Enterprise Server Data Recovery
Adaptec SmartRAID 3154-8i Data RecoverySupermicro workstations / Custom server builds / Asus RS720
Adaptec SmartRAID 3154-8i data recovery at Rossmann Group in Austin, Texas. This Adaptec hardware raid controller supports RAID levels 0, 1, 5, 6, 10, 50, 60 across up to 128 drives via SAS/SATA. Commonly found in Supermicro workstations, Custom server builds, Asus RS720. Per-drive imaging costs $600 to $1,500 depending on drive condition, plus an array reconstruction fee. The most common failure we handle is array build/verify failed. All work is backed by our no-data-no-fee guarantee; you pay nothing if we cannot recover your files.
Adaptec SmartRAID 3154-8i Specifications
The Adaptec SmartRAID 3154-8i uses a PMC/Microsemi SmartROC 3100 chipset. Unlike Broadcom/Dell controllers that store metadata at the end of each drive, Adaptec reserves sectors at the beginning. This means the metadata layout requires a different parsing approach in Data Extractor Express RAID Edition. Stripe size defaults to 256KB. The controller uses its own proprietary metadata format, not DDF.
- Manufacturer
- Adaptec
- Controller Type
- Hardware RAID
- Interface
- SAS/SATA
- RAID Levels
- 0, 1, 5, 6, 10, 50, 60
- Max Drives
- 128
- Cache
- 4GB DDR4
- Battery-Backed Cache
- Yes
Recovery Tool Support
PMC/Microsemi SmartROC 3100 chipset. Adaptec uses its own proprietary metadata format (not SNIA DDF) stored in a reserved region at the end of each member drive, the same tail placement as Broadcom/Dell DDF. Data Extractor Express RAID Edition requires a different parsing approach for Adaptec metadata. Default stripe size is 256KB.
Compatible Server Lines
The Adaptec SmartRAID 3154-8i is found in the following server platforms. If your server uses this controller and the array has failed, we can reconstruct the RAID offline from individual drive images.
Failure Modes
RAID controller failures differ from individual drive failures. The controller metadata, stripe maps, and parity calculations must all be intact for the array to function. Below are the failure modes specific to the Adaptec SmartRAID 3154-8i.
Array Build/Verify Failed
Occurs when a newly created or expanding array encounters media errors during the initial build or verify pass. The controller aborts the build and may leave the array in an inconsistent state where parity has not been fully computed across all stripes.
Symptoms you may notice
- Adaptec maxView Storage Manager shows build progress stalled at a percentage
- Array status displays 'Build/Verify Failed'
- Manual intervention required to force-online the array
Related search terms
Controller Replacement / Foreign Array
Adaptec metadata is controller-specific. Moving drives to a different Adaptec model (or even a different unit of the same model) may fail to recognize the array because the metadata includes a controller identifier. The replacement controller sees the physical drives but does not assemble them into a logical drive.
- New controller does not see existing logical drive in maxView
- maxView shows individual physical drives but no logical drive
- Attempting to import the configuration fails or is not offered
How We Recover Adaptec SmartRAID 3154-8i Arrays
Step 1: Individual Drive Imaging
Every drive from the array is imaged independently using the PC-3000 and DeepSpar Disk Imager. Drives with head failures or firmware corruption are repaired first. Each drive is imaged sector-by-sector to a clean target before any reconstruction begins.
For SAS/SATA drives, we use the appropriate interface hardware. SAS drives require dedicated SAS HBAs; SATA drives connect directly. This preserves every readable sector without relying on the original Adaptec SmartRAID 3154-8i controller.
Step 2: Array Reconstruction
We use Data Extractor Express RAID Edition to reverse-engineer the Adaptec SmartRAID 3154-8i's metadata structure: stripe size, drive order, parity rotation, and offset values. The array is reconstructed from the drive images without needing the original controller hardware.
Once the virtual array is assembled, we extract the file system (NTFS, ext4, XFS, VMFS, ZFS, or other) and verify file integrity before delivering the recovered data.
The Adaptec SmartRAID 3154-8i includes a battery-backed or flash-backed write cache (4GB DDR4). If the server lost power during a write operation, pending writes are preserved in the cache. On restart with a healthy controller, the firmware automatically flushes this cached data to disk; no manual intervention is needed. If the controller itself has failed, recovering cached data requires an identical replacement controller (same model, firmware revision) to which the cache module can be transferred.
Recovery pricing for Adaptec SmartRAID 3154-8i arrays has two components: per-drive imaging and array reconstruction. Drive imaging costs $600–$900 to $1,500 per drive depending on condition (firmware repair vs. head swap). Array reconstruction adds a separate fee depending on the number of drives and RAID level complexity.
See our full pricing breakdown for details. Our No Data, No Fee guarantee means you pay nothing if we cannot recover your files.
Why does Adaptec store metadata at the beginning of the drive instead of the end?
My Adaptec 3154 array shows 'Build/Verify Failed' after adding a new drive. Is the data lost?
I replaced my Adaptec 3154 controller and the new one does not see my logical drive. What do I do?
How much does Adaptec SmartRAID 3154 recovery cost?
Need help with a different setup? We also recover NAS arrays, standalone RAID, and enterprise SSDs.
Server Recovery Overview →Since 2008
Other Recovery Services
Nationwide Coverage
Popular Service Areas
Adaptec SmartRAID 3154-8i array down?
Ship the drives to our Austin lab for a free evaluation. No data, no charge.
