SSD Data Recovery - NVMe, M.2, and SATA Drive Recovery
From the technician 2 million YouTubers trust. If your SSD is not detected or data became inaccessible, we perform component-level repair instead of canned software clicks; fixing the controller, firmware, or power path so your files can be imaged safely.
Technician repairing a storage device
How Much Does SSD Data Recovery Cost?
SSD data recovery at Rossmann Group costs $200–$1,500: $200 for simple data copies from functional drives, $250+ for file system repairs, $600 to $900 for circuit board repair, $900 to $1,200 for firmware reconstruction, and $1,200 to $1,500 for advanced board rebuilds. Every case starts with a free evaluation and a firm quote before paid work begins. If we cannot recover your data, you pay nothing.
We recover data from NVMe, M.2, and SATA SSDs using PC-3000 Portable III for firmware-level repair and JBC microsoldering stations for component-level board work. Unlike hard drive recovery, SSD failures involve dead controllers, corrupted firmware translation layers, and shorted power management ICs. Software tools cannot reach data on a drive whose controller is dead. All work is performed in-house at our Austin lab; we do not outsource to third-party labs. Walk-in service in Austin or mail-in from all 50 states.
Drives We Recover From
Updated February 2026
18 min read
What SSD Recovery Customers Say
4.9 across 1,837+ verified Google reviews
I consulted Rossmann Repair Group for data recovery services. A new IT client was recently referred to me, because his main computer crashed and his business database went offline as a result. It turned out that the computer crashed because its main storage, a 500 GB Solid State Hybrid Drive, failed. That part was easy - replace it with a new 1 TB SSD and reinstall Windows along with the software he uses. However, the data on the SSHD was critical and would have meant serious problems for his business if he didn't get that back. That's where Rossmann Repair Group came in.
Shomari Hohn
Went in to ask if they could retrieve my SSD from my Surface Pro 4 for me and they gave me a good rate, but was still a bit too expensive for me. So, they let me use their equipment for about an hour until I was able to fish it out myself and recover my data.
Aravind Udayakumar
Sent in a SSD for data recovery for a client of mine. Data was recovered! What else can I say. Thank you.
David Dachenhaus (DDock)
Amazing place! Super friendly and knowledgeable people! I have a LaCie Rugged Pro SSD that stopped mounting. It turns out the enclosure was the problem, not the SSD itself. They helped diagnose the issue and offered solutions—all free of charge. Great experience, and I highly recommend them! 😊
Ludwig JonssonLaCie
What is SSD Data Recovery?
SSD data recovery is the process of extracting inaccessible files from solid-state NAND flash memory when the drive's controller, firmware, or electronics have failed. Unlike hard drive recovery, which centers on mechanical repairs like head swaps and platter work, SSD recovery requires board-level electronics repair: microsoldering failed surface-mount components, reprogramming corrupted firmware through PC-3000, or repairing the power delivery circuit so the original controller can power on and serve its data. Software tools cannot reach data on a drive whose controller is dead.
SSD recovery methods include:
  • Logical recovery: Repairing corrupted file systems, rebuilding lost partitions, and carving deleted files from drives where the controller is still functional and TRIM has not unmapped the target blocks
  • Firmware recovery: Forcing the controller into safe/diagnostic mode via PC-3000, injecting a working firmware loader, and rebuilding the flash translation layer (FTL) so the drive can map and serve its data again; common on SATAFIRM S11 and other Phison/Silicon Motion controller failures
  • Hardware-level recovery: Component-level microsoldering to repair original controller power circuitry, replace shorted PMICs, or inject factory-mode firmware loaders to bypass failed controllers; perform board trace repair for surge-damaged or liquid-damaged drives; and chip-off NAND extraction for unencrypted drives as a last resort when the PCB is destroyed beyond repair
Last updated: March 2026
At a Glance
SSD Data Recovery Pricing
SSD data recovery costs $200–$1,500, depending on the failure type. Simple data copies start at $200. File system recovery starts at $250. Circuit board repair is $600 to $900. Firmware reconstruction is $900 to $1,200. Advanced board rebuilds are $1,200 to $1,500. We provide a firm quote after a free evaluation.
Honest ranges so you can budget without a sales call. Free evaluation and a firm quote before any paid work begins. If it turns out easier than expected, you pay less; not a flat "worst-case" tier. If we cannot get your data, you pay $0 (optional return shipping only). See all service pricing.
Service TierPriceDescription
Simple CopyLow complexity$200
File System RecoveryLow complexityFrom $250
Circuit Board RepairMedium complexity – PC-3000 required$600–$900
Firmware RecoveryMedium complexity – PC-3000 required$900–$1,200
Advanced Board RebuildHigh complexity – precision microsoldering and BGA rework$1,200–$1,500
Your drive's circuit board is severely damaged and requires advanced micro-soldering
Advanced component repair. Micro-soldering to revive native logic board or utilize specialized vendor protocols
50% deposit required upfront; donor drive cost additional
All tiers: Free evaluation and firm quote before any paid work. No data, no fee on all tiers (advanced board rebuild requires a 50% deposit because donor parts are consumed in the attempt).
Target drive: The destination drive we copy recovered data onto. You can supply your own or we provide one at cost. All prices are plus applicable tax.
Important: Previously messed with or tampered drives may not qualify for "no data, no fee" unless agreed in advance.
Match Your SSD Symptom to a Recovery Tier
The behavior your SSD exhibits tells us the failure type, which determines the recovery method and cost. Find your symptom below.
SymptomLikely FailureRecovery MethodPrice Range
Not detected in BIOSDead controller or shorted PMICBoard-level microsoldering, component replacement$600–$900 to $1,200–$1,500
Shows SATAFIRM S11 / 0 bytesFirmware translator corruptionPC-3000 safe mode, translator rebuild$900–$1,200
Hot to touch / burning smellShorted PMIC or controller componentFLIR thermal imaging, component replacement$600–$900
Wrong capacity shownFTL mapping table corruptionPC-3000 Techno Mode, FTL reconstruction$900–$1,200
Slow reads / frequent freezesNAND degradation, ECC threshold exceededMulti-pass thermal imaging via PC-3000$900–$1,200 to $1,200–$1,500
Formatted / deleted filesLogical damage (TRIM status determines feasibility)File system rebuild if TRIM has not unmapped blocksFrom $250
SSD Data Recovery Cost Comparison
ProviderPrice RangePricing ModelNo Data, No Fee
Rossmann Group$200–$1,5005 published tiers with exact prices, firm quote after free evaluationYes
DriveSavers$2,000 - $7,000+Call for quote, percentage-based legacy modelVaries
Ontrack / Secure Data$800 - $3,000+Call for quoteVaries
Industry estimates based on published customer reports and competitor pricing pages (2024-2025). Actual quotes vary by case.
Large labs price SSD recovery the same way they price hard drive recovery: a wide range quote after a blind evaluation, then the final bill lands at the top of the range. We publish our tiers upfront, give a firm quote after a free hands-on evaluation, and charge nothing if recovery fails. Read the full breakdown of how large lab pricing works.
Why We Publish Our Prices
Most data recovery labs hide their pricing behind a phone call because their business model depends on quoting based on how desperate you sound. We publish ours because we are confident in what we charge. A firmware rebuild is a firmware rebuild whether you found us through Google or through a referral. The price does not change based on who is asking.
Every recovery listed on this page is performed in-house at our Austin lab. We do not outsource to a third-party lab. We do not broker your drive to another company. The same technicians who diagnose your SSD are the ones who repair it, image it, and verify the files. You can watch the actual work on Louis's YouTube channel, where we record live recoveries, including the failures. That level of visibility is the opposite of what large labs offer.
Rossmann Repair Group is also one of the most visible advocates for the Right to Repair movement. Louis has testified before the FTC and state legislatures to fight manufacturer restrictions that block independent repair shops from accessing the parts, tools, and documentation needed to fix your devices. That fight is not separate from what we do here. When a manufacturer designs an SSD so that only their authorized service center can access the encryption keys, that is a repair restriction. We work around it with engineering, not permission.
Can Data Be Recovered From a Dead SSD?
In most cases, yes. A "dead" SSD usually means one of three things: the controller has failed (drive not detected, shows 0 bytes), the firmware translation layer is corrupt (wrong capacity, SATAFIRM S11), or a power management IC has shorted (drive gets hot instantly when plugged in). None of these conditions destroy the data stored in the NAND flash. Flash cells hold charge without power. The data persists even when the controller cannot read it.
For shorted components, we locate the failure with a FLIR thermal camera and replace the damaged IC under a JBC microsoldering station. For firmware corruption, we force the controller into diagnostic mode via PC-3000 and rebuild the flash translation layer from raw NAND metadata. For controller death, we repair the surrounding power delivery circuit so the original controller can power up and serve its data.
The one scenario where SSD data is permanently gone: hardware-encrypted drives where the controller is destroyed beyond repair. Modern NVMe controllers bind AES-256 encryption keys to unique hardware fuses inside the silicon. If the controller cannot be revived through board-level repair, the keys are lost and the NAND contains only unreadable ciphertext. This is why we focus on repairing the original board rather than attempting chip-off; the decryption chain depends on the original controller functioning.
Is SSD Data Recovery Worth It?
That depends on what is on the drive. If the files are irreplaceable (business records, project files, family photos, research data), the value of recovery exceeds the cost. If the files exist in backups or cloud storage, recovery is unnecessary.
Our SSD recovery pricing ranges from $200–$1,500. A file system rebuild costs From $250. Board-level repair costs $600–$900. Firmware reconstruction costs $900–$1,200. Before committing, you get a free evaluation and a firm quote. We do not start work until you approve the price. If we cannot recover your data, you pay nothing under our no data, no fee guarantee.
The risk calculation is straightforward: you pay $0 to find out whether recovery is possible, and you only pay if we deliver your files. Compare that to national labs where the same firmware rebuild can cost $2,000 to $5,000 with no published pricing.
How Long Does SSD Data Recovery Take?
Recovery time depends on the failure type. Firmware repairs (translator corruption, safe mode access, FTL rebuilds) take 3 to 7 days once the drive reaches our lab. Board-level microsoldering (PMIC replacement, trace repair, controller power path restoration) takes 1 to 2 weeks because diagnosis requires thermal imaging and component-level testing before any soldering begins.
NAND degradation cases with multi-pass read retries and thermal stabilization take 1 to 2 weeks, as each pass requires adjusted voltage thresholds and cooling periods between reads. We provide a time estimate alongside the price quote after the free evaluation. If your case is time-sensitive, mention that when you ship the drive; we prioritize urgent cases.
Why Software Cannot Recover a Dead SSD
The top search results for "SSD data recovery" are software tools: Disk Drill, EaseUS, Stellar. These tools scan the file system through the operating system. They work when the drive is detected and the controller is responding. When the controller is dead, no software on any computer can reach the NAND. Here is why.
Dead Controller
Software requires a functioning controller to communicate with the drive over USB, SATA, or NVMe. If the controller is dead, the drive does not enumerate. No interface, no access, no recovery path for any software tool.
TRIM Erasure
When you delete files on an SSD, the operating system sends a TRIM command. The controller marks those blocks as invalid and returns zeroes to any read request. Software cannot access data the controller has logically unmapped. This is the opposite of hard drives, where deleted files persist until overwritten.
Encrypted NAND
Modern SSD controllers encrypt all data at rest using AES-256. The encryption key lives inside the controller. Even if you desolder the NAND chips, without the controller's key the raw data is unreadable ciphertext.
Already tried software? If your SSD is not detected in BIOS, software was never going to work. Read the full comparison of software vs professional recovery, or send the drive for a free evaluation.
How SSD Recovery Works
SSDs fail differently than spinning drives - no moving parts, but controllers, firmware, and NAND all introduce unique challenges.
  1. 01
    Evaluation
    Chris diagnoses power rails, controller response, and NAND status. Free quote with realistic odds before any paid work.
  2. 02
    Repair & Imaging
    Component-level board repair, firmware reconstruction, or direct NAND reads depending on architecture. Image-first workflow to protect your data.
  3. 03
    Data Return
    Files verified, transferred to your choice of media. No data = no charge on qualifying jobs.
Recent SSD Recovery Cases
Samsung 980 Pro 2TB
Controller Short
Dead to system. FLIR showed thermal runaway on the PMIC. Replaced the shorted capacitor and reflowed the power management IC. Drive booted in PC-3000. Full image, 100% of files recovered.
100% recovered
Kingston A400 480GB SATA
SATAFIRM S11 / 0 Bytes
Drive enumerated with wrong model string and zero capacity. Firmware translator was corrupt. Rebuilt the translator and service area modules via PC-3000 SSD utility. Full file system intact.
100% recovered
Apple M1 MacBook Pro
Liquid Damage
Coffee spill killed the logic board. Ultrasonic cleaning, then rebuilt corroded power rails and replaced two shorted capacitors near the SSD power path. Board booted, Secure Enclave decrypted, data extracted through the repaired board.
100% recovered
Crucial MX500 500GB
Degraded NAND
Drive dropped offline after years of heavy writes. Service area partially unreadable. Placed in safe mode via PC-3000, rebuilt translator from surviving metadata, multi-pass read with thermal optimization.
99% recovered
MacBook Air (Soldered SSD)
SSD Shorted & Smoked
Board-level short caused the SSD controller area to overheat and smoke. Thermal imaging located the failed component. Replaced the shorted IC, restored power path, and imaged the soldered NAND through the repaired board. Watch this case.
100% recovered
Lab Environment Verification
0.5µm Particles: < 100 per ft³|Status: ISO 14644-1 Class 4 Equivalent
SSD recovery requires a clean bench for precision micro-soldering, not an entire cleanroom. Our Laminar Flow Bench maintains ISO 14644-1 Class 4 equivalent air quality at the work surface.
Recent Recoveries
DateDrive / ControllerIssueToolResult
Feb 20262TB Phison E12Firmware Translation Layer CorruptionPC-3000 Portable IIIFull Recovery
Feb 2026Samsung 870 EVODegraded NAND / Bad BlocksPC-3000 Read-Retry98% Recovered
Jan 2026Silicon Motion SM2258XTController LockupPC-3000 Firmware ReconstructionFull Recovery
Watch Real SSD Recoveries
Full walkthrough: save mode activation, firmware injection, translator rebuild, and heat-assisted NAND reading on a failing NVMe drive.
Video Summary
This video walks through a complete NVMe SSD recovery case from initial diagnosis to final file extraction. The drive fails to enumerate in the operating system, showing no capacity and no model string. The PC-3000 Portable III with its PCIe SSD adapter communicates with the failed controller at the hardware level, bypassing the normal host interface entirely. The first step is placing the controller into Techno Mode, a diagnostic state that halts normal controller logic and allows the recovery tool to issue low-level vendor commands. From there, PC-3000 reads the service area modules where the firmware translation layer (FTL) is stored. Several FTL modules are corrupt, preventing the controller from mapping NAND addresses to logical block addresses. The repair involves injecting a working firmware loader and rebuilding the translator using surviving metadata from the NAND chips. Because the NAND cells have accumulated write wear and some pages show charge retention loss, standard reads return ECC errors. The video demonstrates the heat-assisted read technique: controlled warming of the NAND package shifts the voltage threshold distributions back into readable range, reducing uncorrectable bit errors enough for the ECC decoder to reconstruct the data. After the translator rebuild, the drive becomes accessible through the PC-3000 imaging pipeline. The case shows why controller failure on an NVMe drive does not mean permanent data loss, provided the NAND itself still holds valid charge and the service area metadata can be reconstructed.
MacBook Air SSD thermal failure: damage assessment, short circuit detection, and soldered NAND recovery feasibility.
Video Summary
This video covers a MacBook Air that arrived with visible thermal damage: the SSD controller area on the logic board had shorted, drawing excessive current, and the area around the NAND package showed heat discoloration. The SSD is soldered directly to the logic board with no removable module. The diagnosis begins with a FLIR thermal camera to locate the shorted component before applying power. The failed IC is identified near the NAND power rail. Repair involves desoldering the failed component under a JBC microsoldering station, fitting a matching donor part, and rebuilding the damaged board traces adjacent to the pad. Because this is an Apple Silicon MacBook, the NAND is encrypted by the Secure Enclave inside the M-series SoC. Chip-off recovery is not viable: desoldering the NAND packages produces only AES-256 ciphertext with no accessible key. The only path to the data is restoring enough board functionality that the Secure Enclave can power on and decrypt in place. After component replacement and trace repair, the board powers on. The Secure Enclave initializes, the APFS volume mounts, and the data is extracted through the repaired board. The case illustrates why board-level microsoldering capability is required for Apple T2 and M-series SSD recovery, and why labs without soldering capability cannot handle these cases.
See our full library of documented SSD recoveries →
Why Choose Rossmann
Component-level diagnosis
Microscope work, BGA rework, board-level repair; real component-level diagnosis, not just software.
YouTube transparency
We show the work, not stock photos. Founder Louis Rossmann is a Right-to-Repair leader.
In-house only
Your device stays in our Austin lab. No outsourcing, no middlemen.
No BS pricing
Clear ranges, free evaluation, no data = no charge.
Component-Level Repair
No Data = No Fee
All Work In-House
2M+ YouTube Followers
Software recovery tools (Recuva, R-Studio, Disk Drill) work by scanning the file system through the operating system. They require the OS to see the drive. If the SSD controller is dead, the drive does not enumerate, and no software on earth can reach the NAND. There are no spinning platters to image with a sector reader; the controller is the only gateway to the flash memory. A dead controller means zero access at the software level.
ScenarioSoftware ToolsBoard-Level Lab
Controller deadNo access. Drive not detected by OS.Component-level board repair restores access for imaging.
Files deleted (TRIM ran)Blocks logically unmapped. Unrecoverable.Unrecoverable. TRIM is permanent.
Firmware corruption (SATAFIRM S11)Drive shows wrong identity. Software cannot connect.PC-3000 rebuilds translator and service area modules.
Hardware-encrypted driveCiphertext only, even if drive is detected.Repair original controller to preserve decryption chain.
Liquid damageDrive shorted. Do not power on.Ultrasonic cleaning, component replacement, then imaging.
NAND degradedECC errors cause read failures and corrupted output.Multi-pass thermal reads via PC-3000, FTL reconstruction.
Software tools require a functioning controller and visible drive. Board-level lab work addresses the hardware failure first, then images the data.
Safe to Try
  • Open Disk Management (Windows) or Disk Utility (macOS) and check if the drive appears at all, even without a partition
  • Try a different USB-to-NVMe or USB-to-SATA adapter; cheap enclosures fail often and mimic a dead drive
  • Check BIOS/UEFI detection; if the drive shows its correct model and capacity, the controller is alive and software tools have a chance
Stop Immediately
  • Drive gets hot to the touch within seconds of connecting; this indicates a shorted component drawing excessive current
  • Burning smell from the drive or enclosure; continued power destroys adjacent NAND chips
  • Drive reports as SATAFIRM S11 or shows 0 bytes capacity; the firmware translation layer is corrupt and repeated power cycles risk overwriting the service area
Have a spinning hard drive instead? Clicking, beeping, or not detected - we do those too. Clean bench, PC-3000, donor parts on hand. We also handle RAID arrays and NAS devices.
Hard Drive Recovery →
SSD Failure Types We Handle
Each failure has its own diagnostic path and repair strategy.
Most data recovery labs are built around hard drives. Their tooling is clean rooms, platter swaps, and head stacks. None of that applies to SSDs. An SSD has no platters, no heads, and no spindle motor. When an SSD fails from physical or electronic damage, the fix is component-level electronics repair under a microscope. Labs that lack microsoldering capability send these cases back as unrecoverable. Note: many SSD failures happen without warning. SMART monitoring can catch wear-related failures on SSDs, but controller lockups and firmware bugs bypass SMART entirely.
Controller Failure
Symptoms: not detected, shows 0GB/8MB, instant disconnects, shows as SATAFIRM S11, or runs unusually hot. Common controllers: Phison, Silicon Motion, Marvell, Samsung, SandForce.
Our approach: diagnose PMIC/power rails, replace shorted components, or inject factory-mode firmware loaders to bypass a failed controller. We then use PC-3000 to initialize firmware and image.
Typical outlook: These are usually recoverable. A dead controller doesn't mean dead NAND. Depending on encryption architecture, we replace the controller IC or repair its power path.
NAND / Firmware Corruption
Symptoms: system hangs on access, disk reports odd capacity, partitions vanish after unsafe shutdown/updates.
Our approach: rebuild translator and metadata, direct NAND read if necessary, then extract the data by applying ECC and rebuilding the flash translation layer.
Typical outlook: Good odds when the corruption is logical rather than physical. The data is still on the chips - we just need to make sense of the scrambled map.
Board-Level Repair Techniques
Power Rail Repair
A shorted capacitor or blown PMIC (power management IC) kills the drive instantly. We use a FLIR thermal camera to locate the short, then replace the failed component under a JBC microsoldering station. Common on Samsung 970/980 EVO drives after power surges.
Controller Failure Recovery
A dead controller does not always mean dead data. While older architectures sometimes allowed for direct controller transplantation, modern solid-state drives use complex internal mapping that makes simple chip swapping impossible. Instead, we bypass the failed controller by repairing the surrounding power delivery circuitry, correcting localized shorts, or injecting specialized factory-mode firmware loaders via PC-3000 directly into the controller's diagnostic interface to initialize the drive and reconstruct the translation layer.
Trace and Connector Repair
Bent M.2 edge connectors, cracked PCBs from drops, and corroded traces from liquid damage all sever the electrical path between NAND and controller. We repair broken traces with jumper wires under magnification and rebuild corroded pads with fresh solder.
NAND Chip-Off
Modern NVMe controllers use complex, proprietary error-correction algorithms (LDPC). Because the data is heavily mathematically encoded across the NAND chips, traditional "chip-off" data recovery is often impossible without functioning controller hardware. We focus on advanced logic board repair and firmware manipulation to temporarily revive the original controller, allowing it to decrypt and decode your data natively.
Liquid damage note: corrosion spreads every hour a wet drive sits unpowered. If your SSD got wet, do not try to dry it with rice or a hair dryer. Ship it to a lab. We ultrasonically clean the board, neutralize corrosion, and assess component damage before applying power.
Troubleshooting Guides
Key SSD Failure Terms
Controller Lock
The SSD controller IC enters a protective state after detecting internal errors, preventing all data access. The NAND retains your files, but the controller refuses to serve them. Recovery requires forcing the controller into a diagnostic mode via PC-3000 or repairing the failed power delivery circuit that caused the lockup.
NAND Degradation
Flash memory cells lose their ability to hold charge after repeated program/erase cycles. TLC NAND is rated for roughly 1,000 to 3,000 P/E cycles; QLC NAND for roughly 100 to 1,000. As cells wear, read errors increase until the controller's ECC can no longer correct them. We use PC-3000's Read Retry with adjusted voltage thresholds and thermal stabilization to recover sectors that fail at standard sensing margins.
The flash translation layer (FTL) maps logical block addresses to physical NAND pages. When this map corrupts from power loss or firmware bugs, the drive appears empty, shows wrong capacity, or reports as SATAFIRM S11. PC-3000 rebuilds the translator tables by scanning raw NAND metadata and reconstructing the address map.
PMIC Failure
The power management IC regulates voltage to the controller and NAND. A power surge or voltage spike shorts the PMIC, killing the drive instantly. The NAND is unaffected because flash cells hold charge without power. We locate the short with FLIR thermal imaging and replace the failed PMIC under a JBC microsoldering station.
The Reality of Deleted Files and TRIM
When you delete a file on an SSD, the operating system sends a TRIM command telling the controller which LBAs (logical block addresses) are no longer needed. The controller marks those pages as invalid in its flash translation layer (FTL). The physical NAND cells are not erased at this point. Most modern SSDs implement DRAT or DZAT (Deterministic Read After TRIM / Deterministic Zeroes After TRIM), which means the controller immediately returns zeroes when those addresses are read through the normal interface, even though the underlying NAND cells still hold their original charge. The actual physical erasure happens later during garbage collection, when the controller consolidates valid pages into new blocks and erases the freed blocks asynchronously. Depending on workload and idle time, that physical erasure can take minutes to hours. Once a TRIM command is fully processed, the controller intentionally blocks access to the deleted files through standard interfaces. Unless the drive suffered an immediate hardware failure preventing background garbage collection, the data is typically permanently unrecoverable via conventional software.
This is the opposite of how hard drives work. On a spinning disk, deleted files sit untouched until new data overwrites them. On a TRIMmed SSD, the data becomes inaccessible through the controller within seconds of deletion. Physical NAND erasure follows during garbage collection, but the controller will not serve the data from the moment TRIM completes.
The distinction that matters: if you deleted files and the drive kept running, TRIM has already done its job and those blocks are logically unmapped. If the drive died from a hardware failure (dead controller, shorted PMIC, firmware corruption), the data may still exist on the raw NAND. However, on modern drives with hardware-level encryption (virtually all contemporary NVMe and many SATA SSDs use Self-Encrypting Drive technology by default), the decryption keys are tied to the controller. If the controller is permanently dead and cannot be revived through firmware repair or component-level microsoldering, extracting the raw NAND yields only unreadable ciphertext. Recovery in these cases depends entirely on restoring controller functionality, not on chip-off NAND extraction.
TRIM on Windows
Windows enables TRIM automatically on any SATA or NVMe SSD using native Microsoft drivers. The Storage Optimizer (formerly Disk Defragmenter) schedules a weekly "Retrim" pass that re-issues TRIM commands for all previously deleted blocks, ensuring the controller stays current even if the initial TRIM was missed. On a healthy Windows system, deleted data is typically logically unmapped and rendered inaccessible within seconds of deletion during normal use, and any stragglers are caught by the next weekly Retrim cycle.
TRIM on macOS
On Macs with a T2 chip (late 2017 through 2020, starting with the iMac Pro) or Apple Silicon (M1/M2/M3/M4), every byte written to the internal SSD is encrypted by default using AES-256 in XTS mode, with keys managed by the Secure Enclave inside the SoC. This encryption is always-on and transparent; you do not need to enable FileVault for it to be active. When files are deleted, macOS sends a standard TRIM command, and the controller handles it like any other SSD: the LBAs are marked invalid in the FTL and reads return zeroes. The Secure Enclave does not destroy any keys in response to individual file deletions.
What makes T2/M-series recovery different is not TRIM behavior; it is the always-on hardware encryption tied to the specific SoC. Because every block on the NAND is AES-256 encrypted with keys that exist only inside the Secure Enclave on that specific chip, desoldering the NAND yields only ciphertext regardless of whether TRIM has run. Chip-off is useless on these machines. The only recovery path when the logic board is dead is board-level microsoldering to get the Secure Enclave operational again so it can decrypt in place. We will not accept payment for a case we know cannot succeed.
Crypto-shredding, where the Secure Enclave destroys the volume encryption key and makes all data on the drive permanently irrecoverable, happens only during a full disk erase (Erase All Content and Settings, or a DFU restore). That operation is instant and absolute. It is distinct from per-file TRIM, which leaves the encryption keys intact.
On older Macs without a T2 chip using third-party SSDs, TRIM is not enabled by default. Users must run sudo trimforce enable to activate it. Until that command is run, deleted files persist on the NAND and standard recovery applies.
TRIM on Linux
Linux TRIM behavior depends entirely on the distribution and file system. Many distros batch TRIM commands via a weekly fstrim.timer service, creating a window where deleted data remains on the NAND before the timer executes. However, modern setups (such as Btrfs) increasingly default to asynchronous real-time discard, which unmaps blocks in the background continuously. If real-time discard is active, the data is unmapped immediately and is unrecoverable through the controller.
Write Amplification and Garbage Collection
TRIM tells the controller which blocks are free. Garbage collection is what the controller does with that information: it consolidates valid pages from partially-empty blocks into new blocks, then erases the old ones to create clean write targets. This runs continuously in the background whenever the drive is powered on and idle. Every consolidation cycle means extra writes to the NAND that the host never requested. That ratio of actual NAND writes to host writes is called write amplification. A drive with a write amplification factor of 3x wears its cells three times faster than the host workload alone would suggest. Heavy random writes, a nearly full drive, and aggressive garbage collection all push the factor higher, accelerating the path toward ECC failure and controller lockup.
The practical takeaway: if your SSD died from a hardware failure and never had the chance to run garbage collection after the crash, the metadata in the service area is likely intact, giving us a strong chance to reconstruct the FTL. If the drive was running for days in a degraded state, grinding through garbage collection cycles before it finally locked up, the controller may have already damaged the service area beyond repair. The sooner a failing drive is powered off and sent to a lab, the better.
SSD Recovery Feasibility by Failure Scenario
Operational ConditionEncryption StatusPhysical / Logical StateRecovery Feasibility
TRIM enabled (NTFS, APFS)UnencryptedLogical deletionNear zero; controller has zeroed the blocks
TRIM enabled (exFAT, FAT32)UnencryptedLogical deletionModerate; these file systems issue TRIM less aggressively
TRIM disabled or not issuedUnencryptedLogical damageHigh; NAND retains all data
TRIM disabled or not issuedEncrypted (key available via working controller)Logical damageHigh; decrypt in place, then image
TRIM disabled or not issuedEncrypted (key unknown or lost)Any stateZero; no viable decryption path
Any TRIM stateAny encryptionSevere physical damage (dead controller)Depends on board repair feasibility; TRIM cannot execute on a dead controller
TRIM cannot execute on a physically dead controller. If the drive died from a hardware failure before the OS sent TRIM commands, deleted data is still on the NAND.
Form Factors and Interfaces
SATA (2.5-inch)
SATA SSDs use the same AHCI protocol as spinning hard drives, capped at 600 MB/s. Controllers from Samsung (MEX/MJX), Silicon Motion (SM2259), and Phison (S12) follow well-documented architectures, common in laptops and desktops. Phison S11 controllers are the most common source of SATAFIRM S11 firmware failures. PC-3000 supports these natively over a standard SATA port; no adapters required.
M.2 and NVMe
M.2 is a physical connector shape, not a protocol. An M.2 slot can carry either SATA or NVMe. NVMe drives communicate over the PCIe bus with multi-queue command sets that reach 7,000+ MB/s on Gen 4 hardware. Recovery requires the PC-3000 Portable III with its dedicated PCIe SSD adapter; the tool issues low-level vendor commands over PCIe lanes to force controllers into safe/diagnostic mode, load custom firmware, and read NAND directly. Standard USB enclosures cannot do this.
NAND Cell Architecture and Degradation
Data Retention Warning: Unlike magnetic hard drives, SSDs do not hold data indefinitely when powered off. While solid-state storage is reliable, data can eventually degrade if the drive is left unpowered for years. Drives that have endured heavy write activity (exhausting their rated endurance) are particularly vulnerable to charge leakage and can begin losing data in as little as a year if stored in warm environments without power. If your SSD fails, do not leave it in a drawer for months before seeking recovery; the charge in the NAND cells will leak, leading to uncorrectable bit errors.
As NAND flash cells degrade through program/erase cycles, their voltage distributions widen and the margins between states shrink. The controller compensates using error correction (LDPC or BCH), but once bit errors exceed the ECC threshold, the controller cannot resolve the page. If the corrupted pages sit in the service area where the firmware and flash translation layer (FTL) live, the controller loses its map of where data is stored. The drive drops offline and reports 0 bytes or fails to enumerate entirely. The NAND still holds the data; the controller has lost the ability to find it.
At that point, PC-3000 forces the failed controller into diagnostic mode (Techno Mode), injects a working firmware loader, and rebuilds the translator from NAND metadata. For drives with severe NAND degradation or charge retention loss, we apply controlled heat to shift voltage thresholds back into readable range; a technique demonstrated in our NVMe recovery walkthrough.
SSD Recovery Process: Step by Step
Every SSD that arrives at our Austin lab goes through these diagnostic and repair stages. The specific path depends on the failure type, but the workflow is consistent.
  1. Current Profiling: We connect the SSD to a bench power supply with current limiting and measure draw at 5V (2.5" SATA) or 3.3V (M.2 NVMe). A healthy SSD draws minimal current at idle but shows initialization spikes when it tries to load firmware. A shorted PMIC or controller pulls well above normal and shows as a hot spot on our FLIR thermal camera within seconds. This tells us whether the failure is a short circuit (needs component replacement) or a firmware/logical issue (needs PC-3000).
  2. Safe Mode Access: For firmware-locked drives, we short specific PCB pads to force the controller into its factory diagnostic mode (called "Techno Mode" on Phison, "Factory Access Mode" on Samsung, "Test Mode" on Silicon Motion). This bypasses the corrupted firmware and gives PC-3000 direct access to the controller's internal registers.
  3. Translator Rebuilding: PC-3000 scans raw NAND metadata to reconstruct the flash translation layer (FTL), which maps logical addresses to physical NAND pages. Without this map, the drive cannot locate any files. The rebuild process reads spare area bytes from every NAND page to piece together the correct logical-to-physical mapping.
  4. Multi-Pass Imaging: Using PC-3000 Data Extractor, we image the SSD sector by sector. Sectors that fail on the first pass get queued for retry with adjusted read parameters. For degraded NAND, we apply thermal stabilization to shift voltage thresholds into a readable range. The result is a sector-by-sector clone on a target drive.
  5. File System Extraction: We mount the cloned image, verify file integrity, and transfer recovered data to the customer's choice of media. The original failed SSD is returned or securely retired per the customer's instructions.
Hardware Encryption and Secure Enclaves
Most modern SSDs encrypt data at the hardware level. The controller generates an encryption key on first use, stores it internally, and encrypts every write transparently. When the drive functions normally, you never notice. When the drive fails, encryption determines whether chip-off recovery is even possible.
Self-Encrypting Drives and TCG Opal
Drives that comply with the TCG Opal specification store the media encryption key (MEK) internally, typically wrapped by a Key Encryption Key (KEK). On modern NVMe controllers, this KEK is cryptographically bound to unique, irreversible hardware fuses or a Physically Unclonable Function (PUF) inside the specific controller silicon that shipped with the drive. If the controller dies, simply swapping it for a matching replacement will not work because the donor IC will lack the unique hardware key required to unwrap the MEK. In these cases, chip-off recovery is also impossible, as the raw NAND contains only AES-256 ciphertext. Recovery relies entirely on our ability to perform component-level repair on the original board: fixing power rails or replacing PMICs so the original controller can power up and decrypt its own storage.
BitLocker and FileVault
BitLocker (Windows) and FileVault (macOS) add a software encryption layer on top of the drive. Recovery requires the original password, recovery key, or TPM chip. If you have the recovery key, we image the drive and decrypt offline. If the key is lost and the TPM chip is on a dead motherboard, the motherboard itself needs repair to release the key. We handle both the drive-side and board-side work.
Apple solders NAND directly to the logic board and ties the encryption key to the Secure Enclave inside the T2 chip (late 2017 through 2020 Macs, starting with the iMac Pro) or the M-series SoC (2020 onward). The NAND cannot be read without the Secure Enclave on the same board. If the logic board dies, the encryption key is inaccessible unless the board is repaired at the component level. Chip-off is useless here; the raw NAND is AES-256 encrypted with a key that exists nowhere else. The only recovery path is logic board microsoldering to get the board powered on so the Secure Enclave can decrypt in place. We documented one such case where a MacBook SSD that shorted and smoked required full board-level repair before the Secure Enclave could decrypt.
Bottom line: on any hardware-encrypted drive, desoldering the NAND without the original encryption key produces unreadable data. Board-level repair to restore the original controller or security chip is the only path that preserves the decryption chain. This is why microsoldering capability matters for SSD recovery; not every lab has it.
Controller-Specific Failures We See Regularly
Certain SSD controllers have well-documented failure patterns. If your drive uses one of these, the symptoms below will be familiar.
Phison E12 Sudden Death
The Phison PS5012-E12 controller (found in Corsair MP510, Sabrent Rocket, Inland Premium, and Team MP34) has a known failure mode where the controller locks up after a power loss event. The drive drops out of BIOS entirely or reports 0 bytes. The FTL stored in the SLC cache region gets corrupted because the controller was mid-write when power was cut. PC-3000 forces the E12 into Vendor Specific Command mode, bypasses the corrupted SLC cache, and rebuilds the translator from the TLC main area.
Silicon Motion SM2262EN Firmware Lock
The SM2262EN (used in HP EX950, ADATA SX8200 Pro original revision, and Kingston KC2000) is a DRAM-equipped NVMe controller. When the host system crashes during a write, the controller enters a locked state where it responds to SMART queries but refuses all read/write commands. The drive appears in BIOS with correct capacity but is inaccessible. We use PC-3000's Silicon Motion NVMe utility to clear the lock flag, inject a clean firmware loader, and rebuild the mapping tables from NAND spare area data.
Samsung 980 Pro 0E Error
Samsung 980 Pro drives with the Elpis controller develop a firmware bug that causes the 0E health indicator to degrade rapidly, eventually bricking the drive. Samsung issued firmware patches, but drives that were not updated in time die with the controller stuck in a write-protect state. PC-3000's Samsung NVMe module can issue Vendor Specific Commands to override the write-protect flag and image the drive before the controller locks out permanently.
Why Consumer SSDs Fail Without Warning
Enterprise SSDs contain tantalum supercapacitors that provide 10 to 50 milliseconds of backup power during an outage, long enough for the controller to flush its DRAM cache and finalize the flash translation layer (FTL) to NAND. Consumer NVMe and SATA SSDs omit these capacitors to hit lower price points. When power cuts mid-write on a consumer drive, the controller loses volatile state before the FTL update completes. The mapping table stored in the service area is left partially written, which corrupts the logical-to-physical address map. On the next power cycle, the controller cannot locate any data. The drive reports 0 bytes, shows the wrong model string, or fails to enumerate entirely.
DRAM-less Drives Are More Vulnerable
Budget NVMe controllers like the Phison E21T, Silicon Motion SM2263XT, and Maxio MAP1602 use Host Memory Buffer (HMB) instead of onboard DRAM. The FTL mapping tables live in your computer's system RAM, allocated by the NVMe driver. A system crash, BSOD, or hard reboot deallocates that memory before the controller can write its state back to NAND. The result is identical to a power loss: corrupted FTL, unreadable service area, and a drive that appears dead. DRAM-equipped controllers like the Phison E18 or Samsung Elpis keep a local copy of the mapping table in their onboard SRAM/DRAM, which provides a fractional-second buffer during power transitions. This does not make them immune, but it reduces the window of vulnerability from milliseconds to microseconds.
SLC Cache Flush Interruption
Modern TLC and QLC SSDs use a pseudo-SLC write cache: incoming data lands in NAND cells programmed to a single bit per cell (fast, high endurance), then the controller folds that data into TLC/QLC pages (three or four bits per cell) during idle periods. If power drops during this folding operation, the data exists in two conflicting states across different physical NAND pages. The FTL metadata no longer matches the actual NAND contents. On Phison controllers, this manifests as a Vendor Specific Command (VSC) lockout where the controller refuses all read/write operations until the inconsistency is resolved. PC-3000 resolves this by reading raw NAND metadata from both the SLC cache region and the TLC/QLC main storage, identifying which copy is authoritative, and rebuilding the translator from scratch.
Unpowered Storage and Charge Leakage
NAND flash cells store data as trapped electrical charge on a floating gate (planar NAND) or a charge trap layer (3D NAND). That charge leaks over time. The JEDEC JESD218B specification defines client SSD data retention as one year at 30 degrees Celsius for a drive at end of rated endurance. A drive stored in a hot environment, an attic, a parked car, or a non-climate-controlled storage unit, leaks charge faster. Worn cells that have consumed most of their rated program/erase cycles leak faster still. As charge leaks, the voltage distributions for each programmed state shift and overlap. QLC cells, which encode four bits across sixteen voltage levels, have the tightest margins and degrade first. TLC cells with three bits across eight levels follow.
When voltage distributions overlap beyond the controller's ECC correction threshold (LDPC on modern drives, BCH on older ones), pages become unreadable through the normal interface. PC-3000's Read Retry feature applies shifted reference voltages during reads, effectively recalibrating the sensing margins to account for the charge drift. For drives with severe retention loss, controlled heating of the NAND package temporarily improves charge distribution separation, allowing marginal pages to be read before the thermal energy dissipates.
Practical takeaway: if a failed SSD has been sitting unpowered in a drawer for months, send it to a lab sooner rather than later. Every week of unpowered storage at room temperature narrows the voltage margins further. A drive that is recoverable today may not be recoverable in six months.
Manufacturer-Specific Recovery
Samsung
870 EVO (SATA), 970/980/990 NVMe families. Proprietary controllers (Phoenix/Elpis/Pascal) and default encryption are common. The 990 Pro firmware degradation bug is a frequent case; controller repair and safe imaging for all Samsung models.
Crucial / Micron
MX500 (SATA), P5/P5 Plus (NVMe). We address firmware quirks, power issues, and overheating failures.
Western Digital / SanDisk
WD Blue/Black (e.g., SN750, SN850X with firmware 620311WD lockout), SanDisk Extreme portable with hardware encryption/USB bridge failures; repair controller/bridge or transplant NAND while preserving keys.
Kingston, Seagate, ADATA & Others
A2000/KC2500, FireCuda 520, SX8200, and more. Realtek/Phison/SMI variants handled in-house with PC-3000.
Apple Proprietary & T2/M-series
Older Apple blade SSDs via adapters; T2/M-series require logic-board repair to access integrated, encrypted storage. See MacBook Data Recovery.
Specific SSD Failure Modes & Recovery Techniques
Firmware Corruption Recovery
SATAFIRM S11, 0GB capacity bugs, and translation layer failures fixed with PC-3000 firmware tools; not canned software.
Learn more
Chip-Off & NAND Flash Extraction
When the controller is dead beyond repair, we desolder NAND chips and reconstruct your data from raw flash; with honest limits on encrypted drives.
Learn more
NVMe & PCIe SSD Recovery
M.2 NVMe drives fail differently than SATA SSDs. Thermal throttling, PCIe lane failures, and controller burnout require specialized diagnostic workflows.
Learn more
The Cleanroom Myth for SSDs
SSDs have no spinning platters. Any lab charging you cleanroom fees for SSD work is padding the bill.
Learn more
Rossmann vs. DriveSavers
Transparent pricing and board-level repair vs. $3,000+ "call for quote" bait-and-switch. See the real numbers.
Learn more
Does Data Recovery Void Your Warranty?
Short answer: no. The Magnuson-Moss Warranty Act protects you, and we explain exactly how.
Learn more
Real SSD Recovery Case Studies
Watch unedited video of actual SSD recoveries: controller repairs, firmware rebuilds, NAND extractions. 2.49M+ YouTube subscribers watch these.
Learn more
NAND Thermal Stabilization
Degraded NAND cells need precise temperature control to shift read thresholds. We use targeted thermal manipulation through PC-3000 to recover sectors that fail at room temperature.
Learn more
Microsoft Surface SSD Recovery
Early Surface Pro and Go models use soldered NAND behind adhesive-sealed screens. Newer Pro models and Surface Laptops use removable M.2 2230 drives, but access still requires specialized disassembly.
Learn more
SanDisk Extreme Firmware Failure
Class-action design flaw in SanDisk Extreme and Extreme Pro Portable SSDs. Defective solder joints and R332G190 firmware cause sudden total data loss. USB bridge bypass and PC-3000 recovery.
Learn more
SSD Data Recovery FAQs
Can you recover data from a dead SSD?
Yes, if the NAND flash is intact. A dead SSD means the controller, power management IC, or firmware has failed. We repair the failed component so the controller can read the NAND again, then image the drive through PC-3000.
Our SSD recovery runs $200 to $1,500 across 5 published tiers. Simple copies are $200. File system recovery starts at $250. PCB repair is $600 to $900. Firmware corruption is $900 to $1,200. Advanced component repair and controller-level reconstruction are $1,200 to $1,500. Free evaluation, firm quote, no data no fee.
NVMe recovery follows the same pricing as other SSDs: $200 to $1,500 depending on failure type. Simple copies and file system work sit at the lower end. Firmware corruption on a Gen 4 drive with proprietary encryption runs $900 to $1,200. Advanced component-level repair is the highest tier at $1,200 to $1,500.
Is SSD data recovery harder than hard drive recovery?
The failure modes are different. Hard drives fail mechanically: head crashes, seized motors, platter scratches. SSDs fail electronically: controller death, firmware corruption, NAND degradation, encryption lockout. SSD recovery requires microsoldering and firmware-level tools instead of clean rooms and head swaps.
Can encrypted SSDs be recovered?
Yes, by repairing the original controller or security chip so the drive decrypts through its own hardware. Desoldering encrypted NAND without the media encryption key produces only ciphertext. The decryption chain must remain intact.
What's your success rate for SSD recovery?
We do not publish a made-up percentage. Every drive is different. We evaluate yours for free and give a straight answer on whether recovery is realistic before you pay anything.
Why is my SSD showing 0 bytes?
A 0-byte capacity reading means the controller lost its firmware translation layer (FTL). The NAND still holds your data, but the controller cannot locate it. We rebuild the translator tables using PC-3000's SSD utility to restore correct capacity and file system access.
Why does my SSD show up as SATAFIRM S11?
SATAFIRM S11 is a generic firmware string that appears when the controller loses its service area data. The drive reverts to a factory-default identity because it cannot load the modules that define its model name, capacity, and flash translation map. PC-3000 rebuilds those modules and restores normal operation.
Can deleted files be recovered from an SSD?
Only if TRIM has not executed. When TRIM runs, the controller logically unmaps the deleted blocks (returning zeros to the OS via DRAT/DZAT), with electrical erasure happening later during garbage collection. Once a TRIM command is fully processed, the controller intentionally blocks access to the deleted files through standard interfaces. If the drive died from a hardware failure before the controller could run TRIM, the deleted data is still on the NAND and recoverable.
Does the freezer trick work on SSDs?
No. The consumer 'freezer trick' was a myth for hard drives with stiction. For SSDs, uncontrolled condensation from a household freezer can short components and destroy the drive. However, professional labs do use precise, controlled thermal manipulation (both targeted heating and freezing) to alter NAND threshold voltages and improve readability on degraded cells. This requires exact temperature targets and real-time monitoring through PC-3000 to catch shifts in sensing margins.
How long does SSD data recovery take?
Standard turnaround is 3 to 10 business days from the day we receive the drive. Firmware and controller repairs finish faster. Chip-off NAND extraction with manual page reconstruction takes longer and applies only to unencrypted drives; Apple T2/M-series and other hardware-encrypted drives require board repair instead. Rush service is available on request.
Can data be recovered from an SSD not detected in BIOS?
Yes. A drive invisible to BIOS has a dead controller, blown power management IC, or severed PCIe/SATA connection. We identify the failed component with thermal imaging and a bench power supply, repair it, and image the drive once the controller responds.
What causes SSD controller failure?
Power surges, voltage regulator failures on the host motherboard, and accumulated thermal stress are the most common causes. The controller IC or its PMIC shorts, and the drive goes dead. The NAND retains data because flash cells hold charge without power, though this charge will gradually leak over many months.
Can you recover data from a water-damaged SSD?
Yes. Liquid corrodes solder joints and shorts components, but NAND flash cells are sealed BGA packages that survive liquid contact. We ultrasonically clean the PCB, replace shorted components, and rebuild corroded traces before applying power.
Do you recover data from Apple T2 or M-series Macs?
Yes. Apple solders NAND directly to the logic board and ties the encryption key to the T2 or M-series Secure Enclave. No commercially viable method exists to extract the key; the board must be repaired at the component level so the Secure Enclave decrypts in place. We do this work in-house.
Is chip-off recovery possible on encrypted SSDs?
Chip-off on an encrypted drive produces only ciphertext. This includes Apple T2 and M-series Macs, where AES-256 keys are bound to the Secure Enclave and never leave the SoC. Without the media encryption key stored in the original controller or security chip, desoldered NAND is unreadable. The only viable path is repairing the original board so the drive decrypts through its own hardware.
Can I recover SSD data myself with software?
Only if your operating system detects the drive with its correct capacity. Software tools scan the file system through the controller. If the controller is dead and the drive does not enumerate, no software can reach the NAND. That requires hardware-level repair.
What is the difference between logical and physical SSD failure?
We classify SSD failures into three categories. Logical failure means the drive is 100% healthy, but the file system is corrupt or data was deleted. Firmware failure means the physical electronics work, but the controller's internal map (translator) or service area is corrupted, requiring PC-3000 to rebuild. Physical failure means a hardware component is dead (shorted PMIC, cracked solder joints, or dead controller), requiring microsoldering to fix.
Should I keep powering on a failing SSD?
Stop. A shorted controller or PMIC draws excessive current when powered, and that heat damages adjacent NAND packages. Each power cycle also risks the controller overwriting corrupted service area data, which makes firmware reconstruction harder.
My laptop SSD failed. How do I get my data?
Remove the SSD from the laptop (M.2 drives slide out after removing one screw; 2.5-inch SATA drives unplug from a connector or caddy). Test it in another system or external enclosure. If it does not appear in BIOS on any system, the controller or PMIC has failed and you need professional recovery. Do not attempt to reinstall the operating system on the same drive. Ship the bare SSD to our Austin lab for a free evaluation.
My portable SSD stopped working. What happened?
Portable SSDs (Samsung T5/T7, WD My Passport SSD, SanDisk Extreme) contain an internal NVMe or SATA drive connected through a USB bridge chip. The bridge chip is the most common failure point: cold solder joints crack from thermal cycling during file transfers. When the bridge fails, the host sees no device or a blank disk. We open the enclosure, bypass the bridge, and read the internal SSD directly through PC-3000. If the bridge encrypted the data, we repair the bridge instead of bypassing it.
Can you recover a Samsung 970 or 980 EVO/Pro?
Yes. Samsung Phoenix and Elpis controllers use hardware encryption by default, so chip-off yields ciphertext. Because the encryption keys are tied to the unique silicon of the original controller, you cannot simply swap the main controller IC. We perform physical component repair (replacing shorted PMICs or repairing power rails) to revive the original board, or we use PC-3000 Vendor Specific Commands (VSC) to bypass firmware panics like the 980 PRO 0E error. Once the drive initializes, we image the data through the controller's native decryption pipeline.
Can an SSD be repaired?
SSDs have no moving parts to repair in the traditional sense. When we say SSD repair, we mean component-level board work: replacing blown capacitors, shorted PMICs, failed voltage regulators, or reflashing corrupted firmware through JTAG/SPI. The goal is to get the original controller functional enough to image the data. Once the data is extracted, the original drive is not reused. We perform all board-level SSD repair in-house at our Austin lab using JBC microsoldering stations and FLIR thermal imaging to locate failed components.
What to do before shipping
These steps protect the NAND and reduce the risk of further damage before we receive the drive.
Do NOT:
  • Stop using the drive immediately; don't write new data
  • Do not open the SSD; leave any corrosion/contamination to us
Do:
  • Pack in an anti-static bag with padding; include your contact info
  • Use tracked shipping to our Austin lab; request signature on delivery
  • Provide passwords/keys if the volume is encrypted
Transit Time
1 Business Day
Major Origins
  • New York City 1 Business Day
  • Los Angeles 1 Business Day
  • Chicago 1 Business Day
  • Seattle 1 Business Day
  • Denver 1 Business Day
View All Locations
Sources & References
Technical claims and specifications on this page are sourced from public documentation. Verify independently.
  1. ACE Lab PC-3000 Portable III: Manufacturer documentation for SSD recovery capabilities, including PCIe/NVMe adapter support, vendor-specific safe mode commands, firmware loader injection, and NAND flash direct reading. This is the primary diagnostic and imaging tool used in our lab.
  2. JEDEC JESD218B: Solid-State Drive Requirements and Endurance Test Method: Industry standard defining SSD endurance testing, NAND flash data retention periods, and program/erase cycle specifications. Client SSD data retention is defined as 1 year at 30°C; enterprise is 3 months at 40°C.
  3. Magnuson-Moss Warranty Act (15 U.S.C. §2302): Federal law establishing that manufacturers cannot void a warranty for using an independent repair provider. Relevant to customers concerned about warranty status after third-party data recovery.
  4. Competitor pricing ranges are based on published customer reports and competitor pricing pages as of early 2025. DriveSavers, Ontrack, and Secure Data figures reflect publicly available quote ranges, not internal data.
Ready to get your data back?
