RAID 50 Data Recovery Services
RAID 50 stripes data across multiple RAID 5 sub-arrays (spans), combining parity protection with striped throughput. When a span loses more than one member, or when the controller loses track of span boundaries, the entire volume goes offline. We recover RAID 50 arrays by imaging every member through write-blocked channels, identifying span assignments from controller metadata, and reconstructing each sub-array independently before reassembling the stripe. For other levels, see our RAID data recovery overview. Free evaluation. No data recovered means no charge.
14 min read
Architecture
How Does RAID 50 Architecture Work?
RAID 50 is a nested RAID level that combines RAID 5 parity protection with RAID 0 striping. The controller divides member drives into two or more spans, builds a RAID 5 array within each span, then stripes data across the spans at the block level.
Per-span RAID 5 group
Each span operates as an independent RAID 5 group with its own parity rotation. A span of four drives dedicates one drive's worth of capacity to parity, leaving three drives of usable space. Two such spans in a RAID 50 configuration yield six drives of usable capacity from eight physical drives.
Stripe-level layer
The stripe-level layer distributes sequential I/O across spans. A write that exceeds the stripe size of one span continues on the next, doubling throughput compared to a single RAID 5 group of the same total member count.
Per-span fault tolerance
Fault tolerance is per-span: each span tolerates exactly one member failure. A two-span RAID 50 can survive two simultaneous failures only if they occur in different spans. Two failures in the same span break that span's parity, and because the stripe layer interleaves data across all spans, the entire volume becomes inaccessible.
Minimum drive count
RAID 50 requires a minimum of six drives (two spans of three). In practice, most deployments use 8 to 16 drives across two to four spans. Controllers that support RAID 50 include the Dell PERC H730 and H740P, the HP Smart Array P408i-a, the Broadcom MegaRAID 9460-16i and LSI MegaRAID 9271-8i, and the Adaptec SmartRAID 3154-8i.
Failure Modes
Why Do RAID 50 Arrays Fail?
RAID 50 failures fall into two categories: multi-drive failures within a single span that exceed RAID 5 fault tolerance, and controller-level metadata corruption that makes the span structure unreadable even when all drives are physically healthy.
Same-Span Double Failure
The most common RAID 50 data loss scenario. One drive in a span fails, the array runs degraded, and a second drive in the same span fails during the rebuild. Drives purchased together share manufacturing batch characteristics and similar operating hours. When one fails from wear, its neighbors carry elevated risk. A rebuild forces sustained sequential reads across every surviving member in that span, which is the highest-stress workload a drive can face. When two drives fail in the same span, that span drops offline and the array needs offline per-span reconstruction, not another rebuild. See two drives failed in the same array.
Controller Metadata Loss
Hardware RAID controllers store span definitions, member assignments, stripe sizes, and parity rotation directions in proprietary on-disk metadata and controller NVRAM. A controller firmware update, battery failure, or physical controller replacement can leave this metadata inconsistent or absent. The drives are healthy, but the controller no longer knows which drives belong to which span or what stripe size was configured.
Hot Spare Assigned to Wrong Span
Global hot spares are shared across all spans in a RAID 50. When a drive fails, the controller assigns the hot spare to the degraded span and starts a rebuild. If two drives fail in different spans near-simultaneously, the hot spare can only cover one. Some controller firmware versions have handled this race condition poorly, assigning the spare to the wrong span or beginning a rebuild before the first span finishes its own resync.
URE During Rebuild
A degraded RAID 50 span is a single-parity RAID 5, so a URE on a surviving member in that span behaves like losing a second block with no parity to cover it. Enterprise drives specify a worst-case URE floor of 1 per 10^15 bits, and a single-span rebuild of a four-drive span with 8 TB members reads 24 TB (about 1.9 x 10^14 bits), so the per-span probability against that floor is modest.
The dominant risk is correlated mechanical failure of same-batch survivors during the long rebuild window, not the first read error. What a URE does when it lands is controller-specific: modern PERC and LSI/Broadcom MegaRAID puncture the affected stripe and continue, losing only that stripe, while legacy controllers abort the span.
SMR Member Ejection During Span Rebuild
Shingled Magnetic Recording drives keep only a small Conventional Magnetic Recording media cache. If an SMR drive is used to replace a failed member, the sustained sequential writes the span rebuild generates overflow that cache, and the drive stalls for background reshingling. Hardware RAID controllers read that latency as a dead drive and eject the replacement.
Ejecting the replacement drive does not by itself destroy the array, but it traps the single-parity RAID 5 span in a degraded state, extending the window in which a surviving member can fail. If a surviving member fails before a CMR replacement finishes rebuilding, the span collapses, and because the cross-span stripe interleaves data across every span, the whole logical volume drops offline. This compound rebuild failure is frequently misdiagnosed as total array loss when only one span was destroyed. Consumer WD Red SMR drives (the EFAX line) and Seagate consumer SMR units (Barracuda SMR variants) are widely documented product lines that should never sit in a parity array.
Rebuild Risk
Why Is Rebuilding a Large-Capacity RAID 50 Array Dangerous?
RAID 50 rebuild risk scales with member capacity. Larger drives require longer rebuild windows, and longer rebuild windows mean more time for a second failure to occur in the degraded span.
  • A four-drive span in RAID 50 using 8 TB members holds 24 TB of data (three data drives) plus 8 TB of parity. Rebuilding a failed member requires reading every sector of the three surviving drives: 24 TB of sequential reads. At 150 MB/s sustained (typical for enterprise HDDs under rebuild load), that takes approximately 44 hours.
  • With 16 TB members, the rebuild reads 48 TB. At 150 MB/s, that is approximately 89 hours of sustained I/O. Four days of degraded operation with every surviving drive running at maximum throughput.
  • During this window, every surviving member in the degraded span is under continuous stress. Drives from the same batch, powered on for the same number of hours, operating in the same thermal environment, face correlated failure risk. The drive that failed first was the weakest link; the others are not far behind.
  • URE probability scales with capacity, but only the rebuilding span is read during a span rebuild, so judge it per span. Enterprise drives specify a worst-case 1 URE per 10^15 bits. A rebuild on a four-drive span with 8 TB members reads 24 TB (1.92 x 10^14 bits), and with 16 TB members 48 TB (3.84 x 10^14 bits): against the 10^15 floor that is a modest per-span probability, not a near-certainty. Because each span is single-parity, a URE on a survivor in the degraded span does behave like a second loss in that span, but the larger driver is the correlated mechanical failure of same-batch survivors over the long rebuild window.
If your RAID 50 is degraded: Power down. Do not rebuild, repair, or reinitialize. Label each drive with its slot number and span assignment (if visible in the controller BIOS). Then contact us for a free evaluation. An in-place rebuild of a degraded span forces sustained sequential reads across the survivors under maximum stress, which is exactly why rebuilding a degraded array destroys data.
Process
How Is RAID 50 Data Recovered?
RAID 50 recovery adds a layer of complexity over standard RAID 5 recovery: we must identify which drives belong to which span, reconstruct each RAID 5 sub-array independently, then reassemble the stripe across spans. All work is performed on cloned images. No data is written to your original drives.
  1. Evaluation and span documentation. Record the controller model, firmware version, member count, span configuration, stripe size, and filesystem type. For hardware RAID controllers (Dell PERC, HP Smart Array, Broadcom MegaRAID), we document the BIOS-reported virtual disk configuration and any foreign config or degraded state messages. This step is free.
  2. Write-blocked forensic imaging. Each member drive is connected through hardware write-blockers to PC-3000 or DeepSpar imaging hardware. We clone the full LBA range, including sectors beyond the user-addressable area where controllers store RAID metadata. Drives with mechanical failures (clicking, not spinning, seized motors) receive head swaps on a 0.02 micron ULPA-filtered clean bench before imaging. Imaging uses adaptive retry settings and head-maps to maximize data capture from weak sectors.
  3. Span boundary identification. Using the cloned images, we extract controller metadata from reserved sectors to determine which drives belong to each span. Dell PERC controllers store this in DDF (Disk Data Format) headers; Broadcom MegaRAID uses a proprietary metadata structure at the end of each member. When controller metadata is damaged, we identify span boundaries by analyzing parity distribution patterns across member images: drives within the same span share a parity rotation cycle, while drives in different spans have independent parity sequences.
  4. Per-span RAID 5 reconstruction. Once span membership is established, we load each span's member images into Data Extractor Express RAID Edition and reconstruct the RAID 5 sub-array: detect stripe size, parity rotation direction (left-symmetric, left-asymmetric, right-symmetric, right-asymmetric), member ordering, and data offset. Each span is validated independently with parity consistency checks (XOR of all blocks in each stripe should equal zero).
  5. Stripe-level reassembly. After each span is reconstructed as a virtual RAID 5 volume, we assemble the stripe across spans. This layer interleaves blocks from each virtual sub-array in the order the controller originally wrote them. The span stripe size (which can differ from the within-span stripe size) is detected from data continuity patterns at span boundaries.
  6. Filesystem extraction and verification. The reassembled volume is mounted read-only. R-Studio and UFS Explorer handle filesystem-level recovery for EXT4, XFS, Btrfs, ZFS, and NTFS. Priority data (databases, virtual machines, shared folders) is verified first.
  7. Delivery and secure purge. Recovered data is copied to your target media. After confirmed receipt, all working copies are securely purged on request.
Controller-Specific RAID 50
What Are the Controller-Specific RAID 50 Recovery Challenges?
Each hardware RAID controller family stores RAID 50 span definitions and stripe parameters in a different proprietary format. Recovery requires parsing these formats from raw disk images when the original controller is unavailable or corrupted.
Dell PERC H730 / H740P
Dell PERC controllers store RAID 50 configuration in DDF (Disk Data Format) metadata blocks located in reserved sectors near the end of each member. The DDF header records span count, drives per span, stripe element size, and the virtual disk GUID that ties members to their parent array. When a PERC controller labels drives as "Foreign," the DDF epoch timestamps reveal whether importing the foreign config is safe or would trigger a backward resync from stale data. We read DDF headers from every member image in a hex editor before any assembly decision.
The 9460-16i supports up to 240 virtual drives and arbitrary span configurations. RAID 50 metadata sits in a reserved DDF-variant metadata region at the end of each member. Span assignments are encoded as drive group indices. Data Extractor Express RAID Edition includes a parser for Broadcom MegaRAID metadata, but firmware versions prior to 5.10 used a slightly different offset for the span mapping table. If the automatic parser fails, we extract the span group IDs manually from the raw metadata dump and feed them into the reconstruction as explicit parameters.
Broadcom Tri-Mode 9500 / 9600-Series (NVMe RAID Members)
The Broadcom Tri-Mode MegaRAID line spans two generations, and getting the part right matters because the metadata parser and imaging path both depend on it. The 9560-16i and 9580-8i8e are 9500-series parts: both are built on the SAS3916 RAID-on-Chip (the 16-port RoC; the SAS3908 is the 8-port RoC used on cards like the 9560-8i), the 9580-8i8e adds 8 internal plus 8 external ports, and both present a PCIe Gen4 host interface. The 9670-24i is a distinct 9600-series part built on the SAS4124 RAID-on-Chip with 24G SAS, so we do not treat it as a 9500 member.
"Tri-Mode" means one connector speaks SAS, SATA, and NVMe, so any of these controllers can carry NVMe drives as RAID 50 members, and the span and geometry metadata still sits in a DDF-variant region in the trailing sectors of each member, matching the classic MegaRAID pattern above. We image NVMe members on the PC-3000 SSD with the PC-3000 SSD Extended add-on that provides NVMe support, then reassemble the span set offline in Data Extractor Express RAID Edition against those images.
HP Smart Array controllers store array definitions in both on-disk metadata and the controller's NVRAM-backed cache. RAID 50 span assignments are recorded per-physical-drive in a metadata region that also includes the Smart Storage Battery status flags. If the battery degraded and the controller disabled write caching, pending writes trapped in cache may contain partial span-level stripe data that must be flushed before reconstruction can produce a consistent result. We power the cache module independently to extract any unflushed writes.
LSI MegaRAID 9271-8i / Adaptec SmartRAID 3154-8i
The 9271 uses LSI-proprietary metadata at the end of each member with a configuration-on-disk (COD) structure that encodes span topology and drive group membership. The Adaptec 3154 uses a different metadata layout but follows the same architectural pattern: span assignments stored per-drive, stripe size and parity rotation stored once in a global configuration record. Stripe size and parity rotation are read from each controller's on-disk configuration record rather than assumed from a vendor default. We parse both formats from cloned images using PC-3000 and cross-validate span assignments by checking parity consistency within each detected group.
Virtual Reconstruction
How Is RAID 50 Reconstructed When Controller Metadata Is Lost?
When the controller is dead, replaced, or its metadata overwritten by a firmware update or reinitialization, we determine RAID 50 parameters from the raw data on each member image. This requires identifying three layers: span membership, within-span RAID 5 parameters, and the cross-span stripe configuration.
Span Membership Detection
Drives within the same RAID 5 span share a parity rotation cycle. We analyze the first several hundred stripe offsets across all member images, looking for groups of drives where parity blocks (identifiable by their high-entropy signature relative to filesystem data blocks) rotate in a consistent pattern. Drives that share the same parity cycle belong to the same span. Drives whose parity positions are uncorrelated belong to different spans.
Within-Span Parameter Detection
Once span groups are identified, each span is treated as an independent RAID 5 recovery problem. Data Extractor Express RAID Edition tests common stripe sizes (64 KB, 128 KB, 256 KB, 512 KB) and parity rotation schemes against filesystem anchor points. A correct configuration produces valid EXT4 superblock copies, XFS allocation group headers, or NTFS MFT entries at predictable offsets. An incorrect configuration produces random data at those offsets.
Cross-Span Stripe Assembly
After each span is reconstructed as a virtual volume, the cross-span stripe size must be detected. This is the block size at which the controller alternated between spans. We look for data continuity breaks at regular intervals on the first reconstructed span: where sequential file content abruptly ends and resumes on the next span's reconstructed volume. The interval between these breaks is the cross-span stripe size. Common values match the within-span stripe size, but some controllers allow independent configuration.
Recovery Implications
RAID 50 vs RAID 10: Recovery Implications
RAID 50 and RAID 10 are both nested RAID levels used in enterprise environments, but their failure modes and recovery complexity differ.
AttributeRAID 50RAID 10
Fault toleranceOne drive failure per spanOne drive failure per mirror pair
Capacity overheadLoses one drive per span to parity (higher usable capacity at scale)50% capacity overhead (every drive is mirrored)
Recovery complexityRequires span identification, per-span RAID 5 reconstruction, then cross-span stripe assemblySimpler: identify mirror pairs, find the healthy member of each pair, stripe them together
Same-group double failureTwo drives failing in the same span is unrecoverable through normal means (same limitation as RAID 5 within that span)Both drives in a mirror pair failing loses that pair's data. Recoverable if the failure is electrical and board-level repair restores one member.
Rebuild characteristicsRebuild risk increases with member capacity due to URE probability across large sequential readsRebuild is fast because it only copies one drive, not the entire span
From a recovery perspective, RAID 10 failures are simpler to diagnose and reconstruct. RAID 50 failures require more reconstruction steps and carry higher risk when controller metadata is lost, because the span-level topology adds a layer of parameters that must be detected correctly.
How Much Does RAID 50 Recovery Cost?
RAID 50 recovery pricing has two components: a per-member imaging fee for each drive in the array, plus an array reconstruction fee of $400-$800. RAID 50 arrays typically have more members than single-level arrays, so the total per-drive cost is higher, but the per-drive rate is the same. If we recover nothing, you owe $0.
Per-Member Imaging
  • Logical or firmware-level issues: $250 to $900 per drive. Covers filesystem corruption, firmware module damage requiring PC-3000 terminal access, and SMART threshold failures that prevent normal reads.
  • Mechanical failures (head swap, motor seizure): $1,200 to $1,500 per drive with a 50% deposit. Donor parts are consumed during the transplant. Head swaps are performed on a validated laminar-flow bench before write-blocked cloning.
Array Reconstruction
  • $400-$800 depending on member count, span count, filesystem type (ZFS, Btrfs, mdadm, EXT4, XFS, NTFS), and whether RAID parameters must be detected from raw data versus captured from surviving controller metadata. RAID 50 reconstructions require two levels of assembly (per-span RAID 5 plus cross-span striping), which adds verification steps compared to a flat RAID 5.
  • Data Extractor Express RAID Edition performs parameter detection and virtual assembly from cloned member images. R-Studio and UFS Explorer handle filesystem-level extraction after reconstruction.
No Data = No Charge: If we recover nothing from your RAID 50 array, you owe $0. Free evaluation, no obligation.
Example: An eight-member RAID 50 (two spans of four) with one mechanically failed drive and seven healthy members would cost $1,200 (head swap) + 7 × $250 (logical imaging) + $400-$800 (reconstruction) = approximately $3,350 to $3,750.
RAID 50 Use Cases
Where Is RAID 50 Typically Deployed?
RAID 50 appears in environments that need more capacity than RAID 10 provides but better fault isolation than a single flat RAID 5 array across many drives.
Database Servers
SQL Server and Oracle instances on Dell PowerEdge or HP ProLiant hardware frequently use RAID 50 for data volumes. The striped throughput handles sequential table scans, while per-span parity protects against single-drive failures without the 50% capacity cost of RAID 10. Transaction logs are typically on a separate RAID 1 or RAID 10 volume.
Surveillance and Media Ingest
Video surveillance systems (Milestone, Genetec) and broadcast ingest servers use RAID 50 for sustained write throughput across multiple camera streams or capture channels. Sequential write performance benefits from the cross-span striping, and the per-span parity protects against drive failures during 24/7 recording.
Virtualization Datastores
VMware ESXi and Hyper-V hosts use RAID 50 volumes as shared datastores for virtual machine disk files. The cross-span striping provides parallel I/O for multiple concurrent VM workloads. RAID 50 offers a balance between the capacity efficiency needed for large VM libraries and the fault tolerance required for production workloads.
RAID 50 Recovery Questions
What is RAID 50 and how does it differ from RAID 5?
RAID 50 combines RAID 5 and RAID 0. Two or more independent RAID 5 sub-arrays (spans) are striped together at the span level. Each span provides its own single-parity fault tolerance, and the striping across spans increases throughput. RAID 5 is a flat array across all members; RAID 50 partitions those members into separate parity groups. This means RAID 50 tolerates one drive failure per span rather than one failure across the entire pool.
How many drives can fail in a RAID 50 before data is lost?
RAID 50 tolerates one drive failure per sub-array (span). In a two-span RAID 50, two drives can fail simultaneously as long as each failure occurs in a different span. If two drives fail in the same span, that span loses its parity protection and the entire array goes offline because the stripe-level data across spans is interdependent.
What is the minimum number of drives for RAID 50?
RAID 50 requires a minimum of six drives: two spans of three drives each. Each span needs at least three members to form a valid RAID 5 group (two data, one parity). Enterprise deployments typically use 8 to 16 drives split across two to four spans of four or more drives each.
Why is rebuilding a degraded RAID 50 array dangerous?
A RAID 50 rebuild reads every sector of every surviving drive in the degraded span under sustained sequential I/O. On arrays with 8 TB or larger members, this process takes 24 to 72+ hours. During the rebuild window, any second failure in the same span destroys the array. Drives from the same manufacturing batch share similar wear profiles, so a failure in one drive correlates with elevated failure risk in its neighbors.
When should I use RAID 50 versus RAID 10?
RAID 50 offers better storage efficiency than RAID 10 at scale. RAID 10 mirrors every drive, losing 50% of raw capacity to redundancy. RAID 50 loses one drive per span to parity. In an eight-drive configuration, RAID 10 yields four drives of usable space; RAID 50 with two four-drive spans yields six drives of usable space. RAID 10 provides faster rebuilds and simpler failure isolation. RAID 50 provides higher usable capacity with acceptable read performance for sequential workloads.
How long does RAID 50 data recovery take?
An 8-member RAID 50 where all surviving drives image cleanly takes five to seven business days. Arrays with mechanically failed members that need head swaps or donor sourcing add four to eight weeks per affected drive. The reconstruction phase (span identification, stripe mapping, parity validation, filesystem extraction) typically takes two to three days after all member images are complete. A +$100 rush fee to move to the front of the queue is available to move to the front of the queue.
Degraded RAID 50? Power down, label your drives.
Free evaluation. Offline reconstruction from cloned images. No data = no charge. Mail-in from anywhere in the U.S.
