WD Purple Surveillance Data Recovery
WD Purple drives are built for surveillance DVR and NVR systems, running 24/7 write workloads that standard desktop HDDs cannot sustain. When a Purple drive fails, recovery requires donor head matching and proprietary NVR filesystem parsing to extract multiplexed video streams. All recovery work is performed at our Austin, TX lab.
Pricing starts at $600 for firmware-level repairs, $1,200–$1,500 for head swaps, matching the published tiers on our hard drive data recovery service. Free evaluation. No data recovered means no charge.
Updated March 11, 2026
Do NOT Initialize, Format, or Run chkdsk
When you connect a WD Purple surveillance drive to a Windows PC, Disk Management will show it as "Not Initialized" or "Unallocated." This is normal. Surveillance systems use proprietary filesystems that no PC operating system can read. Running chkdsk on a physically failing drive will compound mechanical damage. Power the drive off and contact a recovery lab.
WD Purple Product Line and Surveillance Workloads
Can you recover data from a failed WD Purple surveillance drive?
Yes, in most cases. Firmware translator corruption and the resulting UNC or BSY lockups are repaired on PC-3000 by rebuilding the Service Area translator; clicking drives go to a donor head swap on the 0.02 µm ULPA-filtered clean bench, the same workflow as any hard drive data recovery case. Footage the NVR already overwrote in its loop cannot be recovered.
WD Purple (Standard)
CMR (Conventional Magnetic Recording) platters. Rated for 180 TB/year write workload. Supports up to 64 cameras.
Current models carry the PURZ suffix; legacy models carry the PURX suffix.
WD Purple Pro
CMR (Conventional Magnetic Recording) platters for AI-enabled NVRs. 550 TB/year write rating. Supports up to 64 HD cameras plus 32 concurrent AI streams.
Models carry the PURP suffix. Models at 12TB and above are Helium-sealed.
What are the most common WD Purple failure modes?
The most common modes are firmware translator and Module 32 G-list corruption after power loss (BSY or UNC) and PCB surge damage needing a U12 ROM transfer.
Surveillance Drive Firmware Internals: Workload Rate Limit and Donor Matching
This section corrects a misconception that has spread through legacy donor-matching forums: the "AC-family" designation sometimes attached to surveillance drives refers to 1990s Western Digital Caviar IDE models such as the AC2420, not modern surveillance hardware.
Workload Rate Limit on WD Purple and Purple Pro
Standard WD Purple is rated 180 TB/year and Purple Pro is rated 550 TB/year. These figures appear on the WD Purple datasheet and are not arbitrary marketing. They are statistical engineering thresholds tied to MTBF and AFR projections at the design workload.
Marvell Donor Matching Beyond the Family Code
Most published donor-matching guides stop at family code, capacity, and head count. For modern Purple drives that is not enough. Firmware revision band compatibility determines whether the donor's Service Area module formats can be paired with the patient at all without a deeper firmware migration.
ROM adaptives are stored in the U12 SPI flash on the PCB and contain unique servo calibration and voltage settings for the original head stack. A donor PCB will not initialize the heads, because the servo coefficients and voltage offsets are bound to the patient. ROM extraction and rewrite is performed on a dedicated SPI programmer with the chip in a stable thermal state. The full donor-matching axis set is documented on how donor drives are matched in modern hard drive recovery.
WD Purple Failure Modes
How is surveillance drive recovery different from consumer hard drive recovery?
The recovered image sits in a proprietary NVR filesystem (Hikvision HIKBTREE, Dahua DHFS, or a Swann or Lorex vendor-specific format) that no PC can mount, so frames are carved after imaging.
Standard WD Purple drives share the Marvell controller firmware architecture with other WD families (Blue, Black, Red). The 24/7 surveillance workload creates distinct failure patterns. These are the categories we encounter most frequently in professional hard drive recovery service casework on Western Digital surveillance units.
Translator Corruption After Power Loss
WD Purple drives maintain a translator module in the Service Area firmware that maps logical block addresses (the sectors your NVR writes to) to physical locations on the platters. When the NVR loses power during a write operation, the drive's internal write cache fails to flush to its final platter locations. The translator loses synchronization, and the drive reports its correct model and capacity but throws uncorrectable read errors (UNC) or locks the SATA bus into a busy (BSY) state when user data is requested.
Recovery procedure: Connect the drive to PC-3000 via the WD Marvell utility. Access the Service Area firmware modules. Read and verify the translator integrity. Rebuild the corrupted mapping tables to restore the logical-to-physical address translation. Pricing: $600–$900.
Firmware Module Corruption and BSY States
Power surges and abrupt shutdowns can corrupt critical firmware modules in the WD Service Area. Module 32 (the Relocation List) is a frequent point of failure: it tracks remapped bad sectors. When the list overfills its allocated space, the firmware enters a retry loop and the drive becomes unresponsive or enters a BSY (Busy) state. The drive may spin and be detected by the NVR BIOS but cannot serve any data.
Recovery procedure: Image the drive using selective head reading to work around degraded heads. Pricing: $600–$900.
ROM Adaptives and PCB Repair
A power surge that damages the PCB on a WD Purple drive cannot be fixed with a simple board swap. Modern Western Digital drives store unique head-calibration data in the U12 ROM chip. A donor board without the patient ROM creates a calibration mismatch, causing clicking and risking platter damage.
The repair procedure requires desoldering the U12 ROM chip from the original (damaged) PCB, reading its contents via an external programmer, and writing those adaptive parameters onto the donor board's ROM. Only then can the drive initialize correctly through PC-3000. The same ROM-transfer step is part of every hard drive data recovery case where the original board has been damaged by surge or short.
When WD Purple PCB Damage Is the Real Failure
Not every dead WD Purple is a head problem. A subset of intake drives arrive after a surge event or a faulty NVR power supply, and the heads inside are still healthy. The preamplifier sits on the head stack flex cable, but its power rail is generated on the PCB. When the PCB-side driver for that rail fails, the symptom looks like a head problem: the drive may click once, fail to ready, or hold the SATA bus in BSY. The heads themselves are intact. Distinguishing the two cases before opening the drive is the difference between a firmware/electronics tier recovery and a full head-swap with platter cleaning.
Preamp Power-Rail Diagnostics with FLIR Thermal Imaging
The bench workflow begins with the patient PCB on an isolated lab supply, current limited so a downstream short cannot cascade further damage. The PCB is powered for ramp-up only, no SATA link. The FLIR thermal camera surveys the board for hot spots within the first few seconds. A drive whose PCB power rails come up clean and whose ROM reads correctly but which still fails to ready is treated as a mechanical case and moved to the clean bench.
The PCB rail map is verified against the head-stack flex connector pinout before any rework is attempted. The U12 SPI ROM is read with the external programmer before power is applied to a rework candidate, so the adaptive parameters are captured even if the rework step destroys the donor PCB.
Board-Level Rework on the PCB Power Stage
When the thermal survey identifies a failed driver IC or a shorted passive on the PCB power stage, the failed component is removed at the bench using the Hakko FM-2032 soldering iron on the FM-203 base station, paired with hot air rework where the package geometry requires it. This is a PCB-only repair: the rework station never touches the head stack assembly, the platters, or the actuator. Soldering on the drive mechanism itself is not part of HDD recovery and is not performed here. The PCB repair exception applies strictly to the surface-mount components on the controller board.
After the failed component is replaced, the ROM adaptives captured earlier are written back to the U12 SPI on the repaired board through the external programmer. The drive is then re-mated to its original head stack and read on PC-3000 Express or DeepSpar Disk Imager through a controlled spin-up.
Cost Impact of a PCB-Only Repair
PCB damage with intact heads is the cheaper end of the WD Purple recovery spectrum. No donor head stack is sourced, no clean-bench head swap is performed, and no platter cleaning is needed. The work stays inside the firmware and electronics tier of HDD recovery rather than the head-swap tier. Pricing reflects that: PCB and firmware-tier work falls in the $600–$900 band, against $1,200–$1,500 for a full head stack assembly replacement and $2,000 when platter cleaning is required after a head crash. The deeper background on what PC-3000 does during the post-rework verification pass is on what PC-3000 actually does, and the broader workflow context lives on hard drive data recovery.
WD Head Swap Recovery Process
This walkthrough demonstrates a full head stack assembly replacement on a Western Digital drive. The same Marvell controller architecture and head matching process applies to standard WD Purple surveillance drives. The clean bench, tooling, and verification steps shown apply to head swap and firmware repair on mechanical hard drives across every brand we recover.
Mechanical Recovery Procedure for WD Purple Drives
A head stack assembly replacement on a WD Purple drive is performed inside the 0.02 µm ULPA-filtered laminar flow clean bench. The bench is what separates a recoverable platter set from a contaminated one; even a single particle landing between a flying head and the platter surface during open-cover work is enough to score a track. What follows is the bench sequence used on the standard WD Purple PMR family.
Clean-Bench Head Stack Swap on WD Purple Drives
The patient is opened inside the clean bench with the cover screws documented and the top cover lifted in a single motion to avoid disturbing the actuator. The WD Purple head stack is a ramp-load design, which means the heads must be parked off the platter surface before removal and re-engaged onto the parking ramp before the platters are spun back up.
  1. The platters are first held with the WD-specific head comb tool inserted between the platters at the rest position, so the actuator cannot pivot during head removal.
  2. The actuator latch is released and the parked head stack is walked off the ramp in one continuous motion, keeping the heads parallel to the parking surface so the suspensions do not flex.
  3. The patient head stack is set aside on a static-dissipative carrier. The donor stack is staged on its own carrier with the heads still on its donor parking ramp.
  4. The donor heads are transferred onto the patient ramp using the head comb as a guide; the comb stays in place until the heads are fully seated on the ramp surface and the actuator latch is re-engaged.
  5. The patient platters are visually inspected under the stereo microscope for ramp residue or scoring before the cover is replaced. The drive is closed and powered up on the bench supply with the comb removed only after the actuator parking position is verified.
Background on the procedure and tooling used across every brand we recover is on what a head swap involves.
Donor Matching Procedure for the WD Purple PMR Family
A donor that matches the patient model number is the starting point, not a match. The head stack will physically install across nearby family members, but the patient's adaptive parameters will not drive a mismatched head correctly. The parameters below are checked against the patient ROM and Service Area before any donor is opened, and which of them are decisive depends on the exact drive.
  1. Model family: PURX, PURZ, and Purple Pro are not cross-compatible for head transplants.
  2. Firmware revision band: the donor must fall inside the patient's firmware revision band, as recorded in the Service Area module headers. Out-of-band donors typically lack compatible Service Area module formats.
  3. Head map: head count and the physical position assignment of each head.
  4. DCM anchor characters: the "J" or "2" anchor character near the end of the Drive Configuration Matrix string, together with the character immediately preceding it, must align between donor and patient for preamplifier compatibility.
  5. PCB ROM and U12 SPI compatibility: the donor PCB ROM layout, U12 SPI flash size, and PCB revision must accept the patient adaptive blob during ROM transfer. Newer PCB revisions on the same model can carry a different SPI part and break the transfer without an additional translation step.
The general donor-matching framework that this WD Purple list specializes is on how donor drives are matched.
Service Area Rebuild After a Head Transplant
After a successful head transplant, the Service Area is brought up under PC-3000 WD utility control. The deeper reference on the PC-3000 toolchain itself is on what PC-3000 actually does.
Mechanical recovery on the WD Purple family is priced in the head-swap tier at $1,200–$1,500, with $2,000 reserved for cases where platter cleaning is required after the heads have transferred material onto the recording surface.
Donor Matching for WD Purple Head Stacks
A WD Purple head swap requires a donor drive whose head stack assembly matches the patient on multiple axes, not just capacity. Buying the same model number off a marketplace is the starting point, not the end of the search. The fields below are checked against the patient drive's ROM and Service Area data before any donor is opened.
  • Family code (PURX vs PURZ): the legacy PURX series and the current PURZ series are not interchangeable for head transplants.
  • Capacity code and head count: a 4TB Purple may ship with two or three platters depending on the production run. The patient's head count is read from the Service Area first, then the donor is selected to match.
  • Micro-jog and write current tolerances: each head is calibrated to its own platter at the factory; the calibration is stored in the patient ROM. The donor heads must fall inside the same micro-jog and write current band for the patient's adaptives to drive them correctly.
  • Manufacturing site code and firmware revision band: WD heads built at different sites use different supplier components. A donor outside the patient's firmware revision band typically lacks compatible Service Area module formats and cannot be paired without a deeper firmware migration.
A WD Blue, Red, or Black drive is not a valid donor for a Purple, even at the same capacity. The full donor-matching workflow is documented on how donor drives are matched.
Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available. The donor cost is itemized separately from the head-swap labor tier ($1,200–$1,500) so customers can see exactly where the spend is going.
ROYL Firmware Behavior on WD Purple
Imaging Timeouts on the Recovery Bench
On the bench, the DeepSpar Disk Imager and PC-3000 Data Extractor are configured with aggressive short hardware read timeouts, with worn sectors queued for a second pass instead of stalling the link.
ROYL Service Area Module Map and PC-3000 Access
Modern WD Purple drives run the ROYL firmware architecture on Marvell controllers. The firmware loader sits in the U12 SPI ROM on the PCB; the working firmware modules sit magnetically on the platters in the negative-cylinder Service Area. On a Service Area corruption case the resident firmware cannot complete its boot handoff, and the drive returns a generic ROM-model identifier or holds the SATA bus in a permanent busy state. Recovery access goes through the PC-3000 WDC Marvell utility, which pushes a utility-family loader into the controller's RAM. From that loader the bench reads and rewrites Service Area modules over the SATA PHY using vendor-specific commands.
  • Module 01 (Directory): the offset and length map for every other module in the Service Area. Module 01 is read first because the rest of the access plan is keyed off the directory.
  • Module 0A (Head map): the physical head configuration. A degraded head is logically disabled here so the drive can initialize past head identification and the surviving surfaces can be imaged.
  • Module 32 (G-list): the grown defect list. An overfilled Module 32 produces the slow-responding bug, where read throughput collapses into kilobytes per second as the firmware loops on the defect parse. The recovery workflow clears Module 32 and disables background relocation for the imaging window.
  • Module 33 (P-list): the factory primary defect list, read-only at the bench and used as a sanity check against the head map.
  • Module 47 (Adaptive parameters): the head-stack calibration table. Micro-jog offsets, preamplifier gain, and thermal fly-height control voltages live here. The Module 47 contents are what the U12 ROM transfer is protecting on a PCB swap; a donor Module 47 will not drive the patient heads correctly.
  • Modules 102, 103, and 109 (ROM shadows): magnetic backups of the U12 ROM image. If the original PCB is destroyed by overvoltage and the SPI flash is unreadable, the ROM shadow modules are read off the platters and reassembled into a valid image for the donor PCB.
PCB Matching Beyond the Family Code
The donor-matching section above lists the head-stack axes that determine whether a donor body will read against the patient adaptives. The PCB itself has a separate set of matching axes, used when the failure is electrical rather than mechanical. A WD PCB carries a silkscreened identifier in the form 2060-xxxxxx-yyy REV with a trailing revision code.
  • 2060- six-digit base: a board with a different six-digit base is not a valid donor regardless of which Purple model the marketplace listing claims it fits.
  • U12 SPI flash footprint: the SPI ROM package and density must accept the patient's adaptive blob during the U12 transfer. Newer board revisions on the same generation occasionally swap the SPI part, which breaks the direct transfer without an intermediate read and reflash.
  • Diode and TVS protection footprint: a board that was destroyed by overvoltage may have damaged TVS diodes still in place. The donor is checked for equivalent protection components before the U12 ROM is moved, so the rebuilt drive is not handed back to the same power rail that killed the original.
The U12 ROM itself is desoldered from the patient board using the Atten 862 hot-air rework station with a low-profile nozzle, read out on an external SPI programmer, then reflowed onto the matched donor PCB. The transfer is verified by checking the adaptive table contents against the read-back image before the rebuilt PCB is mounted on the patient body. The general donor and PCB matching framework is on how donor drives are matched.
24/7 Duty-Cycle Wear at Recovery Time
A WD Purple deployed in a security closet or a tightly packed NVR rack spends years at an elevated steady-state temperature with a write-heavy duty cycle. The wear pattern at recovery time is different from a desktop WD Blue or Black drive at the same age, and the bench plans the imaging strategy around it.
  • Fluid dynamic bearing lubricant migration: the spindle motor uses a fluid dynamic bearing with an oil film pumped into a herringbone groove and contained by a capillary seal. Sustained operation above the bearing's designed thermal window accelerates oil migration past the seal. A Purple that arrives with non-repeatable run-out, spindle wobble during the spin-up phase, or audible bearing noise is treated as a candidate for an imaging-only window before the bearing degrades further, with no expectation that the original spindle will survive long enough for a multi-pass image.
  • Preamp thermal aging: the head preamplifier IC on the flex cable sees continuous current at elevated temperature for the full deployment lifetime. Drives that arrive after long surveillance runs sometimes present with a head channel whose read amplitude has drifted outside the patient ROM's adaptive window. The bench reads channel margin per head before committing to an imaging order, and a marginal head is bypassed in the first pass rather than allowed to stall the extraction of pristine bands served by the other heads.
  • Voice coil bearing and ramp wear: the VCM pivot bearing and the ramp-load parking surface accumulate wear from the continuous seek pattern of NVR ingest, which never lets the actuator rest in a stable parked state for long. A Purple with retract clicks at power-on, ramp residue visible under the stereo microscope, or audible roughness during seek is treated as a mechanical-tier case even when the firmware will still respond.
Firmware-tier work on the standard WD Purple family is priced at $600–$900, with mechanical-tier work at $1,200–$1,500. Helium-sealed Purple Pro drives that require opening the sealed chamber for head work are priced from the helium head-swap tier at $3,000–$4,500. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available.
DVR and NVR Shipping Logistics
Surveillance drives carry chain-of-custody concerns that consumer drives do not. If the footage is part of an active insurance claim, an HR investigation, or a criminal case, the integrity of the drive between your site and our lab matters as much as the recovery procedure itself. This is a mail-in service; all work happens at the Austin, TX lab. The shipping protocol below applies to single drives, full NVR enclosures, and multi-drive arrays.
  • Power down before removing drives: a hot-pulled drive in an active NVR can leave dirty caches and corrupt the proprietary index. Power the NVR down at the appliance, not the breaker, then disconnect.
  • Label every slot before pulling drives: for multi-bay enclosures (RAID 5, RAID 6, spanned, or JBOD), the slot order is part of the array geometry. Mark each drive with its bay number using a non-conductive label before you remove it. Out-of-order drives in a multi-drive array force trial-and-error reconstruction and add hours to the recovery.
  • Anti-static handling: ship drives in their original anti-static bags inside a rigid box with at least two inches of foam padding around each drive. Do not use bubble wrap as the primary cushion.
  • Chain-of-custody documentation: include a signed packing slip with the drive serial numbers, the NVR make and model, the slot position they came from, and a contact name. We log the drives into the case file on receipt and photograph the labels before any work begins. Full procedure on chain-of-custody for shipped drives.
  • Write-blocker imaging on arrival: the first action after intake is a read-only image with PC-3000 Express or DeepSpar Disk Imager, not a mount. The patient is never written to until the firmware state has been read out and verified against the Service Area. This protects original surveillance footage from accidental reallocation triggers during diagnostics.
Standard turnaround for firmware-tier work is 3-6 weeks; head-swap tier work runs 4-8 weeks. +$100 rush fee to move to the front of the queue is available for time-sensitive cases and applies to the firmware and head-swap tiers.
WD Purple Pro Helium Drives
WD Purple Pro drives at 12TB and above are sealed with Helium to reduce aerodynamic drag on the platters, enabling higher platter density and lower operating temperatures. These are not standard breather-filter drives. The sealed Helium environment is critical to head stability and platter spacing.
Physical recovery on a Helium Purple Pro requires specialized atmospheric handling during the head swap process. The read/write heads on a Helium drive are engineered to float on an air bearing surface tuned for helium's low gas density (roughly one-seventh that of atmospheric air). If a Helium drive is opened and powered up in standard atmospheric conditions, the higher density of nitrogen and oxygen sharply increases the aerodynamic lift on the slider, breaking the calibrated fly-height equilibrium and causing the heads to pitch and crash into the platter surface. Our lab performs Helium drive work using controlled-atmosphere techniques on our 0.02 µm ULPA-filtered clean bench.
If your NVR uses WD Purple Pro drives in a multi-drive configuration, do not attempt to rebuild a degraded RAID or spanned volume. Remove all drives from the NVR enclosure, label their slot positions, and send the complete set for RAID recovery.
Proprietary NVR Filesystems
Even after a successful physical repair and sector-by-sector clone, the video data on a WD Purple drive is stored in a proprietary filesystem determined by the NVR/DVR manufacturer, not by Western Digital. Different brands use different proprietary formats:
NVR BrandFilesystemKey Challenge
HikvisionCustom block allocator with HIKBTREE indexIndex corruption after power loss breaks timestamp mapping
DahuaDHFS (proprietary)Multiplexed stream interleaving requires frame-level carving
Swann / LorexVendor-specific proprietaryCircular recording overwrites oldest blocks; no file boundary markers
Hanwha / NightOwlVendor-specific proprietaryRequires raw H.264/H.265 NAL start code scanning for recovery
After physical drive repair and cloning, we identify the NVR manufacturer's filesystem by scanning for known signatures, then parse the proprietary index structures to map timestamps to video data blocks. If the index is corrupted beyond repair, we fall back to sequential H.264/H.265 frame carving, which recovers all surviving video but loses timestamp associations. Footage is delivered in standard MP4 format playable in VLC or any modern media player.
WD Purple Recovery Pricing
Air-filled WD Purple surveillance drives follow our standard HDD pricing tiers. Purple Pro 12TB and larger helium-sealed mechanical cases use helium HDD pricing because the sealed chamber, donor match, and refill procedure change the repair cost.
Air-filled WD Purple pricing
Helium-sealed WD Purple Pro pricing
    From $600
    $3,000–$4,500
    $4,000–$5,000
Helium cost
Multi-drive NVR arrays configured in RAID 5, RAID 6, or spanned volumes require imaging each drive individually, then reconstructing the virtual array. These cases are quoted after evaluation based on array complexity and drive count.
What Western Digital Drive Owners Say
Christopolis
Andrew Hansen
Kyle Hartley (crazybangles)
Christopolis
WD Purple Recovery FAQ
Can I do a PCB swap on my dead WD Purple drive?
No. Modern WD Purple drives store unique adaptive parameters in the ROM chip (U12) on the PCB. These parameters calibrate the specific flight height of each read/write head. A board swap from a donor drive will produce clicking and risk platter scoring. The original ROM must be desoldered, read via an external programmer, and the adaptive data transferred to the donor board before the drive can initialize.
Why does my WD Purple show 0 bytes of data?
WD Purple drives store address translation data in firmware modules within the Service Area. If the drive experiences sudden power loss during a write operation, the translator that maps logical block addresses to physical platter locations can corrupt. The drive may spin, identify in BIOS, and report its correct capacity, but read attempts return uncorrectable errors (UNC) or the drive locks into a busy (BSY) state. This is a firmware-level failure requiring PC-3000 to rebuild the translator. Consumer recovery software cannot bypass this hardware-level lock.
What is the difference between WD Purple and WD Purple Pro?
Standard WD Purple drives use CMR (Conventional Magnetic Recording) platters and are rated for 180 TB/year write workload, supporting up to 64 cameras. WD Purple Pro drives also use CMR but are built for heavier AI-enabled NVR workloads (up to 550 TB/year), supporting up to 64 HD cameras plus 32 concurrent AI streams. Purple Pro models at 12TB and above are Helium-sealed, which changes the physical recovery procedure. Standard Purple drives use air-filled enclosures with breather filters.
Can you recover overwritten surveillance footage?
No. When an NVR reaches capacity and loops back to overwrite the oldest footage, the magnetic state of those sectors is physically altered. Recovering overwritten data from a modern hard drive is not possible. If the NVR continued recording after the incident you need footage from, the oldest recordings may have been overwritten depending on drive capacity and camera count.
How much does WD Purple data recovery cost?
Air-filled WD Purple recovery follows our standard HDD pricing tiers. Firmware repair (translator corruption, BSY state) runs $600–$900 using PC-3000. Head swap for air-filled Purple drives costs $1,200–$1,500. Purple Pro 12TB and larger helium-sealed mechanical cases use helium HDD pricing from $200–$5,000+. Free evaluation; no data recovered means no charge.
My NVR says the WD Purple drive is unformatted. Should I format it?
No. Surveillance NVRs use proprietary filesystems that Windows and Linux cannot read. When you connect a surveillance drive to a PC, Disk Management shows it as "Not Initialized" or "Unallocated." This is normal. Power the drive off and contact a recovery lab.
Why can't you use a WD Blue or Red as a donor for my Purple drive?
WD Blue, Red, and Black drives share the broader Marvell controller family with Purple, but the head stack assemblies are not interchangeable even at the same nominal capacity. Donors must match by family (PURX or PURZ), capacity code, head count, manufacturing site, and a compatible firmware revision band before they will calibrate against a Purple ROM.
Does WD Purple use SMR or CMR?
The modern WD Purple line is CMR (Conventional Magnetic Recording).
What does WD Purple's 180 TB/year workload rate limit actually mean?
The 180 TB/year figure for standard WD Purple and the 550 TB/year figure for WD Purple Pro are statistical engineering thresholds tied to MTBF and AFR projections published on the WD Purple datasheet.
Can you recover a DVR or NVR hard drive even if the recorder unit is dead?
Yes. The recorder unit and the hard drive are independent components for recovery purposes. We image the drive via PC-3000 Express or DeepSpar Disk Imager outside the recorder enclosure, then parse the proprietary filesystem from the image. Common surveillance filesystems we handle include Hikvision HIKBTREE, Dahua DHFS, and the vendor-specific formats used by Swann, Lorex, Hanwha, and NightOwl recorders. If the original recorder is dead, the recovered video is delivered as standard MP4 files playable in VLC or any modern media player. No DVR or NVR appliance is needed to view the footage on delivery.
Need Surveillance Footage Recovered?
Send your WD Purple drive or complete NVR system to our Austin lab. Free evaluation, no data no fee. Call (512) 212-9111 for questions.
