Fujitsu Data Recovery
Since 2008 | No Data, No Fee | $100–$2,000 | Nationwide Mail-In
Fujitsu's hard drive business passed to Toshiba on October 1, 2009. ACE Lab's PC-3000 supported-drive list groups the Fujitsu ATA families under Fujitsu. PC-3000 is what we use for firmware work on the MHW, MHZ, and MHY laptop series and the MPG desktop series. We handle both consumer and enterprise SCSI/SAS mechanisms. No data recovered = no charge.
In-House Austin Lab
Single location, no outsourcing
No Data, No Charge
Free evaluation always
Fujitsu HDD Timeline
Fujitsu's hard drive business passed to Toshiba in October 2009. The transition drives (Toshiba MJA series) are still listed under Fujitsu on ACE Lab's PC-3000 supported-drive list.
ACE Lab's supported-drive list groups the Fujitsu ATA families under one manufacturer entry: MPA, MPB, MPC, MPD, MPF and MPG; MHD, MHK, MHM, MHN, MHR, MHS, MHT, MHV, MHW, MHX, MHY and MHZ; and the Toshiba-branded MJA2xxxBH.
11 min read
Fujitsu Recovery Cost
How Much Does Fujitsu Data Recovery Cost?
Fujitsu data recovery costs $100–$2,000, determined by the failure type, not the drive's age or model. Simple data copies from a functioning drive cost $100. File system recovery for corrupted partitions is from $250. Firmware repair for translator corruption or G-List overflow costs $600–$900. Head swaps for clicking Fujitsu drives cost $1,200–$1,500. Platter damage starts at $2,000. Free evaluation and a firm quote for every drive.
Critical Warning
Do Not Swap the PCB
Fujitsu drives store unique adaptive calibration data (head positioning, servo parameters) in non-volatile memory on the PCB. That data has to move to the replacement board before the drive is powered, which is why that transfer is part of our PCB-swap procedure. Do not attempt a PCB swap on any Fujitsu drive. Send it for free evaluation instead.
Toshiba MJA Identification
Is Your Toshiba MJA Actually a Fujitsu?
Fujitsu launched the MJA2 BH series. After Fujitsu's hard drive business passed to Toshiba in 2009, the series carried on under the Toshiba name. ACE Lab's PC-3000 supported-drive list groups these models under Fujitsu rather than Toshiba, so send us the model number off the label with the drive. Drives that are Toshiba designs end to end are covered on our Toshiba data recovery page.
What Hard Drive Recovery Customers Say
Andrew Hansen
Kyle Hartley (crazybangles)
Christopolis
Patrick Dughi
Fujitsu Recovery Pricing
Five published tiers. Pricing is based on the failure type, not the drive model or age. We evaluate every Fujitsu drive for free.
Fujitsu Firmware Architecture
How Does Fujitsu Firmware Architecture Work?
Fujitsu hard drives keep a Service Area (SA) on the platters, outside the user data area. It contains the translator tables, the defect lists (P-List and G-List), and firmware modules. ACE Lab's PC-3000 supported-drive list covers the Fujitsu ATA families, and that is the bench our firmware work runs on.
When the translator becomes corrupt, the drive initializes but reports zero capacity or fails to present the user data area.
Fujitsu Firmware Recovery Sequence
    Connect via PC-3000. Select the Fujitsu family. Identify the drive by model prefix (MHT, MHV, MHW, MHZ, MHY, MPG, or MJA).
    Read Service Area. Identify which structures are corrupted: the translator, the defect lists, the head maps, or the adaptive parameters.
    Rebuild firmware. Regenerate the translator table. Clear or compact corrupted G-List entries. Patch any damaged microcode modules.
    Image the drive. Clone the drive sector-by-sector to a target disk using PC-3000 Data Extractor. Work from the clone, never the original.
Common Failure Modes by Product Line
Recovery by Fujitsu Product Line
Fujitsu's production spanned desktop, laptop, and enterprise drives.
MHW / MHZ / MHY Laptop
These are Fujitsu's 2.5-inch SATA laptop drives. When the translator corrupts, the drive spins, identifies, and then reports zero capacity.
MHT / MHV Legacy Laptop
Earlier 2.5-inch drives from the MHT and MHV series.
MPG Desktop
Fujitsu's MP-prefix desktop drives. ACE Lab's supported list carries the MPA, MPB, MPC, MPD, MPF and MPG families.
MAP / MBA Enterprise
Fujitsu's enterprise line used SCSI and SAS interfaces for server and SAN deployments. When these drives are RAID members, we image each drive individually before reconstructing the array.
Translator Corruption Deep Dive
Translator Corruption in Fujitsu Firmware
The translator table maps logical block addresses (LBAs) to physical cylinder-head-sector (CHS) locations on the platters. When it becomes corrupt, the drive initializes and may even report its correct model number, but it shows zero capacity or an incorrect size. The operating system cannot access any data because the LBA-to-physical mapping is broken.
Recovery involves reading whatever fragments of the translator remain, then using the zone map definitions and head configuration data to reconstruct the mapping from scratch.
Translator corruption is not data loss. The user data sectors are physically intact on the platters. Only the mapping table that tells the controller where each LBA is located is damaged. Rebuilding the translator restores access without any physical intervention. This is a $600–$900 firmware-tier recovery.
Rebuilding the Translator on MHZ, MHY, and MHW Drives
On the 2.5-inch MHZ, MHY, and MHW laptop families we see translator failure present as a drive that spins, identifies its correct model string, then reports 0 LBA or a mismatched capacity.
We read what survives of the translator on the PC-3000 and image every sector through PC-3000 Data Extractor onto a target disk. All work happens on the clone. The original never writes again, so if the reconstruction proves imperfect we can iterate without risking further SA damage.
Motor Seizure
What Causes Motor Seizure in Stored Fujitsu Drives?
A Fujitsu drive pulled out of long storage can come back with a seized spindle motor or with heads stuck to the platters. Either way, we have to open it on a ULPA-filtered clean bench.
If the spindle motor has seized, we move the platters into a donor chassis. That's the surface and platter tier ($2,000).
Stiction vs Spindle Seizure on MHT and MHV Drives
Bearing seizure is a motor problem: the spindle can't start. Head stiction is a surface bonding problem: the parked head-slider is stuck to the platter and can't break away on spin-up.
We distinguish the two on the bench before any power-on imaging attempt. Head stiction is priced at the firmware tier ($600–$900). See our hard drive stiction breakdown for the broader mechanism across other manufacturers.
PCB Failures
What Causes PCB Failures on Early 2000s Fujitsu Drives?
When a Fujitsu PCB fails, the drive doesn't spin, doesn't respond to power, or makes a faint click without spinning up. PCB repair requires transferring the adaptive data from the original board's non-volatile memory to the donor board before applying power.
PCB repair on Fujitsu drives follows the same principle as any manufacturer: the adaptive data stored in non-volatile memory on the original PCB must be transferred to the replacement board. We read that memory chip with a programmer and write its contents to a tested donor board.
PCB Faults on MAP and MBA Enterprise Drives
A clean donor board alone does not solve a PCB fault. We transfer the adaptive data off the original board and only then apply power through a current-limited bench supply. When the drive belongs to a server or SAN array, we image each member drive individually before any array logic runs.
Donor Matching Methodology
Donor Matching for Fujitsu Head Swaps
A clicking MHW, MHZ, or MHY drive needs more than a same-model donor. We screen every donor before any head transplant happens on the ULPA-filtered clean bench. The full breakdown of why each criterion matters across manufacturers is documented in our donor matching technical reference.
1. Model Family and Firmware Revision
We start with the model number on the label. Firmware revision narrows it further, because a head swap needs a donor whose firmware microcode matches the patient's, not just the same model string on the label.
2. Head Map
The head map records which physical heads are active and which were retired during factory test. Two drives that report the same capacity can carry different head maps. Reading the head map from PC-3000 against the patient's SA tells us whether the donor stack will track correctly on the patient's platters.
3. Platter Count
Capacity points on Fujitsu drives were hit through different platter and head combinations across production runs. Two drives with the same capacity on the label can carry different platter counts, so the donor stack has to match the patient's head count.
Why this matters for Fujitsu specifically. Fujitsu's hard drive business passed to Toshiba in 2009, so the donor pool is finite and shrinks every year. Burning a viable donor on a mismatched swap removes that donor from the pool permanently.
FLIR Thermal Inspection Before Bench Power
Before applying bench power to a recovered or donor Fujitsu PCB, we image the board with a FLIR thermal camera under a current-limited supply.
A hot spot shows us a fault we'd miss by looking, such as a shorted decoupling capacitor under the motor driver. We cut power as soon as something on the board runs hotter than it should, rework the failed component, and re-image before the next power cycle. The full PC-3000 workflow once the board passes thermal QA is documented in our PC-3000 technical reference. The cross-manufacturer view of board-level diagnostics on legacy HDDs sits on our hard drive data recovery page.
Data Security
Data Security During Fujitsu Recovery
Your Fujitsu drive stays in our Austin lab from intake through return. Every drive is logged, serialized, and tracked. Recovery work happens on isolated, air-gapped systems. We securely erase every working copy once the case closes. The rest of our data security practices are published separately.
Legacy Fujitsu drives often contain irreplaceable business records, archived project data, personal collections from the early digital era, and enterprise data from decommissioned servers. These drives predate modern backup ecosystems; in many cases the data exists nowhere else.
Shipping
Shipping
Shipping
Mail-in
Fujitsu Recovery Questions
How much does Fujitsu data recovery cost?
Fujitsu data recovery costs $100–$2,000 depending on the failure type. Simple data copies from a functioning drive cost $100. File system recovery is from $250. Firmware repair for translator or G-List corruption runs $600–$900. Head swaps for clicking drives cost $1,200–$1,500, and we require a 50% deposit because the donor parts get used up. Surface damage starts at $2,000. Free evaluation; no data recovered, no charge.
Are donor drives still available for Fujitsu head swaps?
Fujitsu's hard drive business passed to Toshiba on October 1, 2009. That means the supply of Fujitsu donor drives is finite. We match donors by model number, head count, firmware revision, and manufacturing date to ensure mechanical compatibility.
My Fujitsu laptop drive is clicking. Can you recover it?
Clicking on a Fujitsu MHW, MHZ, or MHY laptop drive means the drive cannot lock onto its servo tracks. Damaged heads do that, and so does firmware the drive cannot read or a board carrying adaptive parameters from another unit. Where the bench finds the head stack at fault, we replace it with a matched donor in our ULPA-filtered clean bench and image the platters using PC-3000.
Can I swap the PCB on my old Fujitsu drive?
Not without transferring the adaptive data. Fujitsu drives store unique calibration parameters (head positioning, servo data) in the PCB's non-volatile memory. We read that memory chip with a programmer and write it to the replacement board before powering the drive.
Is my Toshiba MJA drive actually a Fujitsu?
Yes. Fujitsu launched the MJA2 BH series, and it kept going under the Toshiba name after Fujitsu's hard drive business passed to Toshiba in 2009. ACE Lab's PC-3000 supported-drive list still groups the MJA2xxxBH models under Fujitsu rather than Toshiba, so tell us the model number when you ship it.
Why does my old Fujitsu drive not spin after storage?
A drive that sat unpowered for years can come back with a seized spindle motor or with heads stuck to the platters. If the spindle motor has seized, we transplant the platters into a donor chassis on the clean bench. That's the surface and platter tier ($2,000). If the heads are stuck, we free them on the clean bench and keep them. That's priced at the firmware tier ($600–$900).
Can you recover data from Fujitsu enterprise SCSI/SAS drives?
We recover data from Fujitsu MAP and MBA enterprise drives that use SCSI and SAS interfaces. These drives appeared in server arrays, SAN storage, and legacy enterprise systems. When these drives are part of a RAID array, we image each drive individually before reconstructing the array offline.
Need Fujitsu Data Recovery?
We evaluate every Fujitsu model and every Toshiba MJA transitional drive for free. We identify the firmware architecture and failure pattern before quoting. No data, no charge.
