iPhone Data Recovery
Get Your Photos Back From a Dead or Water-Damaged iPhone
We specialize in recovering data from iPhones that won't turn on, have liquid damage, or are "not detected" by your computer. Our board-level repair gets your phone working just long enough to safely copy your photos, messages, and contacts.
Free evaluation. If we can't recover your data, you don't pay.
Board-level iPhone repair for data recovery
What happened to your iPhone?
Select your situation below to see how we can help
Water or Liquid Damage
Phone got wet and now won't turn on, or it died days after water exposure. We remove corrosion and repair the power circuits to recover your data.
Typical cost: $300 - $650
Phone Won't Turn On
Went dead overnight or won't charge? We diagnose the board and fix just enough to boot it and copy your data safely.
Not Detected by Computer
Phone turns on but iTunes or Finder won't see it? This often points to a charging port or board issue we can fix.
Typical cost: $300 - $450
Transparent Pricing
You get a firm quote after our free evaluation. If recovery turns out easier than expected, you pay less. If we can't recover your data, you pay nothing.
๐Ÿ“ฑ
Pre-X iPhones
Older devices without Face ID. Simpler power paths make recovery more straightforward.
$300 - $450
๐Ÿ“ฒ
iPhone X and Newer
Face ID models with higher integration. More complex board work required.
$450 - $650
๐Ÿ”ง
Complex Cases
Severe corrosion, heavy jumper work, or long screw damage requiring extensive repair.
Quoted after evaluation
Important: Don't repeatedly power on a water-damaged iPhone. Every attempt can worsen corrosion and damage the storage power rails.
How We Recover Your Data
Our goal is simple: get your phone working just long enough to safely copy your data. We don't restore phones for daily use; we focus entirely on your files.
Evaluate
We document the symptoms, model, and any prior repair attempts. No charge for evaluation.
Repair the Board
Microsoldering to replace damaged components, repair traces, and restore power to the storage.
Copy Your Data
Once stable, we boot the phone, enter the passcode, and safely image all your files.
4
Deliver
Your data is copied to a new drive or your own media. We verify key files before delivery.
Why Choose Rossmann?
iPhone data recovery requires board-level repair skill, not magic software. We do all the work in-house at our Austin lab using the same techniques we teach to millions on YouTube.
Board-Level Expertise
Microsoldering, PMIC diagnostics, and trace repair. Real engineering, not software tricks.
Transparent Pricing
Upfront price ranges, free evaluation. No data recovered means no payment.
Nationwide Mail-In
Ship from anywhere in the U.S. Clear instructions and fast turnaround.
Proven Track Record
2.49M+ YouTube subscribers. 4.9 star average across hundreds of reviews.
What Makes Us Different
Work done in-houseYes, Austin lab
Evaluation feeFree
No data, no fee guaranteeYes
Public repair videosHundreds on YouTube
Talk to the technicianYes, directly
Technical Details
For those who want to understand what actually goes wrong and how we fix it. Click to expand each section.
Long Screw Damage (LSD)
Phone died after a screen repair? Wrong screw length can sever internal traces.
Long screw damage happens when an over-length screw is driven into the standoff near the display connector. It drills through inner PCB layers and cuts traces for image, touch, or boot-critical nets.
Diagram showing how long screw damage occurs when over-length screw penetrates iPhone logic board PCB layersMicro-jumper repair technique for restoring severed traces from long screw damage on iPhone logic board
Our fix: Remove torn copper, reconstruct the path with micro-jumpers, protect with conformal coating, then stabilize for data imaging.
Apple Says Recovery Isn't Possible
Why Apple support says no, and why they're wrong.
Apple's service model is device replacement, not board-level repair. They don't offer data recovery because their business model doesn't include component-level work.
iPhone storage is hardware-encrypted to the CPU and Secure Enclave, so "chip-off" reads won't work. The only path to your data is to repair the logic board enough to boot, enter the passcode, and export your files.
Apple forum showing data recovery isn't offered
Board-level repair labs like ours routinely recover data Apple says is lost.
Why "Rice" and Drying Don't Work
Water corrodes components under shields. Drying doesn't fix electrical damage.
Water wicks under RF shields where it corrodes capacitors and IC pins on critical power lines. That's why "rice" or simple drying fails. The corrosion causes electrical shorts that prevent the phone from booting.
Corroded iPhone logic board
Proper treatment: Remove shields, ultrasonic clean the board, diagnose and repair damaged power paths, then boot long enough to copy your data.
Quick answers to common questions. Click any question to see the full answer.
Can you get data off a dead iPhone?
Yes, data can often be recovered from a dead iPhone if the storage chip and Secure Enclave are intact. We repair the board just enough to boot, enter the passcode, and copy your data. Cost: $300-$650 depending on model. Time: 2-7 business days after evaluation.
Can you recover data from a water-damaged iPhone?
Yes. We remove shields, clean the board ultrasonically, diagnose power circuits, and repair what is needed to boot. Then we copy your photos, messages, and contacts safely. Important: Don't try to power on or charge a wet phone. Every attempt can worsen damage.
Can I recover data without a backup?
Yes. iPhone storage is encrypted to the device, so we cannot just remove the chip. We repair the phone to a bootable state, enter your passcode, and export directly from the device. No iCloud or iTunes backup needed. We copy directly from your phone.
Can Apple recover my data?
No. Apple does not offer data recovery services. Their model is device replacement. They will tell you the data is gone. Board-level repair labs like ours routinely recover data that Apple says is lost.
What if my phone died after a screen repair?
This is likely "long screw damage" where the wrong screw length cut internal board traces. We repair these by mapping the damage and rebuilding connections with micro-jumpers. This is a board problem, not a screen problem. Microsoldering is the fix.
How long does recovery take?
Most iPhone data recoveries complete in 2-7 business days after evaluation. Complex cases with severe damage may take longer. We give you an estimate after seeing the device.
What if you cannot recover my data?
You don't pay. Our policy is no data, no fee. If the CPU, storage chip, or Secure Enclave are physically destroyed, recovery is not possible. We will tell you honestly.
Do I need to know my passcode?
Yes. iPhone data is encrypted and requires the passcode to access. Without the passcode, even with a working phone, the data cannot be decrypted. If you don't know your passcode, recovery is not possible.
Ready to recover your iPhone data?
Get a free evaluation and honest assessment of your recovery chances. No data, no fee.
