SanDisk Extreme Portable SSD Data Recovery
Mail-in SanDisk Extreme Portable SSD data recovery service starts by separating bridge failure, firmware panic, and controller-bound encryption. We open the enclosure, test the ASMedia ASM2362 bridge, image the internal NVMe SSD through PC-3000 Portable III when possible, and repair the original hardware path at our Austin lab. Free evaluation. No data, no fee.
Rossmann does not currently offer in-lab recovery for SanDisk in-house NVMe controller firmware reconstruction; the controller is not on ACELab's PC-3000 SSD support matrix. Recovery for this drive is hardware repair only: USB bridge bypass, microsoldering, and direct NVMe imaging of the internal NVMe SSD.
The SanDisk Extreme and Extreme Pro Portable SSDs (V2 generation) have a documented design flaw that causes sudden, total data loss. A class-action lawsuit (Krum v. Western Digital, Case No. 5:23-cv-04152) was filed in August 2023 after thousands of users lost data without warning. The root cause is a combination of defective solder joints and a firmware bug that Western Digital's patch did not resolve.
We recover data from these drives by opening the enclosure, bypassing the failed ASMedia ASM2362 USB bridge chip, and reading the internal NVMe SSD directly through the PC-3000 Portable III. When the bridge chip's solder joints are the sole failure point, the internal SSD is often intact.
Updated September 2026
What Causes The SanDisk Extreme Failure
What Causes the SanDisk Extreme Portable SSD to Fail?
Attingo Data Recovery (Vienna, Austria) published a hardware analysis in November 2023 identifying two manufacturing defects in the SanDisk Extreme V2. Their managing director, Markus Hafele, reported receiving approximately one defective SanDisk Extreme Pro per week over several months. Both defects cause solder joints to crack under thermal cycling. The published teardown work does not pin the defect to one specific chip or to one of the two boards inside the enclosure.
Defect 1: Oversized components. The surface-mount components on the internal PCB are physically larger than the pad layout was designed for. This creates weak mechanical contact between components and their solder pads, producing high impedance connections that generate excess heat at the junction points during file transfers.
Defect 2: Solder joint bubbles. The solder used in manufacturing contains internal voids (bubbles) that weaken the mechanical bond. Hafele attributed this to either poor-quality solder or unsuitable factory conditions such as high humidity. These weakened joints crack from thermal cycling during normal use: the drive heats during sustained transfers, then cools, expanding and contracting the joint until it fractures.
Western Digital responded by adding epoxy resin to reinforce solder joints on newer production runs. Those newer units continued to fail. Western Digital maintained that the firmware update addressed the problem; the addition of structural epoxy suggests otherwise.
Affected Models
Which SanDisk Extreme Models Are Affected?
The class-action filing and Western Digital's firmware update target these specific models. Inside, an Extreme Portable is an NVMe SSD reached through a USB bridge, and the exact parts vary between models and production runs, so the hardware in the unit on the bench is confirmed by opening it rather than by the model number.
ModelModel NumberCapacity
Extreme Portable V2SDSSDE61-4T004TB
Extreme Pro Portable V2SDSSDE81-4T004TB
Extreme Pro Portable V2SDSSDE81-2T002TB
Extreme Pro Portable V2SDSSDE81-1T001TB
WD My Passport SSDWDBAGF0040BGY4TB
Internally, an Extreme Portable is an NVMe SSD connected through an ASMedia USB bridge chip. The SSD inside runs a SanDisk NVMe controller with 3D TLC BiCS4 NAND.
Symptoms
What Are the Symptoms of the SanDisk Extreme Failure?
The failure is typically sudden and total, with no SMART warning beforehand. The drive disconnects mid-transfer, then reappears as uninitialized or completely absent, with no partition table visible to the operating system.
  • Drive disconnects or ejects mid-transfer without warning
  • "You need to format the disk in drive before you can use it" prompt after reconnecting
  • Drive appears in Disk Management as uninitialized with no partition table
  • "Disk not readable" error on macOS
  • Drive not recognized by the computer at all (no USB enumeration)
  • Replacement drive from Western Digital fails with the same defect
Do not format the drive. If Windows or macOS prompts you to initialize or format, close the dialog. The data is still on the NAND flash; the filesystem metadata is intact on the internal SSD. Formatting will overwrite the partition table and file allocation structures.
Why the Western Digital Firmware Patch Does Not Fix It
In May 2023, Western Digital released a firmware updater for affected Extreme and Extreme Pro models. The patch addressed firmware-level disconnection handling but did not address the physical solder defects identified by Attingo.
Users continued reporting failures after applying the update, including journalists from The Verge and Ars Technica whose patched and replacement drives failed again.
Western Digital's own update instructions tell owners to create and verify a backup of all critical data before running the updater. If the drive has already failed, the firmware patch has no mechanism to restore lost data.
If your SanDisk Extreme still works, back up everything now. The failure pattern is sudden: working one moment, blank the next. No warning, no gradual degradation.
Firmware Updater Coverage By Capacity
Which Capacities Did the May 2023 Firmware Updater Cover?
The May 2023 Western Digital updater covered affected Extreme and Extreme Pro models across multiple capacities. Reported coverage varied by SKU, and some owners found no patch listed for their specific capacity at launch. The 4TB units show the highest incidence of sudden failure, with the 2TB also significant.
The documented updater version string is 3.2.3.1. It is a firmware-updater build, not a recovery utility. Running it on a drive that already dropped its partition table or stopped enumerating does nothing for the lost data, and Western Digital's own documentation warns that an interrupted update can finish what the solder cracks started.
How We Recover Data From SanDisk
How Is Data Recovered from a Failed SanDisk Extreme?
Recovery depends on which component failed: the USB bridge chip, its solder connections, or the internal NVMe SSD itself. The internal NVMe SSD is often intact when the bridge chip is the sole failure point.
  1. 01
    Enclosure Disassembly and Bridge Bypass
    We open the enclosure and remove the internal NVMe SSD. If the ASMedia ASM2362 bridge chip or its solder joints are the failure point, the internal SSD is often completely intact. We connect it directly to the PC-3000 Portable III using an NVMe adapter, bypassing the USB interface entirely. If the drive mounts and data is accessible, this is the simplest recovery: a direct sector-by-sector image to your return media.
  2. 02
    Solder Joint Repair (Microsoldering)
    When the bridge chip itself is functional but the solder joints have cracked, we rework the connections under a Hakko microsoldering station with FLIR thermal imaging to identify the specific cold joints. This preserves the proprietary unlock command path. If the drive was configured with hardware encryption enabled, the bridge must be repaired rather than bypassed, because Western Digital's unlock handshake requires the bridge to reach the NVMe controller.
  3. 03
    SSD PCB Component Repair
    If the internal SSD power delivery circuit has been damaged by voltage irregularities from the failing bridge, the recovery requires board-level microsoldering. The internal SSD runs a proprietary SanDisk NVMe controller; no dedicated PC-3000 Active Utility exists for WD proprietary controllers, so software-level firmware repair is not available for this model. Damaged power management components on the SSD PCB must be replaced to restore stable voltage to the original controller before the drive can be imaged. See the SanDisk Extreme component recovery details for hardware diagnostic workflows.
  4. 04
    Data Extraction and Verification
    Once the internal SSD is accessible (via bridge bypass, solder repair, or PCB component repair), we image the entire drive sector-by-sector to a known-good destination. File structure verification confirms completeness before we ship your return media back.
SanDisk Extreme Recovery Pricing
All SSD recoveries start with a free evaluation, and you receive a firm quote before any paid work begins. Most SanDisk Extreme cases fall into the Circuit Board Repair or Firmware Recovery tiers; bridge-only failures where the internal SSD is intact recover at the Simple Copy or File System Recovery level.
Most SanDisk Extreme cases fall into the Circuit Board Repair ($900–$1,200) or Firmware Recovery ($900–$1,200) tiers. Bridge-only failures where the internal SSD is intact resolve at the Simple Copy ($200) or File System Recovery (From $250) level. Call (512) 212-9111 for a free evaluation.
Why Software Cannot Fix This
Why Recovery Software Cannot Fix a Failed SanDisk Extreme
When the USB bridge fails, the drive does not enumerate to the operating system. Recovery software requires a visible block device to scan. No enumeration means no volume, no sectors, and no path to the data. The ASMedia bridge chip must be functional before any software-based approach can reach the NAND.
Tools like Disk Drill, Recuva, R-Studio, and EaseUS send read commands through the OS storage driver. The OS driver talks to the USB mass storage interface, which talks to the ASMedia bridge chip, which talks to the NVMe SSD.
If the bridge chip or its solder joints have failed, the chain is broken at the hardware level. Software operates above this break point.
Some users report partial success with DiskDrill on drives that intermittently connect. This is risky: each reconnection stresses the cracked solder joints further, and the drive can fail permanently mid-scan. If your drive is connecting intermittently, stop using it and send it for professional recovery before the remaining solder joints give out.
Hardware Solder Joint Repair
The SanDisk Extreme and Extreme Pro Portable SSDs use a QFN-packaged ASMedia ASM2362 bridge IC to translate between the USB-C port and the internal NVMe SSD. This bridge chip sits on a perimeter array of flat solder pads plus a central thermal pad connecting it to the PCB. When those solder joints crack, the drive stops working entirely. No firmware update can fix a broken physical connection.
Thermal cycling is the mechanism. During sustained file transfers, the ASM2362 bridge chip generates heat. When the transfer ends, the chip cools. Each heat/cool cycle expands and contracts the solder joints by a few microns.
In a well-manufactured joint, this is routine and the solder absorbs the stress. The published teardown work on these drives reports voids in the solder and components oversized for their pads, either of which concentrates mechanical stress at specific points. That work does not say which chip or which of the two internal boards carries the defect, so the failing joint is found on the bench rather than assumed.
Western Digital added epoxy resin underfill to later production runs to mechanically reinforce the joints. Those units still fail, because the epoxy does not restore electrical conductivity to a joint that has already fractured internally.
Why Firmware Updates Cannot Fix Hardware Solder Defects
Western Digital's May 2023 firmware patch modified how the internal drive's controller handles sudden USB disconnection events. This addressed one failure mode: the controller firmware entering an unrecoverable state after the bridge chip dropped the USB link mid-write. The patch did not address the reason the bridge chip dropped the link in the first place. A cracked solder joint is a mechanical failure. It cannot be corrected by rewriting firmware registers. The firmware update is a software guardrail for an ongoing hardware problem.
How We Repair Cracked Solder Joints on the Bridge IC
When the free evaluation identifies a solder joint failure (the internal SSD tests healthy when removed, but the drive does not function in its enclosure), we repair the bridge chip connections using a Hakko microsoldering station under microscope. The specific approach depends on the joint condition:
  • 1.
    Reflow. For joints that have partially fractured but still have enough solder volume to bridge the pad, controlled reheating with a hot air station reforms the connection. We use FLIR thermal imaging to map the board's heat distribution and identify which joints have failed. Reflow is faster and less invasive, but it reuses the original defective solder. It is a viable path when the goal is data extraction rather than long-term drive use.
  • 2.
    Re-tinning and replacement. For joints with complete fractures or severe void contamination, the ASM2362 must be removed entirely. We clean the pads on both the chip and the PCB, then apply fresh leaded solder paste to the footprint. The chip is then placed back on the board and reflowed with a controlled temperature profile. Re-alloying the pads replaces the defective solder with known-good material and produces a joint that does not carry the factory voids.
Encrypted Drives: Why Bridge Bypass Fails
Hardware encryption on these drives is handled by the internal SSD's own SanDisk NVMe controller, not the ASM2362 bridge chip. The controller operates as a Self-Encrypting Drive (SED) with AES-256 encryption.
On a unit where the owner set a password, the drive stays locked until the correct credential reaches the SSD controller, so a password-protected drive is worked with the enclosure hardware intact rather than around it.
Drives without user-set passwords still use the bridge chip for USB-to-NVMe protocol translation. Where no hardware unlock was configured, there is no unlock handshake to pass and bridge bypass is the fastest recovery path: remove the SSD, connect it to the PC-3000 Portable III via NVMe adapter, and image directly.
Bridge solder repair falls in our Circuit Board Repair tier ($900–$1,200). The free evaluation determines which tier applies before any paid work begins.
How Does Firmware Panic Corrupt The
How Does Firmware Panic Corrupt the SanDisk Extreme?
The SanDisk controller is a DRAM-less 4-channel NVMe controller. Operating behind a USB bridge, it cannot use the Host Memory Buffer (HMB) protocol and relies entirely on a small on-die SRAM cache for the Flash Translation Layer (FTL) mapping table. When power drops during a garbage collection cycle or FTL flush from SRAM to the BiCS4 NAND, the write aborts mid-page & the FTL mapping table corrupts.
DRAM-Less Architecture & FTL Vulnerability
Controllers with onboard DRAM (like Samsung's Elpis or Phison PS5018-E18) keep a full copy of the L2P (Logical-to-Physical) mapping table in dedicated DDR4 memory on the SSD PCB. The SanDisk NVMe controller skips that DRAM chip entirely. The controller relies entirely on its limited internal SRAM cache. This saves Western Digital a few dollars per unit in manufacturing cost but limits performance under sustained workloads.
The tradeoff is severe vulnerability to sudden power loss. On the SanDisk Extreme Portable, power and data run through the ASM2362 USB bridge. A cracked solder joint on the bridge chip drops the power and PCIe link mid-operation. If the controller was writing FTL updates from its SRAM cache to the 96-layer BiCS4 NAND at that moment, the write aborts. Partial FTL pages leave the mapping table in an inconsistent state.
The controller detects the inconsistency on the next power cycle and enters a protective firmware panic state. It refuses to boot normally. The drive appears as "55DD SCSI Disk Device" in Windows Device Manager or reports 0 bytes in Disk Management. The ASM2362 bridge may still enumerate via USB, but the NVMe namespace behind it is inaccessible.
Why Automated FTL Reconstruction Is Not Available
ACE Lab's PC-3000 SSD does not have a dedicated Active Utility for SanDisk in-house NVMe controller silicon. No commercial data recovery tool currently supports automated FTL reconstruction for this proprietary Western Digital controller. When the controller enters a firmware panic state, recovery depends on board-level repair to restore stable power and signal paths to the original controller so it can rebuild its own FTL mapping on the next clean boot cycle.
Firmware-Hang Vs Controller Death Vs NAND Wear
Firmware-Hang vs Controller Death vs NAND Wear
Three failure classes hit the SanDisk Extreme, and the observable signal tells them apart. A firmware-hang still enumerates over USB but exposes 0GB or a bad capacity. Controller or PMIC death gives no enumeration and no LED activity. NAND wear shows slowing reads and accumulating uncorrectable errors. Each maps to a different in-house path.
The fastest way to know which repair your drive needs is to watch how it behaves when you plug it in. A drive that enumerates but reports the wrong size is a different problem from one that draws no power at all, and both differ from a drive that reads slowly and throws errors. The table maps each observable signal to its failure class and the recovery path that class allows on the SanDisk NVMe controller.
Failure ClassObservable SignalIn-House Recovery Path
Firmware-hang / FTL panicDrive disconnects mid-transfer, then reappears uninitialized with the partition table missing. Enumerates as "55DD SCSI Disk Device" or reports 0GB / wrong capacity. The USB bridge still enumerates, but the NVMe namespace behind it is inaccessible. User data and filesystem metadata remain intact on the NAND; the controller refuses to expose them.Hardware repair to restore stable power and signal so the original controller runs its own crash-recovery on a clean power cycle. No external FTL tool exists for this controller.
Controller / PMIC electrical deathNot recognized at all, with no USB enumeration and no LED activity. Often a shorted 90430VM330 PMIC pulling the power rail to ground, which collapses the voltage the controller needs to come up.FLIR thermal localization of the shorted component, then replacement with a Hakko FM-2032 on an FM-203 base. Circuit Board Repair tier ($900–$1,200).
NAND wear-outGenerally: reads slow over time, uncorrectable errors accumulate past the controller's ECC / LDPC threshold, or the controller imposes a read-only state as its spare-block pool is exhausted. The exact host signals for this specific hardware are not independently documented, so treat this as the general mechanism, not a fixed error code for this drive.Evaluated case by case once the drive is imageable through the original controller. Worn cells are not repaired by board work; the goal is a stable image while the controller still reads them.
Rossmann does not currently offer in-lab recovery for SanDisk in-house NVMe controller firmware reconstruction. None of the three classes above is recovered by swapping in an external translator; the controller is not on ACELab's PC-3000 SSD support matrix. The honest path for all three is returning the original silicon to a state where it reads its own NAND.
Why A Failed Drive Reports 0GB
Why a Failed SanDisk Extreme Reports 0GB or Goes Read-Only
A drive that suddenly shows 0GB has not lost its data. The capacity parameters the host reads, the namespace size, the logical block count, live inside the Flash Translation Layer. When the controller cannot reconcile the persisted Logical-to- Physical (L2P) table with what is actually on the NAND, it will not bring that FTL online, so it has no capacity figure to report and falls back to a safe ROM mode using fallback identifiers.
In that ROM mode the drive enumerates with a generic descriptor, the "55DD SCSI Disk Device" string, and answers capacity queries with 0GB because the real capacity number is locked behind the FTL it could not load. The user data still sits on the 96-layer BiCS4 NAND, untouched. What is missing is the map that turns logical block addresses into physical pages, not the pages themselves.
The detailed sequence of how a mid-write bridge drop corrupts that map is covered in the firmware panic section, and the progression from intermittent disconnects to a write-protected state is laid out in common failure states.
A read-only fallback is the same defense from the other direction. When the controller can still expose the namespace but detects that its mapping or spare-block accounting is no longer trustworthy, it stops accepting writes to keep from making the inconsistency worse. Existing files stay visible while new writes fail with write-protected or "media was unplugged" errors. Both 0GB and read-only are the controller protecting state it cannot safely change, not evidence that the NAND has been erased.
Symptom Decision Matrix
Which SanDisk Extreme failure is causing my symptoms?
Four observable symptom patterns map to four distinct root causes inside the Extreme Portable: thermal-fatigued ASM2362 solder joints, a shorted 90430VM330 PMIC, FTL corruption on the SanDisk NVMe controller, and mechanical USB-C connector shear. Each pattern points at a specific recovery tier in our NVMe SSD pricing matrix. Use the symptom table to identify which failure mode matches your drive before shipping it in.
Observable SymptomLikely Root CauseDiagnostic RealityRecovery Tier
OS File Explorer freezes; transfer speeds drop to KB/s; drive runs hot to the touch.Thermal throttling and ASM2362 solder fatigue.Sustained thermal cycling creates microfractures in ASM2362 solder joints.Circuit Board Repair ($900–$1,200)
Drive disconnects mid-operation; Windows reports "No Media"; macOS shows a greyed-out unmountable volume.90430VM330 PMIC short or failure.Failed PMIC stops generating the voltage rails (core logic and VCCQ) needed by the NVMe controller and NAND array.Circuit Board Repair ($900–$1,200)
After sudden disconnect or power loss, drive shows as empty or unformatted; partition table missing.Firmware panic and FTL corruption.Mid-write power loss left the FTL mapping table inconsistent; controller refuses to boot the namespace.Firmware Recovery ($900–$1,200)
Drive only connects when the cable is held at a specific angle; USB-C port physically loose.USB-C connector mechanical shearing.Surface-mount anchor pads sheared from PCB by lateral force on the connector.Circuit Board Repair ($900–$1,200)
Common Failure States Of The SanDisk
Common Failure States of the SanDisk Extreme
SanDisk Extreme failures present in several ways depending on the extent of the hardware damage. Disconnect the drive as soon as symptoms appear. Drives with intact internal SSDs typically recover at the Simple Copy ($200) or File System (From $250) tier. Drives with shorted power components require board-level microsoldering and fall into the Circuit Board Repair tier ($900–$1,200).
Intermittent Disconnections
The drive disconnects briefly during large file transfers, then reconnects. Write speeds may throttle below 50 MB/s on a drive rated for 1,050 MB/s. The cracked solder joints on the ASM2362 bridge chip are still making partial contact, but thermal expansion during sustained I/O breaks the connection momentarily. At this stage, the internal SSD & its FTL are usually intact.
Link Downgrade & Read-Only State
The USB link downgrades from USB 3.2 Gen 2 (10 Gbps) to USB 2.0 (480 Mbps) or drops entirely during writes. Some drives enter a read-only state where existing files are visible but new writes fail with "media was unplugged" or "write-protected" errors. The solder joint fractures are widening. The drive can still be read in this state, but each power cycle risks further electrical damage.
Firmware Panic & FTL Corruption
The ASM2362 bridge drops the PCIe link during a write or garbage collection cycle, corrupting the FTL mapping table on the SanDisk NVMe controller. The drive now reports 0 bytes in Windows Disk Management, appears as "55DD SCSI Disk Device," or shows "media not present" in macOS Disk Utility. The USB bridge may still enumerate, but the NVMe namespace is inaccessible. Recovery at this stage requires board-level repair to restore the controller to a bootable state.
Complete Electrical Failure
The drive draws 0 amps on a USB power meter. No LED activity, no USB enumeration. A part on the power path has shorted, cutting supply to both the NVMe controller & the NAND. This can happen when repeated voltage irregularities from the failing bridge stress the power delivery circuit beyond its tolerance. Recovery requires FLIR thermal imaging to locate the shorted component, then component-level replacement with a Hakko FM-2032 on an FM-203 base station.
Why Chip-Off Recovery Fails On SanDisk
Why Chip-Off Recovery Fails on SanDisk Extreme SSDs
Chip-off recovery in general is a documented technique for some SSDs; see our chip-off NAND recovery overview for the cases where it applies. It does not work on the SanDisk Extreme Portable SSD.
The SanDisk NVMe controller uses always-on AES-256 hardware encryption, even if the user never set a password. Removing the BiCS4 NAND chips yields only ciphertext that can't be decrypted without the original controller.
Always-On Encryption: The Controller Key Binding
Every byte written to the 96-layer BiCS4 TLC NAND passes through the controller's AES-256 encryption engine before it reaches the flash cells. This happens at the hardware level, transparently, with negligible performance penalty. The user doesn't configure it. It's active from the moment the drive leaves the factory.
The media encryption key is generated on the controller and wrapped by a key tied to the controller's hardware-unique root. That root is unique to each individual controller chip. ACE Lab has confirmed that this controller encrypts all user data at the hardware level & that chip-off produces no recoverable files.
This is the same encryption architecture used across modern NVMe SSDs implementing TCG Opal or IEEE 1667 security. The SanDisk implementation binds the key to the controller hardware, not to a user password. A dead controller means a dead key. Board-level repair to revive the original controller is the only path that preserves the key relationship & makes the NAND contents readable.
LDPC Error Correction: The Second Barrier
Even if the encryption barrier didn't exist, raw NAND reads from BiCS4 96-layer TLC would be unusable. The controller uses Low-Density Parity-Check (LDPC) error correction codes with controller-specific parameters to compensate for the inherent bit error rates in 3-bit-per-cell TLC NAND.
Between the AES-256 encryption & the LDPC encoding, desoldered NAND chips from a SanDisk Extreme are two layers removed from readable data. No chip-off programmer on the market can reverse either layer without the original controller. Board-level microsoldering to bring the dead controller back to life is the recovery method, not chip removal.
90430VM330 PMIC Failure & Power Delivery
The 90430VM330 Power Management IC regulates voltage rails for both the SanDisk NVMe controller & the BiCS4 NAND array. Repeated voltage irregularities from the failing ASM2362 bridge chip stress the PMIC over time. When it fails, it typically shorts to ground, pulling the power rail to 0V & cutting all power to the internal SSD.
Diagnosing a shorted PMIC is a straightforward procedure with a FLIR thermal camera. We apply controlled voltage to the power rail & watch for abnormal heat signatures. A shorted PMIC draws current & heats up immediately, showing as a bright spot on the thermal image. Replacement uses a Hakko FM-2032 iron on an FM-203 base station with a Zhuo Mao BGA rework station for precision component placement.
After PMIC replacement, the NVMe controller boots with its original encryption keys intact. The NAND contents decrypt normally. This is the board-repair-is-data-recovery principle: reviving the original silicon preserves the cryptographic relationship between controller & NAND. For SanDisk Extreme drives with complete electrical failure, PMIC repair is the entry point before any FTL reconstruction or data imaging can begin.
Inside The Controller
Inside the Controller: What the Firmware Bug Does at the FTL Level
The SanDisk controller is a DRAM-less, 4-channel NVMe controller managing 96-layer BiCS4 TLC NAND. Behind the ASMedia ASM2362 USB bridge, it cannot negotiate Host Memory Buffer (HMB) for L2P mapping storage. Every read and every write goes through a small on-die SRAM that holds only a working subset of the Flash Translation Layer. The rest of the FTL lives in dedicated system blocks on the NAND itself.
The firmware bug Western Digital's May 2023 patch addressed is not a single defect in one routine; it is a class of race conditions between the bridge link state, the SRAM cache flush schedule, and the NAND program/erase pipeline.
The SRAM-Only FTL Window
When a host write arrives, the controller stages it in SRAM, programs it to the SLC write cache band of the NAND, and updates the in-SRAM L2P map. The updated map page is not immediately persisted; it is held in SRAM and flushed to the NAND system area on a scheduled interval or when a flush command arrives from the host. The window between the SRAM update and the NAND flush is where the failure mode lives.
If the ASM2362 bridge drops the link inside that window, two things happen at once: the host never receives completion for the in-flight commands, and the controller never gets to write its updated L2P page to NAND.
On the next power-up, the controller reads the last persisted L2P table from the system blocks, finds it inconsistent with the actual NAND content (because data was written to the cache band but never logged in the map), and refuses to expose the namespace. That is firmware panic.
Pseudo-SLC Cache Exhaustion and the GC Race
On a freshly-formatted Extreme Portable, sustained writes hit the pseudo-SLC cache at 1,050 MB/s. The cache is a portion of the BiCS4 array running in 1-bit-per-cell mode. Once full, the controller starts folding cached data into TLC blocks (three-bit-per- cell) in the background while continuing to accept host writes. This folding is garbage collection. GC reads SLC pages, programs them into TLC pages, and erases the source SLC blocks.
Every GC cycle updates the L2P map. Every L2P update lives in SRAM until the next scheduled flush. During heavy sustained writes, the controller is simultaneously accepting host data, folding cache to TLC, and updating dozens of L2P entries per second. The window for a bridge drop to land inside a non-persisted L2P update is wide.
The patched firmware tightened the flush schedule and added crash-recovery journaling, but the underlying race exists because the bridge can drop at any microsecond and the controller's only persistence path goes through that same bridge for its power supply.
Why the Patch Mitigates But Cannot Eliminate
The May 2023 firmware changes reduce the probability that a bridge link drop translates into a corrupt mapping table. Western Digital did not publish what those changes were at the FTL level, so treat any specific account of the internal fix with suspicion.
They do not change the fact that the bridge will eventually drop again. They do not add DRAM to the controller. They do not give the controller an independent power supply that survives a USB disconnect.
On drives where the bridge has already begun fracturing, the patch arrived too late: the L2P table was already corrupt the moment the controller stopped seeing valid power. See the firmware corruption recovery page for the broader class of FTL failures we encounter on NVMe drives and the lab workflow for diagnosing them.
What We Can And Cannot Recover
What We Can and Cannot Recover In-House for the SanDisk Extreme
Rossmann does not currently offer in-lab recovery for SanDisk in-house NVMe controller firmware reconstruction. That controller is not present on ACELab's PC-3000 SSD supported-controller matrix. There is no commercial Active Utility for automated translator rebuild, module-table repair, or system-area reconstruction on this proprietary Western Digital silicon. Our recovery path for this drive is hardware repair only: USB bridge bypass, microsoldering of the ASM2362 or the 90430VM330 PMIC, USB-C connector reconstruction, and direct NVMe imaging of the internal NVMe SSD through the PC-3000 Portable III adapter.
What We Can Recover
  • Bridge-only failures. ASM2362 cracked solder joints, dead bridge IC, USB-C connector torn from PCB. The internal NVMe SSD is removed from the enclosure and imaged directly via NVMe adapter on the PC-3000 Portable III. This is the most common case and resolves at the Simple Copy ($200) or File System Recovery (From $250) tier.
  • PMIC failure. Shorted 90430VM330 Power Management IC located via FLIR thermal imaging and replaced with a donor part using a Hakko FM-2032 on an FM-203 base. Once stable rails return, the original controller boots with its encryption keys intact. Circuit Board Repair tier ($900–$1,200).
  • Bridge solder reflow or re-alloying. When the bridge IC itself is alive but its solder joints have fractured, we rework the connections under microscope with an Atten 862 hot air station or Zhuo Mao rework station. This is required when the drive used Western Digital's hardware unlock, because the unlock handshake requires the bridge in-circuit. Circuit Board Repair tier ($900–$1,200).
  • Logical recovery after a successful image. Once we have a sector-level image of the internal NVMe SSD, partition table repair, file system metadata reconstruction, and file carving proceed in software against the image file, not the live drive.
What We Cannot Recover
  • FTL reconstruction on SanDisk in-house NVMe silicon. Rossmann does not currently offer in-lab recovery for SanDisk in-house NVMe controller firmware reconstruction. ACELab's PC-3000 SSD support matrix does not list this controller family. No commercial tool can rebuild a corrupt L2P table on this silicon. If the controller is alive but the FTL is corrupt and the drive will not boot its namespace, the recovery depends on bringing the original controller back to a state where it can run its own internal crash-recovery on the next clean power cycle. There is no external translator we can swap in.
  • Chip-off and NAND-only recovery. The SanDisk NVMe controller encrypts every byte with an AES-256 key. Desoldering the BiCS4 NAND chips yields ciphertext that cannot be decrypted without the original controller. The chip-off NAND recovery page covers the SSDs where chip-off is viable; the SanDisk Extreme Portable is not one of them.
  • Remote or software-only recovery. No remote session, no downloadable utility, and no recovery-software license can fix a SanDisk Extreme that fails to enumerate. The repair is physical and requires the drive in our Austin lab.
  • Encrypted drives via bridge bypass. If the user enabled Western Digital's hardware unlock and the bridge IC must be bypassed because it is dead, the internal SSD will not present its data namespace without the bridge in circuit. The bridge has to be repaired, not bypassed, in this configuration.
The capability boundary above is the honest answer to the question that drives most SanDisk Extreme searches. If a vendor promises FTL reconstruction or chip-off recovery on the SanDisk NVMe controller, that promise contradicts the public ACELab support matrix and the controller's own encryption architecture. See the flagship SSD data recovery service page for our full controller-by-controller capability matrix.
Evaluation Path For Affected Owners
What to Do If Your SanDisk Extreme Already Failed
Stop reconnecting the drive. Every plug-in cycle on cracked ASM2362 joints adds thermal and mechanical stress that can turn a partial fracture into a complete open. The drive has to be opened, tested, and imaged at the Austin lab, so this is a mail-in process: there is no diagnostic fee.
The evaluation tells you which of the failure classes above your drive falls into and which tier applies before any paid work starts. Bridge-only failures resolve at the Simple Copy ($200) or File System Recovery (From $250) level; a shorted PMIC or sheared USB-C connector falls in Circuit Board Repair ($900–$1,200). Use the free evaluation request to start, or call (512) 212-9111.
If you are still deciding where to send it, the main SSD data recovery service page lays out our controller-by-controller capability boundary in full, so you can confirm what is and is not possible on the SanDisk NVMe controller before you ship.
RMA Vs Data Recovery
SanDisk Extreme RMA or Data Recovery: Which First?
An RMA replaces the hardware, nothing else. Western Digital ships you a replacement unit and does not return the original failed drive, and it does not recover the data that was on it. If the files matter, recover them before you file the RMA, not after.
Once a drive reaches a manufacturer return center it is not sent back to the owner, so the data goes with it. Neither SanDisk nor Western Digital runs data recovery under the standard limited warranty; that warranty covers a replacement device, not the contents. Western Digital's limited warranty terms put the responsibility to back up and protect data on the owner.
Your situationFirst move
Data is backed up elsewhere, or you do not need itFile the RMA directly and take the replacement unit.
Data matters and the failed drive is the only copyRecover first (mail-in, free evaluation, no data no fee), get written verification, then RMA the empty failed unit.
You already shipped the drive to WD on an RMAThe data left with the drive; the manufacturer does not recover it.
Sending the drive to an independent lab does not automatically void the warranty. The federal Magnuson-Moss Warranty Act bars a manufacturer from voiding a warranty over independent service unless it proves that service caused the damage. The claim that opening the drive voids the warranty does not hold up.
The order of operations when the only copy is on the failed drive is short: recover the data, get the recovery verified in writing on letterhead, then file the RMA for the replacement unit. Start with the free evaluation and the no data, no fee path before you box anything up for Western Digital.
Media Coverage And Class-Action Timeline
Media Coverage and Class-Action Timeline
The SanDisk Extreme failure received coverage from Tom's Hardware, Ars Technica, The Register, PetaPixel, The Verge, and PCWorld. The case is consolidated as In Re: SanDisk SSDs Litigation (Case No. 5:23-cv-04152-RFL) in the Northern District of California under Judge Rita F. Lin. Western Digital's motion to dismiss was partially denied in June 2024; the fraud by omission claim survived. Discovery is active with no settlement reached.
  1. May 2023Western Digital acknowledges firmware issue affecting Extreme and Extreme Pro models. Releases a firmware updater covering affected models across multiple capacities.
  2. Aug 2023Krum v. Western Digital filed (Case No. 5:23-cv-04152, N.D. California). Seeks damages exceeding $5,000,000 on behalf of all U.S. purchasers since January 2023.
  3. Nov 2023Attingo Data Recovery publishes hardware analysis contradicting WD's firmware-only explanation. Identifies oversized components and defective solder joints as root cause. Tom's Hardware, PetaPixel, TechSpot, and Neowin cover the findings.
  4. Dec 2023Court appoints Bursor & Fisher, P.A. and Silver Golub & Teitell LLP as lead counsel for the plaintiff class.
  5. Jun 2024Judge Rita F. Lin partially denies Western Digital's motion to dismiss. Nationwide class claims and the fraud by omission claim survive. WD's argument that firmware updates remedied the defect is rejected.
  6. Late 2024Fact discovery and depositions underway. No settlement announced. The case remains active before Judge Lin in the Northern District of California.
SSD Recovery Calculator
Estimate Your SanDisk Recovery Cost
What type of SSD do you have?
Is the SanDisk Extreme Portable SSD subject to a class-action lawsuit?
Yes. Krum v. Western Digital Technologies, Inc. (Case No. 5:23-cv-04152-RFL, N.D. California) was filed in August 2023 on behalf of all U.S. consumers who purchased SanDisk Extreme, Extreme Pro Portable, or WD My Passport SSD models. In June 2024, Judge Rita F. Lin partially denied Western Digital's motion to dismiss, allowing the fraud by omission claim & nationwide class claims to proceed. Discovery is active with no settlement reached.
Will the Western Digital firmware update recover my lost data?
No. The firmware update released by Western Digital in May 2023 is a preventive measure for drives that have not yet failed. It does not restore data that has already been lost. WD's own update documentation warns that the process itself carries risk of data loss if interrupted. If your drive has already stopped mounting or shows 'disk not readable,' the firmware patch cannot help.
How much does SanDisk Extreme data recovery cost?
Recovery ranges from $200–$2,500 depending on the failure. USB bridge bypass where the internal SSD is intact and mounts cleanly costs $200. Board-level microsoldering to repair cracked solder joints on the bridge chip falls in the $900–$1,200 range. Cases where both the bridge and the internal SSD controller are damaged cost $900–$1,200. No data recovered means no charge.
Is the SanDisk failure caused by firmware or hardware?
Both, but hardware is the root cause. Attingo Data Recovery's analysis (November 2023) identified two manufacturing defects: oversized components that make weak contact with PCB pads, and defective solder joints with internal bubbles that crack under thermal cycling. Western Digital's firmware patch addressed software-level disconnection handling but cannot fix physical solder cracks. Newer production runs added epoxy resin to reinforce solder joints, which confirms Western Digital was aware of the hardware problem.
Which SanDisk Extreme models are affected?
The most commonly affected models are the SanDisk Extreme Portable V2 4TB (SDSSDE61-4T00), Extreme Pro Portable V2 4TB (SDSSDE81-4T00), Extreme Pro Portable V2 2TB (SDSSDE81-2T00), Extreme Pro Portable V2 1TB (SDSSDE81-1T00), and WD My Passport SSD 4TB (WDBAGF0040BGY). Units manufactured after November 2022 appear most susceptible, with the 4TB variants showing the highest failure rates.
Can data recovery software recover my SanDisk Extreme?
In most cases, no. When the USB bridge chip or its solder joints fail, the drive does not enumerate to the operating system at all. Recovery software requires a visible, mountable volume to scan. The drive must be disassembled and the internal NVMe SSD accessed directly, bypassing the failed USB bridge entirely. This requires hardware tools, not software.
What is the difference between reflow and re-alloying repair on the bridge chip?
Reflow reheats the existing solder joints to reform the connections. It is faster but reuses the original defective solder and is considered a temporary fix. Re-alloying removes the ASM2362 bridge chip entirely, cleans the pads on both the PCB and the IC, and applies fresh leaded solder paste. This replaces the factory-defective, void-filled solder with known-good material. For data recovery purposes, reflow is often sufficient because the goal is one successful data extraction, not long-term drive reliability.
Is my data lost forever if my SanDisk SSD won't turn on?
Not necessarily. A SanDisk Extreme that draws 0 amps & shows no LED activity has lost power delivery somewhere on its board, often a shorted part on a power rail. The data on the NAND flash chips is still physically present; it just has no power reaching it. We locate the shorted component using FLIR thermal imaging & replace it with a Hakko FM-2032 microsoldering iron. Once the PMIC is replaced, the NVMe controller boots with its original encryption keys intact & the data becomes accessible. This type of board-level repair falls in the Circuit Board Repair tier ($900–$1,200).
Can SanDisk Extreme firmware be updated after the drive has failed?
No. Western Digital's firmware updater requires the drive to mount as a functional block device through the USB interface. If the ASM2362 bridge chip's solder joints have cracked or the SanDisk NVMe controller has entered a firmware panic state, the drive can't communicate with the updater. The firmware patch was designed as a preventive measure for drives that still function. It can't restore a drive that has already failed, & WD's own documentation warns that the update process itself risks data loss if interrupted.
Why can't chip-off recovery work on SanDisk Extreme SSDs?
The SanDisk NVMe controller uses always-on AES-256 hardware encryption, active even without a user-set password. Desoldering the BiCS4 NAND chips & reading them in an external programmer produces only encrypted data with no way to obtain the decryption key. The controller's LDPC error correction parameters are also proprietary, making raw NAND reads indecipherable even if encryption were bypassed. Recovery instead depends on board-level microsoldering to restore power and signal paths to the original controller, preserving the encryption key relationship.
Why does my SanDisk Extreme get so hot before it fails?
The Extreme Portable enclosure is compact aluminum housing a full NVMe SSD running at PCIe 3.0 x2 throughput. During sustained writes, the pseudo-SLC cache fills within seconds on the 1TB and 2TB units, and the controller falls back to direct TLC programming on the 96-layer BiCS4 NAND. Direct TLC writes generate substantially more heat than SLC-cached writes. The thermal load concentrates on the bridge chip and the SanDisk NVMe controller with no real heatsink path to the outside. Teardown work on these drives ties that cycling, repeated across hundreds of file transfers, to solder joints that crack until conductivity fails; it does not say which chip or board carries the weak joint.
Why does my SanDisk Extreme connect only when I hold the USB-C cable at a certain angle?
Lateral force on the USB-C cable transfers through the connector shell to the four surface-mount anchor pads that secure the receptacle to the PCB. On many failed units, those anchor pads have sheared loose from the board, leaving the connector held only by its data and power pins. Holding the cable at a specific angle temporarily restores contact through the partial connection. The internal NVMe SSD is usually intact in this failure mode. Recovery is either microsoldering to rebuild the USB-C port footprint or removing the internal SSD and imaging it directly through an NVMe adapter.
Does the Western Digital firmware fix tool work on a SanDisk Extreme that already shows 'disk not readable'?
No. The Western Digital firmware updater requires the drive to enumerate as a writeable block device through the USB stack so the utility can deliver the firmware payload through standard storage commands. Once the ASM2362 bridge chip has cracked solder joints or the SanDisk NVMe controller has entered firmware panic, the drive doesn't present a writeable namespace to the operating system. The updater has no path to push new firmware. Western Digital's own documentation warns that an interrupted update can corrupt the firmware and cause total data loss; running it on an already-failing drive can finish what the solder cracks started.
My SanDisk Extreme is not detected by my computer. What should I do first?
Stop plugging it in. Every reconnection attempt on a drive with cracked ASM2362 solder joints applies more thermal and mechanical stress to the failing joints and can push partial fractures into complete electrical opens. Do not run CHKDSK, do not format, do not install driver-repair utilities, do not try a different USB-C cable for the twentieth time. If the drive is not appearing in macOS Disk Utility or Windows Disk Management at all, the failure is hardware (bridge solder, PMIC, or USB-C connector), not driver or filesystem. The repair path is physical: open the enclosure and get to the internal NVMe SSD. On a drive where no hardware unlock was ever configured, the SSD can be imaged directly on an NVMe adapter. Where WD Security was enabled, the bridge has to be repaired rather than bypassed, because the unlock handshake only reaches the SSD through that bridge.
Can I recover a SanDisk Extreme that is not recognized by Disk Utility using recovery software?
No. Recovery software (Disk Drill, EaseUS, R-Studio, PhotoRec, Recuva) operates above the OS storage stack. It requires the drive to enumerate as a block device with a readable LBA range. When the ASMedia ASM2362 bridge chip's solder joints have fractured or the 90430VM330 PMIC has shorted, there is no block device for software to scan. The drive does not appear in /dev/disk on macOS or as a Physical Drive in Windows. Software cannot bridge a physical electrical gap. Worse, sustained reconnection attempts during software scans force the controller into read-retry loops that generate heat and accelerate further solder joint failure.
Why does my SanDisk Extreme freeze during large file transfers before it dies completely?
The Extreme Portable uses pseudo-SLC caching. The cache is a small fraction of the drive's capacity, so a large transfer exhausts it. Once exhausted, the controller falls back to direct triple-level cell (TLC) programming on the 96-layer BiCS4 NAND, which is slower and hotter. The drive thermally throttles to protect the controller, dropping write speeds well below the 1,050 MB/s rating while the ASM2362 bridge chip heats up. Repeated cycles of this thermal load propagate void cracks through the bridge's solder joints. The freeze is the warning sign that the next reconnect may not happen.
Can the SanDisk Extreme firmware fix be applied to a drive that already lost its data?
No. The May 2023 Western Digital firmware patch modifies how the SanDisk NVMe controller handles sudden USB disconnects. It is a preventive software guardrail for drives that still enumerate and still mount. If the drive has already entered firmware panic, lost its partition table, or stopped enumerating, the updater has no protocol path to deliver the payload, and the patch contains no logic for FTL reconstruction or data restoration. Western Digital's documentation explicitly warns that running the update on a drive in an unstable state can complete the data loss. The firmware fix is not a recovery tool.
SanDisk Extreme not mounting?
Free evaluation. $200–$2,500. No data, no fee.
