ADATA & XPG SSD Data Recovery
ADATA uses Silicon Motion, Realtek, and InnoGrit controllers across its SSD lineup. The SU800 runs a Silicon Motion chip, and PC-3000 SSD's Silicon Motion utility handles it. The XPG Gammix S70 Blade runs an InnoGrit controller.
SSD pricing starting at $200. No Data, No Fee. Free Evaluation. Since 2008.
ADATA SSDs We Recover
Silicon Motion NVMe SSDs
SX8200 Pro original revision (SM2262EN, TLC+DRAM), Legend 850 (SM2269XT, DRAMless).
SATA SSDs
SU800 (SM2258, TLC+DRAM). SU650 (SM2258XT and Maxio variants).
PC-3000 SSD with Silicon Motion modules in-house.
Updated September 2026
10 min read
ADATA SSD Recovery
How ADATA SSD Recovery Works
ADATA and its XPG gaming brand use controllers from different manufacturers: Silicon Motion (SX8200 Pro, SU800, SU650, Legend 850), Realtek, and InnoGrit (Gammix S70 Blade). Identifying which controller is inside the drive determines which PC-3000 SSD module we use. ADATA complicates this by shipping different controller revisions under the same model number. We open the drive and identify the controller on the PCB before starting recovery. Free evaluation, firm quote. This controller-first method is the same one our SSD data recovery lab applies to every NAND-based drive, whatever the brand on the label.
Controller Identification
Controller Identification Before Recovery
We identify the actual controller on the PCB by visual inspection before starting any recovery work.
SATA Drives
ADATA SATA SSD Recovery: SU800 & SU650
The SU800 uses the Silicon Motion SM2258 controller with onboard DRAM.
We have to open an SU650 to see what's inside. ADATA has shipped the SU650 with different controllers across production runs, and each one has a different firmware architecture and a different recovery path, so the silicon has to be read off the board before any work starts.
PC-3000 SSD covers both the SM2258 and SM2258XT controller families through the Silicon Motion module. To get data off one, we short the ROM pin to force the controller into safe mode, load a loader into its RAM, and rebuild the flash translation layer.
NVMe Drives
ADATA NVMe Recovery: Legend & Gammix Series
ADATA's NVMe lineup uses controllers from multiple vendors. The XPG Gammix S70 Blade uses an InnoGrit controller.
SSD Pricing
ADATA SSD Recovery Pricing
SSD Recovery Calculator
Estimate Your ADATA SSD Recovery Cost
What type of SSD do you have?
Shomari Hohn
Aravind Udayakumar
David Dachenhaus (DDock)
Ludwig Jonsson
LaCie
Controller Architecture Grid
ADATA SSD Controllers and Recovery Methods
SX8200 Pro SM2262EN
The SM2262EN is an NVMe Gen3 controller with 8 channels and onboard DRAM. ACE Lab lists the SM2262EN in its Silicon Motion family on the PC-3000 SSD supported list. To recover one, we short the ROM pin so the controller boots into safe mode, push a loader into its RAM, and rebuild the flash translation layer from there.
SM2262EN recovery details
SU800 and SU650: SM2258 and SM2258XT
4-channel SATA controllers. The SU800 uses the SM2258 with onboard DRAM. The SU650 (some variants) uses the SM2258XT, a DRAMless variant that stores FTL metadata directly in NAND. A failing SM2258XT can hang in an indefinite busy (BSY) state. PC-3000 enters ROM mode via controller pin shorting and rebuilds the corrupted flash translation layer.
SM2258XT recovery details
Legend 960 Max
We open the Legend 960 Max and identify the controller on the PCB before we pick a recovery workflow.
Gammix S70 Blade
The Gammix S70 Blade pairs an InnoGrit controller with TLC NAND, and it's rated for sequential reads above 7 GB/s.
IG5236 recovery details
Legend 850: SM2269XT
The SM2269XT is a Silicon Motion NVMe Gen4 controller with 4 channels. It's a DRAMless HMB design, and the Legend 850 pairs it with TLC NAND. With no onboard DRAM, the mapping table lives in host memory. If power drops before that table is saved to NAND, the FTL can end up corrupted. ACE Lab lists the SM2269XT in the same NVMe Silicon Motion family as the SM2262EN. The job looks the same: we short the ROM pin for safe mode, load a loader into RAM, and rebuild the flash translation layer.
Multi-Controller Identification
Why Controller Identification Matters for ADATA Drives
ADATA drives use controllers from Silicon Motion, Realtek, InnoGrit, and Maxio. The SU650 alone has shipped with at least three different controllers.
For ADATA drives, the model number on the label is not sufficient to determine the controller. We always open the drive and visually confirm the controller IC before selecting a recovery workflow.
On most ADATA drives with firmware corruption, consumer recovery software hits a wall. Those tools send standard NVMe or SATA commands, and corrupted firmware can't process them. PC-3000 doesn't depend on that firmware. It reaches the controller at the hardware level through pin shorting or a safe-mode boot sequence specific to each controller family.
3+
Controller vendors used by ADATA: Silicon Motion, Realtek, InnoGrit, and others
PCB
Visual inspection of the controller IC determines recovery workflow, not the model number
Chip-Off
Chip-Off Recovery
Chip-off recovery (desoldering NAND chips and reading them on a standalone programmer) has limited viability across the ADATA lineup.
ADATA SSD Data Recovery FAQ
My ADATA SX8200 Pro is not detected. Can you recover it?
Yes. The original SX8200 Pro revision runs a Silicon Motion SM2262EN controller, and PC-3000 SSD's Silicon Motion utility supports the SM2262EN. With it we put the controller in safe mode, load a loader into the drive's RAM, and rebuild the FTL mapping. NVMe SSD firmware recovery costs $900–$1,200.
Is chip-off recovery possible on ADATA SSDs?
It depends on the controller. Board-level repair to revive the original controller is the primary recovery path.
My ADATA Legend shows 0 bytes or wrong capacity. What happened?
The Legend 850 uses a DRAMless Silicon Motion SM2269XT controller. A power loss during a NAND write can corrupt the flash translation layer, causing the drive to report wrong capacity or 0 bytes. PC-3000 SSD rebuilds the corrupted FTL from NAND contents. Do not format or initialize the drive.
How much does ADATA SSD recovery cost?
It depends on whether the drive is SATA or NVMe. SATA SSD recovery starts at $200, and NVMe SSD recovery starts at $200. Evaluation is free, and there's no diagnostic fee.
Do you recover XPG-branded drives? Are they different from ADATA?
XPG is ADATA's gaming/performance brand. The controller inside decides if we take one in, not the XPG badge. The original XPG SX8200 Pro revision uses a Silicon Motion SM2262EN. The XPG Gammix S70 Blade uses an InnoGrit controller.
Send Us Your ADATA SSD
Free evaluation. Firm quote. No data, no fee. Ship your ADATA or XPG SSD to our Austin lab.
