Hard Drive Clicking: Common Causes and What to Do
Your hard drive is clicking. Turn it off immediately.
Do not run any software on a clicking drive. Recuva, DiskDrill, CHKDSK; these tools force the drive to read. If the heads are broken, "reading" means scraping the platters. You are destroying your data with every attempt. Do not put it in the freezer. Do not open the drive. Just turn it off.
A clicking hard drive is a mechanical failure symptom. The repetitive noise occurs when the drive's read/write heads fail to locate servo tracks and repeatedly reset to their home position. If your hard drive is making a clicking sound, it is not normal. Power down the device immediately to prevent the heads from scratching the platters and causing permanent data loss.
12 min read
What Customers Say
4.9 across 1,837+ verified Google reviews
Sent my hdd for data recovery, process was simple and I was able to pre-authorize an amount. They worked on my drive within 2 days of receiving it and the total cost was literally 1/10th of the amount of another service I got a quote from. Professional, quick, affordable. Nothing to complain about.
Andrew Hansen
My satisfaction with Rossmann Repair Group goes beyond just 5 stars. I had a hard drive die some time ago, but I had no idea where I could send it knowing it would be safe, or there being a chance I'd be ripped off.
Kyle Hartley (crazybangles)
Had a raid 0 array (windows storage pool) (failed 2tb Seagate, and a working 1tb wd blue) recovered last year, it was much cheaper than the $1500 to $3500 Canadian dollars i was quoted by a Canadian data recovery service. the price while expensive was a comparatively reasonable $900USD (about $1100 CAD at the time).
ChristopolisSeagate
Walked in with my wife's dead hard drive, walked out 20 minutes later with it fixed. They were friendly, professional, did the work in a snap, and saved me the hefty repair prices for other (mail in) hard drive recovery services!
Patrick Dughi
Common Causes of Hard Drive Clicking
  • Physical damage (drops, impacts, shipping damage)
  • Head wear and tear (actuator arm degradation after years of use)
  • Electrical problems (power surges, defective adapter, unstable USB power)
  • Read/write head misalignment (heads knocked off servo tracks)
  • Service area corruption (firmware damage on the reserved platter area)
What Does a Clicking Hard Drive Mean?
A clicking hard drive means the read/write heads have physically failed. Every hard drive has servo tracks etched on the platter surface that tell the heads where they are. When the heads are damaged, they cannot find these tracks. The drive arm sweeps outward, finds nothing, resets, and slams into its mechanical stop. That repeating click is the arm hitting its limit.
This is mechanical damage that no software can repair. If your drive stopped working after a crash or sudden failure, the clicking confirms physical head damage. Unlike a beeping hard drive, where the platters cannot spin at all, a clicking drive has spinning platters but blind heads. Recovery requires transplanting working heads from an exact-match donor drive inside a particle-free clean bench.
Is It Clicking, Beeping, or Grinding?
  • Clicking or ticking (head failure)Platters ARE spinning. Heads are damaged and cannot locate servo tracks. Repair means transplanting working heads from a donor drive.
  • Beeping or buzzing (stiction)Platters are NOT spinning. Motor is stalled because heads are bonded to the platter surface or the spindle bearing is seized. Beeping drive recovery →
  • Grinding or scraping soundsHeads have already crashed into the platters and are cutting grooves into the magnetic surface. Stop the drive immediately. Grinding or scraping sounds →
  • Other hard drive soundsWhirring, humming, or intermittent noises can indicate bearing wear, PCB failure, or firmware corruption. Other hard drive sounds →
What NOT to Do with a Clicking Hard Drive
Searching for how to fix a clicking hard drive will return dozens of DIY suggestions. All of them will destroy your data. Here is why.
Do Not Put It in the Freezer
The freezer trick dates to the 1990s when lower-density platters and wider head gaps made drives more tolerant of thermal contraction. It occasionally worked on stuck bearings in older drives. Modern drives use fluid dynamic bearings and platters with nanometer-scale head gaps. Freezing causes condensation to form on the platters the moment you power the drive on. Condensation on a spinning platter causes immediate head crashes and corrosion of the magnetic coating.
Do Not Run Recovery Software
Recuva, DiskDrill, CHKDSK, and similar tools force the drive to read sector by sector. If the heads are broken, every read attempt drags the damaged head slider across the magnetic coating. You will see the software "scanning," but what is happening inside the drive is the equivalent of dragging sandpaper across a DVD.
Do Not Tap or Shake the Drive
Tapping a clicking drive will not re-seat the heads. The heads fly nanometers above the platter surface on a cushion of air. Impact can cause the heads to contact the platters (a head crash), shear off entirely, or scatter debris across the platter surface. Physical force makes a bad situation worse.
Do Not Open the Drive
Opening a hard drive outside of a particle-filtered environment contaminates the platters within seconds. A single dust particle is larger than the gap between the heads and the platter surface. Dust particles become projectiles at platter speed, scoring the platters and making recovery impossible.
Do Not Swap the Circuit Board
In the 1990s, swapping a burned printed circuit board (PCB) from an identical drive sometimes worked. Modern drives have an 8-pin ROM chip soldered to the PCB that stores factory-calibrated adaptive parameters: head flight height, micro-jog offsets, and defect maps unique to that specific drive. A replacement board carries different calibration data. Its firmware will fly the heads at the wrong altitude, and the heads crash into the platters within seconds. Recovering from a PCB failure requires micro-soldering the original ROM chip onto the replacement board before powering the drive.
Can You Fix a Clicking Hard Drive?
No software will fix a clicking hard drive. The clicking is a mechanical failure: the read/write heads cannot locate servo tracks, so the actuator arm resets in a loop. Recuva, DiskDrill, and cloning utilities all require functional heads to read the platters. Running them on a clicking drive accelerates platter damage.
The only path to recovering data from a clicking drive is a physical head swap performed in a particle-filtered clean bench. We source an exact-match donor drive & transplant the donor heads onto the patient drive's platters. The original PCB stays on the patient drive, but its factory-calibrated adaptive parameters (head flight height, micro-jog offsets) were tuned for the dead heads, not the donors. We use PC-3000 to modify the adaptive parameters in RAM and configure the head map so the drive accepts the donor hardware. This is not a permanent repair. The donor heads are working in a mismatched environment and degrade faster than factory-original heads, so we image the platters immediately.
After imaging, the original drive is not reusable. The goal was never to fix the drive; it was to extract your data. Head swap hard drive data recovery at our lab costs $1,200–$1,500. No data, no charge.
Why Hard Drives Click
Think of it like a record player. The arm needs to follow invisible grooves to know where it is on the platter. These grooves are called servo tracks.
When the read/write heads are damaged, the drive becomes blind. It moves the arm out to find the tracks, sees nothing, panics, and pulls the arm back to reset. The click you hear is the arm hitting the stop at high speed. Over and over.
You cannot fix a blind arm with software. You have to give it new eyes. That is what a head swap is; we transplant working heads from a donor drive. In many cases, SMART errors like rising pending sector counts (SMART 197) show up before clicking starts, giving you a window to back up.
This has to be done in a particle-free environment. One dust speck is bigger than the gap between heads and platters.
How PC-3000 Recovers a Clicking Drive Without More Damage
Connecting a clicking drive to a standard motherboard or USB bridge forces the operating system to issue sequential read commands with default 30-second timeouts. When the degraded heads stall on a bad sector, the OS retries the same sector repeatedly. Each retry drags the failing head across the platter surface, generating debris and scoring the magnetic coating.
PC-3000 Data Extractor controls the physical SATA/USB PHY link directly, bypassing the operating system entirely. We disable the drive's internal retry logic, set custom read timeouts at the millisecond level, and build a head map that tells the imager which heads are stable and which are degraded. The stable heads image first. The degraded heads image last, in short bursts with thermal cooldown intervals between passes.
DeepSpar Disk Imager adds a second layer: if a sector causes the drive to freeze, it power-cycles the drive automatically and resumes from the next LBA. Consumer software has no equivalent. It will hang on a single bad sector until the heads collapse, turning a recoverable hard drive recovery into permanent data loss.
Firmware Corruption: When the Heads Are Fine
Not every clicking drive has broken heads. Hard drives store their operating firmware in a reserved area on the platters called the Service Area (SA). The SA contains translator modules, defect tables, and configuration data the drive needs to boot. If these modules degrade or corrupt after a power loss, the drive cannot initialize.
What happens next sounds identical to head failure: the heads sweep the platters searching for the firmware, fail to read it, and the actuator arm hits the parking ramp. The loop repeats, producing the same clicking pattern. But the heads themselves are physically intact.
We distinguish firmware clicking from head failure using PC-3000 terminal access. By connecting to the drive's diagnostic serial port, we can read the SA status registers and identify which modules failed. If the translator or defect table is corrupted, we rebuild the damaged modules using PC-3000 without ever opening the drive. Firmware repairs fall into our $600–$900 tier rather than the $1,200–$1,500 head swap tier, because the drive never needs to enter the clean bench.
Some Western Digital models (WD10SPZX, WD Elements) are frequent firmware clickers. The drive resets its arm because it cannot read its SA, not because the heads are damaged. If your drive is not detected by the computer but still spinning and clicking, firmware corruption is a strong possibility.
How We Diagnose a Clicking Drive Before Opening It
A clicking drive could be a $600–$900 firmware repair or a $1,200–$1,500 head swap. The difference is whether the heads are physically intact. We determine that before touching a single screw.
The first step is PC-3000 terminal access. We connect to the drive's diagnostic serial port & read the Service Area (SA) status registers. These registers report which heads passed the drive's internal startup self-test & which returned ABRT (abort) errors. If Head 0 passed but Head 1 returned ABRT, we know Head 1 is degraded or dead.
When a single head fails & the drive clicks, we use PC-3000 to edit the head map in RAM, virtually disabling the failed head. The drive initializes on the surviving heads, & we image the accessible platter surfaces immediately using PC-3000 Data Extractor with millisecond-level timeouts. This captures data from the healthy platters before we commit to a physical head swap for the remaining surfaces.
For cases where the clicking source is ambiguous, FLIR thermal imaging of the PCB identifies electrical shorts without invasive probing. A shorted TVS diode or failed motor controller IC produces a localized thermal hotspot visible under the FLIR camera within seconds of applying current-limited power. If the PCB is the cause, the fix is component-level board repair; the drive never needs to enter the clean bench.
How Platter Damage Escalates with Each Power Cycle
Leaving a clicking drive powered on does not produce a static failure. The damage compounds with every rotation. Understanding this progression explains why turning the drive off immediately is the single most important thing you can do.
Early-stage head degradation
Before the clicking starts, one or more heads lose read stability. The drive slows down, files take longer to open, & localized bad sectors appear. The firmware compensates with internal retries. If caught at this stage with PC-3000 or DeepSpar Disk Imager timeout management, data can often be extracted without a physical head swap. This is a firmware-tier recovery ($600–$900).
Initial head contact (first power cycle)
The heads lose aerodynamic lift & strike the platter surface. The drive clicks as the actuator arm sweeps, fails to find servo tracks, & slams into the parking ramp. If you power off within the first cycle, damage is typically limited to a narrow scoring ring near the landing zone. The remaining magnetic surface is intact. A head swap at this stage recovers the majority of data ($1,200–$1,500).
Debris cascade (repeated power cycles)
Each time you unplug & replug the clicking drive, the damaged heads sweep across the platters again. The mechanical friction shears off the magnetic coating, generating metallic debris particles. This debris is caught in the internal airflow & deposits on otherwise healthy platter surfaces. Multiple visible scoring rings appear. Files in the scored zones are permanently gone. The undamaged zones are still recoverable, but the process requires platter cleaning before donor heads can be installed. Recovery cost escalates toward the surface damage tier ($2,000).
Catastrophic scoring (drive left running)
If the drive runs for hours while consumer software forces read commands with no timeout management, the heads grind wide bands through the magnetic coating down to the bare aluminum or glass substrate. The internal chassis fills with metallic dust. Installing donor heads into this environment destroys them on the first rotation. At this stage, the data has been physically converted to dust. This is a head crash beyond recovery.
The difference between a $1,200–$1,500 head swap & permanent data loss is often the number of times someone powered on the drive "just to check." Every power cycle is a gamble with worsening odds.
Why Donor Head Matching Requires More Than the Same Model Number
A head swap fails if the donor heads are incompatible with the patient drive's platter geometry & firmware. Manufacturers produce the same model number across multiple hardware revisions, different factories, & different platter counts. The donor must match on several criteria simultaneously.
For Western Digital drives, a compatible donor requires matching the model number, the head map (number of active heads & their physical assignment), the Drive Configuration Matrix (DCM) code, the manufacturing date within a narrow window, & the preamplifier chip revision. The preamp is the microchip on the actuator arm that amplifies the analog signal from the heads. If the donor preamp revision does not match the patient drive's firmware expectations, the drive initializes but produces read errors across every surface.
Seagate drives require matching the model number, head map, site code (manufacturing facility), & the first portion of the part number. For the Seagate Rosewood family (ST1000LM035, ST2000LM007), the manufacturing date code determines the preamp version because Rosewood firmware does not expose preamp data through standard terminal commands. A 2016 Rosewood uses a different preamp than a 2019 Rosewood even though the model number is identical.
We maintain a cataloged donor inventory sorted by firmware revision, head map, & manufacturing date. When your drive arrives, we read its configuration using PC-3000 & match it against inventory before committing to a swap. If we don't have a compatible donor in stock, we source one. The donor drive cost is separate from the labor cost. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available. For a detailed walkthrough of the matching process, see our donor matching technical reference.
Preamp Failure vs. Physical Head Crash
A clicking drive doesn't always mean the heads physically struck the platters. The preamplifier (preamp) is a microchip soldered directly onto the head stack assembly's flex cable. It amplifies the microvolt-level signals from the GMR read sensors into millivolt-level signals the PCB's read channel can process. When the preamp dies, the heads receive no readable signal from the platters. The drive spins up, the voice coil actuator sweeps the arm searching for servo tracks, finds nothing, and slams into the parking ramp. The click pattern is identical to a physical head crash.
The difference matters for your data. A preamp failure leaves the platters physically unscored. The magnetic coating is intact; the electronics just can't read it. A physical head crash grinds the coating off the platters, destroying data in the scored zones permanently. Both require a head swap, but a preamp failure caught early has better recovery prospects because no platter surface has been damaged.
We distinguish these failures using PC-3000 terminal diagnostics before opening the drive. On Seagate F3-architecture drives (Rosewood, Grenada, Barracuda families), the spin-up sequence outputs diagnostic hex codes through the serial terminal port. A preamp failure produces a specific fault status flag in the initialization log. When we see that code, we know the platters are likely clean and can proceed with a standard head swap ($1,200–$1,500) rather than the surface damage tier ($2,000).
How the Voice Coil Actuator Produces the Click
The voice coil actuator (VCA) is the electromagnetic motor that positions the heads over specific tracks. It operates on the same principle as a loudspeaker coil: current through a coil in a magnetic field produces linear force. When the drive's controller loses servo sync, it drives the VCA at maximum current, sweeping the heads from the inner diameter to the outer diameter searching for valid servo marks. The arm hits the crash stop or parking ramp at each extreme, producing the click.
During a head swap, donor heads introduce minor geometric offsets relative to the patient drive's original servo tracks. The drive's firmware stores micro-jog calibration values that fine-tune each head's concentric alignment over the tracks. We use PC-3000 to adjust these micro-jog parameters in RAM so the donor heads track correctly. If micro-jog calibration is skipped, mechanically sound donor heads will overshoot track centers, fail servo lock, and click against the ramp; mimicking a physical failure despite being perfectly functional.
Failure ModePC-3000 Diagnostic IndicatorPlatter ConditionLab Procedure
Mechanical head crashMassive read errors; drive ID missing or truncatedScoring rings visible on plattersPlatter cleaning + head swap + selective head map imaging
Preamp IC failurePreamp fault status flag in terminal spin-up logPlatters unscored; magnetic coating intactHead swap with matching preamp revision
Translator corruption0 bytes capacity; BSY state lock in terminalPlatters intact; heads functionalSA firmware regeneration via PC-3000 (no head swap needed)
Adaptive parameter driftHigh bit error rate; slow reads; intermittent servo errorsPlatters intact; heads partially degradedRecalculate SAP/RAP in PC-3000 RAM; image with adjusted read channel
After the Head Swap: Translator Rebuild & Read Channel Tuning
Swapping donor heads into a clicking drive is the mechanical half of the job. The engineering half happens in PC-3000 after the drive is sealed and connected. The donor heads have different electrical impedance, different thermal fly-height characteristics, and different signal-to-noise profiles than the original heads. The drive's firmware was factory-calibrated for heads that are now dead. Three firmware systems need recalibration before imaging can begin.
Translator Module Reconstruction
The translator is a firmware module in the drive's Service Area that maps Logical Block Addresses (the sector numbers your operating system sees) to physical cylinder-head-sector locations on the platters. As heads degrade before they fail completely, the drive logs increasing numbers of bad sectors into its defect tables (the G-List and P-List). If these tables overflow, or if the drive loses power while writing an SA update, the translator module corrupts.
A corrupted translator means the drive can spin and the heads can read, but the firmware can't map your files to physical locations. The drive reports 0 bytes of capacity or locks in a BSY (busy) state. We use PC-3000 to boot the drive into factory mode, bypass the corrupted modules, and run a translator regeneration. This process scans the physical media's defect markers and rebuilds the LBA-to-CHS mapping from scratch. On Western Digital drives, translator regeneration is one of the most common PC-3000 procedures we perform on clicking drives that turn out to be firmware failures rather than mechanical.
Adaptive Parameter Recalibration (SAP, RAP)
Every hard drive stores factory-calibrated adaptive data in its ROM chip and Service Area. These parameters are unique to the original mechanism:
Read Adaptive Parameters (RAP)
Tune the read channel amplifiers and equalization filters for each individual head element's electrical impedance. When donor heads replace the originals, the impedance mismatch distorts the analog signal. Without RAP recalculation, the read channel produces a high bit error rate and the drive appears to fail even though the heads are mechanically sound.
Servo Adaptive Parameters (SAP)
Calibrate the voice coil motor's control loop for track-following accuracy. If SAP isn't corrected for the donor heads, the VCA overshoots track centers and the heads lose servo lock. The drive clicks; not because of a mechanical problem, but because the firmware is flying the donor heads with the wrong calibration data.
During a head swap, the original PCB and its ROM chip stay with the patient drive to preserve the base logic and encryption keys. PC-3000 extracts the RAP and SAP modules, recalculates values to compensate for the donor heads' variances, and writes them into the drive's RAM. This is why a head swap requires PC-3000 or equivalent vendor-specific tooling. Generic imaging software has no interface to modify adaptive parameters.
PRML Read Channel Tuning for Weak Signals
Modern drives don't use simple peak detection to read data. They use Partial Response Maximum Likelihood (PRML) and Extended PRML (EPRML) read channels that continuously sample the overlapping analog waveforms from the platters and run a Viterbi detector algorithm to determine the most probable binary sequence. The read channel's equalization filters are factory-tuned for the original heads' impedance and fly-height characteristics.
Donor heads produce a different analog signal profile. The signal entering the read channel's equalization filters is weaker, noisier, or shifted in phase relative to what the firmware expects. On healthy platters with clean donor heads, the mismatch is small enough that RAP recalculation fixes it. On degraded platters where the magnetic signal is already faint from prior head contact or aging, the mismatch is the difference between reading data and reading noise.
PC-3000 provides access to the drive's read channel registers during imaging. When imaging with donor heads produces high error rates, we adjust the equalization filter settings and preamplifier gain values to compensate for the impedance mismatch between the donor heads and the original factory calibration. The imaging throughput drops because PC-3000 manages instability through hardware timeouts, PIO mode fallback, and sector-level skip logic; the platters still spin at their native RPM. On drives where initial imaging stalls on large swaths of unreadable sectors, read channel adjustment combined with multi-pass imaging can recover additional sectors that would otherwise fall below the bit error rate threshold.
Types of Clicking Failures We Handle
Seagate Rosewood / LaCie
Found inside Backup Plus Slim, Expansion Portable, and LaCie Mobile Drive enclosures. Rosewood drives have a weak parking ramp; a minor bump knocks heads onto the platters. The click often transitions to grinding or scratching as damaged heads cut grooves into the platter surface. If you hear grinding or scraping sounds, the platters may already be scored. Stop immediately.
More about Rosewood recovery →
Western Digital
WD10SPZX, WD10JMVW, WD Elements, WD Passport
WD Slim (WD10SPZX) and Passport/Elements portable drives produce a rhythmic click-click-pause pattern. The heads seek servo tracks, fail, and reset. Some WD clicking is firmware corruption rather than physical head damage; the drive resets its arm because it cannot read its firmware modules from the system area. PC-3000 can distinguish firmware faults from head failure without opening the drive.
Modern WD Passport and Elements portable drives use native USB circuit boards with hardware encryption handled by the main controller. There is no standard SATA connector inside these enclosures, so recovering data requires working through the original board to preserve the encryption keys. See our Western Digital data recovery and WD My Passport recovery pages for model-specific procedures.
Toshiba / HGST
MQ01ABD, MQ04ABF, Canvio Portable
Toshiba 2.5-inch drives can produce rapid woodpecker-style clicking. Some Toshiba/HGST models also develop motor bearing issues that sound like buzzing rather than clicking. Clean bench diagnosis is required; the sound alone does not distinguish head failure from bearing failure.
Toshiba and legacy HGST models require exact-match donor heads that differ by firmware revision. When a single head fails and causes clicking, we use PC-3000 to disable the failed head in the drive's configuration and image the surviving platters first before performing a physical hard drive data recovery head swap. See Toshiba data recovery and Hitachi data recovery for the specific models we stock donors for.
External USB Drives
WD My Passport, Seagate Backup Plus, LaCie Rugged
External drives add a variable: the USB-to-SATA bridge board inside the enclosure. A damaged USB cable, a failing bridge chip, or unstable USB power from a laptop running on battery can interrupt the drive mid-spin. The heads lose their position and reset, producing a sharp click that sounds identical to mechanical head failure. Before assuming the worst, try a different USB cable and a powered USB hub. If the clicking persists, the internal drive likely has physical head damage from a drop or impact. We bypass the USB bridge entirely using PC-3000 to diagnose the bare SATA drive inside.
LaCie portable drives typically house Seagate Rosewood SATA disks, which have a fragile parking ramp design that makes them vulnerable to head failure from minor impacts during transport. Our external hard drive data recovery page covers all enclosure brands, including LaCie recovery.
Not Sure What You Have?
Different symptoms point to different problems. If your drive is not clicking but has other issues:
Watch a Head Swap
Here is what recovering a clicking drive actually looks like. This is a Western Digital head swap performed on our clean bench.
What you are seeing
  • Drive opened inside laminar flow bench with ULPA filtration
  • Damaged head assembly removed from patient drive
  • Donor heads transplanted from exact-match drive
  • Drive imaged immediately before heads degrade further
The equipment is real. The process is real. We document our work so you can see exactly what you are paying for.
What This Costs
Most data recovery companies hide their prices behind call-for-quote forms so they can size up your wallet. We do not do that. Here is what things cost.
ProblemRossmannDriveSavers / Big Labs
Clicking Drive / Head Swap$1,200–$1,500$2,000-$7,000+
Beeping Drive / Stuck Heads$1,200–$1,500$1,500-$2,700
Not Detected / Firmware$600–$900$1,000-$2,500
Logical Recovery$100–$250+$500-$1,500
Evaluation FeeNoneFree evaluation, but common fees elsewhere
Why the difference? We do not bankroll PPC ads, affiliate kickbacks, or vanity certificates. Your invoice reflects engineering time, donor parts, & imaging hours; not marketing overhead. Read our DriveSavers pricing analysis.
Head swap & surface damage tiers require a 50% deposit. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available. Need it faster? +$100 rush fee to move to the front of the queue. Typical turnaround for clicking drive head swap cases: 4-8 weeks.
Why is my hard drive clicking?
A clicking hard drive indicates physical failure of the read/write heads. The heads use magnetic servo tracks to navigate the platters. When the heads are damaged, they cannot find these tracks, so the drive resets the arm repeatedly. That is the clicking sound. This is mechanical damage that no software can repair.
Can I put my clicking hard drive in the freezer?
No. The freezer trick is a myth from the 1990s that does not apply to modern drives. Modern drives use fluid dynamic bearings and high-density platters. Removing a frozen drive from the freezer causes condensation to form on the platters the moment the cold metal contacts warm ambient air. Powering on the drive with this moisture present causes immediate head crashes and corrosion. You will destroy your data.
How much does clicking hard drive recovery cost?
At Rossmann Repair Group, clicking drive recovery requiring a head swap typically costs $1,200-$1,500. Large data recovery labs like DriveSavers charge $2,000-$7,000 or more for the same procedure. We use the same equipment but do not have their marketing overhead.
Can data recovery software fix a clicking hard drive?
No. Data recovery software requires the drive to mechanically function and read data. A clicking drive cannot read because the heads are physically broken. Running software forces the damaged heads to scrape across the platters repeatedly, destroying the magnetic coating that contains your data.
What should I do if my hard drive is clicking?
Turn it off immediately. Do not run any software, do not try to recover files, do not put it in the freezer. Every second the drive runs with damaged heads, you risk permanent data loss. Contact a professional data recovery lab with proper clean bench equipment.
Can I fix a clicking hard drive by swapping the circuit board?
No. Modern hard drives have a ROM chip on the PCB that contains unique adaptive parameters such as head flight height and micro-jog calibration written at the factory. Swapping a circuit board without micro-soldering and transferring this specific ROM chip will cause the replacement board to fly the read/write heads at the wrong altitude, crashing them into the platters and permanently destroying your data.
Why is my external hard drive clicking?
An external hard drive may click due to physical head failure from drops, or due to electrical issues. A damaged USB cable, a failing USB-to-SATA bridge inside the enclosure, or unstable power from a laptop on battery can interrupt the drive mid-spin. This causes the read/write heads to lose position and reset, producing a sharp clicking sound. Professional diagnostics can bypass the USB bridge to determine if the internal SATA drive is mechanically intact.
Is it normal for a high-capacity Helium hard drive to click?
Occasional random clicking in high-capacity helium drives (12TB+) can be normal preventive head parking. A loud, continuous, rhythmic click indicates failure. If a helium drive has mechanical head failure, recovery requires a head swap inside the sealed chamber with helium refill after reassembly. We perform helium head swaps in-house at our Austin lab. The procedure costs more than standard air drives because helium donors are expensive & the helium refill adds $400-$800 ($3,000–$4,500 total for the head swap tier). If the clicking is firmware corruption rather than physical head damage, we repair it through PC-3000 terminal access without opening the drive.
Are Seagate drives more likely to click than other brands?
Seagate's Rosewood platform (ST1000LM035, ST2000LM007) has a weak parking ramp design that makes the heads vulnerable to even minor impacts. A bump during transport can knock the heads onto the platter surface, causing immediate clicking or grinding. These drives ship inside Backup Plus Slim, Expansion Portable, and LaCie Mobile Drive enclosures. We stock Rosewood donor heads because we see these models weekly. Other Seagate drive families including Barracuda desktop drives and IronWolf NAS drives also develop clicking from head wear, but the failure rate on Rosewood portables is disproportionately high relative to other 2.5-inch platforms.
My clicking hard drive still shows up in Windows. Can I copy my files off it?
A clicking drive that temporarily mounts in Disk Management is in a state of imminent failure. The heads are damaged but still intermittently reading servo tracks between resets. Running any file copy, Disk Drill scan, or CHKDSK forces the failing heads to sweep across every sector linearly, scraping the magnetic coating off the platters. Professional imaging with PC-3000 and DeepSpar Disk Imager reads around bad sectors with millisecond timeouts, imaging healthy heads first. Consumer software has no head management; it will grind through degraded sectors until the heads collapse, turning a recoverable hard drive recovery into permanent data loss.
Do SSDs make a clicking noise when they fail?
No. Solid state drives have no moving parts: no platters, no actuator arm, no spindle motor. An SSD fails silently or disappears from your BIOS entirely. If you hear clicking from a laptop that uses an M.2 NVMe or 2.5-inch SATA SSD, the noise is coming from a failing cooling fan bearing, a motherboard power relay, or (in older MacBooks) a stuck optical drive mechanism. SSD data recovery addresses controller failures and NAND degradation, not mechanical sounds.
Can a bad power supply or USB cable cause clicking?
Yes. 3.5-inch external desktop drives like the WD My Book require a 12V power adapter to spin the platters. A wrong adapter, a frayed cable, or a dying power brick delivers unstable voltage that causes the spindle motor to repeatedly stall and restart, producing a rhythmic ticking identical to mechanical head failure. Before shipping your drive for data recovery, test with the original OEM adapter and a different USB cable. If the clicking stops, the drive itself may be fine; the enclosure electronics were the problem.
Will a clicking hard drive stop clicking on its own?
It will stop when the heads destroy themselves on the platters or the motor seizes. The clicking is a microcode loop: the actuator arm sweeps out searching for servo tracks, fails, slams into the parking ramp, and repeats. The firmware will not recalibrate. Each cycle degrades the head suspension assembly further, and the vibration causes the slider to drop closer to the platter surface. Leaving the drive powered on hoping it will fix itself guarantees that recoverable head damage escalates into permanent platter scoring.
How should I package a clicking hard drive for mail-in recovery?
Wrap the bare drive in an anti-static bag, then surround it with 3-4 inches of bubble wrap on all sides. Place it in a rigid corrugated box; the drive should not shift when you shake the box. Do not use loose packing peanuts or crumpled newspaper, which generate static and allow the drive to move during transit. A clicking drive may have heads resting on the platters rather than parked on the ramp, so any impact during shipping can score the magnetic surface. See our mail-in instructions for prepaid shipping labels and step-by-step packaging guidance.
Why does running chkdsk or SpinRite destroy a clicking hard drive?
chkdsk issues standard read commands through the OS. SpinRite bypasses the OS but still sends standard ATA read commands to the drive controller. Both rely on the drive's internal retry logic. When a head is physically degraded, the firmware retries each failed sector hundreds of times, dragging the damaged head slider across the magnetic coating. Thousands of forced retries generate microscopic debris that contaminates adjacent tracks. A drive that needed a $1,200-$1,500 head swap now has scored platters requiring a $2,000 surface damage recovery, or the data is permanently lost.
My hard drive is making a clicking noise but still works. Is that normal?
A hard drive making a clicking noise while still accessible is in early-stage head failure. The heads are intermittently reading servo tracks between reset cycles. Each read attempt forces the degraded heads across the platter surface. Do not copy files, defragment, or run antivirus scans. Power it off and send it for professional imaging with head management. On external drives, first verify the noise is not from an underpowered USB port by trying the OEM adapter or a powered USB hub.
My local computer shop said they can fix it for $100. Should I let them?
Ask them one question: do you have a PC-3000 and a clean bench? If they say they will try running a scan or see if the software can find it, take your drive and leave. Running software on a clicking drive destroys data.
Why is head swap recovery so expensive?
The equipment costs money; a PC-3000 system runs around $10k. The donor drives cost money; we have to destroy a working drive to save yours, and it has to be an exact match. The labor is skilled and time-intensive. But we do not have a marketing department, we do not pay for Google Ads, and we do not have salespeople trying to upsell you. That is why we are about half the price of the big labs for the same work.
Do I pay if you cannot recover my data?
No. No Data, No Charge means exactly that. If the platters are too damaged and we cannot get your files, you pay nothing for the attempt. You only pay return shipping if you want the original drive back.
What are the chances you can recover my clicking drive?
It depends on platter condition. If you turned it off immediately and the platters are not scratched, the odds are good. If someone ran software on it first, tried to open it, or kept powering it on hoping it would work, the odds drop. The sooner you stop, the better your chances.
Can data be recovered from a clicking hard drive?
Yes, in most cases. If you power off the drive immediately after the clicking starts, the platters are usually unscored and a head swap recovers the data. Recovery requires transplanting exact-match donor heads in a 0.02 micron ULPA-filtered clean bench, then imaging the platters sector-by-sector using PC-3000 Data Extractor with millisecond-level timeouts. Clicking caused by firmware corruption rather than physical head damage is even more straightforward; we rebuild the corrupted Service Area modules through PC-3000 terminal access without opening the drive. The longer the drive runs while clicking, the worse the prognosis. A drive powered off after one click cycle is a $1,200-$1,500 head swap. A drive left running overnight with consumer software forcing reads may have scored platters beyond recovery.
Can I just buy a new head assembly online?
The heads have to be an exact match; same model, same revision, often same firmware version. You cannot just order generic heads. And even if you find the right donor, you need a clean environment to do the swap. One dust particle is enough to cause a head crash.
Is a clicking hard drive a physical problem?
Yes. Clicking indicates a mechanical failure of the read/write heads or actuator arm. Software cannot cause or fix a clicking sound. The drive needs to be opened in a filtered environment for head replacement.
Can you fix a clicking hard drive?
A clicking drive cannot be "fixed" to work reliably again. The goal is data recovery: replacing the failed heads with matched donor parts to extract data from the platters before the drive is retired. Head swap recovery costs $1,200-$1,500 at Rossmann Repair Group.
Can I fix a clicking hard drive at home?
No. Opening a hard drive outside a filtered environment exposes the platters to dust particles that cause additional damage. DIY head swaps require specialized tools (head combs, a 0.02 micron filtered workspace) and firmware-level knowledge to rebuild the drive's translator module.
Can a power surge cause a hard drive to click?
Yes. A severe power surge can bypass the external power supply & strike the PCB. If the surge destroys the TVS diodes & reaches the internal preamplifier chip on the actuator arm through the interface contacts, the preamp dies. Without a functioning preamp, the read/write heads receive no signal from the platters. The drive spins up, the arm sweeps searching for servo tracks, finds nothing, & clicks. The fix depends on where the damage stopped: if only the external TVS diode is blown, PCB-level repair restores function. If the surge reached the internal preamp, a physical head swap is required.
Why does my Western Digital hard drive click three times and then spin down?
This is a diagnostic signature of Western Digital head failure. When a WD drive powers on, it attempts to read its Service Area (SA) firmware from the innermost platter tracks. The microcode retries this initialization a fixed number of times. If the heads are too degraded to read the SA, the firmware aborts after those retries & cuts power to the spindle motor to prevent further platter damage. The spin-up, click-click-click, spin-down pattern means the heads are physically unable to read firmware. This requires a head swap, not a firmware repair.
What if the clicking heads scratched the platters?
If the drive ran long enough for the damaged heads to gouge the magnetic coating, the data in those scratched zones is gone permanently. The coating turns to dust inside the drive. Recovery is still possible for the remaining undamaged areas. We use PC-3000 and DeepSpar Disk Imager in multi-pass mode, reading around the degraded zones with configurable head maps and timeout parameters. Each pass captures sectors the previous pass missed. Running consumer software on a scored drive destroys the donor heads within minutes and guarantees total loss.
Why are DriveSavers and other big labs more expensive?
They spend a lot on marketing. DriveSavers is an Apple partner, Ontrack does enterprise contracts; they have big sales teams and advertising budgets. That overhead gets passed to you. We use the same class of equipment; PC-3000, laminar flow benches, donor inventory. The work is identical. The price is not.
Are clicking Toshiba or Canvio external drives recoverable?
Toshiba Canvio portables and internal laptop models (MQ01ABD, MQ04ABF series) are recoverable. These drives suffer from rapid head failure and, less commonly, spindle motor bearing seizures that produce a buzzing or rapid clicking. Running a drive with failing heads scores the magnetic coating on the platters, so immediate power-off is critical. We perform head swaps using exact-match donors. Toshiba data recovery starts at $1,200-$1,500 for head swap cases. No data, no charge.
The clicking will not fix itself.
Every power cycle risks more damage. Free evaluation. No data, no charge. Mail-in from anywhere in the U.S.
