External Hard Drive Data Recovery
Air-filled HDDs $100–$2,000 | Helium desktop externals $200–$5,000+ | Nationwide Mail-In
External hard drives fail for two reasons: the USB enclosure dies, or the internal drive mechanism fails. When the enclosure is the problem, the drive inside is often intact and recovery is straightforward. When the internal drive clicks, beeps, or is not detected, we use the same head swap and firmware repair techniques as any other HDD recovery.
Many WD My Passport drives add a complication: the USB board encrypts data by default. If that board fails, connecting the mechanism outside the original USB path can show only encrypted gibberish. We preserve the original encryption path or extract the required key metadata with PC-3000 when the model supports that workflow.
Updated May 2026
9 min read
Why Do External Hard Drives Fail?
External hard drives fail when the USB bridge board or native USB PCB dies, the internal drive mechanism sustains physical damage, or the drive firmware becomes corrupted. Board failures are common; the internal mechanism can still be intact and recovery starts at $100.
Firmware corruption causes the drive to spin without being recognized. If it failed mechanically from a drop or a seized motor, it has to go on our clean bench.
Most external hard drives are internal mechanisms inside a plastic or metal shell. Some use a USB-to-SATA bridge board, while some portable models use a native USB PCB. Either the board or the drive mechanism can fail independently.
USB Bridge/Enclosure Failure
A common cause of a dead external drive. The bridge chip fails, the USB connector cracks, or a voltage regulator blows. The internal drive is fine.
Recovery: Remove the drive from the enclosure and image it directly. $100.
Warning: Don't take a WD My Passport out of its enclosure without professional help.
Dropped While Spinning
Portable drives travel in backpacks and get knocked off desks.
Recovery: Head swap in our ULPA-filtered clean bench. $1,200–$1,500.
Power Surge Damage
Using the wrong power adapter or experiencing a surge can blow the TVS diodes on the PCB. The drive may be silent but the protection circuit saved the data.
Symptoms: Drive completely dead, no spin, no lights, possibly burnt smell.
Recovery: PCB repair or replacement with ROM transfer. $600–$900.
Firmware Corruption
The drive spins but the computer does not recognize it, or it shows the wrong capacity. The Service Area modules on the platters are damaged or the translator table is corrupt.
Recovery: Translator rebuilding. $600–$900.
What Customers Say
Andrew Hansen
Kyle Hartley (crazybangles)
Christopolis
Patrick Dughi
Can You Repair an External Hard Drive Instead of Recoveri...
Can You Repair an External Hard Drive Instead of Recovering It?
Once the factory seal is broken, we don't get the original mechanism working again. We copy your data onto a healthy drive.
When we open a drive in our ULPA-filtered clean bench to perform a head swap, the goal is solely to stabilize the mechanism long enough to extract data to a healthy drive.
Why PCB Swaps Fail
Buying a matching Printed Circuit Board online and swapping it will not work. Every PCB contains a ROM chip programmed with unique adaptive parameters for that specific mechanical assembly. Recovery requires preserving the original ROM data and matching it to a compatible donor board before PC-3000 can access the firmware modules.
What Recovery Actually Produces
The outcome of hard drive data recovery is your files on a new, healthy drive. Once the factory seal is broken and donor heads are installed, the original mechanism cannot be returned to reliable working condition. We image sector by sector using PC-3000 and deliver recovered data on a transfer drive.
External Hard Drive Repair Cost vs. Data Recovery Cost
External Hard Drive Repair Cost vs. Data Recovery Cost: How Do They Differ?
External hard drive repair and data recovery are different jobs. Repairing the hardware for reuse is rarely cost-effective. Recovering data ranges $100–$2,000 for air-filled mechanisms and $200–$5,000+ for helium-sealed desktop externals, depending on the failed component. PCB and connector repair are stabilization steps for imaging; the original drive is not returned to daily-use condition.
Intent 1: Repair the hardware so the drive can be reused
A snapped USB connector, a blown TVS diode, or a damaged voltage regulator can be reworked at the board level. The work uses Hakko micro-soldering for through-hole and small SMD pads. Surface-mount rework on the larger pads is handled with the Atten hot-air station. These repairs are performed strictly to bring the drive into a stable state for imaging. Once the drive is opened in the ULPA-filtered clean bench, or once a native USB board has been hand-soldered with jumper wires to a SATA breakout, the original mechanism is no longer fit for continued daily use. For a healthy drive that just needs a port replaced and is not being imaged, buying a replacement external is usually cheaper than paying any lab to rebuild the existing one.
Intent 2: Recover the data off a failed external drive
Cost is set by which component failed and which workflow is required. Bridge or enclosure failure with a healthy internal mechanism is a Tier 1 simple copy starting at $100. Filesystem corruption starts at $250. Firmware Service Area corruption or WD encrypted-bridge work that requires PC-3000 Portable III is $600–$900. A clean-bench head swap with donor matching is $1,200–$1,500. Surface damage with platter cleaning and a fresh donor head stack is $2,000. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available. For desktop externals with verified helium mechanisms, we use our helium HDD pricing.
Why "repair" almost always means recovery for a clicking or dead drive
On a drive that is clicking, undetected, or has stopped spinning, the component that has actually failed is either inside the sealed mechanism (the read/write heads, the spindle motor, or the firmware Service Area) or, on some WD models, on the external PCB where the AES encryption MCU lives. None of those repairs leave the drive in a state suitable for long-term reuse. The cost of imaging the stabilized drive onto fresh media is the cost of getting the data back. Buying a replacement enclosure or new external is a separate, post-recovery step at retail prices.
No diagnostic fees. Free evaluation before any paid work. No data, no recovery fee. Rush placement: +$100 rush fee to move to the front of the queue.
Why Does Direct SATA Connection Fail on Encrypted WD My P...
Why Does Direct SATA Connection Fail on Encrypted WD My Passport Drives?
Direct SATA connection fails on many WD My Passport drives because sectors on the platters are encrypted with AES-256 through the original USB board path. The Data Encryption Key can live in board firmware, controller state, or service-area metadata depending on the model. Removing the drive can produce encrypted gibberish.
Some WD bridge controllers encrypt sectors on-the-fly, even if you never set a password. The key path depends on the controller family and board firmware, which is why the original USB board matters during recovery.
Many WD My Passport and My Book models use hardware AES-256 encryption through the USB board. This encryption can be active even if you never set a password. The board generates a Data Encryption Key (DEK) stored in board firmware or related service-area metadata, depending on the controller family.
When the USB board fails, many users or repair shops remove the internal 2.5" mechanism and connect it outside the original USB path. The data on the platters is encrypted. The result is gibberish. The drive appears to work, but every file is unreadable. This is not corruption; the data requires the original encryption key to decode.
Depending on the model, we preserve the original USB path, read key metadata from board flash, or extract the required service-area metadata with PC-3000. The goal is to reconstruct the encryption path before imaging the drive.
Do not remove a WD Passport drive from its enclosure.
If you already have, stop. Do not format or write to the drive. Send both the drive and the original bridge board.
If you set a password on your WD drive, you will need to provide it for recovery.
Affected WD Models
  • My Passport (many hardware-encrypted models)
  • My Passport Ultra
  • My Book (desktop models)
Encryption Bridge Repair Cost
Bridge-only failure with healthy internal drive: $100 if no encryption is involved. Encrypted WD models requiring DEK extraction fall into the firmware tier at $600–$900. If the internal drive also needs mechanical work, we quote the combined mechanical and encryption workflow after evaluation.
What External Hard Drive Brands Do We Recover?
We recover data from all major external hard drive brands: Western Digital, Seagate, LaCie, Toshiba, G-Technology, Buffalo, & Transcend. The internal drive mechanism determines recovery cost, not the enclosure brand.
Western Digital
  • WD My Passport
  • WD My Passport Ultra
  • WD My Book
  • WD Elements
  • WD Easystore
  • Seagate Backup Plus
  • Seagate Expansion
  • Seagate One Touch
  • Seagate Portable Drive
  • Seagate Game Drive
LaCie
  • LaCie Rugged
  • LaCie Rugged Mini
  • LaCie Porsche Design
  • LaCie d2
  • LaCie Mobile Drive
Other Brands
  • Toshiba Canvio
  • G-Technology G-Drive
  • Buffalo MiniStation
  • Transcend StoreJet
How Do We Recover External Hard Drives with PCB Failures?
External hard drive PCB failures are diagnosed by inspecting board-level components for burnt TVS diodes, failed voltage regulators, or cracked solder joints. Recovery may require preserving ROM data, repairing the original board, or pairing the drive with a compatible donor board before imaging the drive directly via PC-3000.
Here's the PCB from an older LaCie Rugged external drive. The enclosure failed, but the drive inside was fine.
How Much Does External Hard Drive Recovery Cost?
External hard drive recovery pricing is based on the internal drive and failure type. Air-filled externals use standard HDD pricing from $100–$2,000. Desktop externals with verified helium mechanisms use helium HDD pricing from $200–$5,000+ for mechanical work. No diagnostic fee. No data, no charge.
Encrypted WD models with a failed bridge require firmware-tier work ($600–$900) for encryption key extraction. Helium-sealed desktop internals are priced from the helium HDD table below. For a tier-by-tier breakdown across every failure type, see the full hard drive recovery cost guide.
Air-filled external HDD pricing
Helium-sealed desktop external HDD pricing
    From $600
    $3,000–$4,500
    $4,000–$5,000
Helium cost
What Factors Determine External Hard Drive Recovery Cost?
Recovery cost depends on which component failed: the USB bridge board, the drive firmware, or the read/write heads. Bridge-only failures start at $100. Firmware corruption costs $600–$900. Head swaps cost $1,200–$1,500 because they require donor parts & clean bench work.
Failure TypeSymptomsRecovery TierTypical Turnaround
Bridge/Enclosure FailureDrive not detected; no unusual sounds$1003-5 business days
File System CorruptionRAW partition; "needs to be formatted" promptFrom $2502-4 weeks
Firmware CorruptionSpins but not recognized; wrong capacity shown$600–$9003-6 weeks
Head Swap (Mechanical)We found failed read/write heads on the bench$1,200–$1,5004-8 weeks
Surface/Platter DamageSevere head crash; visible scoring on platters$2,0004-8 weeks
WD Encryption Bridge RepairWD Passport/My Book bridge dead; data shows as gibberish via SATA$600–$900 (encryption adds firmware-tier work)3-6 weeks
Bridge or Enclosure Failure
The USB bridge board died & the drive inside is healthy. We bypass the failed board when the model allows it and image through PC-3000. Minimal lab time, no clean bench work required.
Firmware Corruption
The drive spins but is not recognized. The Service Area modules or translator table on the platters are damaged. Requires PC-3000 firmware-level access to rebuild the translator and restore drive identification.
$1,200–$1,500 to $2,000
Mechanical Failure
The read/write heads crashed after a drop. We have to source exact-match donor heads, swap them in our ULPA-filtered clean bench, and image the drive sector by sector on PC-3000 for error-tolerant reads.
Encrypted WD My Passport or My Book models with a failed bridge require firmware-tier recovery at $600–$900. This covers preserving or reconstructing the bridge encryption path, reading supported metadata with PC-3000, and imaging only after the decrypted data path is available.
What Should You Do When Your External Hard Drive Fails?
Disconnect the drive immediately & stop all power cycles. Clicking or grinding means physical damage, and it gets worse every time you power it on. Do not run recovery software or CHKDSK on a drive making abnormal sounds.
Both CHKDSK & recovery software force read attempts that can scratch platter surfaces & destroy data permanently. If the drive is making abnormal sounds, leave it powered off and review how to choose a competent recovery lab before sending it anywhere.
Safe First Steps
  • Stop using it immediately. The less you use a failing drive, the better your recovery chances.
  • Try a different USB cable. Try a known-good cable first.
  • Try a different USB port or computer. Rule out port or driver issues before assuming the drive is dead.
  • Note any sounds. Write down what you heard and when it started, then leave the drive off. It is useful case history, not a diagnosis.
What NOT to Do
  • Do not remove WD Passport drives from their enclosure.
  • Do not open the drive itself. The internal mechanism requires a clean bench environment to access.
  • Do not keep powering on a clicking drive. Each power cycle can cause more platter damage.
  • Do not use data recovery software on a failing drive. It forces the drive to work harder and can make recovery impossible.
What Should I Do If My External Hard Drive Is Making Noise?
Power it off. One thing is worth ruling out first: a bus-powered 2.5" portable has to draw its spin-up current through the USB port, so try a known-good cable & a powered port before assuming the drive is dead.
A mechanical noise is a physical fault, and bad sectors belong in that same physical column even when no sound reaches you. The drive that spins up quietly and mounts but reads as RAW is usually a logical fault in the file system or partition table, though unreadable sectors beneath that metadata can leave a mechanically sound drive reading RAW as well, so it still earns a full image before any file-system repair.
A bus-powered portable muddies this picture because the host is part of the circuit. A laptop port that will not deliver spin-up current, or a tired USB-Y or Micro-B cable, can leave a healthy mechanism behaving like a failing one.
The test worth running is the cheap one: a different port, a powered hub, and a fresh cable, before the drive is written off. Our existing notes on USB power starvation walk through that test in detail, and the same caution underpins our full hard drive recovery service.
If the drive is making any mechanical sound, power it off and ship it. The deeper mechanics live in our writeups on a drive that beeps instead of spinning, a clicking hard drive, and what a head crash does to the platters.
How Do You Safely De-Shell a Sealed External Hard Drive Enclosure?
Don't. If you haven't opened the enclosure yet, ship it to us intact.
Seagate Backup Plus Slim
Inside the Slim is a standard 2.5-inch SATA drive on a separate USB-to-SATA bridge board. That's the older modular design, & it makes bridge bypass straightforward.
Toshiba Canvio
Canvio units built on the MQ04UBB400 or MQ01UBD100 are native USB. The USB connector and bridge sit on the drive's own logic board, so you can't shuck one of these & plug it into SATA. Triage starts by inspecting whether the internal drive has a SATA edge connector or only USB pads.
Rule. If the customer has not opened the enclosure already, ship it to us intact. A cracked PCB on a MyPassport Ultra escalates a straightforward recovery into a costly firmware-tier donor-board and ROM-transfer case. There is no upside to opening a sealed enclosure at the kitchen table.
Why Do Some Modern 2.5-Inch Portable Drives Have No SATA Connector?
Modern WD My Passport portables don't have a SATA edge connector, & neither do Toshiba Canvio units built on the MQ04UBB400 or MQ01UBD100. The USB port is soldered right onto the drive's own logic board. There is no modular bridge to discard.
The older external drive architecture was a standard internal SATA drive plugged into a small detachable bridge board. When the bridge failed, the lab discarded it, connected the bare SATA drive to PC-3000 and proceeded.
How to Identify a Native USB Drive
Two Western Digital PCB part numbers tell these apart. SpyGlass and SpyGlass 2 drives on USB boards carry board 2060-800041. SpyGlass 2 Ultra drives carry 2060-810035.
The USB-to-SATA Conversion Workflow
  1. Locate the SATA differential pair test pads on the native USB PCB. These tap directly into the SATA TX+, TX-, RX+, and RX- lines before they enter the integrated USB bridge block, plus a ground reference.
  2. Micro-solder thin enameled wires to those test pads using a Hakko FM-2032 on an FM-203 base station. The pads are small and the surrounding traces are dense, so this is bench work, not field work.
  3. Route those wires to a SATA breakout board feeding PC-3000 Portable III.
  4. Inject external 5V power and ground to the board.
  5. Bring the firmware Service Area online through PC-3000 Technological Mode, stabilize the translator, and image the drive on PC-3000.
Why Does an External Drive Spin Up on One USB Port but Not Another?
A bus-powered 2.5-inch portable drive's spin-up surge can exceed a weak port's budget, so the bridge or spindle browns out before the platters reach speed. That's why the computer keeps finding the drive and losing it, only on that one port.
A spinning drive draws less current than a drive starting from rest. The moment the spindle motor breaks static friction and accelerates the platter stack to full speed is the peak-draw event, so a marginal port can fail at spin-up even when it could sustain the same drive once it is already turning.
A self-powered 3.5-inch desktop external with its own AC brick never sees this problem. It is the bus-powered 2.5-inch portable, drawing everything from the host, that is power-budget-constrained.
Power starvation and mechanical head damage can present the same way, which is why the triage runs on behavior rather than on the noise alone. A power-starved drive often spins up partially and drops, or never spins, and the behavior changes when you move it to a different port or cable. Seagate's own clicking article lists power supply failure among the causes of a clicking, non-functioning drive, so clicking does not rule the supply out.
What does separate the two is that head damage keeps producing the same noise no matter which port or power source you give it. If you are still unsure which class you are dealing with, our main recovery intake walks the same triage before any drive is opened.
A powered USB hub or a USB Y-cable, the kind that pulls current from two host ports at once, resolves a genuine power-starvation case & does nothing for head damage or firmware corruption.
If it still clicks or refuses to enumerate after you have given it adequate power, the fault is internal & no amount of supply fixes it. Knowing which side of that line a drive falls on is the difference between a clean copy job and choosing a recovery lab for clean-bench work, which is also where the gap between those two outcomes shows up in what recovery costs.
At intake the bench settles this with tooling already named on this page. We pull the bare drive out of its enclosure, power it on a current-limited bench DC supply instead of the host's USB port, listen for a clean spin-up & seek, & watch the FLIR thermal camera for a shorted rail that would betray a board fault rather than a supply shortfall.
A drive that spins cleanly on adequate bench power but failed on the host was power-starved & needs nothing more than a proper supply.
How Does PC-3000 Bypass a Failed USB Bridge Controller?
PC-3000 Portable III bypasses a failed USB bridge by connecting directly to the drive's SATA interface.
External drive enclosures use bridge ICs to translate between USB & SATA protocols. Common bridge-chip families include ASMedia, JMicron, and Initio parts. Some Initio bridge boards are used in hardware-encrypted Western Digital models.
Bridge Bypass Workflow
  1. Remove the bare SATA drive from the external enclosure housing.
  2. Connect the drive to PC-3000 Portable III's SATA ports.
  3. Issue the proprietary ATA command sequence to force the drive's microcontroller into Technological Mode (Factory Mode).
  4. Stabilize the firmware: rebuild corrupted translator tables, disable background reallocation, & tune the read channel for optimal head performance.
  5. Image the drive sector by sector using PC-3000 for error-tolerant reads.
Native USB Drives Without SATA Ports
To communicate with the drive's microcontroller in Technological Mode, a supported native-USB workflow or a temporary SATA conversion is required. This allows PC-3000 firmware-level access for data extraction.
Why Do We Preserve the USB Bridge PCB on Encrypted WD Externals?
On a bridge-encrypted WD, the encrypted key lives in two places: the bridge board's EEPROM & the drive itself. Your original bridge is one of the two places we can read it from. Hook up the bare SATA drive without that key and all you get is ciphertext.
A customer who shucks the enclosure and connects the bare drive to a desktop sees scrambled ciphertext, a RAW filesystem, and a prompt to format the disk. Accepting that prompt does not damage the encryption keys, but it destroys partition and journal metadata that the recovery workflow needs to reassemble the plaintext volume. The first instruction we give every WD external customer is to leave the original bridge attached and ship the drive and enclosure together.
Does a WD Security Password Stop Recovery?
The Data Encryption Key is wrapped by a Key Encryption Key. If you never set a WD Security password, that key is a factory default hardcoded in the bridge firmware. PC-3000's WD decryption option can find it & decrypt the drive.
Firmware-tier casework on a readable encrypted bridge starts at $600–$900 and is covered by the no data, no recovery fee guarantee if the key cannot be reassembled. Rush placement: +$100 rush fee to move to the front of the queue.
Should You Initialize a Shucked External Drive?
When a USB port dies and the bare drive is connected over SATA, Windows Disk Management often pops an "Initialize Disk" prompt. Clicking through writes a fresh GPT or MBR over the partition table of an otherwise-healthy drive, which on a hardware-encrypted external can destroy the only readable map to your data. Cancel every one of these prompts and ship the drive.
A bridge or USB port fails, the owner shucks the bare drive, connects it to a desktop SATA port, and Windows offers to "help." On a hardware-encrypted bridge the bare platters read as ciphertext, so the volume legitimately shows up as RAW or unallocated. That is the encryption working as designed, not a damaged drive, and it is not a reason to initialize. Cancel this prompt:
  • "Initialize Disk" (the Disk Management dialog offering GPT or MBR). Microsoft's own documentation says initializing a disk erases all data on it.
A drive showing as RAW after a shuck is normal on an encrypted external and does not mean the platters are damaged. If the drive is instead clicking, or keeps beeping on known-good power, the problem is in the drive itself and continued power risks platter scoring from a head crash. Either way, stop, leave the partition table untouched, and let the lab image first. The bridge-level encryption recovery path is documented on the hard drive data recovery flagship page.
What Equipment Performs External Hard Drive Recovery in the Lab?
External hard drive recovery uses three pieces of named equipment in the Austin lab: a ULPA-filtered clean bench for any procedure that opens the drive lid, PC-3000 Portable III for native-USB and single-drive firmware diagnostics, and PC-3000 Express for parallel multi-drive SATA imaging.
Lab capability determines which external drive failures can be recovered. The three pieces of equipment below cover the full path from clean-bench head work through firmware repair and final imaging. Each one names a specific role, so customers and other technicians can verify what the lab owns and uses.
A ULPA-filtered clean bench is enough for the minutes the lid is off during a head swap. The clean bench is engaged for head stack removal, donor head transplant, platter cleaning, and any procedure that opens the drive lid on a 2.5-inch portable or a 3.5-inch desktop external.
ACE Lab's hardware unit. We run it from a control computer, & it has SATA diagnostic ports and a USB host port. Portable III handles Service Area access, translator rebuild, and head map editing on the patient drive.
PC-3000 Express
A PCIe tester board in a dedicated workstation. It has six diagnostic ports & works up to four SATA or PATA drives at once. Express is the workhorse for multi-day, multi-drive recoveries where long passes on high-capacity mechanical drives need stable parallel throughput. Operating both Express and Portable III lets the lab image a SATA drive on one bus while working a native-USB patient on another, instead of serializing the queue.
All three are used inside the single Austin lab at 2410 San Antonio Street. None of this work is outsourced. The procedures applied to an external WD My Passport or a 2.5-inch portable drive are the same procedures applied to a desktop hard drive, documented in full on the hard drive data recovery flagship page.
What Does 3.3V on SATA Power Pin 3 Do to a Power Disable Drive?
Western Digital says a SATA drive built with the optional Power Disable feature won't power up when pin 3 of its SATA power connector is driven with 3.3V. Older power supplies do that. The drive sits in a hard reset. It isn't defective.
When to Preserve the Bridge vs. Bypass It
Removing the bridge PCB and addressing the bare SATA drive is the default path for any natively non-encrypted enclosure, including many generic ASMedia-based units and unencrypted JMicron variants. The customer's filesystem sits on the platters in standard form, so direct PC-3000 imaging produces a clone that mounts on any host.
Encrypted WD My Passport and My Book drives are the opposite case. The data on the platters can be ciphertext. Imaging the bare SATA drive alone may produce only encrypted data unless the required key metadata is available.
The lab workflow is to identify the controller family, preserve the original bridge path when needed, read the relevant board or service-area metadata when the model supports it, and use PC-3000 Data Extractor decryption workflows only when the required metadata is readable. We still ask customers to send the original bridge PCB because controller family and damage state determine which path is available.
Honest Limitation on Modern WD Hardware AES
Hardware AES-256 on a healthy encrypted bridge is not something the lab attempts to break. Many WD external drives ship with a factory-default encryption path and no user password, and PC-3000 workflows can recover those cases when the required key metadata is readable.
Pricing for an encrypted-bridge case normally starts at $600–$900 for firmware-tier work and assumes the original bridge metadata is readable; the no data, no recovery fee guarantee applies if the key cannot be reassembled. Rush placement: +$100 rush fee to move to the front of the queue.
How Are Donor Heads Matched for 2.5-Inch Portable Drives?
A 2.5-inch donor head stack has to match your drive on preamplifier silicon revision, physical head map, & firmware microcode. Match only the model number and the heads won't initialize.
Seagate Portable Donors
Firmware Revision
The firmware controls read channel calibration & servo decoding. The donor must be matched closely. Different revisions can produce different head calibration parameters.
Site Code
The manufacturing facility code and date-family are part of donor matching. Different production runs can use sub-components that affect compatibility.
Western Digital Portable Donors
Drive Configuration Matrix (DCM)
A code on the WD drive label. For donor matching we line up the J or 2 anchor character near the end of the DCM string, plus the character right before it.
Microjog Calibration
Microjogs are factory alignment calibrations for each individual head. The donor head microjog values must fall within a narrow tolerance of the patient drive's original values.
ROM Head Map and Adaptives
The ROM stores head-map and adaptation data such as servo calibration, microjog values, and read-channel profiles.
Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available. For a detailed breakdown of the matching process, see our donor drive matching technical reference.
How Does SMR Architecture Complicate External Drive Firmw...
How Does SMR Architecture Complicate External Drive Firmware Recovery?
SMR drives store data on overlapping tracks, requiring a dynamic translator layer that is vulnerable to corruption from sudden power loss. Firmware-level recovery on a portable SMR drive costs $900 & takes longer than on a conventional CMR drive.
Many high-capacity portable external HDDs use SMR to maximize capacity in 2.5-inch form factors. Because SMR tracks overlap, the drive cannot perform random writes directly.
PC-3000 SMR Recovery Workflow
On WD SMR families, we use PC-3000 Portable III to lock background firmware operations and build a map from the second-level translator data.
Data is then extracted via Physical Block Address (PBA) rather than Logical Block Address (LBA), bypassing the broken mapping. This is a firmware-tier recovery at $900. SMR drives take longer at this tier because their tracks overlap.
How Does FLIR Thermal Imaging Prevent Secondary Damage Du...
How Does FLIR Thermal Imaging Prevent Secondary Damage During Diagnostics?
FLIR thermal cameras detect short circuits & failing components on an external drive's PCB before full power is applied. A shorted capacitor or failed voltage regulator glows on the thermal display under restricted low-voltage current, allowing technicians to isolate the fault first.
When a dead external hard drive arrives with no spin & no detection, plugging it in to listen for sounds is risky. If a short circuit exists on the PCB, applying full bench power can send a surge through the preamplifier chip inside the sealed drive assembly.
Thermal Signatures We Identify
Shorted Ceramic Capacitors & PMICs
Microscopic internal cracks in ceramic capacitors or failed Power Management ICs show as concentrated hot spots on the thermal display.
Bridge Chip Hot Spots
If the USB-SATA bridge chip shows a concentrated thermal anomaly, the chip itself has failed. Recovery proceeds via direct SATA connection through PC-3000.
Which USB-SATA Bridge Chips Fail in External Hard Drives?
USB-SATA bridge failures can look like power faults, intermittent USB dropouts, or transfer stalls under sustained load. Some WD enclosures add hardware AES-256 encryption, so to recover the data we need the original board or the key metadata. The bridge family determines whether we can bypass the enclosure or must preserve the original key path first.
Many external hard drives use a bridge IC to translate between USB and the internal SATA interface. Others use a native USB PCB. The board is a common failure point. We identify the chip, then decide whether to bypass it via direct SATA imaging, convert a native USB board, or extract the key first for encrypted bridges.
Bridge ChipCommon EnclosuresTypical Failure ModeRecovery Approach
Initio INIC-1607ESome WD My Passport modelsHardware AES-256 bridge failure; data may be unreadable without key metadata stored on or associated with the failed bridgePreserve the original bridge path, recover bridge metadata when possible, or decrypt through a supported PC-3000 workflow
Initio INIC-3608Some WD My Passport Ultra and Slim modelsHandles password and key-encryption-key authentication, then passes the ATA unlock to the drive's internal processor, & the drive does the AES itself. If the bridge dies, the unlock chain breaks, and a healthy mechanism can look like a dead driveShip with the original board intact, preserve the bridge encryption path, and attempt key-metadata recovery before any SATA-direct imaging is meaningful
When the bridge is the only failure and the internal SATA drive is healthy, recovery is a Tier 1 simple copy at $100. Rush service: +$100 rush fee to move to the front of the queue. Encrypted bridge or native-USB cases require firmware-tier work at $600–$900 because the required encryption metadata must be readable before any data is usable.
What Happens Inside a Portable Hard Drive When You Drop It?
A 2.5-inch portable hard drive's shock tolerance drops sharply once the platters are spinning and the heads are flying. Seagate rates its 500GB to 2TB Mobile HDD models for 400 G of operating shock & 1,000 G non-operating. The 3TB Mobile HDD is rated lower, at 300 G operating & 650 G non-operating.
A drive dropped while powered on is treated as a head-crash suspect on arrival. We inspect the platter surface under microscope before any power is applied to a swapped head stack. The full procedure for a dropped portable is documented in the next section. For internal hard drive recovery scenarios beyond external enclosures, see hard drive data recovery.
What Is the Recovery Workflow for a Dropped External Hard Drive?
A dropped external hard drive is treated as a head-crash suspect until the clean-bench inspection proves otherwise. The workflow is: power off, ship intact with the original enclosure, bench triage, clean-bench head stack assessment, donor match, head swap, imaging with adaptive head map, and file verification on fresh target media.
Dropped externals that stop responding may have suffered a head crash where the heads contacted the platter surface. Every additional power-on cycle risks scoring the platters further. The procedure below is the order we follow in the Austin lab on a standard 2.5-inch or 3.5-inch drop case.
  1. Power off and label. Unplug USB and external power. Label the drive with the date of the drop and any sounds heard (clicking, beeping, grinding, silence). Do not re-power to "test" it.
  2. Ship intact. Ship the drive in the original enclosure with the original bridge board, even if visibly damaged. For WD My Passport models with hardware encryption, the bridge may be required to reconstruct the key path. Pack with anti-static wrap and at least two inches of cushioning.
  3. Free evaluation on arrival. We open the enclosure, inspect the bridge, and connect the bare mechanism to a PC-3000 Portable III via direct SATA. If the drive spins cleanly and enumerates, the failure is bridge-only and recovery is a Tier 1 simple copy at $100.
  4. Clean-bench head stack inspection. If the drive clicks, beeps, or fails to spin, we open it in our ULPA-filtered clean bench. Under microscope, we assess the head stack for bent sliders, contaminated air-bearing surfaces, and head-to-platter contact patterns.
  5. Donor sourcing. We match the donor by exact model, firmware revision, and head preamp configuration. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available.Donor cost is disclosed in the quote before any clean-bench work.
  6. Platter surface triage. If the platters show scoring or contamination from the head crash, we escalate to Tier 5 surface damage at $2,000 for platter cleaning and a fresh donor head stack. We contact you before escalating tiers.
  7. Head swap in the clean bench. The donor head stack assembly is transplanted into the patient drive under the ULPA-filtered hood. The procedure is typically a Tier 4 head swap at $1,200–$1,500. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available.
  8. Adaptive imaging. We clone sector by sector using PC-3000 for error-tolerant reads.
  9. File-system reconstruction. The sector image is mounted in PC-3000 Data Extractor. For NTFS drives, we parse the Master File Table; for HFS+ Mac drives, we parse the Catalog File. The directory tree is rebuilt without writing a single byte back to the damaged mechanism.
  10. Verification on fresh media. Recovered files are written to a new external drive (either your supplied blank drive or one we provide at market cost). We run sample-file verification on the target media before shipping back. No data, no charge.
How Does WD My Passport Hardware Encryption Affect Data Recovery?
Many WD My Passport drives encrypt your data with AES-256 on the USB board, even if you never set a password. The Data Encryption Key can live in bridge firmware, controller state, or service-area metadata. Removing the drive or replacing the bridge board can render data unreadable until the key path is preserved or reconstructed.
Many WD My Passport generations use hardware AES-256 encryption as a standard design feature, not only as an optional security mode. Customers usually discover this only when the bridge fails and a technician pulls the bare drive into a SATA dock: the internal platters are filled with encrypted ciphertext that looks like random noise.
The encryption stack depends on the controller generation. A user password, when set, becomes part of the key path. When no password is set, many models still use a factory encryption path that depends on board firmware, controller state, or service-area metadata. The Data Encryption Key is what encrypts and decrypts sectors read from or written to the platters.
Recovery requires preserving the original bridge path or reading the required key metadata from the failed bridge, ROM, or Service Area when the model supports that workflow. The exact path depends on the controller family and the condition of the original board.
Practical consequences for the customer: do not remove the drive from its enclosure, do not swap the USB board with a donor, and do not ship the drive without the original USB board.
Losing that board can remove the easiest recovery path, especially when board firmware, ROM data, or controller identity values are required. WD Passport recoveries with a dead USB board often land in the firmware tier at $600–$900 when the internal mechanism is healthy; dropped Passports with head failure escalate to $1,200–$1,500. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available.
External Hard Drive Recovery: Common Questions
How much does external hard drive data recovery cost?
External hard drive recovery starts at $100 for a simple enclosure failure where the internal drive is healthy. Air-filled internal drives use standard HDD pricing from $100–$2,000. Desktop externals with verified helium mechanisms use helium HDD pricing from $200–$5,000+ for mechanical work. We provide a firm quote after a free evaluation. No data recovered means no recovery fee.
Can data be recovered from a dead external hard drive?
Yes. Many dead external drives have a failed USB bridge board or native USB PCB, not a failed drive. We bypass the failed board when the model allows it and image through PC-3000. If the drive itself has mechanical damage, we perform head swaps in our ULPA-filtered clean bench. WD My Passport models may require bridge-level encryption key extraction before direct connection.
Why is my external hard drive not showing up?
Common causes include: failed USB bridge/enclosure (drive is fine, interface is dead), USB cable failure, drive firmware corruption, mechanical failure (clicking), or PCB damage from power surge. Many "dead" external drives just have a failed enclosure; the internal drive is often fine.
My computer says the external hard drive needs to be formatted. What should I do?
Do not click "Format" and do not run CHKDSK. Windows throws this prompt when the partition table or Master File Table (MFT) is unreadable, often after a sudden disconnect or power failure. The drive's file system has gone RAW, but the underlying data is still on the platters. Formatting or running CHKDSK overwrites the original directory structure.
We connect the drive through PC-3000 Data Extractor and virtually parse the MFT (for NTFS) or Catalog File (for HFS+ Mac-formatted drives) in RAM, reconstructing the directory tree without writing a single byte back to the damaged media. This is a Tier 2 file system recovery starting at $250 when no physical damage is present.
Why is my external hard drive beeping?
Power it off and stop retrying it. Seagate states that a single intermittent beep most often means the drive is not getting enough power, so a different port, a powered hub, or a Y-cable is worth trying once. If it still beeps on good power, it needs the bench. The beep won't tell us which part failed. We find that out once the drive is open.
Can you recover data from an encrypted WD My Passport?
Yes, but do not remove the drive from its enclosure. Many WD My Passport models use hardware AES-256 encryption through the USB board, even if you never set a password. If that board fails, the encryption metadata can be stored in board firmware, controller state, or service-area metadata depending on the model. We preserve the original USB path when required, or extract the key metadata through PC-3000 when the model supports that workflow.
My external hard drive was dropped. Can you recover it?
Usually yes. Dropped drives often suffer head crashes or stuck heads. We perform head swaps in our clean bench environment using donor parts. Success depends on platter condition. The sooner you stop using it after the drop, the better the recovery chances.
Should I try to open the external drive enclosure myself?
Opening the plastic enclosure is usually safe. Opening the internal hard drive mechanism is not; that requires clean bench conditions. However, if you have a WD My Passport or other encrypted drive, do not remove the drive from its enclosure.
Can I just put the failed external drive in a new third-party enclosure to recover the data?
It depends on the original enclosure. In a generic non-encrypted 3.5-inch desktop external, the bridge just translates USB to SATA & the platters hold plaintext. If that bridge died and the drive inside is healthy, a new generic enclosure or a SATA dock often works.
On a WD My Passport or My Book with hardware AES-256 at the bridge, swapping enclosures produces ciphertext: the Data Encryption Key is bound to the original bridge SPI flash or service-area metadata, and a generic third-party enclosure does not carry that key path.
Many newer WD portables integrate the USB controller directly into the HDD PCB with no exposed SATA edge connector, so there is no enclosure to swap into at all; recovery requires a supported native-USB workflow or a SATA conversion on PC-3000 Portable III.
If the drive is clicking, a new enclosure won't help, & more power cycles risk platter scoring.
Is it cheaper to repair an external hard drive than recover the data?
Data recovery is not a drive repair. When we open a drive in the clean bench and swap heads, the drive is only kept alive long enough to image the data sector by sector using PC-3000. The mechanism is not stable for continued use after the factory seal is broken and donor parts are installed. The cost covers extracting your data to healthy media, not returning a working drive.
Does the capacity of my external hard drive affect the recovery cost?
Capacity alone does not change the base recovery tier for air-filled external drives. A standard head swap costs $1,200–$1,500. High-capacity portable drives often use Shingled Magnetic Recording (SMR), which complicates firmware-level recovery.
Desktop externals with verified helium mechanisms use helium HDD pricing from $200–$5,000+. The higher helium range reflects sealed-chamber architecture and tighter platter/head tolerances. Helium cost: $400-$800 additional for head swap and surface damage tiers. This covers the helium refill required after opening the sealed chamber. Helium donor drives must be an exact match. Typical donor cost: $200–$600 depending on model and availability, plus helium refill cost ($400–$800) required after opening the sealed chamber.
Do you charge per gigabyte for external hard drive recovery?
No. Recovery cost is determined by the physical state of the hardware, not the volume of data stored. PC-3000 Data Extractor images the drive sector by sector.
Getting 10MB of documents off takes the same clean-bench work and the same donor heads as getting 900GB of video files off the same drive. The pricing tiers ($100 for enclosure failure up to $1,200–$1,500 for a head swap) reflect what component failed, not how full the drive was.
Are donor parts included in the recovery price, or do I pay extra?
Donor parts are separate from the Tier 4 head swap price of $1,200–$1,500. Finding a compatible donor means matching the exact model number, firmware revision, and preamp configuration. The donor drive is destroyed during the procedure; we harvest the head stack assembly and install it in our ULPA-filtered clean bench.
Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available. We communicate the donor cost during the free evaluation before any paid work begins. There are no hidden parts fees after you approve the quoted price.
Is the transfer drive included in the recovery cost?
The destination drive is separate from the recovery fee. After imaging, we write the recovered data to a new, healthy external hard drive or flash drive. You can ship a blank drive with your mail-in package, or we provide one at market cost. The original drive cannot be reused after clean-bench work breaks the factory seal and donor parts are installed.
How long does external hard drive data recovery take?
Turnaround depends on the failure type. A bridge-only failure where the internal drive is healthy follows the 3-5 business days simple-copy queue. Firmware corruption requiring PC-3000 Service Area rebuilds follows the 3-6 weeks firmware queue. Head swaps follow the 4-8 weeks mechanical queue because donor sourcing must match the exact model, firmware revision, & head preamp configuration. +$100 rush fee to move to the front of the queue if you need faster turnaround. Contact us before shipping so the intake note is attached to the work order.
Why does Rossmann publish external hard drive data recovery pricing?
External hard drive data recovery pricing is published because we operate a single lab in Austin, TX with no franchises, no outsourcing, and no diagnostic fee.
The technician who diagnoses your drive is the same person who performs the recovery. Our five published tiers ($100 to $2,000) cover PC-3000 firmware work, clean bench head swaps, and platter cleaning without a diagnostic fee.
Why do Seagate Backup Plus external drives often fall into firmware or head-swap pricing?
Seagate Backup Plus Slim and Portable drives from the Rosewood era can develop firmware faults and degrading heads. Firmware repair on Rosewood costs $600–$900 because we have to stabilize the firmware, work around translator corruption, and image the drive without letting background repair routines make the media worse.
If the drive was dropped & we find failed heads on the bench, it moves up to $1,200–$1,500 for a clean bench head swap with closely matched donor parts.
Can I reduce WD My Passport recovery costs by swapping the USB board myself?
No. Many WD My Passport drives use a native USB PCB rather than a standard SATA connection. Buying a donor board and plugging it in is dangerous: in some cases it overwrites the original encryption key and all the data is lost. Each board's ROM stores unique adaptive parameters for head calibration, and the AES-256 encryption key may be tied to the controller family and original board metadata.
Does a broken external drive enclosure mean my hard drive is dead?
Usually not. The enclosure is a plastic shell around a drive mechanism and a USB bridge board or native USB PCB. If only the board or USB port broke, the internal mechanism may be healthy and recovery is a Tier 1 simple copy at $100. We bypass the failed board when the model allows it and image through PC-3000.
If it was dropped while spinning & we find crashed read/write heads on the bench, it becomes a $1,200–$1,500 head swap. We evaluate the drive and board path to determine which scenario applies before quoting.
Can you recover a WD My Passport that spins up but is not recognized by Windows?
Yes. Many WD My Passport drives use a native USB PCB tied directly to the drive firmware. When the firmware Service Area (SA) modules become corrupted, the drive spins but cannot enumerate over USB. We convert the native USB PCB to a standard SATA pinout and use the PC-3000 WD utility to diagnose and rewrite the corrupted SA modules directly on the platters. This is a firmware-tier recovery at $600–$900.
Why does my external drive freeze and disappear during large file transfers?
This can be a symptom of USB bridge faults, UAS negotiation problems, power instability, or a degrading internal drive. The internal SATA drive may be healthy in bridge-only cases. We remove the mechanism when the model allows it and image it directly via PC-3000, eliminating the faulty bridge from the data path. This is typically a Tier 1 recovery at $100 when the bridge is the only failure.
Can data be recovered after an I/O device error on an external hard drive?
An I/O (Input/Output) device error means the operating system cannot read from or write to the drive. Common causes include bad sectors, a failing USB cable, degraded read/write heads, or a corrupted bridge chip. Disconnect the drive immediately.
If the drive is clicking or making unusual sounds, it has a hardware fault, & running it longer can cause platter scoring. Try a different USB cable first to rule out cable failure. If the error persists, the drive needs professional diagnosis via PC-3000 direct SATA connection to determine whether the failure is in the bridge, firmware, or heads.
Is there an external hard drive repair service near me?
Mechanical hard drive data recovery requires a ULPA-filtered clean bench, exact-match donor parts, and PC-3000 firmware-level imaging. Our nationwide mail-in service ships directly to our Austin, TX lab, the only physical Rossmann location.
Why does external hard drive data recovery get expensive?
External hard drive data recovery gets expensive when the drive needs clean-bench labor, donor matching, and sector-by-sector imaging after mechanical work. Our head-swap tier is $1,200–$1,500 because it covers donor matching, a ULPA-filtered clean bench, and PC-3000 imaging.
We operate a single lab in Austin, TX, with no franchises and no outsourcing. The technician who diagnoses your drive is the same person who performs the recovery. Our five published tiers ($100 to $2,000) cover the same PC-3000 procedures & clean bench head swaps without a diagnostic fee.
What is the cheapest way to recover data from an external hard drive?
If the drive makes no unusual sounds, try a different USB cable & port first. If that doesn't work & the drive isn't clicking or beeping, free tools like Recuva can recover logically deleted files from a healthy drive.
If the drive is clicking, beeping, or completely dead, software can't help & will make the problem worse. At that point, the cheapest path is a lab with published pricing: our bridge-only recovery starts at $100, with no diagnostic fee.
How much does it cost to recover a dropped WD My Passport?
A dropped WD My Passport that needs a head swap costs $1,200–$1,500 plus the donor drive. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available. Because many WD Passport drives use hardware AES-256 encryption tied to the USB board, ship the original bridge with the drive. We need it to preserve or reconstruct the encryption workflow before we image the swapped mechanism. If the bridge also failed, we quote the combined encryption and mechanical workflow after evaluation. Rush placement is available: +$100 rush fee to move to the front of the queue.
What does it cost to diagnose whether the bridge or the internal drive failed?
Nothing. Diagnosis is free. We open the enclosure and test the internal mechanism through the appropriate PC-3000 path, direct SATA for SATA mechanisms and a native USB workflow when required. If the drive enumerates and reads cleanly, the board was the only failure and recovery is a Tier 1 simple copy at $100.
If the mechanism is clicking, not spinning, or unreadable, we quote the correct tier (firmware $600–$900, head swap $1,200–$1,500, or platter damage $2,000) before any paid work begins. There is no diagnostic fee regardless of outcome, and no data means no charge.
Do I pay anything if the external drive is too damaged to recover?
Head-swap and surface-damage cases require the deposit listed in the pricing table because clean-bench labor and donor matching begin before imaging. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available. If we discover during clean-bench work that the damage is more severe than the quoted tier, we communicate the revised assessment before any escalation.
Is recovery cheaper for a 2.5-inch portable external than a 3.5-inch desktop external?
Air-filled portable and desktop drives use the same standard tiers. Firmware repair is $600–$900, and air-filled head swap is $1,200–$1,500. 3.5-inch desktop externals with verified helium mechanisms use $3,000–$4,500 head swap or $4,000–$5,000 surface damage pricing. They're sealed, and their platter and head tolerances are tighter, so mechanical work on them is more delicate. Helium cost: $400-$800 additional for head swap and surface damage tiers. This covers the helium refill required after opening the sealed chamber. Helium donor drives must be an exact match. Typical donor cost: $200–$600 depending on model and availability, plus helium refill cost ($400–$800) required after opening the sealed chamber.
2.5-inch portables often use Shingled Magnetic Recording. That makes the firmware work more complex, but it doesn't change the headline tier price. +$100 rush fee to move to the front of the queue is available on both form factors.
Is external hard drive data recovery worth the cost?
That depends on the value of the data, not the value of the drive. A replacement external drive is cheap compared with mechanical recovery. If the data on it is replaceable, buy a new drive.
If the data is irreplaceable (family photos, business records, creative work), recovery runs from $100 for bridge-only work to $1,200–$1,500 for air-filled head swaps. We provide a firm quote after a free evaluation so you can decide before any paid work begins.
What is the actual repair cost for an external hard drive at a professional lab?
External hard drive repair at a professional lab isn't a flat fee. What it costs depends on what failed inside the enclosure. A bridge-board-only failure where the internal mechanism is healthy is a Tier 1 simple copy at $100. Firmware-tier work, including encrypted WD Passport bridge reconstruction, is $600–$900.
A clean-bench head swap on an air-filled portable or desktop external is $1,200–$1,500, plus the donor cost, which we list separately. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available. Helium-sealed desktop externals are priced on our helium HDD table, $200–$5,000+. There is no diagnostic fee, and no data recovered means no charge. See the hard drive data recovery hub for the full tier table and component-level workflow.
How does external hard drive repair cost change when the drive was dropped versus simply not powering on?
The price depends on what we find in the evaluation, not on what the drive was doing when it arrived. If the mechanism turns out to be intact and the fault is the USB bridge, it's the Tier 1 simple-copy path at $100. A dropped drive that needs a head transplant falls into the Tier 4 air-filled head-swap tier at $1,200–$1,500 plus donor cost. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available.
If the platter surface is scored, it moves up to Tier 5 surface damage at $2,000 for platter cleaning. We confirm which path applies during the free evaluation before quoting. Brand-specific cost detail is published on the Seagate data recovery, Western Digital data recovery, and LaCie data recovery hubs.
What does external hard drive repair cost cover that a flat-rate or per-GB price does not explain?
Our published external hard drive repair tiers ($100 to $2,000) cover the actual cost drivers: PC-3000 firmware-level access, ULPA-filtered clean-bench labor, donor matching by exact model and firmware revision, and adaptive imaging with PC-3000.
Flat-rate or per-gigabyte pricing hides which of those steps you are paying for and lets a vendor swap them silently. Our donor parts cost is disclosed separately in the quote. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available. +$100 rush fee to move to the front of the queue when faster turnaround is required.
What is the difference between a logical recovery and a physical recovery for an external hard drive, and how long does each take?
A logical recovery applies when the drive is mechanically healthy: it spins up, the heads track, the host sees the device. The damage is in the file system metadata (MFT on NTFS, Catalog File on HFS+). We connect through PC-3000 Portable III, scan for lost partition tables, and reconstruct the directory tree in RAM without writing to the original media.
Logical work is Tier 2 of our HDD pricing. It starts at $250 and runs on the 2-4 weeks queue.
A physical recovery applies when the head stack has crashed, the spindle has seized, or the PCB is damaged. The drive enters the ULPA-filtered clean bench, we source a donor by exact model and firmware revision, and we perform a head transplant or platter migration before imaging can begin. Head swaps run on the 4-8 weeks queue, depending on donor availability and on how much imaging time the platter surface tolerates.
Why does my external drive show up as RAW when I plug it into a different computer?
RAW means the operating system can see the drive, can read its partition table, but cannot interpret the file system inside the partition. One cause is file system metadata (MFT for NTFS, Catalog File for HFS+, container superblocks for APFS) that got corrupted or partly overwritten when the drive was unplugged mid-write or the power supply failed. When that's the cause, the drive itself is usually healthy & your data is still on the platters.
Do not click Format, do not run CHKDSK, and do not run repair utilities. Each of those writes to the same metadata zone you need to recover from. We image the drive read-only through PC-3000 Data Extractor and rebuild the directory in software against the clone. Pricing starts at $250 when the drive is mechanically healthy.
Can a clicking external hard drive be saved if I just turn it off immediately?
Turning the drive off immediately is the right call, and it is the single most important thing a customer can do to keep a clicking drive recoverable. Clicking means the mechanism is involved, whatever the specific fault turns out to be. Every additional power-on attempt risks the working heads scoring the platter surface.
After the drive is off, do not power it back on, do not try a different cable, do not freeze it. Ship it to our Austin, TX lab.
We open the drive in the ULPA-filtered clean bench & inspect the head stack and platter surface under magnification. If we find failed heads, we source a donor with matching model and firmware revision, do the head transplant, and image through PC-3000. See also our guide on beeping and clicking drive symptoms.
How Do You Ship an External Hard Drive for Recovery?
Seal the drive in an anti-static bag, then float that inside a second box with two inches of bubble wrap on every side. No packing peanuts. Ship it on a trackable carrier with declared value to the Austin lab, & send the original enclosure & USB bridge board with it.
Pack your external drive in anti-static wrap with at least two inches of cushioning on all sides. Ship to our Austin, TX lab with a trackable carrier and keep the tracking number. Include the original enclosure and bridge board, even if damaged.
Searching for a drive recovery service in your area works the same way: every mail-in drive is handled at the same Austin bench.
  1. Seal the drive in an anti-static bag.
  2. Float that bag inside a small box, then float the small box inside a larger corrugated box with two inches of bubble wrap on every side.
  3. Leave the packing peanuts out; they compress in transit & let a heavy drive strike the wall of the carton.
  4. Send the original enclosure & USB bridge board even when the shell is cracked or the port is snapped off.
  5. Ship on a trackable carrier & set declared value high enough to cover the hardware.
Where Is the Nearest Rossmann External Hard Drive Repair Service?
One lab, at 2410 San Antonio Street, Austin, TX 78705. Everything else in the country is mail-in. If a search for external hard drive repair near me sent you here from Denver or Tampa, the drive still lands on the same Austin bench a walk-in drop-off would reach, & our nationwide mail-in service covers all 50 states.
We run no drop-off points, satellite counters, partner shops, or contract technicians outside Austin. No franchises. A listing that surfaces under external hard disk repair near me & attaches the Rossmann name to another city is not ours, & a drive left there never reaches this lab.
Mechanical failure inside a clicking external needs a ULPA-filtered clean bench, a donor head stack matched to the patient drive, & PC-3000 firmware-level access to the service area. A counter two miles from your house has none of that. That gap separates an external hard drive repair service from a recovery lab, where a failed drive is recovered rather than repaired for reuse.
Mailing it doesn't change the price. External drives quote out of the same tiers as any other hard drive data recovery case: air-filled mechanisms run $100–$2,000, helium-sealed desktop units run $200–$5,000+, & the helium head swap & refill happen in-house at the Austin bench. No data, no recovery fee.
Shipping
Shipping
Mail-in
External hard drive not working?
Free evaluation, firm quote before any paid work. No data, no charge. Mail-in from all 50 states.
