If a failing NVMe drive holds data you need, stop applying power to it. Repeated power-ups push current through whatever is shorted on the package or board, so a single failed rail can spread to neighboring parts.
If the controller is partly alive, re-powering also risks it completing queued TRIM or Deallocate commands the host already issued. Pull the drive & call (512) 212-9111 for a free evaluation.
What Does Monolithic Mean on an NVMe SSD?
That packaging choice sets the ceiling on recovery before any tool touches the drive. If the NAND is a separate package, chip-off is at least physically on the table. If the controller & NAND are fused in one BGA package, chip-off of the NAND alone is off the table for good, & the only paths run through the original controller.
So the first job on any dead NVMe drive is not to grab a tool. It is to identify the package. We read the drive's form factor & board layout during the free evaluation, then pick a method the physics allows.
Multi-Chip M.2 vs Single-Package BGA NVMe
There are two NVMe package types, & conflating them is the most common technical mistake on this topic. A multi-chip M.2 2280 has a controller BGA & one or more NAND BGAs as distinct parts on the PCB. A single-package BGA NVMe drive, the kind soldered into thin laptops & tablets, puts the controller, NAND, & often DRAM inside one sealed BGA package.
The difference is not cosmetic. It decides whether the NAND can ever be read as a separate chip, & therefore which recovery methods exist.
| Attribute | Multi-chip M.2 2280 | Single-package BGA NVMe |
| Physical layout | Separate controller BGA + separate NAND package(s) on a PCB | Controller, NAND, & often DRAM fused in one BGA package |
| Can the NAND be desoldered alone? | Yes, the NAND package can be removed on its own (chip-off) | No, there is no separate NAND chip to remove |
| What a raw read yields | Scrambled, ECC-encoded, unmapped data; ciphertext if hardware-encrypted | Not separable; the NAND cannot be read apart from the controller |
| Recovery paths | Revive the original controller, or chip-off only on older unencrypted parts | Board repair in place, or reball the whole package onto an identical-model donor board |
On the multi-chip M.2, the NAND can come off, but reading it means reversing the controller's XOR data scrambling, its LDPC error correction, & its flash translation layer. On a hardware-encrypted drive the media key is bound to the original controller, so a raw off-chip read returns ciphertext. Not every consumer NVMe drive runs hardware AES, but the scrambling & error correction are barriers on their own.
On the single-package BGA drive there is nothing to chip-off. If the fault is on the surrounding board, we repair it in place. If the board is damaged past repair but the package itself survives, the package reballs onto a donor board of the identical model.
Both keep the original controller doing the reading. For the general chip-off procedure on discrete NAND, see the chip-off NAND recovery page; for single-fused-die USB & microSD monoliths, which are a different form factor read through test pads, see the monolithic NAND recovery page.
Why a Dead NVMe Controller Leaves Nothing to Talk To
A SATA SSD sits behind a host bus adapter that speaks AHCI, an electrical buffer between the drive & the rest of the board. NVMe removes that layer for speed. The controller either trains its PCIe link & enumerates, or the host sees nothing at all.
Recovery software like R-Studio, Disk Drill, or PhotoRec has its place. It works when the drive is physically healthy & the operating system can already see it: a deleted file, a dropped partition, a formatted volume.
It has no path to a controller that never enumerated, because there is no block device to scan. That is the line between a software job & a lab job.
That is why a dead NVMe controller is not a software problem. The electrical & link-training side, the shorted rails, the severed differential pairs, & the LTSSM stalls that keep a controller from coming up, is covered in depth on the NVMe PCIe lane faults page & the PCIe lane diagnostics page. This page stays on the package architecture that dictates the method.
How Much Does Monolithic NVMe Recovery Cost?
The tier follows the fault, not the drama. Most dead NVMe drives are a board repair: we revive the power tree or the failed passive so the original controller boots, which is the tier that preserves the encryption key. When the controller powers but its firmware or FTL is corrupted, the work moves to system-area reconstruction with PC-3000 SSD.
Reballing onto a donor board is the last resort, used only when the original board is damaged past repair while the package survives. It requires a 50% deposit because donor parts are consumed in the attempt, & the donor cost is additional. A donor drive is a matching SSD used for its circuit board. Typical donor cost: $40–$100 for common models, $150–$300 for discontinued or rare controllers. No data recovered means no charge. +$100 rush fee to move to the front of the queue.
The full failure-class breakdown & the M.2 and U.2 form factors we work on live on the NVMe recovery overview. Published pricing, free diagnostics, & 4.9 stars across 1,837+ Google reviews back the work, all of it done in-house at a single Austin lab since 2008.
Why Reading Raw NAND Off a Dead NVMe Controller Is Hard
Say the drive is a multi-chip M.2 & the NAND package can physically come off. You are still nowhere near the files. The controller wrote that NAND through several transforms, & every one of them has to be undone in the exact order that specific controller used.
- XOR data scrambling
- A reversible XOR polynomial the controller applies before writing, to break up repetitive bit patterns that cause electrical interference & uneven wear. It is a reliability layer, not encryption, but the polynomial & controller architecture have to be known to reverse it.
- LDPC error correction
- Modern 3D TLC & QLC NAND relies on the controller's LDPC soft-decision engine, which re-reads cells at shifted reference voltages. A standalone reader does hard-decision reads only, so an offline dump carries uncorrectable bit flips even with no encryption present.
- Flash translation layer (FTL)
- The map from logical sectors to physical pages, interleaved across dies & planes. It lives in the controller's memory, so a raw dump is a fragmented, interleaved binary matrix until the spare-area metadata on every page is parsed to rebuild it.
Two ways exist to get at the raw NAND without a working controller, & both are why direct reads are the exception, not the rule:
- Desolder & read the die. Remove the NAND package & read it on a dedicated NAND reader. This works only where the NAND is a separate package, which rules out every single-package BGA drive.
- Tap the internal bus. Intercept the controller-to-NAND ONFI or Toggle bus with a bus-tap instrument. It is slow, controller-specific, & still leaves the scrambling, ECC, & FTL to reverse afterward.
Then the encryption wall. On a hardware-encrypted drive the media key is generated inside the original controller & wrapped by a key tied to that controller's hardware-unique root, so it never leaves the original silicon. A raw read returns ciphertext, & a donor controller of the same part number cannot unwrap it.
So the realistic path is to revive the original controller so it reads & decrypts its own NAND. Direct raw-NAND reconstruction is a last resort for older, unencrypted parts. None of this is platter work, so none of it needs a cleanroom.
Is Chip-Off Easier on a SATA SSD Than on an NVMe SSD?
This is a tendency, not a law. Plenty of SATA drives are encrypted & plenty of NVMe drives are not. But when you line up the two interfaces, the NVMe side consistently pushes the work away from raw-NAND reading & toward reviving the original controller.
| Factor | SATA SSD | NVMe SSD |
| Chip-off tooling maturity | More mature; simpler, older controller stacks are well mapped | Less mature; complex, newer controllers with proprietary logic |
| Hardware encryption | Present on some drives; many budget parts use only XOR scrambling | More commonly present, binding the media key to the controller |
| FTL complexity | Simpler translation layers on many parts | More complex, higher-throughput interleaving to reverse |
| Packaging | Often separate NAND packages that can be desoldered | Trends to BGA & single-package designs that cannot be separated |
| Typical realistic path | Chip-off viable on older unencrypted parts; else controller revival | Revive the original controller through board repair |
Choosing the Recovery Path by Package & Controller
The method falls out of two questions: is the NAND separable, & is the controller alive or revivable. Package architecture answers the first. The controller family answers the second, because tool support for live-controller work is stratified.
- Controller powers & enumerates. If the drive trains a link, we image through the original controller with a PC-3000 Portable III on a controlled, stepped-down PCIe link, so it decrypts & descrambles its own NAND.
- Controller powers, firmware corrupted. If the link trains but the controller never asserts ready, PC-3000 SSD reconstructs the system area & FTL on the live controller before imaging.
- Controller dead, board repairable. Board-level microsoldering revives the power tree or failed passives so the original silicon boots. On an encrypted drive this is the recovery, because only that controller can decrypt its NAND.
- Board damaged past repair. On a multi-chip drive the NAND transplants to a donor PCB; on a single-package BGA drive the whole package reballs onto an identical-model donor board.
Live-controller firmware & FTL work depends on the controller family. PC-3000 SSD covers the Silicon Motion, Phison, & Marvell NVMe families on ACELab's supported-drive list.
The newest in-house Gen4 & Gen5 controller designs are not on that list, so those drives cannot get logical firmware work & instead depend on board-level revival of the original silicon. We confirm the exact controller during the free evaluation before quoting a method.
Apple T2 & M-Series NVMe Storage
Apple T2 & M-series Macs are the sharp edge of the encryption rule. The NAND sits as discrete BGA packages on the logic board, but the encryption key stays inside the Secure Enclave. A raw NAND read yields ciphertext, & a chip-off recovers nothing usable.
The only path is reviving the original board so the Secure Enclave can decrypt its own storage. We do not crack, defeat, or work around that security. A full treatment of Apple storage recovery lives on its own page; the point here is that the package holds discrete NAND yet still cannot be read off-chip, which is why board revival is the method.
Can Deleted Files Be Recovered From an NVMe SSD?
TRIM is a logical deallocate, not an instant physical erase, & the host is the one that issues it; the controller only executes what the operating system commands. The controller unmaps the blocks from its translation table.
Recovery of deleted files is only possible when TRIM did not run: the drive was pulled immediately, TRIM was disabled, or the file system does not support it. This is separate from a dead drive. A drive that failed physically before any deallocate ran still holds its data, waiting on a controller revival, not a deleted-file scan.
The Lab Sequence for a Monolithic NVMe Drive
The sequence runs package-first, cheapest test before anything irreversible. Every step happens on an ESD-safe bench with the drive off any production host.
- Package identification. Read the form factor & board under a microscope to classify it as multi-chip M.2 or single-package BGA. This decides whether chip-off is even possible.
- Power-tree triage. Apply the rail through a current-limited supply & read the draw. A hard short points at a failed PMIC or passive before any link attempt.
- Thermal fault localization. Inject current on the shorted rail & find the hot part with a FLIR thermal camera.
- Board repair. Replace the shorted part with a Hakko FM-2032 on its FM-203 base, an Atten 862 hot air station for surrounding parts, & a Zhuo Mao BGA rework station for package-level work, then verify the rails.
- Controlled-link imaging. Bring up a PC-3000 Portable III, step the link down to a stable state, read the controller identity, & image through the original silicon so it decrypts its own NAND.
- Firmware path if the handshake fails. If the controller powers but never asserts ready, reconstruct the system area & FTL with PC-3000 SSD before imaging.
Board repair on an encrypted NVMe drive is the recovery, not a step before it. Only the original controller can decrypt its own NAND, so reviving that silicon is what puts the data back within reach.
What does monolithic mean on an NVMe SSD?
Can you chip-off the NAND from a single-package BGA NVMe drive?
Why not skip a dead NVMe controller and read the NAND directly?
Is chip-off easier on a SATA SSD than on an NVMe SSD?
Can data be recovered from the NVMe storage in a MacBook?
How much does monolithic NVMe recovery cost?
Can deleted files be recovered from an NVMe SSD?
NVMe drive dead or unreadable?
Free evaluation. We identify the package, revive the original controller through board-level repair, then image through it with a PC-3000 Portable III. Recovery from $900–$1,200. No data, no fee.
