Seagate Rosewood Data RecoveryST1000LM035 / ST2000LM007
If your Seagate Backup Plus Slim is beeping, stop powering it on. The Rosewood architecture (7mm height, 90g chassis) causes heads to stick to the platter surface. We use specific preamp matching and firmware unlocking to recover these drives daily at our Austin lab.
8 min read
Is Your Drive a Rosewood?
Rosewood is Seagate's internal codename (also known as the Julius family) for their 7mm 2.5-inch mobile drives manufactured from 2016 onwards. According to Aesonlabs, a Canadian data recovery lab, these drives make up 80% of their incoming hard drive recovery volume due to their ubiquity and fragility.
You can identify a Rosewood drive by its thickness (only 7mm) and the top cover. Unlike older drives with a rigid steel lid, Rosewood drives often use a heavy-duty foil sticker as the top seal.
Common Enclosures:
  • Seagate Backup Plus Slim (2016+)
  • Xbox Game Drive (2TB Green/White)
  • PlayStation Game Drive (PS4/PS4 Pro)
  • LaCie Rugged Mini (USB-C)
  • LaCie Porsche Design Mobile
  • Various HP, Dell, Lenovo Laptops (7mm bay)
Model Number Reference
ModelCapacity
ST1000LM0351TB
ST2000LM0072TB
ST2000LM0152TB
ST1000LM0481TB
ST500LM030500GB
ST2000LM0092TB
ST1000LX0151TB
Check the label on the internal drive assembly. If it starts with ST and contains LM, it is likely a Rosewood.
Why Rosewood Drives Fail
To fit 2TB into a 7mm profile, Seagate made engineering compromises. Understanding these failures helps explain why professional recovery is necessary.
90 Grams, No Torque
The Rosewood chassis weighs only 90 grams. The spindle motor is miniaturized to fit the 7mm z-height. When the heads contact the platter (stiction), the motor lacks the torque to break them free. It tries to spin, fails, and emits the characteristic beep code.
The SMR Kill Command
These drives use Shingled Magnetic Recording (SMR) with a complex Media Cache (MCMT). Running standard repair commands like m0 (translator regeneration) on a Rosewood will wipe the Media Cache, permanently destroying the mapping to your data.
Locked F3 Terminal
Unlike older drives, the firmware terminal is locked by default. Accessing the System Area to fix corruption requires a specialized handshake to patch the ROM in RAM. Without this, the drive remains in a BSY state and will not mount. This procedure is covered in the ACE Lab Seagate Advanced certification.
The Physics of Data Destruction
Why the Freezer Trick Kills Rosewoods
A common myth suggests freezing a drive to shrink metal components. On a Rosewood, this is fatal. When you remove a drive from a freezer (-18°C) to room air, water vapor condenses instantly on the platters. Because modern read heads fly on an air bearing less than 10 nanometers thick, even microscopic condensation droplets act as massive physical obstacles.
Spinning the drive with this condensation creates an immediate head crash, equivalent to a plane hitting a mountain. The slider shatters, and the data is scraped off.
The Software Risk
If your drive is beeping, software cannot help. The beep is the sound of the motor failing to spin.
Every time you plug it in, the drive attempts to spin up. If the heads are stuck or physically damaged, they drag across the micro-smooth platter surface. Repeated power-on attempts will permanently strip the magnetic coating, leaving a ring of bare aluminum and rendering the data unrecoverable.
Our Recovery Process
We don't just swap parts and hope things are fixed. Recovery from rosewood drives requires a protocol that respects the drive's unique architecture. Our lead technician holds the ACE Lab Seagate Advanced certification, which specifically covers Rosewood firmware unlocking and Media Cache repair.
  1. Preamp Matching: We validate the donor part not just by model, but by the preamp vendor code (Agilent, TI, or LSI) found on the head connector. A mismatch here means the heads won't read, even if they fit physically.
  2. Safe Unstick: We use specialized tools to lift the heads vertically off the platter before moving them to the ramp. Dragging them back, which is a common amateur mistake, leaves scratches.
  3. Firmware Stabilization: We patch the ROM to unlock the terminal, then modify System File 93 to disable background processes. This stops the drive from trying to reorganize itself during the imaging process.
  4. MCMT Repair: If the Media Cache Management Table (Sys File 348) is corrupt, we reconstruct it in RAM to allow access to user data without triggering the translator paradox.
Turnaround Times
  • Firmware-only (drive spins)3-6 weeks
  • Head unstick/swap4-8 weeks
  • Multiple donor attempts4-8 weeks
Already Tried DIY?
If you powered it on once or twice, damage is typically limited to a small area of the platter and recovery is still viable. If you ran multiple scan attempts, the damaged area is larger. We will tell you during evaluation if the damage is too severe to justify the cost.
Media Cache (MCMT) and System File 93
Rosewood drives use an aggressive SMR caching layer called the Media Cache Management Table (MCMT), stored in System File 348. Incoming writes land in a conventional (CMR) cache zone first, then the firmware migrates them to the shingled bands during idle time. If this migration fails mid-write, the MCMT becomes inconsistent: the firmware knows data exists in cache but cannot locate the destination band.
The standard Seagate repair command m0 (translator regeneration) is fatal on Rosewood drives. It wipes the entire MCMT, destroying the only map that links cached writes to their final LBA locations. Data that was pending migration is permanently lost.
Our approach starts with System File 93, which controls the SMP (System Management Process) flags. We patch these flags to disable all background auto-repair, defragmentation, and cache migration before we attempt to read any user data. This freezes the drive's internal state and prevents the firmware from making the corruption worse during imaging.
Why Standard Recovery Destroys Rosewood Data
  1. Technician connects drive and sees BSY state
  2. Runs m0 to regenerate translator (standard fix for older Seagates)
  3. Command wipes the Media Cache Management Table
  4. All data pending migration from cache to shingled bands is lost
  5. Drive appears "fixed" but large portions of user data are now zeros
Our Process
  1. Unlock ROM to access the F3 terminal
  2. Patch System File 93 SMP flags to disable auto-repair
  3. Read MCMT (Sys File 348) to verify cache integrity
  4. If MCMT is intact, image user data through the cache layer
  5. If MCMT is partially corrupt, reconstruct the mapping from fragments
Legacy BSY Terminal Commands and Rosewood MCMT Destruction
If you found a guide online for fixing a Seagate drive stuck in a BSY (Busy) state using terminal commands, that guide was written for legacy 7200.11 and ES.2 drives. Those older drives used a Digital Signal Processor (DSP) where the LBA-to-PBA translation was a static math equation based on two defect lists: the P-List (factory defects) and the G-List (grown defects). Running m0,2,2 on a DSP-based drive told the processor to recount those static lists and rebuild the sector map. No user data moved during this process. This type of firmware corruption on legacy drives was a known, reversible condition.
Rosewood drives replaced the DSP with an ARM Cortex controller to handle the computational overhead of Shingled Magnetic Recording. The ARM controller does not use static defect lists for translation. It maintains a live, dynamic database called the Media Cache Management Table (MCMT) in System File 348, which tracks data moving between the CMR write cache and the final shingled bands. When you issue m0,6,2,,,,,22 to a Rosewood, the ARM controller formats the translator by wiping the MCMT. The physical magnetic data remains on the platters, but every pointer linking your cached files to their destinations is erased. The drive may report Ready status afterward. Attempting to read the user area returns zeros or ABR (Abort) errors.
The LED Lock State: Microcode Overlay Error
Rosewood drives produce a second firmware lock state distinct from legacy BSY. When the System Area sectors containing the firmware overlay are unreadable (bad sectors or weak preamp output), the ARM Cortex controller halts during bootcode execution and outputs:
Bad CRC Seg:0x06 LED:0x000000BB FAddr:0x00004300
The solid activity LED indicates a hard lock, not a processing loop. The standard Ctrl+Z terminal interrupt will not work. Recovery requires reading the ROM via COM port, generating an unlock patch for the specific firmware revision, and writing the patched ROM back to bypass the Diagnostic Port Lock before any System File access is possible.
If your Rosewood drive shows this error, it requires professional data recovery with specialized firmware tools. We handle this specific failure mode as part of our Seagate firmware repair workflow using PC-3000.
Commands That Destroy Rosewood Data
  • m0,6,2,,,,,22 / m0,6,3,,,,,22 : Translator regeneration. Wipes the entire MCMT. Data pending cache migration is permanently lost.
  • i4,1,22 : G-List clear. Destroys the Non-Resident G-List (SysFile 35), causing sector-shifting that misaligns the file system.
  • N1 : SMART clear. Destroys diagnostic telemetry needed to assess preamp degradation.
Correct PC-3000 Workflow
  1. Read the original ROM via COM port before any terminal interaction
  2. Apply a Tech Mode unlock patch to the ROM in RAM (not permanent)
  3. Back up all adaptive parameters: SysFiles 1B, 28, 35, 93, and 348
  4. Patch SysFile 93 SMP flags to disable background cache migration
  5. Parse and verify SysFile 348 (MCMT) before imaging
If you already ran m0 or i4,1,22 on a Rosewood drive, power it off immediately. Further power cycles allow the ARM controller to overwrite remaining extents map fragments. We reconstruct damaged MCMT mappings using PC-3000's parsing plugin as part of our hard drive data recovery process, but the longer the drive runs after a destructive command, the less recoverable data remains. Contact us for a free evaluation; if no data is recovered, there is no charge.
Watch Real Rosewood Recovery
See the process for yourself. These videos from our YouTube channel demonstrate the specific challenges of the Rosewood architecture.
Head unstick procedure on a beeping drive
Complete recovery workflow and explanation
Transparent Pricing
We do not use bait-and-switch quotes. You get a firm quote after our free evaluation. If the data is unrecoverable, you pay nothing.
Service TierRossmann PriceDescription
Firmware / Logical$600–$900Drive spins but is not detected. Includes unlocking the diagnostic port and repairing the translator.
Beeping / Stiction (Heads Reusable)$600–$900Heads stuck to platters but undamaged after inspection. We unstick and reuse the original heads. No donor drive needed. Bench labor + PC-3000 imaging.
Beeping / Head Swap (Heads Damaged)$1,200–$1,500Heads stuck and damaged from the stiction event. Full donor head transplant required. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available.
Severe Damage$0 (Unrecoverable)If the magnetic coating is stripped (rotational scoring), we tell you the truth and charge $0.
DriveSavers / Big Labs$2,000 - $7,000Same Rosewood head swap procedure using the same PC-3000 tools.
Why is my Seagate Backup Plus Slim beeping?
The beeping sound is the motor stalling. Seagate Rosewood drives (ST2000LM007) have a lightweight 90g chassis and insufficient motor torque. When heads contact the platters, they stick. The motor tries to spin, fails, and emits a beeping noise.
What happens if I run recovery software on a beeping Rosewood?
Software sends a spin-up command. The motor applies torque. Because the heads are stuck, they drag across the platter surface, scraping off the magnetic data layer. Repeated attempts will permanently destroy the data.
Can I use the freezer trick on a Seagate Rosewood?
No. When you remove a drive from a freezer, water vapor condenses instantly on the platters. Because modern read heads fly on an air bearing less than 10 nanometers thick, even microscopic condensation droplets act as massive physical obstacles. Spinning the drive causes an immediate head crash and rotational scoring.
Why is Rosewood recovery more difficult than older drives?
Rosewood drives use Shingled Magnetic Recording (SMR) with a complex Media Cache Management Table (MCMT). Standard repair commands like m0 (translator regeneration) wipe this table on Rosewood drives, permanently destroying data. They also require unlocking the ROM to access the diagnostic terminal.
How much does it cost to recover a Seagate Rosewood?
Firmware repairs (drive spins but not detected) cost $600–$900. For beeping Rosewood drives, the price depends on head condition. If the heads are stuck to the platters but undamaged (stiction-only), we unstick and reuse them with no donor drive needed; this falls into the firmware-tier range at $600–$900. If the heads are stuck and damaged, a full donor head swap is required at $1,200–$1,500 plus donor drive cost. Head condition can only be determined after opening the drive and inspecting under magnification on the clean bench. If no data is recovered, there is no charge.
Can I fix a BSY Rosewood drive with terminal commands?
No. The terminal BSY fix circulating online was designed for legacy Seagate 7200.11 drives with DSP-based controllers and static defect lists. Rosewood drives use an ARM Cortex controller with a dynamic Media Cache Management Table (MCMT). Running m0 or i4,1,22 on a Rosewood wipes the MCMT, permanently orphaning cached data. The drive may show Ready status afterward, but the user area returns zeros or ABR errors because the translation pointers no longer exist.
What does LED:0x000000BB mean on a Seagate Rosewood drive?
LED:0x000000BB is a Microcode Overlay Error. The firmware overlay failed to load from the System Area into RAM, leaving the drive in a hard lock with a solid activity LED. Standard Ctrl+Z terminal interrupt will not work. The ROM must be read via COM port or external programmer, patched to bypass the Diagnostic Port Lock, and written back before the terminal becomes accessible. This requires PC-3000 or equivalent firmware tools.
Not a Rosewood? Browse all drive families for Barracuda, IronWolf, Exos, WD, Toshiba, HGST, and Samsung.
All HDD Recovery →
Rosewood drive beeping?
Stop powering it on. Mail it to our Austin lab for evaluation. No data, no charge.
