“All I can say is.. WOW. I spilled water on my laptop and couldn't find anywhere that would fix it, I kept thinking I would have to pay $1000+ for data recovery (always backup your files, kids) and thankfully I found Rossmann! I mailed it in right away! They do water damage, no problem. Patrick was great and super helpful through the process and made everything smooth sailing. They also fixed my Mac within 48 hours and shipped it right back out to me. It was like all I did was shutdown the computer!”
USB Flash Drive Data Recovery Services
Thumb Drives, USB Sticks, and Portable Flash Storage
Your USB flash drive is not recognized, shows as RAW, or asks to be formatted? We recover data from controller failures, NAND corruption, and physically damaged flash drives. Our Austin lab handles everything from simple file recovery to complex chip-off procedures.
No Data, No Charge. USB recovery: $200-$1,800 depending on failure type.
USB Flash Drive Failures We Recover
USB flash drives fail differently than hard drives. They have no moving parts, but the controller chips and NAND flash memory can still fail in multiple ways.
Controller Failures
The controller chip manages communication between your computer and the NAND flash memory. When it fails, the drive may not be recognized at all, or show as 0 bytes capacity.
Common controllers: Phison, Silicon Motion (SMI), JMicron, Alcor, Innostor
Recovery approach: Controller repair, firmware reload, or direct NAND chip reading if controller is dead.
These same controller families (Phison, Silicon Motion) also power SATA and NVMe SSDs, so USB flash drive firmware failures follow similar diagnostic patterns.
NAND Flash Corruption
NAND flash memory wears out over time (limited write cycles). Cheap flash drives use lower-quality NAND that degrades faster, leading to bad blocks and data loss.
Symptoms: Files corrupted, drive becomes read-only, random data errors, shrinking capacity.
Recovery approach: Raw NAND dump, error correction, file system reconstruction.
Physical Damage
USB flash drives are vulnerable to physical damage: bent or broken connectors, cracked PCBs, water damage, or drives that have been stepped on or run over.
Symptoms: Visible damage, intermittent connection, drive not recognized.
Recovery approach: Connector repair, PCB jumper wires, or chip-off if PCB is destroyed.
File System Issues
If the drive is still recognized but shows as RAW, asks to format, or files are inaccessible, the file system metadata is damaged but data may be intact.
Causes: Improper ejection, power loss during write, malware, accidental format.
Recovery approach: File system repair, partition table rebuild, file carving from raw data.
PCB-Level Micro-Soldering for Broken USB Connectors
Broken USB connectors are one of the most common physical failures we see. The USB-A, USB-C, or Micro-USB plug gets bent, snapped, or ripped clean off the PCB. When the connector separates, it often tears the copper traces and solder pads that carry data and power signals between the connector and the controller chip.
We repair these under a stereo microscope at 20-45x magnification. Each torn trace is bridged with 0.1mm or thinner magnet wire, soldered directly to the exposed copper. If the original pads are destroyed, we scrape back the solder mask to expose fresh copper further up the trace and solder the replacement connector there. The four critical lines (VCC, D+, D-, GND) must all make solid contact before the drive will enumerate on a USB bus.
Once the connector is repaired and the drive enumerates, we image it sector-by-sector before any file recovery. This avoids stressing the repaired connection with repeated access. Connector repairs run $400-$800 depending on the number of torn traces and how close the break is to the controller's BGA pads.
Monolith USB Flash Drive Recovery
Many modern USB flash drives use a "monolith" design where the controller and NAND flash are encapsulated together in a single chip package. These drives are smaller and cheaper but much harder to recover when the controller fails.
The challenge: There are no separate NAND chips to remove and read directly. Recovery requires micro-soldering wires directly to the chip die to access the NAND memory.
Our approach: We have specialized equipment and adapters for monolith flash recovery. While more expensive than standard chip-off, we can recover data from many monolith drives that other labs cannot handle.
Pinout Mapping with Probe Stations
Most monolith flash drives have no published schematics. To read the integrated NAND, we first identify the test points on the chip package using a logic analyzer and spider board adapters. Each test point is probed to determine which trace carries data (I/O lines), which carries commands (CLE/ALE), and which supplies power (VCC/GND). Once the pinout is mapped, the spider board makes direct contact with the memory array for raw extraction. Our monolith pinout database covers known configurations for common chip families, which speeds up identification when a matching entry exists.
Monolith vs Standard Flash Drive
| Feature | Standard | Monolith |
| NAND Chips | Separate | Integrated |
| Chip-off possible | Yes | Limited |
| Recovery difficulty | Moderate | High |
| Cost range | $200-$1,500 | $1,200-$1,500 |
How We Recover Data from USB Flash Drives
Every USB flash drive recovery starts with a free evaluation. We identify the failure type before quoting a price, so you know the cost before any billable work begins.
- 1
Visual and electrical inspection
We check for physical damage: broken connectors, cracked PCBs, burn marks, or bent pins. If the connector is damaged, we assess whether it can be re-soldered or if direct NAND access is needed.
- 2
Controller and firmware diagnosis
If the drive powers on but is not recognized, we identify the controller chip (Phison, Silicon Motion, Alcor, etc.) and attempt firmware-level repair using manufacturer-specific tools.
- 3
Imaging or chip-off
For working controllers, we create a sector-by-sector image. For dead controllers or destroyed PCBs, we desolder the NAND chips, read them in a programmer, and reconstruct the data using the controller's ECC algorithm and block mapping.
- 4
File system reconstruction and verification
We rebuild the file system from the raw image, verify file integrity, and present a file listing. You approve the results before we transfer your data to a new drive.
Chip-Off NAND Extraction
When the controller chip is dead and firmware repair is not possible, we bypass it entirely by removing the NAND memory chips from the PCB. Standard USB flash drives use discrete NAND in TSOP-48, BGA-152, or TLGA packages soldered to the board. We desolder these chips using a controlled hot-air reflow station at 280-320°C with a preheater to avoid thermal shock to the silicon die.
Each desoldered chip is placed into a PC-3000 Flash reader socket matched to its package type. The PC-3000 Flash module reads the raw NAND pages independently of the original controller. This produces a raw memory dump that contains your data, but scrambled by the controller's wear-leveling algorithm and XOR data whitening pattern. The process is the same technique used for SSD chip-off recovery, but USB flash NAND is simpler because flash drives typically use single-die packages rather than multi-die BGA stacks.
NAND Dump Reassembly and ECC Correction
A raw NAND dump is not a usable disk image. The original controller arranged data across pages and blocks using a Flash Translation Layer (FTL). To reconstruct a readable image, we determine three parameters: the XOR pattern (the scrambling key the controller applied to each page), the page geometry (how data bytes, spare area, and ECC bytes are laid out within each NAND page), and the block mapping order.
PC-3000 Flash's Data Extractor utility automates most of this for known controller families (Phison, Silicon Motion, Alcor Micro). For unknown controllers, we use the built-in XOR analyzer to brute-force the scrambling key and the ECC module to correct bit errors that accumulated from NAND cell degradation. Once the FTL is reconstructed, the output is a standard disk image with your original file system intact.
The same NAND extraction and FTL reconstruction workflow extends to full-size SSD recovery cases. SSD NAND uses more complex multi-die BGA packages with different page geometries and ECC algorithms, but the general XOR analysis and dump reassembly approach is similar.
JTAG Access and Controller Bypass
Some USB flash drive controllers expose JTAG (Joint Test Action Group) debug ports or boundary scan interfaces on the PCB. These test points were placed by the manufacturer for factory testing and firmware programming. When the primary USB interface is unresponsive due to firmware corruption or a locked controller state, JTAG provides a secondary path to the memory.
We connect a JTAG adapter to the debug pins and use boundary scan commands to read the controller's internal registers and, in some cases, access the NAND directly through the controller's memory bus. This is less invasive than a full chip-off because the NAND chips stay soldered to the board. It works on a subset of controllers (primarily older Phison and SSS designs) where the JTAG interface was not disabled in production firmware. Embedded memory controllers used in eMMC devices also expose similar test points, and the technique carries over.
Watch: USB Flash Drive Recovery in Our Lab
Louis walks through a USB flash drive recovery after the customer destroyed the drive during a DIY chip-off attempt. Micro-soldering repairs on ripped pads, bent pins, and damaged traces, followed by NAND chip swapping.
USB Flash Drive Recovery Pricing
USB flash drive recovery costs depend on the type of failure. Simple file system issues are cheapest; controller failures and chip-off procedures cost more.
| Failure Type | Price Range | What's Involved |
| File System / Logical Issues | $200-$400 | Drive recognized, partition repair, deleted file recovery, RAW file system. |
| Controller Failure (Standard) | $400-$1,000 | Drive not recognized, firmware reload or NAND chip-off recovery. |
| Physical Damage / Connector Repair | $400-$800 | Broken USB connector, cracked PCB, micro-soldering required. |
| NAND Chip-Off Recovery | $800-$1,500 | Remove NAND chips, read directly, reconstruct data from raw dump. |
| Monolith Drive Recovery | $800-$1,800 | Integrated controller/NAND, requires micro-wire soldering to access memory. |
We provide a firm quote after evaluating your drive. No surprises. If it turns out to be simpler than expected, you pay the lower price.
See our clean bench validation data and particle test videoWhat NOT to Do With a Failed USB Flash Drive
Avoid These Mistakes
- ✗Do not format the drive. When Windows asks to format, clicking Yes overwrites critical data structures.
- ✗Do not keep plugging it in repeatedly. If the drive has electrical damage, each connection can cause more damage.
- ✗Do not try to repair the connector yourself. USB connectors require precision soldering. Poor repairs can destroy traces.
- ✗Do not use low-quality recovery software. Some tools make aggressive write attempts that can corrupt NAND further.
Safe Steps to Take
- ✓Stop using the drive. The less you use it, the better your recovery chances.
- ✓Note what happened. When did it fail? What were you doing? Any error messages? This helps diagnosis.
- ✓Check if it is recognized. Open Disk Management (Win+X) and see if the drive appears, even as unknown.
- ✓Get a professional evaluation. We diagnose for free and tell you exactly what is wrong before any billable work.
What Customers Say About Flash Media Recovery
“They are the best! My daughter spilled water on her keyboard. Apple store would charge $750 even though we still are in warranty saying they don't cover water damage. Rossmann group fixed it would Q-tips and didn't charge me anything! just told me "next time bring in something really broken". Will tell all my friends to go here for tech need!”
“These guys are awesome! Called a bunch of shops around San Antonio and they all said the whole motherboard would need to be replaced after I spilled water on mine and it would cost me around 1000$ to fix it, not only that, all my data would be lost (might as well buy a new laptop).”
USB Flash Drive Recovery: Common Questions
Can data be recovered from a USB flash drive?
Yes. USB flash drive data recovery is possible in most cases. Even when a flash drive is not recognized, shows as RAW, or has physical damage, the NAND flash chips containing your data are often intact. Professional recovery can access the chips directly if the controller fails.
How much does USB flash drive recovery cost?
USB flash drive recovery costs $200 for a simple copy, from $250 for file system recovery, $450 for PCB repair, and $1,200 to $1,500 for chip-off NAND extraction (50% deposit required). All prices plus tax. No data, no charge.
Why is my USB flash drive not recognized?
Common causes include controller chip failure, damaged USB connector, NAND flash corruption, firmware bugs, or file system damage. If the drive is not recognized at all, it usually indicates controller or physical damage rather than simple file system issues.
Can you recover data from a broken USB stick?
Yes. Physical damage like broken connectors, bent plugs, or snapped PCBs can often be repaired or bypassed. In severe cases, we remove the NAND flash chips and read them directly. The key factor is whether the NAND chips themselves are damaged.
How long does USB flash drive recovery take?
Simple copies take 3-5 business days. Controller and PCB failures take 3-6 weeks. Chip-off recovery takes 4-8 weeks. Monolith drives requiring micro-soldering may take longer. A +$100 rush fee to move to the front of the queue is available to move to the front of the queue.
What brands of USB flash drives do you recover?
We recover data from all USB flash drive brands including SanDisk, Kingston, Samsung, PNY, Lexar, Corsair, Verbatim, and generic drives. The brand matters less than the controller chip inside.
What is chip-off data recovery for a USB flash drive?
Chip-off recovery is used when a flash drive's controller or circuit board is permanently dead. We desolder the NAND memory chips (TSOP-48, BGA, or TLGA packages) from the broken board and read them in a PC-3000 Flash module. The raw dump is then reassembled using the correct XOR pattern, page geometry, and ECC algorithm to reconstruct your files.
Can you fix a USB flash drive with a broken connector?
Yes. If the USB-A, USB-C, or Micro-USB connector has snapped off the circuit board, we use microscope-assisted micro-soldering to repair torn traces and re-attach a new connector. This restores the electrical connection so we can image the drive and extract data without a full chip-off procedure. Connector repair falls under our PCB repair tier ($450). If the damage is severe enough to require chip-off, that tier is $1,200 to $1,500.
Related Data Recovery Services
USB flash drive not working?
