Enterprise Server Data Recovery
Broadcom MegaRAID 9460-16i Data RecoverySupermicro X11/X12 series / Lenovo ThinkSystem SR650 / Dell (via custom configurations)
Broadcom MegaRAID 9460-16i data recovery at Rossmann Group in Austin, Texas. This Broadcom hardware raid controller supports RAID levels 0, 1, 5, 6, 10, 50, 60 across up to 240 drives via SAS/SATA. Commonly found in Supermicro X11/X12 series, Lenovo ThinkSystem SR650, Dell (via custom configurations). Per-drive imaging costs $600 to $1,500 depending on drive condition, plus an array reconstruction fee. The most common failure we handle is drive group degraded / offline. All work is backed by our no-data-no-fee guarantee; you pay nothing if we cannot recover your files.
Updated February 2026
5 min read
Specifications
Broadcom MegaRAID 9460-16i Specifications
The Broadcom MegaRAID 9460-16i is a tri-mode controller supporting SAS, SATA, and NVMe drives simultaneously via 16 internal ports. It is the OEM basis for many server vendor RAID cards (Dell PERC H745, Lenovo RAID 940). Metadata is DDF format, stored on each drive. CacheVault flash-backed cache preserves pending writes during power loss. Data Extractor Express RAID Edition reads MegaRAID DDF metadata to reconstruct arrays without the original controller.
Manufacturer
Broadcom
Controller Type
Hardware RAID
Interface
SAS/SATA
RAID Levels
Max Drives
240
Cache
4GB DDR4
Battery-Backed Cache
Yes
Recovery Tool Support
Data Extractor Express RAID Edition: Supported
Manual Reconstruction: Supported
Tri-mode controller: 12Gb/s SAS, 6Gb/s SATA, 32Gb/s NVMe via PCIe 3.1 x8. Uses DDF metadata stored on each drive. This is the OEM basis for many rebranded controllers (Dell PERC H745, Lenovo RAID 940). Data Extractor Express RAID Edition reads MegaRAID DDF metadata to reconstruct arrays without the original controller.
Compatible Server Lines
The Broadcom MegaRAID 9460-16i is found in the following server platforms. If your server uses this controller and the array has failed, we can reconstruct the RAID offline from individual drive images.
Supermicro X11/X12 seriesLenovo ThinkSystem SR650Dell (via custom configurations)Cisco UCS C240 M5
Failure Modes
Failure Modes
RAID controller failures differ from individual drive failures. The controller metadata, stripe maps, and parity calculations must all be intact for the array to function. Below are the failure modes specific to the Broadcom MegaRAID 9460-16i.
Drive Group Degraded / Offline
One or more physical drives fail or are removed from the enclosure. If redundancy is lost, the drive group goes offline and all virtual drives on that group become inaccessible. The server may fail to POST if the boot volume resides on the affected drive group.
Symptoms you may notice
  • MegaRAID Storage Manager shows drive group status as offline
  • OS loses access to all logical volumes on the affected drive group
  • Server fails to POST if the boot volume is on the offline group
Related search terms
MegaRAID 9460 drive group offlineBroadcom MegaRAID recoveryMegaRAID 9460-16i data recoverySupermicro RAID failed
Consistency Check / BGI Failure
Background initialization or consistency check encounters uncorrectable media errors on one or more drives. The controller marks the affected drives as 'bad' and removes them from the array. If multiple drives are affected, the virtual drive transitions from Optimal to Degraded to Offline.
  • Event log shows 'media error' entries during patrol read or consistency check
  • Virtual drive status changes from Optimal to Degraded
  • MegaRAID Storage Manager flags specific physical drives with 'Unconfigured Bad' state
MegaRAID 9460 consistency check failedBroadcom MegaRAID media errorMegaRAID BGI failureMegaRAID 9460 unconfigured bad
Recovery Process
How We Recover Broadcom MegaRAID 9460-16i Arrays
Step 1: Individual Drive Imaging
Every drive from the array is imaged independently using the PC-3000 and DeepSpar Disk Imager. Drives with head failures or firmware corruption are repaired first. Each drive is imaged sector-by-sector to a clean target before any reconstruction begins.
For SAS/SATA drives, we use the appropriate interface hardware. SAS drives require dedicated SAS HBAs; SATA drives connect directly. This preserves every readable sector without relying on the original Broadcom MegaRAID 9460-16i controller.
Step 2: Array Reconstruction
We use Data Extractor Express RAID Edition to reverse-engineer the Broadcom MegaRAID 9460-16i's metadata structure: stripe size, drive order, parity rotation, and offset values. The array is reconstructed from the drive images without needing the original controller hardware.
Once the virtual array is assembled, we extract the file system (NTFS, ext4, XFS, VMFS, ZFS, or other) and verify file integrity before delivering the recovered data.
The Broadcom MegaRAID 9460-16i includes a battery-backed or flash-backed write cache (4GB DDR4). If the server lost power during a write operation, pending writes are preserved in the cache. On restart with a healthy controller, the firmware automatically flushes this cached data to disk; no manual intervention is needed. If the controller itself has failed, recovering cached data requires an identical replacement controller (same model, firmware revision) to which the cache module can be transferred.
Recovery pricing for Broadcom MegaRAID 9460-16i arrays has two components: per-drive imaging and array reconstruction. Drive imaging costs $600–$900 to $1,500 per drive depending on condition (firmware repair vs. head swap). Array reconstruction adds a separate fee depending on the number of drives and RAID level complexity.
See our full pricing breakdown for details. Our No Data, No Fee guarantee means you pay nothing if we cannot recover your files.
Can you recover a MegaRAID 9460 array that mixed SAS and NVMe drives?
Yes. The 9460-16i is a tri-mode controller supporting SAS, SATA, and NVMe simultaneously. All three drive types store DDF metadata in the same format. We image each drive through the appropriate interface (SAS HBA for SAS drives, NVMe adapter for PCIe SSDs) and reconstruct the array using the DDF metadata regardless of the mix.
My MegaRAID 9460 shows a drive group offline after a consistency check found media errors. Can you recover it?
Yes. When a consistency check or patrol read encounters uncorrectable media errors, the controller may mark drives as 'Unconfigured Bad' and take the drive group offline. We image each drive (including the bad sectors, using sector-level retry in PC-3000) and reconstruct the array. Parity data on the remaining healthy drives fills in the unreadable sectors from the failed drive.
Is the MegaRAID 9460 the same as Dell PERC H745?
The Dell PERC H745 is a rebranded Broadcom MegaRAID 9460 with Dell-specific firmware. Both use the same DDF metadata format. Data Extractor Express RAID Edition handles them identically. If your server has a PERC H745, the recovery process is the same as for a MegaRAID 9460.
How much does MegaRAID 9460 recovery cost?
Per-drive imaging based on condition, plus $400-$800 array reconstruction. NVMe drives in the array are imaged through PCIe adapters at no additional charge. No data recovered means no charge.
Overview
Need help with a different setup? We also recover NAS arrays, standalone RAID, and enterprise SSDs.
Server Recovery Overview →
Nationwide Coverage
View All Locations
Broadcom MegaRAID 9460-16i array down?
Ship the drives to our Austin lab for a free evaluation. No data, no charge.
