BIOS, no enumerationLTSSM stuck in Detect; dead PMIC or destroyed PHYNot the cause: firmware cannot stop Detect from completingDiode-mode short check on the 3.3V rail and a FLIR scan before any power-up
Enumerates intermittently, drops under loadCracked BGA solder that opens when the controller gets hotRare: firmware thermal throttling drops the link, but gracefullyRead Link Status offset 12h on the bench while heating the controller
Enumerates at x1 Gen1 instead of x4 Gen4Severed differential pair, bent M.2 pin, or oxidized contactNot the cause: firmware does not set negotiated widthCompare Link Capabilities offset 0Ch against Link Status offset 12h
Generic alias (SM2263XT) at 0GBNot the cause: the LTSSM already reached L0Controller in ROM mode after a firmware panic; FTL or service area corruptedConfirm L0 in Config Space, then short the ROM_CS pad and inject a RAM loader
POST hangs 30+ seconds, then the drive is marked absentThe link forms then collapses under a speed step-upL0 reached but NVMe Identify Controller (Opcode 06h) times outRetry on a bench diagnostic port; if Identify still times out, the fault is firmware-side
The diagnostic order is what keeps the quote honest. If a drive never reaches L0, no firmware work helps because there is no logical channel to send commands. If it reaches L0 cleanly and stays there, board repair is wasted effort because the hardware is fine. Reading Configuration Space and the Identify Controller response first sets the recovery tier before any paid work begins.
Recovery software limits vs PC-3000 hardware at the protocol layer
Consumer recovery software is good at logical problems on a healthy drive and useless on a drive that never enumerates. The difference is the layer each operates at. Software talks to the file system through the OS storage driver. PC-3000 SSD talks to the controller directly with vendor commands.
CapabilityRecovery software (Disk Drill, EaseUS, R-Studio, PhotoRec)PC-3000 SSD
Operating layerAbove the OS storage driverBelow the OS, direct controller vendor commands
Needs a valid block deviceYes, requires a real capacity to scanNo, works on a 0GB / ROM-mode drive
Drive missing from BIOSCannot see it at allEnters diagnostic mode and reads raw NAND
Reads raw NAND pagesNoYes, through an injected loader
Best use caseDeleted files (no TRIM), lost partition, formatFirmware panic, ROM mode, ATA BSY, dead controller
Software isn't a worse version of PC-3000 SSD. It solves a different problem. If your drive still appears in BIOS at full capacity and you deleted files before TRIM ran, software is the right and cheaper tool. If your drive is gone from BIOS, no consumer tool can reach it, and that is the entire reason hardware labs exist.
Failure modes mapped to the right intervention
A drive that won't enumerate falls into one of four states, and each maps to a specific intervention. The triage at intake is reading what the bus does when power is applied, then choosing loader injection, board repair, or declining a case that can't be recovered.
ROM mode: factory string at 0GB / 1GB / 2MB
The controller failed to validate its on-NAND firmware and fell back to its bootloader. Intervention: PC-3000 SSD loader injection into the controller's volatile memory, then FTL reconstruction. A Phison PS3111-S11 reports SATAFIRM S11 here. Priced in the $600–$1,200 SATA firmware tier.
ATA BSY hang
The controller completed the handshake, then hit an unhandled exception parsing corrupted system blocks and is holding the busy bit high. A Silicon Motion SM2259XT is a common offender. Intervention: a test-pad short at power-on so the controller never loads the bad firmware, then loader injection.
No power, no enumeration: dead PMIC or voltage rail
The board never brings the controller up, so nothing answers the host. Intervention: board-level microsoldering. FLIR thermal imaging locates the short, and the failed PMIC, regulator, or capacitor is replaced. Priced in the $450–$600 SATA or $900–$1,200 NVMe board-repair tier.
Encrypted controller, dead board: chip-off limits
On a modern always-on AES NVMe controller, the AES-256 Media Encryption Key is bound to the original controller silicon, so desoldering the NAND yields ciphertext. Chip-off can't recover it. The only viable path is board-level microsoldering to revive the original controller so it decrypts its own NAND. We do not claim to defeat manufacturer encryption.
Worn service-area NAND: init loop on a controller that still works
At power-on the controller has to read its own operating firmware and bad-block metadata from a reserved service area that lives on the NAND, not on the controller itself. When those service-area cells have taken enough program/erase cycles that raw bit errors climb past the LDPC correction limit, the controller can't load its microcode, so it halts the bus or drops into a read-only safe mode (a 0GB capacity, or a Phison PS3111-S11 reporting SATAFIRM S11). The controller is fine. The cells holding its boot code are not, which is the controller-versus-NAND distinction that decides the path. Intervention: PC-3000 SSD reads the service area below the dead init and rebuilds the translator, applying read-retry voltage shifts to pull marginal cells back under the error-correction limit. A NAND transplant onto a donor board only bypasses a dead controller or PCB; it cannot reverse cell wear, so if the service-area cells are physically too degraded to read, the deeper mechanics of cells aging past their correction threshold are covered on our NAND-layer recovery path. This service-area work is priced in the $600–$1,200 SATA or $900–$1,200 NVMe firmware tier.
Controller support caveat. ACELab's PC-3000 SSD supports the Phison, Silicon Motion, and Marvell families named above. It does not cover Realtek controllers, Innogrit controllers, Maxio MAP1602 / MAP1602A, SandForce controllers, or modern Samsung in-house NVMe controllers such as Elpis and Polaris.
Rossmann does not currently offer in-lab recovery for Realtek, Innogrit, Maxio MAP1602 / MAP1602A, or SandForce. Modern Samsung in-house NVMe controllers such as Elpis and Polaris are outside that list too, and those drives are taken case by case. A free evaluation confirms which controller is inside a given drive before any paid work begins.
When desoldering the NAND is on the table at all, the limits are covered in detail on our chip-off NAND recovery page.
How much does this cost?
Pricing tracks the failure family. Firmware panic and ROM-mode recovery is $600–$1,200 for SATA and $900–$1,200 for NVMe. Board-level repair on a dead controller is $450–$600 for SATA and $900–$1,200 for NVMe. Free evaluation, firm quote before any paid work, no diagnostic fees, no charge if there's no data.
Where the board is too damaged to repair, a NAND transplant to a donor PCB is the last resort, priced at $1,200–$1,500 for SATA and $1,200–$2,500 for NVMe. 50% deposit required; donor drive cost additional. A donor drive is a matching SSD used for its circuit board. Typical donor cost: $40–$100 for common models, $150–$300 for discontinued or rare controllers. Rush service is +$100 rush fee to move to the front of the queue.
We publish these numbers so you know the range before you ship anything. Call (512) 212-9111 or use our free evaluation form.
Frequently asked questions
Why does my SSD not appear in BIOS anymore?
An SSD vanishes from BIOS or UEFI for one of three hardware reasons, not a software one. The controller firmware panicked and the chip dropped into ROM mode (often with a factory string and a 0GB capacity), the controller hit an unhandled exception and is holding the bus busy so the BIOS hangs, or a voltage rail on the board is dead so the controller never powers up to answer the host. In every case the data is still on the NAND. What failed is the controller's ability to present itself to the host. Software can't see a drive that never enumerates at the protocol layer.
Can I recover data from an SSD that won't show up in BIOS at all?
Yes, when the drive is a board-repair or firmware-recovery candidate. A drive that draws power but never answers the host usually has a dead PMIC or voltage regulator (board-level microsoldering territory) or a corrupted Flash Translation Layer the controller refuses to mount (PC-3000 SSD loader-injection territory). Both paths revive the original controller, or interface with it below its dead firmware, so the NAND can be read. Recovery is not possible if TRIM already ran on the deleted blocks, if the NAND itself is worn past the ECC correction threshold across the service area, or if the controller binds an always-on AES key that can't be revived.
Should I keep power-cycling an SSD that disappeared from BIOS?
No. Repeated power cycling is the single most damaging thing you can do to an already-failing SSD. The danger is not the dead state. The danger is the moment the drive momentarily re-detects. If the controller comes back to the host even briefly, the operating system can issue TRIM and the controller can resume garbage collection, both of which finalize the logical-to-physical mappings the recovery depends on. Pull the drive, stop applying power, and send it in.
Why does my SSD show up as 0GB or with a strange factory name?
A 0GB, 1GB, or 2MB capacity paired with a generic name is ROM mode. The controller failed to validate its on-NAND firmware during boot, fell back to its read-only bootloader, and reported a diagnostic identity instead of the real model. A Phison PS3111-S11 reports "SATAFIRM S11." A Silicon Motion controller reports a raw silicon alias such as SM2258AB or holds the bus busy with no string at all. The full-capacity model name is gone because the firmware that knew it is the thing that failed.
Can Disk Drill, EaseUS, or R-Studio recover an SSD missing from BIOS?
No. Recovery software runs above the operating system storage driver and needs the controller to present a valid block device with a real capacity. A drive that never enumerates in BIOS exposes no addressable logical blocks, so there is nothing for the software to scan. Those tools work well for logical failures on a physically healthy drive (deleted files where TRIM never ran, a corrupted partition table, a formatted volume). They cannot interface with a controller that won't answer the host at the protocol layer.
PC-3000 SSD does not go through the operating system storage driver. It connects to the drive over a native SATA or NVMe port with vendor-command access, coordinates entry into the controller's diagnostic mode (a test-pad short on the ROM_CS line during power-on), and injects a volatile microcode loader matched to the silicon revision and NAND geometry into the controller's volatile memory. That loader bypasses the dead on-NAND firmware and gives the workstation raw NAND read access. The Flash Translation Layer is then reconstructed in RAM on the drive itself and the data is imaged read-only, sector by sector, to a destination drive.
My SSD made the BIOS freeze at POST. What does that mean?
A drive that hangs the host and then lets it boot normally once unplugged is answering the bus badly rather than not at all, so the board still has power and a live controller. One state that produces it is ATA BSY: the controller completed the SATA handshake, then hit an unhandled exception parsing corrupted system blocks and holds the busy bit high, and the host waits on a command that never returns. That is a firmware panic, not a dead board. Diagnostic access requires shorting the controller's test pad at power-on so it never tries to load the corrupted firmware.
How much does it cost to recover an SSD not detected in BIOS?
It depends on which of the three failure families the drive falls into. Firmware panic and ROM-mode recovery is $600–$1,200 for SATA and $900–$1,200 for NVMe. Board-level repair on a dead PMIC or voltage rail is $450–$600 for SATA and $900–$1,200 for NVMe. Every case starts with a free evaluation and a firm quote before any paid work. No diagnostic fees. Rush service is +$100 rush fee to move to the front of the queue.
Why can't chip-off recover a modern NVMe SSD that won't power on?
Modern always-on AES NVMe controllers generate an AES-256 Media Encryption Key on the controller and bind it to a hardware-unique root inside the controller silicon. The key never leaves the original controller and is never written to the NAND in plaintext. Desoldering the memory chips and reading them in a NAND reader yields ciphertext that no donor controller can decrypt. For these drives the only viable path is board-level microsoldering to revive the original controller so it can decrypt its own NAND. We do not claim to crack or defeat manufacturer encryption.
No NVMe device found means the drive never enumerated on the PCIe bus, and that has two very different causes. On a healthy drive it is usually a motherboard configuration issue: an M.2 slot set to the wrong interface mode, a shared-lane conflict that disabled the slot when another drive was added, or a BIOS that lists NVMe drives only in its Advanced menu. Rule those out in a known-good native M.2 slot first. If the drive stays invisible, the failure is in the drive: a dead PMIC that starves the controller of power, a PCIe link-training failure, or a firmware panic that stops the controller before it can present a namespace. The first is a free fix at home; the second is a lab job.
Is no NVMe device found the same as a dead SSD?
Not always. The same no NVMe device found message covers a misconfigured motherboard on a perfectly healthy drive and a genuinely dead drive, which is why the at-home checks matter before you panic. The lab tells them apart by connecting the drive to a PC-3000 SSD port over a native PCIe path with vendor-command access. If the controller answers, the problem was the host and the data images normally. If it draws power but never trains the PCIe link, it is a firmware or controller fault. If it draws no power, a dead PMIC or voltage rail has to be repaired by board-level microsoldering before anything can read it. A drive that is invisible to the motherboard is not automatically lost.
Why does my NVMe SSD not show up in BIOS even though it has a power LED?
Power LEDs on M.2 adapters or carrier boards only confirm that 3.3V is reaching the board, not that the controller has booted or completed link training. The PCIe link-training state machine still has to walk through Detect, Polling, Configuration, and Recovery before the BIOS can enumerate the drive. A drive that has power but never appears in BIOS never got through that sequence. The next step is bench enumeration on a PC-3000 Portable III diagnostic port, off any production host, for a drive the host BIOS gives up on after its standard timeout.
What does PCIe link training failure mean?
PCIe link training is the electrical handshake between the host and the NVMe drive. The Link Training and Status State Machine moves through Detect, Polling, Configuration, Recovery, and L0. A failure means the drive never reached L0, so no NVMe commands can be sent. Common causes include a lost 100 MHz reference clock, cracked BGA solder joints under the controller, or a degraded PCIe PHY from thermal cycling. PC-3000 Portable III connects the drive to a dedicated PCIe diagnostic port, off any production host, where enumeration is retried after each board-level repair step until the link holds for imaging.
My SSD shows in Device Manager but 0 bytes in Disk Management. What does that mean?
It means the controller powered up and answered Identify, so Windows lists the disk, but its Flash Translation Layer is torn and it reports zero usable capacity. Recovery software can't scan a 0-byte device because there are no addressable logical blocks to read. The fix is PC-3000 SSD diagnostic-mode access and an FTL rebuild in RAM on the drive itself, which reconstructs the logical-to-physical map the controller lost. Do not click Initialize on it. Pull the drive and send it in for a free evaluation.
Windows is asking me to initialize the disk. Should I?
No. Initializing writes a fresh partition table to the drive; for MBR that write lands at the first sector, LBA 0, and for GPT it's written at both the start and the end of the disk. That overwrites the existing partition metadata, the index a logical recovery relies on to reconstruct partition and file-system boundaries. It doesn't reach the firmware or erase the NAND, but on a drive that only detects intermittently it's one more host write you don't want. Pull the drive and send it in rather than letting Windows write to it.
Ship the drive your BIOS can't see to the Austin lab
Stop power-cycling it first. Free evaluation, firm quote before any paid work, no charge if there's no data. Single location. No franchises. No outsourcing.
