Enterprise Server Data Recovery
LSI MegaRAID SAS 9271-8i Data RecoverySupermicro X9/X10 series / Dell PowerEdge R620/R720 (custom) / Lenovo ThinkServer RD640/RD540
LSI MegaRAID SAS 9271-8i data recovery at Rossmann Group in Austin, Texas. This LSI hardware raid controller supports RAID levels 0, 1, 5, 6, 10, 50, 60 across up to 32 drives via SAS/SATA. Commonly found in Supermicro X9/X10 series, Dell PowerEdge R620/R720 (custom), Lenovo ThinkServer RD640/RD540. Per-drive imaging costs $600 to $1,500 depending on drive condition, plus an array reconstruction fee. The most common failure we handle is bbu / cachevault learning cycle timeout. All work is backed by our no-data-no-fee guarantee; you pay nothing if we cannot recover your files.
LSI MegaRAID SAS 9271-8i Specifications
The LSI MegaRAID SAS 9271-8i is a legacy 6Gb/s SAS controller still found in many active Supermicro and Lenovo servers from 2013-2017. It uses the same MegaRAID DDF metadata family as its successor (Broadcom 9460) but with slightly different reserved sector offsets. Data Extractor Express RAID Edition's MegaRAID module handles both legacy and current metadata layouts.
- Manufacturer
- LSI
- Controller Type
- Hardware RAID
- Interface
- SAS/SATA
- RAID Levels
- 0, 1, 5, 6, 10, 50, 60
- Max Drives
- 32
- Cache
- 1GB DDR3
- Battery-Backed Cache
- Yes
Recovery Tool Support
Legacy 6Gb/s SAS controller using DDF metadata. Same MegaRAID firmware family as the Broadcom 9460 successor but with slightly different reserved sector offsets. Data Extractor Express RAID Edition's MegaRAID module handles both legacy and current metadata layouts.
Compatible Server Lines
The LSI MegaRAID SAS 9271-8i is found in the following server platforms. If your server uses this controller and the array has failed, we can reconstruct the RAID offline from individual drive images.
Failure Modes
RAID controller failures differ from individual drive failures. The controller metadata, stripe maps, and parity calculations must all be intact for the array to function. Below are the failure modes specific to the LSI MegaRAID SAS 9271-8i.
BBU / CacheVault Learning Cycle Timeout
BBU capacitor or battery fails its periodic learning cycle (discharge/recharge test). Controller disables write cache and operates in write-through mode. If an administrator continues operating in write-through mode and a drive fails, rebuild is slower because all writes go directly to disk without caching.
Symptoms you may notice
- MegaRAID Storage Manager shows BBU status stuck on 'Learning' indefinitely
- Write latency increases as controller operates in write-through mode
- Event log entries for BBU learning cycle timeout
Related search terms
Foreign Configuration
Drives moved between 9271 controllers or firmware upgraded to an incompatible version. The DDF metadata on the drives references a controller identifier that does not match the current controller. The controller offers to Import or Clear the foreign configuration at boot.
- Controller shows 'Foreign Configuration' at boot
- Boot menu offers 'Import' or 'Clear' options for the foreign config
- Logical drive is not visible until the foreign config is imported
How We Recover LSI MegaRAID SAS 9271-8i Arrays
Step 1: Individual Drive Imaging
Every drive from the array is imaged independently using the PC-3000 and DeepSpar Disk Imager. Drives with head failures or firmware corruption are repaired first. Each drive is imaged sector-by-sector to a clean target before any reconstruction begins.
For SAS/SATA drives, we use the appropriate interface hardware. SAS drives require dedicated SAS HBAs; SATA drives connect directly. This preserves every readable sector without relying on the original LSI MegaRAID SAS 9271-8i controller.
Step 2: Array Reconstruction
We use Data Extractor Express RAID Edition to reverse-engineer the LSI MegaRAID SAS 9271-8i's metadata structure: stripe size, drive order, parity rotation, and offset values. The array is reconstructed from the drive images without needing the original controller hardware.
Once the virtual array is assembled, we extract the file system (NTFS, ext4, XFS, VMFS, ZFS, or other) and verify file integrity before delivering the recovered data.
The LSI MegaRAID SAS 9271-8i includes a battery-backed or flash-backed write cache (1GB DDR3). If the server lost power during a write operation, pending writes are preserved in the cache. On restart with a healthy controller, the firmware automatically flushes this cached data to disk; no manual intervention is needed. If the controller itself has failed, recovering cached data requires an identical replacement controller (same model, firmware revision) to which the cache module can be transferred.
Recovery pricing for LSI MegaRAID SAS 9271-8i arrays has two components: per-drive imaging and array reconstruction. Drive imaging costs $600–$900 to $1,500 per drive depending on condition (firmware repair vs. head swap). Array reconstruction adds a separate fee depending on the number of drives and RAID level complexity.
See our full pricing breakdown for details. Our No Data, No Fee guarantee means you pay nothing if we cannot recover your files.
Is the LSI 9271 the same as the Broadcom MegaRAID 9460 for recovery purposes?
My LSI 9271 BBU has been stuck on 'Learning' for weeks. Should I be concerned about data loss?
The 9271 shows 'Foreign Configuration' after I moved drives to a new server. Should I import it?
How much does LSI MegaRAID 9271 recovery cost?
Need help with a different setup? We also recover NAS arrays, standalone RAID, and enterprise SSDs.
Server Recovery Overview →Since 2008
Other Recovery Services
Nationwide Coverage
Popular Service Areas
LSI MegaRAID SAS 9271-8i array down?
Ship the drives to our Austin lab for a free evaluation. No data, no charge.
