Western Digital & SanDisk SSD Data Recovery
Western Digital & SanDisk SSDs use proprietary controllers with undocumented firmware and complex flash translation layers. When the controller dies or firmware corrupts, chip-off NAND extraction cannot reconstruct the proprietary FTL mapping. Recovery requires board-level microsoldering to revive the original controller, followed by NVMe diagnostic imaging on the PC-3000 Portable III.
Updated September 2026
WD & SanDisk SSD Symptom Triage
What's Wrong With My WD or SanDisk SSD, & What Does Recovery Cost?
Map the symptom to the fix. A WD or SanDisk SSD that won't show up usually has a dead or panicked controller, not dead NAND, so the data is still there. The table below routes each symptom to its likely cause, the recovery path, & the price tier so you know what you're dealing with before you ship.
What you seeLikely causeRecovery pathPricing tier
Wrong capacity, 0 bytes, "Unknown Device", or a factory alias nameFTL/firmware corruption (controller booted into ROM mode)Firmware-tier recovery where the controller is supported, board repair otherwiseFirmware, $900–$1,200 NVMe / $600–$1,200 SATA
Reads at a few MB/s after sitting unused for monthsTLC charge bleed on stale cells; the drive is otherwise healthyAdaptive read-timeout imaging, no board work neededImaging, from $200 SATA simple copy
Portable drive (My Passport, SanDisk Extreme) dead after the case or USB port failedUSB bridge faultRevive the original bridge through board repairBoard repair, $900–$1,200
Crashes, BSOD, or drops off the bus after a Windows 11 updateDRAM-less Host Memory Buffer allocation mismatchFirmware update if it still enumerates, lab imaging if the FTL already corruptedFree evaluation first
Not sure which row matches your drive? Call (512) 212-9111 or ship it in for a free evaluation, with a firm quote before any paid work & no fee if we can't recover your data. Every WD & SanDisk job runs in-house at our Austin, TX lab on PC-3000 SSD; jump to the full pricing table or read the cost breakdown.
How WD & SanDisk Drives Fail
How Do WD & SanDisk SSDs Fail?
WD & SanDisk SSDs fail differently from other brands because Western Digital designs its own controllers instead of buying off-the-shelf chips from Phison or Silicon Motion. Since acquiring SanDisk in 2016, WD has moved both brands onto shared proprietary silicon & BiCS 3D NAND from its Kioxia joint venture. That vertical integration makes drives cheaper to manufacture but harder to recover when they fail.
Two categories of failure dominate our WD intake. Controller & firmware failures account for the majority: the proprietary controller enters a panic state, the drive drops off the bus, & software can't reach it. The second category is physical: solder defects on portable SanDisk Extreme models, PMIC failures from power surges, & NAND degradation from cell wear. Each requires a different recovery approach & falls into a different pricing tier.
Some WD & SanDisk SSDs, particularly portable models (SanDisk Extreme, My Passport SSD), use mandatory AES-256 hardware encryption. Even on unencrypted NVMe models like the SN770 & SN850X, proprietary flash translation layers and LDPC error correction make raw NAND reads useless without the original controller.
Removing the memory chips won't help on any WD drive. The path to your data is repairing the original controller through board-level microsoldering; see our SSD data recovery service for how hardware encryption affects recovery across all brands.
SanDisk Extreme Portable Failures
What Causes SanDisk Extreme Portable SSD Failures?
SanDisk Extreme Portable V2 & Extreme Pro V2 SSDs have a documented hardware defect that causes sudden disconnection & total data loss. Western Digital attributed the failures to firmware & released patches, but independent lab analysis by Attingo (an Austrian data recovery firm) identified physical solder defects as the root cause.
Attingo's findings: surface-mount components on the PCB are physically too large for their solder pads. The solder paste creates bubbles during reflow, producing brittle joints. Under sustained NVMe write speeds, thermal expansion fractures the joints, severing the electrical connection. Newer production runs shipped with epoxy resin over the affected components, which supports the hardware defect theory even as WD formally denied hardware culpability.
Class-action litigation is active (Krum v. Western Digital, Case No. 5:23-cv-04152, N.D. California). Replacement drives under warranty have exhibited the same defects. Our recovery approach bypasses the USB bridge board, connects the internal NVMe SSD (typically a WD SN550E or SN730E) directly to PC-3000 SSD, & images the NAND through the original controller. Read our full SanDisk Extreme failure analysis for the technical breakdown.
How Much Does WD & SanDisk SSD Recovery Cost?
WD SATA SSD recovery (WD Blue SA510, WD Red SA500, SanDisk Ultra 3D) ranges from $200 for a simple data copy to $1,200–$1,500 for NAND swap cases. WD NVMe recovery (SN770, SN850X, SN550, SanDisk Extreme internals) ranges from $200 to $2,500. Free evaluation. No data, no fee.
WD & SanDisk SATA SSD Pricing
WD & SanDisk NVMe SSD Pricing
Circuit board repair ($450–$600 SATA / $900–$1,200 NVMe) covers component-level microsoldering: replacing failed PMICs, voltage regulators, or shorted capacitors on the original PCB to revive the controller & preserve the encryption key.
NAND swap ($1,200–$1,500 SATA / $1,200–$2,500 NVMe) is reserved for cases where the original PCB is too damaged for repair. 50% deposit required. A donor drive is a matching SSD used for its circuit board. Typical donor cost: $40–$100 for common models, $150–$300 for discontinued or rare controllers.
Rush service: +$100 rush fee to move to the front of the queue. Call (512) 212-9111 for a free evaluation.
Recovery Process
How We Recover Data from WD & SanDisk SSDs
WD & SanDisk recovery follows a five-step process at our Austin, TX lab. All work is performed in-house by the same technician from diagnosis through delivery. No outsourcing, no franchises.
  1. Visual inspection & power analysis. We check the PCB for burned components, cracked solder joints (common on SanDisk Extreme models), & shorted capacitors. FLIR thermal imaging pinpoints any component drawing excess current before we apply full power.
  2. USB bridge bypass (portable drives). SanDisk Extreme & WD My Passport portable SSDs house an internal NVMe drive behind an ASMedia USB bridge chip (ASM2362 or ASM2364). We separate the internal SSD & connect it directly to a native M.2 PCIe slot or PC-3000 adapter, eliminating the bridge as a point of failure.
  3. Controller diagnosis. PC-3000 SSD attempts communication with the WD/SanDisk controller. For Marvell-based drives (WD Red SA500, older SanDisk Ultra 3D), we use the Marvell utility in technological mode. For WD/SanDisk in-house controllers, we attempt managed reads.
  4. Board repair (if controller is dead). When the controller won't initialize, we locate the failed component using FLIR thermal imaging & replace it with a Hakko FM-2032 on an FM-203 base station. Reviving the original controller preserves the AES-256 encryption key.
  5. Imaging & delivery. Once the controller responds, we image every readable sector through PC-3000 SSD, rebuild the file system, verify file integrity, & deliver on your choice of return media.
When Software Can & Cannot Help
Can Data Recovery Software Fix a WD SSD?
Software tools like Disk Drill, EaseUS, PhotoRec, & R-Studio work when the SSD is physically healthy & recognized by your operating system. They handle logical problems: accidental deletion (before TRIM runs), partition corruption, or a formatted volume. That covers a narrow window of failure modes.
Software can't help when the WD controller is dead, the firmware has entered a panic state, or the drive has dropped off the SATA or PCIe bus. A drive that isn't detected in BIOS is invisible to any software running on the operating system. Software also can't help after firmware corruption locks the controller in a permanent busy (BSY) state.
On modern SSDs with TRIM enabled, deleted files stop being readable through software the moment the command reaches the controller. TRIM is on by default on Windows 7 and later; on macOS it is on by default only for Apple-supplied SSDs, so a third-party WD or SanDisk SSD needs TRIM turned on manually with the trimforce command. The OS tells the controller which blocks are no longer needed, & the controller unmaps those logical addresses and leaves the underlying NAND blocks for garbage collection to erase later.
Recovery is possible if TRIM didn't execute: the drive was pulled immediately, TRIM was disabled, or the file system doesn't support TRIM.
WD Proprietary Controller Architecture
WD's Proprietary Controller Architecture
Western Digital abandoned third-party controllers (Marvell, Phison, Silicon Motion) in favor of in-house ARM-based designs after the 2016 SanDisk acquisition. This shift means most modern WD drives use undocumented silicon with no public firmware templates, making recovery dependent on board repair rather than firmware utilities.
The WD Blue SN550, SN570, & WD Green SN350 run four-channel, DRAM-less NVMe silicon paired with BiCS 3D TLC NAND. No external DRAM cache; the FTL relies on a small internal SRAM buffer & Host Memory Buffer (HMB) protocol, borrowing system RAM via DMA. The most common electrical failure on these boards is a shorted Power Management IC (PMIC). When this component fails, the 3.3V input rail reads open circuit & the controller receives no power. FLIR thermal imaging confirms the short before we replace the PMIC using a Hakko FM-2032.
The Triton MP28 drives the WD Black SN750. It includes onboard DRAM for FTL caching & uses 64-layer BiCS3 TLC.
Triton MP28 reaches further than just the SN750 retail model. The same hardware sits under the SN750 Heatsink edition (an EKWB collaboration available up to 2TB), the SanDisk Extreme Pro M.2 NVMe (a parallel SanDisk-branded SKU on the same PCB layout), & the WD PC SN720 OEM module. The controller itself is a tri-core ARM Cortex-R on TSMC 28nm, with eight flash channels at 800 MT/s & four chip enables, paired exclusively with WD/SanDisk 64-layer BiCS3 3D TLC. DRAM topology on the 1TB & 2TB models is SK Hynix DDR4-2400 CL17 (for example, H5AN8G6NAFR-UHC providing 1024 MB of cache on the 1TB). nCache 3.0 carves out a dynamic pSLC zone from the TLC pool (around 14GB on 1TB, around 36GB on 2TB) for burst writes; saturating the cache forces direct TLC writes & a thermal step that, on a stressed PCB, is enough to expose a marginal solder joint or capacitor.
The recovery picture on Triton MP28 is the inverse of the Marvell-era story. PC-3000 Portable III & PC-3000 Express have no Active Utility for the Triton MP28, so firmware-level FTL reconstruction, journal replay, & loader injection are all off the table on this controller today. When an SN750 surfaces with FTL collapse, a Windows "Set Address Failed" Device Manager error, or a refusal to enumerate on the PCIe bus, the lab response shifts entirely to the board. FLIR thermal imaging localizes shorts on the 3.3V, 1.8V, or 1.2V rails. PMIC replacement, capacitor replacement, & voltage-rail short remediation happen on the original PCB using a Hakko FM-2032 on an FM-203 base & an Atten 862 hot air station. If the electrical repair brings the controller back, the drive's own firmware handles translation; if the service-area firmware itself is corrupt on a Triton MP28, the data is currently unrecoverable by commercial labs. Board repair is the only NVMe data recovery path available for NVMe data recovery cases on Triton MP28 drives until ACE Lab releases an Active Utility for WD's in-house controller family.
The WD_BLACK SN750 SE is the exception inside the SN750 family & does not use the Triton MP28 at all. WD released the SN750 SE as a lower-cost PCIe Gen4 part on a foreign controller: the Phison PS5019-E19T, a 4-channel DRAM-less Gen4x4 design that pairs Host Memory Buffer caching with 4th-generation Phison LDPC ECC & optional TCG Opal encryption. NAND on SN750 SE is Kioxia BiCS5 112-layer TLC. Because the SN750 SE rides on Phison silicon, the recovery path is the opposite of the retail SN750. PC-3000 Portable III has a fully supported Phison PS5019-E19T utility for SSD data recovery work: Safe Mode / Test Point boot, microcode loader injection, virtual translator reconstruction, & FTL replay are all available, so firmware-level FTL collapse on an SN750 SE is recoverable inside the lab rather than collapsing to electrical board repair alone. The SN750 SE is on the supported list in our SSD support matrix as a PS5019 device; the retail SN750 is not, because it carries WD's closed in-house silicon. Reading the controller markings under a microscope before quoting is mandatory: an SN750 enclosure with a Phison part underneath is an entirely different job from one with a Triton MP28.
The Polaris MP16+ powers the WD Black SN770 & SN770M. It's a tri-core, four-channel DRAM-less design that relies on HMB for FTL caching, paired with Kioxia BiCS5 112-layer 3D TLC. The multi-step LDPC ECC engine masks early NAND degradation until cell wear reaches a threshold that triggers sudden FTL collapse rather than gradual slowdown.
The WD G2 drives the WD Black SN850X. Unlike the SN770, the SN850X includes dedicated DRAM for FTL caching. A documented ASPM (Active State Power Management) bug in firmware version 620311WD causes the G2 controller to fail PCIe PHY link reinitialization after sleep/wake cycles, rendering the drive invisible to BIOS despite being electrically powered.
The Polaris 3 (A101-000172-A1) is WD's newest controller, powering the WD Blue SN5000 released mid-2024. Fabricated on TSMC's 16nm FinFET process, it's a 4-channel, DRAM-less, PCIe 4.0 x4 design with sequential reads up to 5,150 MB/s. The SN5000 splits across two NAND types: BiCS5 112-layer TLC in capacities up to 2TB & BiCS6 162-layer QLC in the 4TB model. QLC endurance is lower (1,200 TBW for 4TB = 0.16 DWPD over the warranty period), meaning NAND degradation begins earlier & LDPC Tier 3 correction activates sooner than on TLC variants. Recovery difficulty on the 4TB QLC model is higher because the controller's ECC engine is already working at maximum effort by the time the drive fails. Known firmware versions with HMB bugs on SN5000 2TB: 291020WD.
Older WD & SanDisk SATA drives used Marvell 88SS1074 & 88SS9190 controllers (SanDisk Ultra 3D, WD Blue G1, SanDisk Extreme V1). These are well-documented in PC-3000 SSD's Marvell utility, with full technological mode support for terminal access, translator rebuilds, & firmware reconstruction. Recovery on these older drives is straightforward compared to the proprietary in-house family.
Not every drive with a WD or SanDisk label uses WD silicon. Some USB flash drives & external SSDs use third-party controllers. The SanDisk Extreme Go USB drive, for example, uses a Phison PS2308 controller, which has full PC-3000 Phison utility support. Identifying the actual controller inside the enclosure is the first diagnostic step; the brand on the label doesn't always match the silicon on the PCB. Our SSD controller recovery directory maps which utility module covers each controller family.
Marvell 88SS1093 ("Eldora") in Older WD Black & SanDisk PCIe Drives
Before WD pivoted to in-house silicon, the first generation of WD-branded NVMe drives ran on the Marvell 88SS1093, codenamed Eldora. The same controller appeared on the Plextor M8Pe family (M8PeY add-in card, M8PeG with heatsink, M8PeGN bare M.2), the SanDisk A400 NVMe, the Lite-On EP2 & CX2 series with Toshiba 15nm MLC, & on several Lenovo OEM modules including the AM6671 & AM6672. The WD Black Gen 1 paired the 88SS1093 with SanDisk 15nm TLC, making it the first WD-branded client PCIe Gen3 x4 NVMe SSD.
Architecturally, Eldora is a 28nm, tri-core ARM Cortex-R5 design with eight NAND channels, PCIe 3.0 x4, & native NVMe 1.1 (NVMe 1.2 on later firmware builds). The controller supports an onboard DRAM cache; the Plextor M8Pe 512GB pairs it with a 512MB Samsung LPDDR3. Marvell's third-generation NANDEdge LDPC ECC uses soft-decision decoding on cell voltages rather than binary thresholds, which extends endurance on 15nm planar NAND but means a panicked controller will drop to BSY rather than report soft errors.
The technician has to select the exact OEM family & capacity (Plextor M8Pe, WD Black G1, Lenovo AM6671) before injecting the loader; picking the wrong microcode prevents initialization. Unlike the older SATA Marvell 88SS1074 / 88SS9187 / 88SS9189 drives that need a soldered UART terminal connection, the 88SS1093 is an NVMe controller, & PC-3000 Portable III communicates with it natively over the PCIe bus through the M.2 / AIC adapter. Bypassing a BSY state still requires shorting the safe-mode pins at power-on, which forces the tri-core ARM into a ROM-based diagnostic mode so the microcode loader can be injected over PCIe & the FTL reconstructed from NAND. This is the standard ssd data recovery workflow on Marvell-era WD & SanDisk silicon, & it's the reason older drives in this family are usually a much shorter job than anything on WD/SanDisk in-house silicon. See our ssd data recovery service for the broader workflow.
Failure signatures on Eldora drives cluster into three patterns. The drive sticks in BSY within fractions of a second of power-on & never enumerates on the host bus. The 28nm controller package or surrounding PMIC degrades thermally under sustained writes & the drive draws zero power. Or the FTL panics under accumulating NAND wear, the controller drops off PCIe entirely, & the BIOS sees 0 MB.
NAND Interface, ECC, & FTL Architecture
NAND Interface, ECC, & FTL Architecture on WD Controllers
WD's proprietary controllers use Toggle-mode NAND interfaces for bidirectional data transfer between controller & flash dies. This differs from the ONFI interface common on drives using Phison controllers or Silicon Motion recovery procedures. The interface choice matters for recovery because Toggle & ONFI use different timing protocols, pin configurations, & voltage signaling; chip-off tools calibrated for ONFI NAND can't read Toggle-mode dies correctly.
Three-Tiered LDPC Error Correction
WD shifted ECC from software to dedicated hardware blocks within the controller's ARM Cortex-R processor cores. The LDPC engine operates across three correction tiers. Tier 1 applies lightweight correction when the NAND cells are new & bit error rates are low (under 1 error per 10⁸ bits read). Tier 2 engages as cells accumulate P/E cycles & read-disturb errors, running longer decoding iterations on the same hardware. Tier 3 activates near end-of-life, with the Cortex-R cores dedicating full compute cycles to maximum-length LDPC decoding.
This tiered design masks NAND degradation from the host OS until the controller can't correct errors at Tier 3. At that point, drives don't slow down gradually; they fail abruptly as uncorrectable bit errors cascade through the FTL mapping table. For recovery, the LDPC architecture means raw NAND reads without the controller's ECC engine yield compounding uncorrected bit errors. Chip-off on a modern WD NVMe drive produces a dump full of bad pages that no external tool can reconstruct. The controller's own LDPC hardware is the only path to clean reads.
FTL Journal Vulnerability on HMB-Dependent Drives
DRAM-less WD controllers (SN550, SN570, SN580, SN770, SN5000) cache their FTL mapping table in Host Memory Buffer, borrowing 64MB or more of system RAM via PCIe DMA. The FTL map gets flushed back to NAND periodically, but a power loss during an active flush corrupts the journal. The controller boots, finds an inconsistent L2P (logical-to-physical) table, & enters a firmware panic state.
Drives with onboard DRAM (SN750, SN850X) maintain the FTL in local memory & flush it to NAND periodically. The onboard DRAM retains the table long enough for the controller to complete a write cycle in progress, though consumer WD drives lack the dedicated PLP capacitor banks found on enterprise SSDs. HMB drives have no such buffer at all. The system RAM vanishes the instant power drops, & whatever portion of the FTL hadn't been committed to NAND is gone.
Recovery approaches differ by controller family. Phison controllers & Silicon Motion controllers have dedicated PC-3000 "Active Utilities" that can rebuild FTL tables from NAND page metadata. WD's proprietary FTL has no such utility. Recovery on a WD drive with FTL corruption requires reviving the original controller through board-level repair so its own firmware can reconstruct the L2P table from journal fragments stored in the NAND system area. That's firmware-tier pricing: $900–$1,200 for NVMe, $600–$1,200 for SATA. See our SSD controller recovery directory for how PC-3000 support varies across controller families.
How Does SanDisk nCache Caching Fail?
nCache is the proprietary pseudo-SLC (pSLC) caching algorithm that WD and SanDisk use to mask the slow native write speed of TLC and QLC flash. The controller allocates a pool of NAND blocks to operate in 1-bit mode, absorbs incoming host writes into that pool, then folds the data into 3-bit TLC or 4-bit QLC cells during idle time. nCache has been through multiple revisions (2.0, 3.0, and 4.0 on current BiCS5/BiCS6 drives). When the cache pointers or the folding journal are interrupted mid-flush, the FTL comes back inconsistent and the drive drops to a factory alias or disappears from the bus entirely.
Static vs Dynamic Cache Allocation
nCache 4.0 splits the pSLC pool into two zones. The static zone is provisioned outside the user-addressable LBA space and is permanently locked to 1-bit programming. On consumer WD NVMe drives, the static reservation scales with capacity (roughly 6GB static on a 500GB SN850, 12GB on a 1TB). Those blocks see far higher P/E endurance than the surrounding TLC because they only ever hold two voltage states. The dynamic zone scales inversely with how full the drive is: an empty 2TB QLC drive can expose up to 500GB of pSLC because four QLC pages collapse into one pSLC page. As the user fills the drive, the dynamic zone shrinks. Recovery cases coming from a near-full drive look different from a near-empty one because the dynamic pool was much smaller when the failure occurred, and more data was already folded into native TLC or QLC.
Folding Operations and the Performance Cliff
When a sustained write exceeds the combined static and dynamic pSLC pool, the controller has to fold pSLC blocks to TLC or QLC while still accepting new host data. Write throughput collapses from 5,000+ MB/s (pSLC) to 400–500 MB/s (native QLC). The folding operation touches the FTL on every block move, so the drive is at its most exposed during this window. Power loss mid-fold leaves physical NAND blocks containing a mix of new, up-to-date data and old data the controller intended to mark stale. The file system sees that as silent data corruption or unmountable partitions rather than a clean failure.
Sync Points and Journal Fragments
Between full metadata commits, the controller writes a delta journal of L2P changes to reserved system blocks. On a graceful shutdown, the FTL closes cleanly against the last sync point. On an unexpected power loss, the drive boots, walks back to the last sync point, and tries to replay the journal against the surviving NAND state. Consumer WD and SanDisk drives do not carry the capacitor banks found on enterprise SSDs, so nothing keeps the controller alive long enough to finish a flush. If the journal log itself was mid-write when power dropped, the controller reads corrupt delta records, flags the FTL as invalid, and halts the standard boot sequence. The drive reports a raw controller ID in place of its model name, with no usable capacity. Host tools see a device that identifies but offers nothing to read.
Presentation at the Host
nCache corruption typically presents in one of three patterns. First, ROM-mode drop: the drive identifies with a factory descriptor and near-zero capacity as described above. Second, permanent BSY: corrupted metadata loops the controller's background maintenance routine and the drive sits on the bus in a permanent busy state, refusing any ATA or NVMe command. Third, partial mount with stale pages: the FTL loads far enough for the host to see a volume, but the rolled-back journal left a block with mixed-sequence pages. Files appear truncated, headers are garbled, or the volume is mountable read-only. The first two patterns require PC-3000 SSD to intervene at the controller level; the third often allows a direct image but the checksum layer on user files has to be verified against whatever backup or redundancy the customer has.
WD NVMe FTL Corruption
Why Do WD NVMe SSDs Disappear from BIOS?
A WD NVMe SSD that vanishes from BIOS has suffered Flash Translation Layer (FTL) corruption. Power loss during garbage collection or a sudden crash interrupts the controller before it finishes writing the FTL map from volatile RAM back to NAND. The corrupted table causes a firmware panic on next boot.
Unlike SATA drives, which stay on the bus & report an error state (wrong capacity, factory alias like "SATAFIRM S11"), a panicked WD NVMe controller fails PCIe link training entirely. The BIOS sees an empty M.2 slot. The drive physically has power but logically doesn't exist to the system.
A drive in that state is worked on the bench rather than in a production host. When the controller can be brought back far enough to hold a link, imaging runs through the controller itself; when it cannot, the case moves to board-level repair of the underlying electrical failure.
HMB Vulnerabilities
Host Memory Buffer Failures on DRAM-less WD Drives
DRAM-less WD NVMe drives (SN770, SN580, SN5000, SanDisk Extreme M.2) use Host Memory Buffer (HMB) protocol to borrow system RAM for FTL caching. Windows 11 24H2 changed HMB allocation limits, exposing a firmware flaw in WD 2TB models that caused stornvme.sys crashes & BSODs.
HMB drives request a portion of system RAM via DMA. Windows historically limited this to 64MB. The 24H2 update expanded the upper boundary, & WD's firmware on 2TB SN770/SN770M/ SN580 models mishandled the larger allocation. The result: boot loops, blue screens, & in some cases FTL corruption from repeated improper shutdowns during the crash cycle. WD issued emergency firmware fixes through the SanDisk Dashboard utility.
If your WD NVMe drive started crashing after a Windows 11 update, the firmware fix may resolve the BSOD without data loss. If the crash cycle already corrupted the FTL or caused file system damage, the firmware update won't recover your data. Power down, remove the drive, & send it for evaluation. Continued boot attempts stress the controller & risk further corruption.
WD Blue SA510 Firmware Bricking
The WD Blue SA510 SATA SSD suffers from a firmware failure that bricks the drive permanently. The controller (SanDisk A101-000125-B0) enters a panic state & refuses to initialize, reporting 0 bytes or "Unknown Device" in BIOS. No S.M.A.R.T. data, no temperature telemetry, no response to standard ATA commands.
This isn't NAND degradation. The flash cells are intact. The controller's firmware has entered a permanent stall, & the A101-000125-B0 is a proprietary SanDisk design with no public documentation. PC-3000 SSD does not have an active utility for this controller; ACE Lab has confirmed that "native SanDisk controllers are not supported."
Recovery on the SA510 requires a different approach. If the controller has an electrical fault (shorted PMIC, failed voltage regulator), we locate it with FLIR thermal imaging & replace the component using a Hakko FM-2032. If the firmware itself is corrupt but the controller hardware is intact, we attempt to access the NAND through alternative forensic methods. Pricing for SA510 recovery falls in the firmware tier ( $600–$1,200) or board repair tier ( $450–$600) depending on the root cause.
WD Green SN350 & SN3000 OEM Limitations
WD Green SN350 & SN3000 OEM: Endurance & Controller Constraints
The WD Green SN350 carries the proprietary SanDisk Polaris MP16 controller. It's an in-house DRAM-less design that relies on Host Memory Buffer (HMB) to keep the FTL mapping tables in system RAM rather than on the drive. The SN3000 is the Gen4 OEM sibling, built on the same silicon family & sharing the same recovery profile.
Endurance varies wildly inside the SN350 product line. The 960 GB capacity uses 3D TLC NAND. The 1 TB & 2 TB capacities use QLC NAND rated for only 100 TBW; that's roughly one-fifth the write endurance of a typical 1 TB TLC NVMe SSD. The SN3000 OEM variant also ships with QLC. Drives that ride near the TBW limit hit FTL corruption earlier & harder than their TLC siblings.
The dominant failure signature is an abrupt drop off the PCIe bus. The controller stops responding to link training, the M.2 slot reads as empty, & Windows reports the drive as missing rather than as a degraded device. The HMB dependency makes this worse: when the controller panics, the FTL state held in host RAM is lost the moment the system reboots.
Rossmann does not currently offer in-lab recovery for the WD Green SN350 or SN3000. ACELab's PC-3000 SSD has no Active Utility for this controller, so firmware-level FTL repair, virtual translator rebuild, & raw NAND remapping are not options. When the SN350 or SN3000 enters a permanent panic state, the only paths we can offer are electrical board repair (failed PMICs, voltage rails, shorted capacitors) on the original PCB & non-destructive imaging if the controller ever returns to the bus.
Pricing for any work we can perform on these drives falls in the standard NVMe board repair tier ($900–$1,200) when the fault is electrical. We quote firm pricing after evaluation; if the controller is dead & firmware repair is the only viable path, we'll tell you that up front rather than start work that won't finish. A donor drive is a matching SSD used for its circuit board. Typical donor cost: $40–$100 for common models, $150–$300 for discontinued or rare controllers.
WD Dashboard Diagnostic Risks
Why WD Dashboard & SanDisk Dashboard Are Dangerous on a Failing Drive
WD Dashboard, the newer WD Kitfox utility, & the SanDisk Dashboard are consumer-grade tools for monitoring drive health, viewing S.M.A.R.T. telemetry, & pushing firmware updates from the OS. On a healthy drive they're fine. On a drive that's already showing failure signs, two specific Dashboard actions are destructive to recoverable data.
The first risk is the Extended Diagnostic scan. That routine performs a full surface read across the entire LBA range looking for media errors. On a drive that's actively failing, subjecting the controller & degraded NAND to a sustained, intensive read sweep can push the controller over the edge into total failure: a read-only lockout, a panic loop, or a drop off the PCIe bus. The Extended Diagnostic isn't the only Dashboard action to avoid on a failing drive. The separate Performance Optimization / Erase utility acts on unallocated blocks, leaving them queued for the controller's next garbage collection pass; once that pass erases a block, the charge is gone. Treat both functions as hostile to recoverable data on a drive that's already showing failure signs.
The second risk is firmware flashing. WD pushes patches through Dashboard; firmware version 620331WD for the WD Black SN850X is a documented example, released to address the ASPM sleep-wake lockout. The flash itself writes the new binary into a controller firmware slot & triggers a controller reset to activate it. On a drive with marginal NAND or an unstable controller, the reset is where things go wrong: the controller may fail to reload its existing FTL into RAM after the reset, hang during enumeration, or drop off the PCIe bus entirely. The update doesn't erase the FTL; the degraded controller simply fails to remount it, & the host can no longer talk to the drive.
Dashboard does not perform FTL repair. It does not access the controller's service area. It does not issue vendor-specific commands to bypass a stalled controller. It talks to the drive through the host OS driver stack; if the drive has dropped off the bus, Dashboard sees nothing & can do nothing.
If your WD or SanDisk SSD is showing failure signs:
  • Do not run Extended Diagnostics in WD Dashboard or SanDisk Dashboard.
  • Do not accept firmware update prompts from Dashboard or Kitfox.
  • Do not run consumer recovery software against the live drive; image first.
  • Stop writing to the drive. Capture S.M.A.R.T. output once with smartctl -a, then power the drive down until it can be imaged in a lab environment.
WD My Passport, Elements SE & Easystore Bridge Architecture
WD My Passport SSD, Elements SE & Easystore: What's Actually Inside
Owners routinely conflate WD's portable lines. They share enclosures, branding, & even cable types, but the internal architecture differs sharply across product lines & that difference dictates whether a dead enclosure means your data is still reachable.
WD My Passport SSD (2020 & later)
The current My Passport SSD houses a WD Blue SN550E NVMe drive bridged to USB through an ASMedia ASM2362 USB 3.2 Gen 2 to PCIe Gen 3 x2 NVMe controller. AES-256 hardware encryption is active by default, even if you never set a password. The encryption engine sits on the internal drive's NVMe controller, & the ASM2362 bridge relays Western Digital's vendor-unique unlock command to it. Pulling the SN550E out of the enclosure & dropping it into a desktop M.2 slot yields a locked, unreadable volume; a standard M.2 host never sends that unlock handshake, so the OS sees a drive of the correct capacity that refuses to mount.
Recovery on a dead My Passport SSD enclosure requires reviving the original ASM2362 bridge so the decryption handshake can complete on boot. That's board-level repair on the bridge PCB: locating the failed component with FLIR thermal imaging, replacing the failed regulator or bridge IC under microscope with a Hakko FM-2032, & re-pairing the bridge to the internal NVMe drive. Pricing falls in the NVMe board repair tier ($900–$1,200); a donor enclosure of the same model is sometimes required. A donor drive is a matching SSD used for its circuit board. Typical donor cost: $40–$100 for common models, $150–$300 for discontinued or rare controllers.
WD Elements SE SSD & older portable models
The Elements SE line & older portable SSD revisions typically use standard USB-to-SATA or USB-to-NVMe bridge silicon: JMicron JMS578, JMS580, or JMS583 on SATA-based variants, & Realtek RTL9210 on some NVMe variants. These bridges generally do not bind hardware encryption to the bridge silicon. When the bridge or USB port dies on an Elements SE, the internal drive can usually be connected directly to a SATA or M.2 host & imaged through the normal SATA or NVMe path. The recovery profile collapses to whatever's wrong with the internal drive itself rather than the enclosure.
WD Easystore: not an SSD product line
WD Easystore is predominantly a portable HDD product family sold through big-box retail. If you have an Easystore that's failing, the device inside is almost certainly a 2.5" SMR or CMR mechanical drive (commonly a shucked WD Blue or WD Red), not an SSD. The procedures on this page do not apply. Failure modes, recovery tooling, & pricing for Easystore HDDs are different; see our external hard drive recovery service for the correct workflow.
Diagnostic split: where is the actual fault?
Three distinct fault locations produce nearly identical customer-facing symptoms on every portable WD SSD: a damaged USB-C port on the enclosure, a failed bridge IC on the enclosure PCB, & an internal NVMe or SATA drive that's dropped off its own bus. The recovery path is different for each. Port damage often resolves with connector replacement under microscope. Bridge failure requires board repair on the bridge PCB, & on My Passport SSD that path is usually the only path to your data because the internal drive's AES-256 lock is cleared only through the vendor-unique unlock handshake the bridge relays. Internal drive failure means the bridge is fine & the work shifts to the NVMe or SATA SSD inside.
SanDisk Extreme Pro Portable V2 (E81) Bridge Architecture
SanDisk Extreme Pro Portable SSD V2 (E81): ASM2364 Bridge Over an Internal PC SN730E
The Extreme Pro Portable V2 (model prefix E81 / SDSSDE81) is built around an ASMedia ASM2364 USB 3.2 Gen 2x2 bridge wrapped around a discrete M.2 NVMe module: SanDisk's PC SN730E, an 8-channel DRAM-based in-house WD controller on BiCS4 96-layer TLC. The SN730E is not in ACELab's PC-3000 SSD supported list. Rossmann does not currently offer in-lab recovery for SanDisk PC SN730E. When the failure is on the bridge side, we can sometimes revive the ASM2364 path through board repair so the internal module re-enumerates; when the SN730E itself is the fault, recovery on the controller side is limited to electrical board work.
Two boards, two failure surfaces
The standard SanDisk Extreme V2 (E61) is a monolithic build: bridge IC, controller, & NAND all sit on a single PCB inside the rugged shell. The Extreme Pro Portable V2 (E81) is a different design entirely. The aluminum chassis houses a USB-C bridge PCB carrying the ASMedia ASM2364, which translates PCIe 3.0 x4 NVMe to USB 3.2 Gen 2x2 at up to 20 Gbps. The bridge connects to a discrete M.2 2280 NVMe module that is itself a full WD client SSD: the PC SN730E. That module is functionally identical to an OEM laptop NVMe drive (multi-core controller, onboard DDR4, BiCS4 96-layer TLC NAND) bonded into a portable enclosure rather than soldered into a laptop.
Two boards means two distinct failure surfaces. A dead enclosure on an E81 does not automatically mean the data is gone; it depends on which board failed.
Bridge IC failure: ASM2364 path
When the ASM2364 dies (USB-C port damage, regulator short, ESD strike, bridge logic fault), the host computer sees no enumeration on the USB bus even though the internal SN730E is electrically healthy. The recovery vector is to bypass the bridge entirely: extract the internal M.2 module & interface with it as a native PCIe NVMe drive through a desktop M.2 slot or a PC-3000 SSD test bench. That sidesteps the dead bridge silicon, the dead USB port, & any bridge-side firmware state.
Extracting the internal module is the hard part. SanDisk bonds the M.2 to the forged-aluminum chassis with industrial adhesive & a thermal compound layer; the chassis is the heatsink, & the bond is engineered for ruggedization, not serviceability. Pulling the module without controlled heat will flex the PCB substrate & fracture the BGA solder joints under the SN730E controller. The correct technique is targeted thermal application at low flow with an Atten 862, localized solvent (isopropyl alcohol or D-limonene) at the adhesive seam, & gentle planar separation rather than prying. Once the SN730E is free, it images through the standard NVMe path.
Internal SN730E failure: limits on this silicon
If diagnostics determine the bridge is fine but the SN730E itself has stalled (firmware panic, PMIC short, FTL corruption), the workflow shifts to standard NVMe controller recovery. The SN730E natively supports TCG Opal AES-256 hardware encryption (the same feature that powers SanDisk SecureAccess password protection) & the key material is bound to the controller silicon. That binding makes chip-off recovery unviable: lifting the BiCS4 NAND yields ciphertext only, with no key path. The recovery must come through the original controller.
The PC SN730E is a WD in-house controller & sits outside ACELab's PC-3000 SSD supported list. Rossmann does not currently offer in-lab recovery for SanDisk PC SN730E. Firmware-tier reconstruction is not available on this silicon. When the controller stalls electrically but the silicon is intact, board-level repair to revive the failed PMIC or voltage rail under FLIR thermal localization & microsolder rework with a Hakko FM-2032 on an FM-203 base can sometimes bring the controller back online so its own firmware reconstructs the L2P state on next boot.
Diagnostic fork on intake
First step on every E81 that comes in is identifying which of the two boards failed. That dictates the entire downstream recovery quote. Indicators that the ASM2364 bridge is at fault: drive does not enumerate on USB at all, USB-C port shows mechanical damage, or the device appears intermittently on insertion. Indicators that the internal SN730E is at fault: the bridge enumerates over USB but the drive reports zero capacity, the device shows up & immediately drops with NVMe link-down errors, or the host sees the device but cannot complete any read. Pricing on E81 work follows the NVMe range: $200–$2,500. Board repair tier on a failed bridge: $900–$1,200. A donor drive is a matching SSD used for its circuit board. Typical donor cost: $40–$100 for common models, $150–$300 for discontinued or rare controllers.
NVMe SMART Attributes For WD & SanDisk
NVMe S.M.A.R.T. Attributes That Predict WD & SanDisk SSD Failure
NVMe drives expose health telemetry through the SMART / Health Information log page, not through the legacy SATA SMART attribute table. Four bytes in that log are worth watching on any WD or SanDisk NVMe SSD; if any of them trip the thresholds below, the drive should be imaged before anything else is done with it.
ByteAttributeWhat it meansImaging trigger
0x00Critical Warning bitmaskBit 0 spare below threshold, Bit 1 thermal threshold exceeded, Bit 2 reliability degraded, Bit 3 drive entered read-only mode, Bit 4 volatile memory backup (PLP) failed.Any non-zero value. Bits 0, 2, or 3 set means image immediately.
0x03Available SparePercentage (0 to 100) of over-provisioned spare NAND remaining for bad block remapping.Trending toward the threshold byte; image before it hits the floor.
0x04Available Spare ThresholdThe vendor floor for Available Spare. Default on WD & SanDisk consumer drives is around 10%.When 0x03 crosses below 0x04, Bit 0 of Critical Warning trips.
0x05Percentage UsedEstimated endurance consumed. Can exceed 100; at 100 the drive may transition to read-only on next firmware initialization.Anything at or above 100, especially on low-TBW QLC drives such as 1 TB & 2 TB SN350.
Read the log on Windows with smartctl -a -d nvme /dev/nvme0 from the Smartmontools package, or with the WD Dashboard health view (read-only viewing is safe; do not run Extended Diagnostics on a failing drive per the section above). On macOS use nvme smart-log /dev/nvme0 after installing nvme-cli. On Linux the same command works without extra setup.
A drive that's tripped Bit 0, Bit 2, or Bit 3 of Critical Warning is reporting that its own firmware no longer trusts the NAND or the controller. That state is unstable; every additional power cycle is a roll of the dice. Capture the SMART log once, image the drive end-to-end with adaptive read-timeout tuning, & only then decide what to do with the imaged data. Imaging is the cheap, reversible step; everything after it is more expensive & riskier.
Why Is My WD Blue 3D Reading Files at 5 MB/s?
A WD Blue 3D SATA SSD that used to read at 500+ MB/s & now drags through the same files at 5 MB/s isn't dying in the way most owners assume. The drive is healthy. The files are intact. What's happening is TLC charge bleed on stagnant data. Floating-gate voltages drift over time on cells that haven't been refreshed by the controller's background scan, & the LDPC engine has to re-read the same page repeatedly at shifted reference voltages to reconstruct the bits. Every retry eats wall-clock time, & the effective read rate collapses.
That puts this firmly in recovery territory rather than the dead-drive bin. The correct response is sector-by-sector imaging with adaptive read-timeout tuning so the controller doesn't panic before the LDPC engine finishes its retries. PC-3000 SSD's imaging utility lets us extend per-sector timeouts & pull a clean image one block at a time, then restore the data to fresh media. This is the standard SATA SSD recovery workflow for charge-bleed cases & it falls in the imaging tier rather than the firmware or board-repair tiers.
A separate, related issue worth knowing about: Synology DSM 7 misparsed WD's SMART attribute 230 (Media_Wearout_Indicator) on certain WD Blue 3D firmware revisions. WD counts that attribute up from 1 toward 100; the smartmontools database underneath DSM 7 read the same value as a count-down from 100, so a healthy drive showing "1" got flagged as "1% lifespan remaining" when it actually meant "1% wear utilized." That's a software parsing bug, not a recovery case. We mention this so customers don't ship healthy drives in panic.
For clarity: there is no programmed power-on-hours hard-lock on consumer WD Blue 3D SATA or NVMe drives. The 32,768-hour & 40,000-hour catastrophic-failure bugs widely reported in trade press are a different product family, the SanDisk-built enterprise SAS SSDs deployed by HPE & Dell EMC. Those advisories don't apply to consumer WD Blue 3D drives, & conflating the two is a common source of misdirected diagnostics.
Why Marvell-Era WD/SanDisk Drives Recover & In-House Drives Often Don't
The Marvell-licensed era ran on modular silicon. Marvell sold the bare 88SS1074 or 88SS1093 to anyone who wanted to ship a drive, & SanDisk, WD, Plextor, Lite-On, & Lenovo each wrote their own FTL on top. Common silicon meant common pinouts: UART pads in the same physical position, JTAG taps wired to the same controller pins, safe-mode shorts that put the same tri-core ARM into the same ROM diagnostic mode no matter which OEM had labeled the case. ACE Lab reverse-engineered that command surface once & shipped a utility that worked across the entire OEM lineup. Translator rebuilds & journal replays are possible on these drives because the underlying VSC command set is bound to the Marvell silicon, not to whichever firmware engineer happened to write the FTL.
The post-2016 WD/SanDisk in-house era runs on monolithic silicon. The same vendor designs the controller & fabricates the NAND, & ACE Lab lists no tech-mode utility for these controllers. When the firmware corrupts on one of these drives, recovery collapses to electrical board repair only: revive the controller hardware (PMIC swap, capacitor work, voltage-rail short remediation under FLIR) so its own firmware can rebuild the FTL itself on next boot. There is no software path around a dead firmware on this generation.
That split is why we quote two recovery paths on a WD drive: one estimate for board repair, & a separate estimate for firmware-tier work, with which one applies depending on which controller family is on the PCB.
WD SN850X ASPM Firmware Bug
WD Black SN850X ASPM Firmware Failure
The WD Black SN850X running firmware version 620311WD contains a documented defect in its Active State Power Management (ASPM) transition logic. The WD G2 controller fails to exit low-power states cleanly after the host PC enters sleep or performs a cold boot.
During wake, ASPM instructs the NVMe controller to reinitialize from its low-power state. The G2 controller hits a timing error in the PCIe PHY link training sequence & enters an infinite fault loop. The drive stays powered but fails link negotiation entirely. BIOS reports an empty M.2 slot. Unlike FTL corruption, the NAND data is intact; the controller simply can't establish communication with the host.
The 4TB SN850X variant (WDS400T2X0E) carries an additional risk. It's a double-sided M.2 module; in tight laptop M.2 slots, the extra thickness causes board flex that fractures BGA solder balls under the controller or NAND packages. Recovery on a physically flexed board requires BGA rework with a Zhuo Mao precision rework station before the controller can be brought back online for PC-3000 imaging.
A stalled G2 controller is enumerated on a dedicated PCIe diagnostic port on the PC-3000 Portable III rather than in a production slot, so each attempt happens under bench control & can be repeated after every repair step. Firmware recovery pricing: $900–$1,200. Board repair for BGA fractures: $900–$1,200. A donor drive is a matching SSD used for its circuit board. Typical donor cost: $40–$100 for common models, $150–$300 for discontinued or rare controllers.
WD Black SN770 Polaris MP16+ & Win 11 24H2 HMB Failure
WD Black SN770: Polaris MP16+ Silicon & the 200 MB HMB Overflow
The SN770 runs on the SanDisk Polaris MP16+ controller, a DRAM-less in-house WD design that is not in ACELab's PC-3000 SSD supported list. Rossmann does not currently offer in-lab recovery for the WD Black SN770. When the controller silicon is intact & the failure is electrical (PMIC short, blown decoupling, dead voltage rail), we can sometimes revive the drive through board-level repair so the original firmware completes the FTL rebuild itself. There is no software path around dead Polaris MP16+ firmware.
What's actually on the SN770 PCB
The SN770 shipped in February 2022 as WD's mid-range Gen4x4 NVMe. Underneath the label, it is a tri-core ARM, 4-channel design fabricated on TSMC's 16nm FinFET process, known internally as Polaris MP16+. Unlike the SN850X, there is no onboard DDR4 cache; the FTL mapping tables live in host RAM through the NVMe Host Memory Buffer (HMB) protocol, with the controller firmware hardcoded to request exactly 64 MB. NAND is Kioxia BiCS5 112-layer 3D TLC clocked at 1,200 MT/s, with Circuitry Under Array reducing power draw by roughly 40% versus BiCS4.
Windows 11 24H2 HMB allocation mismatch
Windows 11 version 24H2 shipped a revised StorNVMe driver that raises the default HMB request toward 200 MB (with some configurations attempting up to 256 MB). The SN770 firmware is strictly coded around a 64 MB ceiling. When the host pushes a buffer larger than the controller's map can accept, the controller stalls mid-operation & drops off the PCIe bus. From the OS side that looks like sudden system instability, & a reboot typically yields one of three end states: the motherboard's M.2 polling reports an empty slot, the drive enumerates but shows up in Disk Management as a 0-byte RAW volume, or Windows fails to boot at all with INACCESSIBLE_BOOT_DEVICE or CRITICAL_PROCESS_DIED.
WD published firmware 731130WD, delivered through the SanDisk / WD Dashboard, that widens the controller's acceptable HMB range. The patch only helps drives that still enumerate. If the FTL has already panicked & the drive has dropped off the bus, Dashboard cannot see the device, the update never runs, & even a successful firmware flash would not restore the L2P state that was lost when the controller stalled. The firmware update is a forward fix, not a recovery tool.
What you should & should not do before sending it in
  • Stop using the machine. Every additional boot attempt against a panicked controller risks pushing a partially-mounted FTL into a worse state.
  • Do not accept Dashboard's prompt to run Extended Diagnostics or to re-flash firmware against a drive that is dropping off the bus.
  • Do not run consumer recovery software (Disk Drill, EaseUS, R-Studio) against the live drive. Those tools work on logical failures on healthy hardware; they cannot talk to a controller that is not completing PCIe link training.
  • Capture S.M.A.R.T. output once with smartctl -a if the drive still enumerates, then power it down until it can be imaged.
Firmware-tier recovery limits on Polaris MP16+
The Polaris MP16+ does not have a dedicated PC-3000 SSD active utility. PC-3000 cannot inject a custom loader, rebuild the translator from journal deltas, or read raw NAND pages through the controller's hardware abstraction layer the way it can on a Marvell 88SS1074. When the controller is silent on the bus & the electrical path is intact, the drive is at the limit of what any current lab can offer on this silicon. Pricing on cases where board repair is viable falls into the NVMe board repair tier: $900–$1,200. A donor drive is a matching SSD used for its circuit board. Typical donor cost: $40–$100 for common models, $150–$300 for discontinued or rare controllers.
WD Green Vs Blue Vs Black
WD Green vs Blue vs Black: Recovery Complexity by Tier
Western Digital sells SSDs across four product tiers: Green (budget), Blue (mainstream), Black (enthusiast), & Red (NAS/server). Each tier uses different controller silicon, NAND grades, & caching architectures. Recovery difficulty & pricing vary per tier.
TierModelsControllerDRAMRecovery Notes
GreenSN350SanDisk in-houseNo (HMB)Budget TLC NAND (higher capacities may use QLC). PC-3000 lacks tech-mode support for SN350 firmware. If the controller panics & PMIC is intact, recovery options are limited to board-level electrical repair.
BlueSN550, SN570, SN580, SN5000, SA510 (SATA)SanDisk in-house (SN550/SN570), Polaris MP16+ (SN580), Polaris 3 A101-000172-A1 (SN5000), A101-000125-B0 (SA510)No (HMB on NVMe)Prone to PMIC shorts (NVMe) & firmware bricking (SA510 SATA). SN5000 4TB uses QLC NAND (BiCS6 162-layer) with 0.16 DWPD endurance; TLC variants use BiCS5. SA510 has no PC-3000 utility. SN5000 2TB HMB bug: firmware 291020WD.
BlackSN750, SN770, SN850XTriton MP28, Polaris MP16+, WD G2SN750/SN850X: Yes. SN770: NoDocumented firmware bugs: ASPM fault loop on SN850X (620311WD), HMB allocation panic on SN770 (Win 11 24H2). Stalled G2 controllers are enumerated on a PC-3000 Portable III diagnostic port rather than a production slot.
RedSA500 (SATA)Marvell 88SS1074YesZFS TRIM timeout causes bus dropouts behind LSI HBAs. PC-3000 Marvell utility provides full technological mode support. Recovery is straightforward unless part of a degraded RAID/ZFS pool.
Green & Blue NVMe drives are the hardest to recover because they run SanDisk in-house silicon with no PC-3000 firmware-level support. Black drives have known firmware bugs, but the bugs are documented. Red drives use Marvell silicon with full PC-3000 utility support. SATA SSD pricing: $200–$1,500. NVMe pricing: $200–$2,500.
PC-3000 Recovery Capabilities
PC-3000 SSD Support for WD & SanDisk Drives
PC-3000 SSD support for WD & SanDisk is split. Older Marvell-based drives have full technological mode support with terminal access, translator rebuilds, & firmware reconstruction. Modern proprietary controllers lack dedicated utilities, limiting recovery to managed reads & board-level repair.
Supported (Marvell-Based)
  • Marvell 88SS1074: WD Red SA500 (early models), SanDisk Ultra 3D, SanDisk SSD Plus, SanDisk Extreme V1. Full PC-3000 Marvell utility: terminal TX/RX connection, translator rebuild, safe mode entry.
  • Marvell 88SS9190: SanDisk Ultra II, SanDisk SSD Plus (older revisions). Supported through the same Marvell utility.
Limited Support (Proprietary)
  • SanDisk in-house NVMe: WD Blue SN550, SN570, WD Green SN350. No firmware-level FTL reconstruction is available.
  • SanDisk A101-000125-B0: WD Blue SA510. Unsupported. ACE Lab confirms native SanDisk controllers lack active utility modules.
  • WD proprietary (SN770, SN850X): No dedicated firmware repair capability.
When PC-3000's software utilities can't help, recovery shifts to hardware. We repair the controller electrically (replacing failed PMICs, reflowing BGA connections with a Zhuo Mao rework station), bring the original silicon back online, & image through the now-functional controller. This preserves the hardware encryption key that would be lost in a chip-off approach.
BiCS NAND Generation Map by WD & SanDisk Family
Western Digital & Kioxia co-develop the BiCS (Bit Cost Scaling) 3D NAND used in every modern WD- & SanDisk-branded SSD. Knowing which BiCS generation sits inside a specific drive matters for recovery because LDPC parameters, page sizes, & read-voltage shift behavior all change with layer count.
A chip-off reader has to be loaded with the correct profile for the specific BiCS generation; a profile built for BiCS3 64-layer TLC will not decode BiCS6 162-layer QLC pages, & vice versa. When a drive comes in with stripped silkscreen markings, the family-to-NAND map below is the first cross-reference before deciding which recovery tooling applies.
Model FamilyCapacityControllerBiCS GenerationNAND Architecture
WD Blue SN550AllWD in-houseBiCS496-layer TLC
WD Blue SN570AllWD in-houseBiCS5112-layer TLC
WD Blue SN580AllWD in-house (Polaris MP16+)BiCS5112-layer TLC
WD Blue SN5000500 GB – 2 TBWD Polaris 3 A101-000172-A1BiCS5112-layer TLC
WD Blue SN50004 TBWD Polaris 3 A101-000172-A1BiCS6162-layer QLC
WD Blue SN5100AllWD in-houseBiCS8218-layer QLC
WD Black SN750AllWD in-house (Triton MP28)BiCS3 / BiCS464-layer / 96-layer TLC
WD Black SN770AllWD in-house (Polaris MP16+)BiCS5112-layer TLC
WD Black SN850X1 TB – 4 TBWD G2BiCS5112-layer TLC
WD Black SN850X8 TBWD in-houseBiCS6162-layer TLC
SanDisk PC SN730EAllWD in-houseBiCS496-layer TLC
BiCS5 introduced quad-plane architecture & Circuitry Under Array (CUA), letting the controller schedule four concurrent operations per die. BiCS6 stepped to 162 layers & widened the use of QLC for high-capacity SKUs; QLC drives like the 4 TB SN5000 burn through endurance margin faster, so by the time a customer notices symptoms the LDPC engine is usually already running at the highest correction tier. BiCS8 at 218 layers is the current shipping density on the SN5100.
None of the WD in-house controllers in the table above are in ACELab's PC-3000 SSD supported list. Rossmann does not currently offer in-lab recovery for WD or SanDisk in-house NVMe controllers. Rossmann does not currently offer in-lab recovery for WD Polaris 3 A101-000172-A1. Rossmann does not currently offer in-lab recovery for SanDisk PC SN730E. When one of these drives fails on the controller side, the only path we can offer is electrical board repair to revive the original silicon so its own firmware can rebuild the FTL on next boot. NVMe pricing: $200–$2,500. SATA pricing: $200–$1,500.
PC-3000 Safe Mode Entry and Translator Rebuild on Marvell SanDisk Drives
When a SanDisk Ultra 3D or an early WD Red SA500 running the Marvell 88SS1074 controller drops into a factory alias or a permanent BSY state, the SATA command set is useless. The controller ignores host commands because its own FTL is corrupt. Standard imaging tools report "Drive not ready" or time out. The recovery path is to bypass the SATA bus entirely and talk to the controller through its UART diagnostic port, force it into a loader state, and rebuild the translator in PC-3000's workstation RAM.
UART Terminal Access on 88SS1074
Because every OEM designs a new PCB around the silicon, the RX and TX test pads and the ground reference are in a different location on each drive model. The first step is identifying the correct pads on the PCB under stereo magnification and confirming them against ACE Lab's parameter database for the specific drive variant. Thin-gauge magnet wire is microsoldered to the pads with a Hakko FM-2032 on an FM-203 base using low-residue flux.
Voltage level matters. Older Marvell 88SS9189 and 88SS9190 controllers used 3.3V UART logic. The 88SS1074 dropped to 1.8V for its internal SRAM and terminal bus. Connecting a 3.3V terminal adapter (the one labeled "Terminal 2" on a PC-3000 kit) to a 1.8V controller damages the UART pins. The correct adapter is the Terminal 3 module, which level-shifts to 1.8V. The adapter plugs into the PC-3000 Express or Portable III workstation and the wires on the drive side land on RX/TX/GND. The terminal log should print readable ASCII boot chatter once power is applied; garbled characters usually mean the baud rate parameter is wrong or the voltage level is mismatched.
Safe Mode via VSC Injection
With the terminal connected, PC-3000's Marvell utility injects a sequence of Vendor-Specific Commands that halt the drive's standard boot right before the FTL load stage. The controller stops trying to mount the corrupted translator from NAND and parks in a minimal state where its RAM is writable from the host side. A custom volatile microcode loader is uploaded directly into the 88SS1074's RAM, temporarily replacing the corrupted firmware. The loader gives PC-3000 raw read access to the NAND through the controller's hardware abstraction layer without ever invoking the broken FTL. Because the microcode is volatile, cutting power restores the drive to its original panicked state, so the entire imaging session has to complete in one continuous power cycle.
Thermal manipulation is often part of this stage. Degraded NAND cells shift their threshold voltages with temperature, and read stability on a dying 88SS1074 drive can swing by hundreds of millivolts between ambient and 40–50°C. We apply targeted heat from an Atten 862 hot-air station at low flow, or chill the controller with freeze spray, to find the thermal band where the loader can maintain clean reads long enough to finish the dump.
Translator Rebuild: Journal Replay vs Full NAND Scan
With raw NAND access established, the FTL has to be reconstructed as a virtual translator in RAM on the drive itself. PC-3000 picks one of two workflows depending on what survived in the service area.
Journal Replay is the preferred path. The utility reads the service area blocks (hidden from the host, holding the factory defect list, the firmware modules, and the FTL delta journals), extracts the surviving journals, and replays them in RAM on the drive itself. Each journal entry is a delta record: a small ledger of L2P changes since the last full commit. Replayed in order, they reconstruct the L2P table state right up to the moment of failure. For the 88SS1074, this has to be compiled per STAR (Marvell's internal name for each memory bank and channel grouping); a drive with eight NAND dies across two channels might have four STARs that all need independent journals walked. Journal Replay typically produces a complete file system tree with intact directory structure and is the faster path.
Full NAND Scan is the fallback when the service area journals were overwritten during a panicked folding event or physically damaged. Every NAND page carries an out-of-band (OOB) spare area of 64 to 128 bytes that the controller populates on write. The spare area holds the page's LBA tag, a block sequence number, and wear-leveling counter. PC-3000 reads the spare area across every physical page on every die (tens of millions of pages on a 1TB drive), parses the hex, and builds a global list of every LBA tag and which physical page claims it. Because SSDs do out-of-place writes, the same LBA often appears on dozens of different physical pages (old copies that were never garbage collected). The utility compares block sequence numbers, discards the stale copies, and pins each LBA to the physical page with the highest sequence number. The Marvell controller also XOR-scrambles and interleaves data across channels for throughput, so the utility applies the correct descrambling map from ACE Lab's parameter database before the data is usable.
Once the virtual translator is built, PC-3000's Data Extractor maps logical files onto physical pages and writes the image to a destination drive. That image is what we hand off to the file system layer for repair. Firmware-tier recovery on SanDisk Ultra 3D and early WD Red SA500 drives runs at $600–$1,200. For cases where the controller is electrically dead before any of this workflow can start, circuit board repair ($450–$600 SATA / $900–$1,200 NVMe) has to come first.
Why WD In-House Silicon Cannot Run This Workflow
Nothing in the above workflow works on WD's proprietary in-house silicon (SN550, SN570, SN770, SN850X, SN5000, and the A101-000125-B0 inside the SA510). ACE Lab has not released an Active Utility for WD's post-acquisition in-house silicon. The proprietary data scrambling and multi-gear LDPC error correction built into the in-house die (alongside hardware AES-256 encryption on the portable models that implement it) bind the data to the original controller, so desoldering the NAND and reading it in a programmer returns unintelligible data. Recovery on these drives collapses back to board repair: revive the original controller electrically (PMIC replacement, PCIe PHY reflow, BGA rework with a Zhuo Mao station), let the drive's own firmware walk its own journals in-place on the NAND, and image through the natively-rebuilt FTL before the controller overheats or the fragile state destabilizes again.
WD/SanDisk Diagnostic Signatures
WD & SanDisk First-Inspection Diagnostic Signatures
The first ten minutes on a WD or SanDisk SSD intake decide which workflow runs next. The host-observable enumeration state, read from BIOS, Disk Management, & dmesg before any imaging tooling is connected, separates four distinct fault classes. Each maps to a different controller state, & getting that mapping wrong costs hours on the wrong utility. The four states below are what we look for before quoting work on any WD- or SanDisk-labeled drive.
Four Host-Observable Enumeration States
State 1, Drive Not Detected. BIOS shows no device on the M.2 or SATA port. lspci on a Linux live USB returns no NVMe endpoint at the slot address. The PCIe LTSSM (Link Training & Status State Machine) never reached L0; the link halted in Polling, Configuration, or Recovery. This is an electrical fault: PMIC short, blown 1.8V or 3.3V rail, cracked solder under the controller BGA, or a physically damaged PHY. The controller never powered up enough to enumerate. Recovery path is board-level repair before any firmware or imaging work can start.
State 2, 0 LBA / 0 GB Capacity. BIOS & the OS both see a device at the slot address, but capacity reports as 0 bytes & Disk Management shows the disk as offline or uninitialized. The LTSSM reached L0 successfully, the PCIe link is up at the negotiated width & speed, but nvme id-ctrl & nvme id-ns return placeholder values because CSTS.RDY (Controller Status Ready bit in the NVMe register set) never asserted. The controller entered ROM mode after failing to load its FTL from the service area; garbage collection is suspended in that state, so the NAND contents are preserved behind the panic. This is the highest-yield failure class because the data has not been overwritten. Do not run Diskpart clean, do not accept a firmware update prompt, & do not initialize the disk: any of those can trigger a service-area rewrite that destroys the data the panic was protecting.
State 3, Generic Model String. The drive enumerates with a generic identifier (NVMe Device, ATA Device, or a vendor-specific PID that does not match the printed model). Capacity may be correct, low, or zero. The controller booted partially & responded to the identify command, but with placeholder strings from its boot loader instead of the model name written into the service area. Same root cause family as State 2 (FTL mount aborted), with the same recovery posture: power down, no host writes, image through the matching vendor utility.
State 4, 0xFFFF VID/PID Drop. The drive was detected normally at boot & then disappeared during operation. On Linux, dmesg logs an AER (Advanced Error Reporting) event followed by a DPC (Downstream Port Containment) trigger; subsequent PCIe configuration-space reads to the slot return 0xFFFF for both Vendor ID & Device ID, which is the canonical "device fell off the bus" signature. The controller hit an unrecoverable internal fault (uncorrectable ECC, machine check, or watchdog timeout), the root port isolated the slot to contain the error, & the controller has not responded since. On Windows the same condition surfaces as \Device\RaidPort1 reset errors in the System log & periodic disconnect-reconnect cycles. SN850X firmware 620361WD was released to address controller stability and power state transition failures that trigger this pattern.
Symptom → Fault → Recovery Path Matrix
Host SymptomBIOS / PCIe StateController FaultRecovery Path
Drive Not DetectedLTSSM halt before L0; no device at slotPMIC short, blown rail, BGA crack, dead PHYBoard-level repair first. NVMe circuit board repair: $900–$1,200. SATA: $450–$600.
0 LBA / 0 GB capacityLink at L0; CSTS.RDY never assertsFTL panic; controller dropped to ROM mode; GC suspendedMarvell drives: PC-3000 Safe Mode entry & translator rebuild. SanDisk in-house silicon: Rossmann does not currently offer in-lab recovery; path is board-level repair so the original firmware can rebuild the FTL on next boot.
Generic model stringLink at L0; identify returns placeholdersFTL mount aborted at boot loader; partial service-area readSame as 0 LBA path. Do not initialize the disk; do not accept a firmware update prompt that may trigger a service-area rewrite.
0xFFFF VID/PID drop after detectionAER + DPC event; config space reads 0xFFFFUncorrectable ECC, machine check, watchdog, or ASPM/HMB firmware bugReseat & cold boot once to confirm reproducibility. Firmware-bug class (SN850X 620311WD/620331WD/620361WD; SN770 731130WD; SN580 281050WD; SN5000 291020WD): vendor firmware updates address future occurrences but do not undo a panic that already corrupted user data. For active panics, image first & flash later.
Recent WD Architectures: SN5100 & SN7100
Two new WD architectures shipped in late 2024 and 2025 & are starting to appear in lab intake. Both run SanDisk in-house silicon on Kioxia BiCS8 NAND, & neither has a PC-3000 SSD active utility.
WD Blue SN5100 is the value mainstream NVMe Gen4x4 follow-on to the SN5000. It runs the SanDisk A101-000103-A1 controller (DRAM-less HMB) paired with BiCS8 218-layer 3D QLC NAND. Shipping firmware revisions include 3530M0WD & 3519H0WD. Rossmann does not currently offer in-lab recovery for SanDisk A101-000103-A1. The A101 family is not in ACELab's PC-3000 SSD supported list, so there is no Active Utility for technological mode & no firmware-level FTL reconstruction path. QLC endurance is the secondary concern: QLC pages spend less time in the lowest LDPC correction tier, so by the time a customer notices read errors the controller is usually already running at its highest correction stage.
WD Black SN7100 is the performance NVMe Gen4x4 successor to the SN770. It carries the SanDisk Polaris 3 A101-000172-A1 controller (also DRAM-less HMB) with Kioxia BiCS8 218-layer 3D TLC. Shipping firmware revisions include 7619M0WD & 7616H0WD. Rossmann does not currently offer in-lab recovery for Polaris 3 A101-000172-A1. Same architectural reason: the A101 family is absent from ACELab's supported list, so the recovery path is electrical board repair to revive the original controller so its own firmware can rebuild the FTL on next boot.
The Windows 11 24H2 HMB-allocation pattern that hit the SN580 (firmware 281050WD) also affected sibling drives on the same controller family: WD published firmware 731130WD for the SN770 & 291020WD for the SN5000 to handle the same elevated HMB cap behavior. A vendor firmware update changes how the controller responds to future HMB allocations; it does not reverse FTL corruption that an earlier panic already wrote to the service area. If the drive is currently failing, image before flashing.
Why Software Recovery Cannot Reach a Panicked WD FTL
Consumer recovery software (Disk Drill, EaseUS, R-Studio, PhotoRec) talks to a drive through the operating system's block layer. A drive in State 2, State 3, or State 4 has either failed to expose a usable block device or has dropped off the bus entirely. There is no block device for software to read from, no LBA range to scan, & no file system metadata to parse. PC-3000 SSD with the matching vendor resource profile is required because it speaks to the controller below the OS block layer, through the diagnostic UART or vendor-specific NVMe admin opcodes, & because it carries the per-controller descrambling maps & LDPC parameters needed to interpret raw NAND data. PC-3000 only helps when an Active Utility exists for the specific silicon, which is the Marvell families on this page & not the SanDisk in-house lines.
For the full cross-brand explanation of why FTL panics require lab tooling & what board-level repair looks like on encrypted drives, see our SSD data recovery overview. NVMe pricing: $200–$2,500. SATA pricing: $200–$1,500.
WD Red SA500 NAS Failures
WD Red SA500 Failures in NAS & ZFS Systems
The WD Red SA500, marketed for 24/7 NAS environments, has documented interoperability failures with ZFS file systems & LSI SAS host bus adapters. Initiating a standard zpool trim command on a pool backed by SA500 drives causes the drives to disconnect from the SATA/SAS bus within minutes.
Behind LSI 9300-8i SAS3 controllers (common in TrueNAS & enterprise servers), the SA500's firmware fails to handle TRIM commands through the SAS-to-SATA translation layer. The drive enters a busy (BSY) state & drops off the bus, degrading the ZFS pool. Sustained read operations during recovery imaging can trigger the same BSY timeout.
For NAS arrays with failed SA500 drives, recovery requires careful handling of the TRIM interaction. PC-3000 SSD's Marvell utility (the early SA500 uses an 88SS1074 controller) bypasses the normal SATA command set & reads the NAND through technological mode, avoiding the TRIM/BSY trigger. The imaged data is then assembled against the ZFS pool structure. If you're running SA500 drives in a ZFS pool, disable TRIM on that pool as a precaution.
WD Red SN700 NVMe in NAS Environments
WD Red SN700 NVMe NAS Drive Failures
The WD Red SN700 is Western Digital's purpose-built NAS NVMe SSD in the M.2 2280 form factor, positioned as a high-endurance caching tier for TrueNAS, Proxmox, & custom ZFS builds. The drive carries a SanDisk in-house controller, a tri-core ARM Cortex-R design fabricated on the TSMC 28nm node, paired with BiCS4 96-layer 3D TLC NAND & onboard DDR4 DRAM from SK Hynix or Micron at a 1 GB per 1 TB ratio (with the 4 TB SKU as the exception, carrying a single 2 GB DDR4 package and relying on a compressed 32-bit FTL addressing scheme to keep the metadata footprint inside that half-ratio buffer). Endurance ratings run from 2,000 TBW on the 1 TB model to 5,100 TBW on the 4 TB.
Rossmann does not currently offer in-lab recovery for the WD Red SN700. These are proprietary WD/SanDisk NVMe controllers absent from the ACELab PC-3000 SSD supported list; firmware-level repair (FTL reconstruction, translator rebuild, tech-mode access) is not available for this silicon. The lab response collapses to board-level electrical work only, & even that depends on the original controller booting under its own firmware before we can image.
The most documented enterprise failure mode is PCIe bus dropout under sustained ZFS workloads. During a zpool scrub or prolonged async write burst, the pseudo-SLC cache exhausts & the controller is forced into direct-to-TLC writes. The controller firmware can fail to acknowledge host requests inside the NVMe timeout window, the host resets the PCIe link, & if the device does not re-enumerate in time ZFS faults the vdev & degrades the pool to DEGRADED or UNAVAIL. Recovery to an online state usually requires a hard system reset or full power cycle so the controller can re-initialize from scratch.
The SN700 ships without onboard PLP capacitor banks. An unexpected power loss while the DRAM cache still holds uncommitted ZIL or SLOG data will discard that buffer; whatever the ZFS Intent Log had not yet flushed to stable storage is gone. Thermal behavior compounds the risk in compact passive Asustor & QNAP enclosures: sustained writes push controller junction temperature toward the 70°C throttle threshold, & prolonged operation in that band accelerates PMIC degradation & voltage-rail wear on the controller package.
Lab response for a non-booting SN700 mirrors what we do for the rest of the proprietary in-house family. Firmware-level repair has no PC-3000 utility, so the work collapses to board-level electrical: FLIR thermal imaging to localize a shorted PMIC or voltage regulator, component-level replacement with a Hakko FM-2032 on the FM-203 base station, Atten 862 hot air rework for surface-mount parts, & Zhuo Mao precision BGA rework when the controller package itself needs reflow or replacement. Once the controller's own firmware can boot, imaging happens through the native controller; chip-off is not an option because the proprietary FTL & LDPC parity cannot be reconstructed from raw NAND dumps. Board repair pricing references $900–$1,200; firmware-tier work, where applicable on related WD NVMe silicon, references $900–$1,200. +$100 rush fee to move to the front of the queue.
If you run SN700s in a ZFS array & one drive has dropped UNAVAIL after a scrub, power the array down before further cycling. Repeated power-on attempts on a drive with a stressed PMIC or voltage-rail short accelerate the failure & can take a recoverable board to a state where the controller can no longer be revived.
How much does Western Digital SSD recovery cost?
WD SATA SSD recovery starts at $200 for simple data copies and goes up to $1,200–$1,500 for NAND swap cases. WD NVMe recovery ranges from $200 to $1,200–$2,500. Free evaluation, firm quote before any paid work, and no data means no charge. Rush service: +$100 rush fee to move to the front of the queue.
Can WD's firmware update recover my lost SanDisk Extreme data?
No. Western Digital released firmware R332G190 in 2023 to prevent future disconnections on SanDisk Extreme V2 and My Passport SSDs. The update does not recover data already lost. If the drive disconnected and now shows a raw or unformatted file system, the firmware update cannot undo the FTL corruption or solder fracture that caused the failure. Lab recovery is required.
Why did my WD NVMe SSD disappear from BIOS?
WD NVMe SSDs use proprietary controllers that enter a firmware panic state when the Flash Translation Layer (FTL) corrupts. Unlike SATA drives that may report a factory alias or wrong capacity, a panicked NVMe controller fails to complete PCIe link training. The motherboard sees an empty M.2 slot. Recovery software can't communicate with hardware the system can't detect. Getting anything off it starts on the bench, with board-level diagnosis of why the controller never comes up.
Is the SanDisk Extreme failure a hardware or firmware problem?
Both. Western Digital attributed the failures to firmware and released patches, but Attingo, an Austrian data recovery lab with 25+ years of experience, publicly documented physical solder defects: oversized surface-mount components on undersized pads, brittle solder joints from bubbles in the reflow process, and thermal-stress fractures during sustained writes. Newer SanDisk Extreme V2 units shipped with epoxy resin over the affected components, which supports the hardware defect theory. The firmware patch likely throttles write speeds to reduce thermal stress on the fragile joints.
Does WD's hardware encryption prevent data recovery?
Some WD and SanDisk SSDs use AES-256 hardware encryption, particularly portable models (SanDisk Extreme, My Passport SSD) and self-encrypting drives. On encrypted models, the key is bound to the controller silicon, so desoldering the NAND yields only ciphertext. Even on unencrypted NVMe models (SN770, SN850X), proprietary flash translation layers and LDPC error correction make chip-off unviable. Board-level repair to revive the original controller is the recovery path for both encrypted and unencrypted drives.
Can data recovery software fix my WD SSD?
Only if the drive is physically healthy and recognized by your operating system. Software tools like Disk Drill, EaseUS, or R-Studio work for logical problems: accidental deletion (before TRIM executes), partition corruption, or formatted volumes. Software cannot help when the WD controller is dead, the firmware has panicked, or the drive has dropped off the SATA or PCIe bus entirely. A drive that isn't detected in BIOS is invisible to any software running on the operating system.
Why does my WD Black SN850X disappear from BIOS after sleep?
The SN850X running firmware version 620311WD has a documented ASPM (Active State Power Management) bug. When the PC enters sleep, the WD G2 controller drops into a low-power state. On wake, it fails to complete PCIe PHY link reinitialization, entering an infinite fault loop. The drive is powered but invisible to BIOS. The NAND data is intact; the controller just can't communicate. ACELab publishes no Active Utility for WD in-house silicon, so there is no loader-injection path around the stalled controller firmware. The recovery path on this drive is board-level diagnostic repair: $900–$1,200 (NVMe circuit board repair).
Is the WD_BLACK SN750 SE the same drive as the WD Black SN750?
No, and the recovery workflow differs completely. The retail WD Black SN750 (and SN750 Heatsink) carries WD's closed-firmware Triton MP28 controller with onboard DRAM. PC-3000 has no Active Utility for that silicon, so firmware-level recovery is off the table and the lab response is electrical board repair only. The WD_BLACK SN750 SE is a different drive on a different controller: the Phison PS5019-E19T, a DRAM-less Gen4x4 design with full PC-3000 Phison utility support. SN750 SE recovery can use Safe Mode boot, loader injection, and virtual translator rebuild inside the lab. Always read the controller die markings before quoting; the enclosure name alone is misleading.
Can chip-off recovery work on a WD or SanDisk NVMe SSD?
No. WD and SanDisk NVMe SSDs use proprietary flash translation layers, dynamic XOR parity, and multi-gear LDPC error correction that cannot be reconstructed from a raw NAND dump. On portable models with hardware AES-256 encryption (SanDisk Extreme, My Passport SSD), NAND desoldering also yields ciphertext with no key. The only viable recovery path is repairing the original controller through board-level microsoldering so the drive's own firmware can serve the data.
Why is my WD Blue SSD not detected by BIOS?
The query covers three distinct WD Blue failure signatures. The SATA WD Blue SA510 runs on the SanDisk A101-000125-B0 controller; firmware bricks here drop the drive from BIOS entirely or report it as "Unknown Device" with 0 bytes & no SMART telemetry. Rossmann does not currently offer in-lab recovery for SanDisk A101-000125-B0. PC-3000 has no Active Utility for that silicon, so the only path is electrical board repair when the fault is on the power rails. The NVMe WD Blue SN550 & SN570 are DRAM-less drives on SanDisk in-house silicon. Rossmann does not currently offer in-lab recovery for SanDisk in-house NVMe controllers. When the PCIe link training fails the drive powers but the M.2 slot reads empty; the drive is then enumerated on a PC-3000 Portable III diagnostic port rather than a production slot. The WD Blue SN580 & SN5000 (also DRAM-less, SanDisk in-house silicon, also non-supported) carry the Windows 11 24H2 Host Memory Buffer bug: Windows raised the HMB cap toward 200 MB, and affected drives blue-screened the host until the allocation was capped. That bug was an OS-side allocation mismatch, not a physical drive failure. Rossmann does not currently offer in-lab recovery for SanDisk SN580. Rossmann does not currently offer in-lab recovery for SanDisk SN5000. The mitigation is a firmware update through the SanDisk Dashboard (281050WD on the SN580) or capping HmbAllocationPolicy in the registry. Pricing ranges: SATA $200–$1,500, NVMe $200–$2,500.
Is SanDisk SSD recovery the same as WD SSD recovery?
For mid-to-high tier drives, yes. Western Digital acquired SanDisk in 2016, & both brands now sit on the same proprietary in-house controller family paired with BiCS 3D NAND. A WD Black SN750, a SanDisk Extreme Pro NVMe, & a WD Red SN700 share controller silicon, firmware architecture, & FTL behavior; the recovery procedure is identical regardless of the label on the enclosure. Budget tiers diverge. The SanDisk SSD Plus uses Silicon Motion SM2246XT or SM2256S DRAM-less SATA silicon, & some WD Green SN350 batches ship with third-party controllers from Phison or other vendors. Those drives are handled through the appropriate PC-3000 utility module rather than a WD-specific workflow. First step on every WD- or SanDisk-labeled drive is identifying the actual controller die under stereo magnification before quoting, because the marketing name will not tell you which silicon is inside.
Why is my WD SSD not detected in BIOS or the Windows installer?
Three separate failure layers produce this symptom & each has a different fix. The first layer is the host driver stack: on Intel platforms with Rapid Storage Technology (IRST) or VMD enabled, Windows Setup may not load the NVMe driver unless IRST/VMD is disabled in BIOS or the matching F6 driver is supplied to the installer. The drive is healthy; the OS just can't see it. The second layer is link training: WD SN850X drives running firmware 620311WD enter an ASPM fault loop after sleep & fail PCIe link negotiation; the drive is powered but the M.2 slot reads empty in BIOS. The third layer is controller panic: a corrupt FTL on a WD in-house controller drops the drive off the bus entirely & the controller stops responding to enumeration commands. A useful first diagnostic is booting an Ubuntu Live USB & running `lsblk` & `dmesg | grep nvme`; Linux sometimes detects the block device & logs PCIe link errors when Windows shows nothing, which narrows the fault to firmware vs. hardware before any work is started.
Is running WD Dashboard safe on a failing SSD?
Read-only viewing of S.M.A.R.T. telemetry is safe. Running the Extended Diagnostic scan, the Performance Optimization / Erase utility, or accepting a firmware update prompt is not. The Extended Diagnostic performs a full surface read across the entire LBA range; on a drive with degraded NAND or a marginal controller, that sustained read load can push the controller into a read-only lockout, a panic loop, or a drop off the PCIe bus. The separate Optimize/Erase function acts on unallocated blocks, leaving recoverable file remnants queued for the controller's next garbage collection pass; once that pass erases a block, the charge is gone. A firmware flash (the 620331WD patch for the SN850X is a documented example) writes new firmware to a controller slot & triggers a controller reset to activate it; on an unstable controller the reset is where things fail, with the controller hanging on enumeration or failing to reload its existing FTL into RAM, after which the host can no longer talk to the drive. Dashboard does not perform FTL repair, does not access the controller's service area, & does not issue vendor-specific commands to bypass a stalled controller. If the drive is showing failure signs, image first, then decide what to run against the image.
What does it mean if my WD SSD shows 0 bytes in Disk Management?
A WD SSD that enumerates on the bus with 0 LBAs, 0 GB capacity, or a generic model string like "NVMe Device" or "ATA Device" is reporting a firmware-panic state, not a dead drive. The PCIe or SATA link trained successfully (BIOS sees the device, dmesg shows the address) but the controller failed to mount its Flash Translation Layer from the service area. Inside the controller, the firmware aborted to a minimal ROM mode that responds to identify commands with placeholder values & garbage collection is suspended, which means your NAND contents remain intact behind the panic. The fix is not Disk Management, not Diskpart clean, & not a firmware update; any of those can trigger a service-area rewrite that destroys what the panic preserved. Power the drive down, stop trying to mount it, & get it imaged through PC-3000 SSD with the matching vendor utility. For WD SN550, SN570, SN770, SN850X, SN580, SN5000, SN5100, & the SA510, Rossmann does not currently offer in-lab recovery for SanDisk in-house silicon; the path on those drives is board-level repair so the controller's own firmware can rebuild the FTL on next boot.
What is the WD Black SN7100 controller, & can it be recovered?
The WD Black SN7100 is the 2024 successor to the SN770 line, built on the new Polaris 3 A101-000172-A1 controller paired with Kioxia BiCS8 218-layer 3D TLC NAND in a DRAM-less Host Memory Buffer design. Shipping firmware revisions include 7619M0WD & 7616H0WD; the March 2026 update shipped without public release notes describing the specific fixes. Rossmann does not currently offer in-lab recovery for Polaris 3 A101-000172-A1. ACELab's PC-3000 SSD supported list does not include the A101 family, so there is no Active Utility for technological mode & no firmware-level FTL reconstruction path. If an SN7100 enters ROM mode after a Windows 11 24H2 update or a failed S0ix power state transition, the only path we can offer is electrical board repair: locate the failed component on the PCB with FLIR thermal imaging, replace the shorted PMIC or voltage regulator with a Hakko FM-2032 on an FM-203 base, & let the controller's own firmware rebuild the FTL on next boot. Pricing: $900–$1,200 (NVMe circuit board repair).
What's inside the WD My Passport SSD, & why won't it work plugged into a desktop after the case breaks?
The 2020-and-later WD My Passport SSD houses a WD Blue SN550E NVMe drive bridged to USB through an ASMedia ASM2362 USB 3.2 Gen 2 to PCIe NVMe controller. AES-256 hardware encryption is active by default, regardless of whether the user set a password. The encryption engine lives on the internal drive's NVMe controller, & the ASM2362 bridge relays Western Digital's vendor-unique unlock command to that controller. When the enclosure dies, pulling the SN550E out & dropping it into a desktop M.2 slot produces a drive of the correct capacity that refuses to mount, because a standard M.2 host never sends the vendor-unique unlock handshake the bridge normally passes through. Recovery keeps the original NVMe controller inside, which holds the key, & restores the unlock path by reviving the original ASM2362 bridge through board-level repair on the bridge PCB; a donor enclosure of the same model is sometimes required. Older WD Elements SE & SATA-based portable models behave differently because they typically use JMicron JMS578/JMS580/JMS583 or Realtek RTL9210 bridges without encryption binding; on those, the internal drive can usually be connected directly to a host & imaged.
WD or SanDisk SSD not working?
Free evaluation. SATA SSD recovery: $200–$1,500. NVMe recovery: $200–$2,500. No data, no fee.
