Professional hard drive data recovery for clicking, beeping, and not detected drives. Our Austin lab processes HDD and SSD recoveries daily via local drop-off and nationwide mail-in. We extract files in-house with PC-3000 tools and validated clean-bench procedures. No data = no charge. Same equipment as enterprise labs at a fraction of the price.
NDA on Request
Confidentiality Guaranteed
Chain of Custody
Legal Documentation
ISO 14644-1 Class 4 Equivalent
0.02µm Validated
100% Confidential
NDA Standard
Hard drive data recovery is the process of retrieving inaccessible data from failed, corrupted, or damaged hard disk drives (HDDs) and solid-state drives (SSDs). Also called hard drive recovery, hard disk recovery, or HDD data recovery, the goal is the same: get your files back from a drive that will not cooperate. Professional data retrieval services use specialized hardware such as the PC-3000 by ACE Lab and DeepSpar Disk Imager to recover data from hard drives when standard software solutions fail. According to Backblaze's Drive Stats data covering over 340,000 drives, the average annualized failure rate across all models is approximately 1.5–1.6%, meaning millions of drives fail each year and require professional recovery.
Recovery methods include:
- Logical repair: Recovering corrupted partitions, formatted filesystems, and deleted files using sector-level imaging and advanced file carving. On modern SMR (Shingled Magnetic Recording) hard drives, deleted files may be permanently unrecoverable due to background UNMAP commands that function identically to solid-state TRIM, instantly returning zeroes to recovery software. Formatted SSDs also self-erase via TRIM, requiring controller-level intervention if supported.
- Firmware repair: Restoring access to drives not detected by the system; includes ROM extraction, translator module rebuilding, and adaptive parameter correction using PC-3000-class tools
- Mechanical repair: Clean bench head swaps and platter work for clicking or beeping drives with physical head damage, performed under ULPA-filtered laminar flow validated to 0.02 µm particle count
Last updated: March 2026
Hard drive data recovery costs $100–$2,000, depending on the failure type. Simple data copies from a functional drive cost $100. File system recovery for corrupted partitions, formatted drives, or volumes the operating system no longer recognizes starts at $250. Firmware repair, where the drive's internal software is corrupted and requires PC-3000 terminal access to rebuild translator tables, ROM data, and adaptive parameters, costs $600–$900. Mechanical failures that require a donor head swap on our laminar-flow clean bench, validated to 0.02 µm particle count, run $1,200–$1,500 and require a 50% deposit because donor parts are consumed in the procedure. The most severe tier covers platter surface damage from head crashes and starts at $2,000. Every recovery begins with a free evaluation and a firm quote before any work begins. If we cannot recover your data, you pay nothing.
Match Your Symptom to a Recovery Tier
The sound your drive makes (or does not make) tells us the failure type, which determines the recovery method and cost. Find your symptom below.
| Symptom | Likely Failure | Recovery Method | Price Range |
| Asks to format, RAW filesystem | File system corruption | Sector imaging + partition rebuild | From $250 |
| Not detected, spins normally | Firmware / translator corruption | PC-3000 terminal, ROM rebuild | $600–$900 |
| Clicking or ticking | Head failure or preamp damage | Donor head swap on clean bench | $1,200–$1,500 |
| Beeping or buzzing | Heads stuck to platters (stiction) | Unstick + head swap | $1,200–$1,500 |
| Not spinning at all | Motor seizure or PCB failure | PCB repair / motor swap | $600–$900 - $1,200–$1,500 |
| Grinding or scraping | Head crash, platter contact | Platter cleaning + head swap | $2,000 |
Watch a Real Recovery
We film our recoveries so you can see the process before sending your drive. This walkthrough covers a full head swap and PC-3000 imaging session.
Drives We Recover From
What Hard Drive Recovery Customers Say
What's Happening to Your Drive?
Select your symptom for a free diagnosis
PC-3000 Recovery Platform
Every Recovery on Camera
In most cases, yes. A "dead" hard drive usually means one of three things: the PCB has failed (power surge, shorted TVS diode), the firmware is corrupted (drive not detected, shows wrong capacity), or the read/write heads have failed (clicking, beeping). None of these conditions destroy the data stored on the platters. The data is magnetic; it persists even when the drive electronics cannot read it.
For PCB failures, we transfer the ROM chip (or extract ROM data via PC-3000) to a compatible donor board. For firmware corruption, we access the drive's terminal interface and rebuild translator modules and adaptive parameters. For head failures, we perform a donor head swap on our clean bench. Each of these scenarios has a different cost tier, but the data itself remains intact on the platters throughout.
The only scenario where data is permanently gone: the platter surfaces themselves are physically destroyed. This happens when a head crash scrapes the magnetic coating off the platters, or when someone runs a clicking drive long enough that the heads grind through the recording layer. If your drive stopped working after a crash or sudden failure, power it off immediately. Every second of contact removes data.
That depends on what is on the drive. If the files are irreplaceable (family photos, business records, legal documents, research data), the value of recovery exceeds the cost. If the files exist in backups or cloud storage, recovery is unnecessary.
The risk calculation is straightforward: you pay $0 to find out whether recovery is possible, and you only pay if we deliver your files. Compare that to national labs where a head swap can run $3,000 to $7,000 for the same procedure we perform at $1,200–$1,500.
Recovery time depends on the failure type and drive capacity. A healthy 1TB drive images in a few hours. Light bad sectors add one to three days as PC-3000 retries weak areas. Firmware corruption (drive not detected, wrong capacity) takes about a week, including terminal diagnostics and translator rebuilding.
Head swaps take one to three weeks because we need to source an exact-match donor drive with the correct firmware revision, head map, and manufacturing batch. Donor availability varies by model. Severe platter damage cases may be unrecoverable; we will tell you before spending your money. We provide a time estimate alongside the price quote after the free evaluation.
At a Glance
- $Cost: From $100 for simple copies, $250–$2,000 for recovery (firm quote after free evaluation)
- Equipment: PC-3000 Portable III + ULPA-filtered clean bench (ISO 14644-1 Class 4 equivalent) for mechanical failures
- Guarantee: No data recovered = no charge (evaluation always free)
Estimate Your Recovery Cost
Select the symptoms your hard drive is showing to get an estimated cost range and recovery outlook. This is a starting point; we provide a firm quote after evaluating your drive for free.
Select all symptoms that apply. This tool gives a rough estimate; your actual quote comes after our free evaluation.
Select symptoms above to see your estimated cost range and recovery likelihood.
Why Choose Our Austin Lab
We are not a middleman. We do not ship your drive to a mystery warehouse. Our certified techniciansrecover your data on-site in Austin using the same class of equipment as national labs: PC-3000, DeepSpar, laminar-flow clean benches, donor inventory, and microscopes. Visit our Austin lab page. You speak directly with the technician handling your case. No scripts. No sales team.
Local and Nationwide
All data recovery performed in our Austin lab. Mail-in accepted from all 50 states.
No Data, No Charge
If we cannot recover your data, you pay $0 (optional return shipping only).
Same Equipment, Lower Price
PC-3000 imaging, validated clean bench; without ad budgets or affiliate kickbacks.
Transparent Pricing
Clear ranges up-front; final quote after free evaluation; no surprise fees.
Direct Communication
Talk to your engineer, not a salesperson. Get straight answers.
Real Proof
2.49M+ YouTube subscribers and hundreds of hour-long recoveries on camera.
How We Compare to National Labs
All four companies listed below use PC-3000 hardware for firmware-level recovery. The difference between us and the national labs is overhead, not capability. Our pricing reflects engineering time and donor parts; theirs reflects advertising budgets, cleanroom real estate, and certification fees.
| Feature | Rossmann Group | DriveSavers | Ontrack | Geek Squad |
| Average Cost | $100–$2,000 | $2,000-$7,000 | $800-$3,000+ | $600-$2,500 (outsourced) |
| Work Location | In-house Austin lab | Novato, CA facility | Multiple global labs | Outsourced to partner labs |
| Equipment | PC-3000, DeepSpar, ULPA-filtered bench | PC-3000, proprietary tools | PC-3000, proprietary tools | Varies by partner |
| No Data = No Charge | Yes, always | Diagnostic fee may apply | Yes | Varies |
| Direct Technician Contact | Yes, talk to your engineer | Through account manager | Through account manager | Store staff only |
| Free Evaluation | Yes | Yes | Yes | $50+ diagnostic fee |
| Proof of Work | 2.49M+ YouTube subscribers, hundreds of filmed recoveries | Client testimonials | 35+ year track record | Best Buy brand reputation |
Data compiled from publicly available pricing and service information as of January 2026. Read our full comparison guide.
Drive Repair vs. Data Recovery
Many clients ask: "Can you repair my hard drive so I can use it again?"
Example: A Seagate ST2000LM007 arrived clicking after a 3-foot drop. We replaced all four read/write heads from a matched donor, imaged 1.87TB through PC-3000 using a head map to bypass damaged Head 2, and recovered 99.4% of the file structure. The original drive was recycled; data was returned on a new external drive.
See our clean bench validation data and particle test videoFailure Types We Handle
Clicking hard drive →
Beeping drive →
Drive not detected →
Drive not spinning →
Logical and Mixed Failures
File system corruption →
Accidentally deleted files or formatted a conventional hard drive? If SMART is clean and reads are fast, DIY tools work. (Note: DIY software cannot recover deleted files on modern SSDs due to the TRIM command permanently wiping unmapped blocks). If reads slow or drop, stop and let us image with pro hardware before it degrades.
Bad sectors / SMART errors →
If SMART reports reallocated or pending sectors, the drive is physically degrading. We fast-pass good regions, then revisit weak areas with head-maps and conservative retries (DeepSpar/PC-3000). Goal: maximum image with minimum stress on the heads.
RAID and NAS recovery →
Time-Critical Data Emergency?
Supported Models & Systems
Operating Systems
- • Windows (NTFS, FAT32, exFAT)
- • MacOS (APFS, HFS+)
- • Linux (EXT4, XFS, Btrfs, ZFS)
- • Server / VMware (VMFS)
Computers
- • Laptop hard drives (Dell, HP, Lenovo, ASUS)
- • Apple MacBooks (Pro, Air)
- • Desktop PCs & Workstations
- • All-in-One PCs
External Drives
- • WD Passport / Elements
- • Seagate Backup Plus
- • LaCie Rugged
- • G-Technology / SanDisk Professional
Storage Types
- • 3.5" Desktop HDD
- • 2.5" Laptop HDD
- • NAS Units (Synology, QNAP)
- • USB Flash & SD Cards
External Hard Drive Recovery
Common external drive models we recover include Seagate Backup Plus Slim (Rosewood ST2000LM007), WD My Passport (SMR-based WD20SMZW), LaCie Rugged (often containing Seagate Barracuda mechanisms), and G-Technology G-DRIVE. External hard drive recovery pricing follows the same five tiers as internal drives: $100 to $2,000 depending on failure type.
Recovery Services By Symptom
The sound your drive makes tells us what has failed. If your hard disk is clicking, beeping, corrupted, or not detected, our engineers can help. Click the symptom that matches yours for detailed information.
Clicking or Ticking
Platters spin but heads cannot find data. Head failure or preamp damage.
Learn more →Beeping or Buzzing
Motor cannot spin. Heads stuck to platters (stiction) or seized spindle.
Learn more →Not Detected
Computer does not see the drive. PCB failure, firmware corruption, or weak heads.
Learn more →Hard Drive Corrupted
File system damaged. Shows as RAW, asks to format, or files inaccessible. Data is often still intact on the platters.
Learn more →Listen to Your Drive
The sound a failing hard drive makes reveals the failure type. Play each clip below and compare it to what your drive sounds like. If yours matches a mechanical failure (clicking, beeping, grinding), power it off immediately and contact us for a free evaluation.
Common Problems We Solve
Dropped Hard Drive
External drive fell? Laptop dropped? Head damage is likely, but data is usually recoverable.
Get help →Water Damaged Drive
Flood, spill, or moisture damage? Don't dry it out. We explain what actually works.
Get help →Power Surge Damage
Lightning strike or power surge? PCB damage is fixable. Data is often 100% intact.
Get help →Making Strange Noises
Clicking, beeping, grinding? Each sound tells us exactly what's wrong. Stop using it.
Diagnose →Other situations: emergency recovery | SSD recovery | cost breakdown | how to choose a service | water damage recovery | fire damage recovery
Recovery by Manufacturer
Different manufacturers have different failure patterns. We track real reliability data from Backblaze's fleet of 340,000+ drives to understand model-specific issues and tailor our approach for each brand.
Seagate Recovery
Higher AFRF3 terminal access, ROM extraction, and model-specific diagnostics. Rosewood slim drives and Barracuda models are our most frequent cases.
View Seagate reliability data →Western Digital Recovery
Low AFRIndustry-leading failure rates. The PC-3000 WD module handles ROM/module repair and Ultrastar enterprise drives. My Passport and Elements external drives are frequent mail-in cases, often requiring specialized firmware patching.
View WD reliability data →Toshiba Recovery
Canvio external drives and MQ/MG internal series. Toshiba drives use a unique head parking mechanism that frequently fails after drops. PC-3000 Toshiba module for firmware and translator repair.
View Toshiba recovery details →Hitachi / HGST Recovery
Samsung Recovery
Maxtor Recovery
DiamondMax, OneTouch, MaxLine. Legacy Maxtor firmware and Seagate-era rebadges (STM models) require different PC-3000 modules. We maintain donor stock for legacy mechanisms out of production since 2006.
View Maxtor recovery details →Fujitsu Recovery
MHW, MHZ, MHY laptop drives and MAP/MBA enterprise SCSI/SAS. Fujitsu exited the HDD market in 2009 (sold to Toshiba). The Toshiba MJA transitional series also uses Fujitsu firmware internally.
View Fujitsu recovery details →AFR = Annualized Failure Rate. Lower is better. Rates vary by model, deployment, and reporting period.
Find Your Drive Family
Recovery approach varies by drive family. Match the model number on your drive label to find specific failure modes and repair procedures.
Seagate Rosewood
ST1000LM035, ST2000LM007
2.5" · 500GB–2TBWD Spyglass / My Passport
WD40NMZW, WD50NMZW
2.5" · 3TB–5TBSeagate Barracuda
ST1000DM003, ST3000DM001
3.5" · 500GB–3TBWD Red / Red Plus
WD20EFRX, WD40EFRX
3.5" · 2TB–6TBToshiba DT01/DT02
DT01ACA100, DT02ABA400
3.5" · 500GB–6TBSeagate Barracuda 7200.11
ST3500320AS, ST31000340AS
3.5" · 500GB–1.5TBView all drive families → | WD Green recovery walkthrough (Part 1) and Part 2
Advanced Failure Modes by Drive Family
Each drive family has distinct firmware architecture and mechanical design. The failure mode dictates the recovery procedure. Generic "data recovery" approaches applied blindly to the wrong family can cause permanent data loss. Below is what we see on the bench, organized by the families that generate the most cases.
The Rosewood platform (ST500LM030, ST1000LM035, ST2000LM007, ST2000LM015) is Seagate's 2.5-inch slim portable drive. It weighs 90 grams. The top magnet is integrated into the lid via silver foil, making clean disassembly for head swaps harder than older Seagate designs. Rosewood drives are our single most common incoming case type.
The signature Rosewood failure is the LED error. When firmware corruption occurs, the drive outputs a continuous stream of LED status codes (such as LED:000000CC) over the serial terminal instead of reaching the F3 T> command prompt. Standard Seagate F3 terminal commands cannot execute while the LED error is active. The PC-3000 Seagate module includes a "Disable Subsystem" ROM function to suppress the LED output, but timing is critical: the unlock sequence must be sent (Ctrl+Z simultaneously with the unlock key) before the LED error stream begins, or the terminal session fails.
A third Rosewood-specific issue is media cache corruption. Rosewood drives use a media cache region on the platters to buffer writes before committing them to the final LBA locations. If power is lost during a cache flush, the mapping between cache sectors and their destination LBAs can become inconsistent. PC-3000's Seagate module can read and reconstruct the media cache map, but only if the heads are stable enough to read the cache zone without further degradation.
The recovery trap: WD SMR drives have a secondary translator in addition to the primary one. If a technician applies conventional (non-SMR) WD firmware repair procedures, the secondary translator can be altered or destroyed. The drive will then appear to function normally during diagnostics but will produce zeroed data on every read. This is permanent and unrecoverable. We use PC-3000's WD module with SMR-aware procedures that preserve both translator layers before any firmware manipulation begins.
WD Blue and WD Red SMR models released around 2020 (2TB, 3TB, 4TB, 6TB capacities) have shown elevated failure rates reported by multiple European data recovery labs. Western Digital has acknowledged an investigation into these failures. The most common failure pattern on these drives is Module 190 translator corruption, where the SMR-specific firmware module that maps logical sectors to shingled bands becomes partially written after a power loss or cache overflow.
Helium-Sealed Drives: One Shot at Recovery
Enterprise drives above 10TB (Seagate Exos X series, WD Ultrastar DC HC series, Toshiba MG series) are hermetically sealed and filled with helium gas. Helium has one-seventh the density of air, which reduces aerodynamic drag on the platters and allows the heads to fly at a lower height with tighter tolerances. This enables manufacturers to fit more platters (up to 10) into a standard 3.5-inch form factor.
Once a helium drive is opened, the helium escapes permanently. The heads were designed to fly in helium's lower-density environment. In normal air, the increased drag changes the fly height, and the heads can contact the platters within minutes to hours. There is no way to reseal a helium drive to factory specification outside the manufacturer's production line.
This means a head swap on a helium drive is a one-shot procedure. The donor drive must also be a helium drive of the same model family and firmware revision, because air-environment heads will not fly correctly in any remaining helium, and helium-spec heads will not fly correctly in air. We open the patient drive on our clean bench, install the donor heads, connect to PC-3000 immediately, and begin imaging. There is no "test fit" or second attempt; the imaging window closes as helium diffuses out.
Seagate's F3 firmware architecture covers the Barracuda 7200.11 through 7200.14, Barracuda LP, and the Momentus families. Each generation has distinct failure patterns. The 7200.11 (firmware SD15, SD1A) was notorious for a firmware bug that caused drives to brick on power-up; Seagate issued a firmware patch, but millions of unpatched drives remain in circulation. The 7200.14 (firmware CC46, CC4H) has a different problem: gradual system area degradation.
The system area (also called the service area or SA) is a reserved region on the platters that stores the drive's operating firmware, defect lists (P-list and G-list), SMART logs, and adaptive parameters. When the SA degrades due to weak heads or media defects in the service zone, the drive loses access to its own operating instructions. It may spin up but fail to identify, or identify with a BSY (busy) state that never resolves.
Recovery requires PC-3000's Seagate F3 module to access the terminal (Ctrl+Z to reach the T> prompt), read whatever SA modules remain, patch corrupted modules from a known-good donor, and rebuild the translator. On 7200.14 drives specifically, the P-list (primary defect list from manufacturing) and G-list (grown defect list from use) can become corrupted independently. If the G-list is lost, the drive attempts to read sectors that it had previously remapped, causing read errors across the image. We back up the original SA before any modification, reconstruct the defect lists, and image with head maps to work around weak heads reading the service zone.
When a WD drive suffers a PCB failure (power surge, shorted TVS diode, blown motor driver), a simple board swap will not work. The replacement PCB has its own ROM data that does not match the patient drive's platter calibration. On boards that have a separate 8-pin ROM chip (typically numbered 25Pxx or 25Qxx), we desolder the chip from the dead board and transfer it to the donor board. On boards where the ROM is integrated into the Marvell controller, we use PC-3000's WD module to read the ROM from the service area of the platters (which requires at least a partially functional PCB) and write it to the replacement board.
WD My Passport and Elements external drives add another layer: hardware encryption. Even when the drive inside is a standard WD Blue or WD Green, the USB-SATA bridge board encrypts all data before it reaches the platters. Losing or damaging that bridge board means the encryption key is gone. We preserve and transplant the original bridge board electronics whenever possible. If the bridge board is destroyed, recovery depends on whether the encryption implementation allows key extraction from the board's controller chip.
A decade ago, a 2TB desktop drive used five platters and ten heads. Current 2TB drives use one or two platters. The platters are thinner, the tracks are narrower, and the heads fly closer to the surface. This means tighter mechanical tolerances and less margin for error during head swaps.
Donor matching for modern high-capacity drives requires more variables than older models. Matching the model number alone is insufficient. We match by firmware revision, head map configuration (which heads are active), manufacturing site code, and platter count. A 4TB WD Red manufactured in Thailand with firmware revision 82.00A82 will not accept heads from the same model manufactured in Malaysia with firmware 83.00A83. The adaptive parameters stored in the ROM are calibrated to the specific platter surfaces in each individual drive.
Start Your Free Estimate
Professional Recovery
Get a Free EstimateSecure Mail-In from Anywhere in the US
1 Business Day
- New York City 1 Business Day
- Los Angeles 1 Business Day
- Chicago 1 Business Day
- Seattle 1 Business Day
- Denver 1 Business Day
- ✓Use the box-in-box method: float a small box inside a larger box with 2 inches of bubble wrap.
- ✓Wrap the bare drive in an anti-static bag to prevent electrical damage.
- ✗Do not use packing peanuts. They compress during transit and allow heavy drives to strike the edge of the box.
Nationwide Hard Drive Recovery Service
Searching for hard drive recovery near you? Unless you live in Austin, TX, the closest qualified lab with PC-3000 equipment and clean bench capability may be hundreds of miles away. Most cities have zero professional HDD data recovery labs. The shops that advertise locally often ship your drive to a third-party lab anyway, adding a middleman, a markup, and a week of transit time.
Our mail-in hard drive recovery service eliminates the middleman. You ship directly to our Austin lab, your drive goes straight onto the bench, and you talk to the engineer doing the work. Turnaround is faster than most local options because there is no broker delay.
We process mail-in recoveries from all 50 states. The shipping process takes 1-2 business days via USPS Priority or FedEx. Pack your drive in an anti-static bag inside a padded box (no bubble wrap directly on the drive). We provide status updates from intake through delivery.
Why Mail-In Beats Local
- Direct access to PC-3000, DeepSpar, and ULPA-filtered clean bench
- No middleman markup; your invoice reflects lab time, not a broker's margin
- Talk to the technician, not a call center
- Same $100–$2,000 pricing whether you are in New York, Los Angeles, or Austin
How to Ship Your Drive
- Place the bare drive in an anti-static bag
- Wrap in 2+ inches of padding (foam or crumpled paper; not loose peanuts)
- Ship via USPS Priority Mail or FedEx Ground to our Austin lab
- Include your name, phone number, and a brief description of the problem
Our Recovery Process
- 1
Evaluate & Protect
- 2
Stabilize Access
- 3
Clean-Bench Mechanics
For clicking, beeping, or stuck heads: exact-match donor head swap on a validated laminar-flow bench.
- 4
Image First, Always
- 5
Recover from Image
- 6
Deliver & Purge
Typical timing: Healthy 1 TB images in a few hours; light bad sectors add days; "not detected"/firmware about a week; head swaps with donor parts 1-3 weeks. Severe platter damage may be unrecoverable; we will tell you when to save your money.
Before You Ship: What to Tell Us
A few details at intake save days of diagnostic time. When you contact us for a free estimate, include whatever you know from the list below. If you only know the symptom, that is enough to start.
Drive Details
- Model number (printed on the drive label, e.g., ST2000LM007, WD40EFRX)
- Capacity (500GB, 1TB, 2TB, etc.)
- Form factor (3.5-inch desktop or 2.5-inch laptop/portable)
- Firmware revision (if visible on the label)
Failure Context
- Symptom (clicking, beeping, not detected, asks to format)
- What happened (dropped, power surge, gradual slowdown, sudden failure)
- Prior attempts (ran recovery software, opened the drive, sent to another lab)
- Priority files (photos, databases, project files; helps us verify recovery)
Hard Drive Data Recovery Pricing
Hard drive data recovery costs $100–$2,000, depending on the failure type. Simple copies start at $100. File system recovery starts at $250. Firmware repair is $600–$900. Head swaps are $1,200–$1,500. Surface damage is $2,000. We provide a firm quote after a free evaluation.
Honest ranges so you can budget without a sales call. See our detailed pricing breakdown. After a free evaluation we give you a firm quote and honest assessment. If it turns out easier than expected, you pay less; not a flat "worst-case" tier. If we cannot get your data, you pay $0 (optional return shipping only). See all service pricing.
| Service Tier | Price | Description |
| Simple CopyLow complexity | $100 | Your drive works, you just need the data moved off it Functional drive; data transfer to new media Rush available: +$100 |
| File System RecoveryLow complexity | From $250 | Your drive isn't recognized by your computer, but it's not making unusual sounds File system corruption. Accessible with professional recovery software but not by the OS Starting price; final depends on complexity |
| Firmware RepairMedium complexity – PC-3000 required | $600–$900 | Your drive is completely inaccessible. It may be detected but shows the wrong size or won't respond Firmware corruption: ROM, modules, or translator tables corrupted; requires PC-3000 terminal access Standard drives at lower end; high-density drives at higher end |
| Head SwapHigh complexity – clean bench surgery50% deposit | $1,200–$1,500 | Your drive is clicking, beeping, or won't spin. The internal read/write heads have failed Head stack assembly failure. Transplanting heads from a matching donor drive on a clean bench 50% deposit required. Donor parts are consumed in the repair |
| Surface / Platter DamageHigh complexity – clean bench surgery50% deposit | $2,000 | Your drive was dropped, has visible damage, or a head crash scraped the platters Platter scoring or contamination. Requires platter cleaning and head swap 50% deposit required. Donor parts are consumed in the repair. Most difficult recovery type. |
All tiers: Free evaluation and firm quote before any paid work. No data, no fee on simple copy, file system, and firmware tiers. Head swap and surface damage require a 50% deposit because donor parts are consumed in the attempt.
Target drive: The destination drive we copy recovered data onto. You can supply your own or we provide one at cost. For ultra-high-capacity drives (20TB and above), the target drive costs approximately $400+ due to the large media required. All prices are plus applicable tax.
Pricing Comparison
| Scenario | Rossmann | DriveSavers / Big Labs |
| "Not detected" firmware issue | $600-$900 | $1,000-$2,500 |
| Head swap (exact donor, clean bench) | $1,200-$1,500 | $2,000-$7,000+ |
| Logical recovery (fast reads) | $100-$500 | $500-$1,500 |
| Evaluation fee | None | Free eval, but fees common elsewhere |
| Marketing Overhead | $0 (Word of Mouth) | Thousands [Read Analysis] |
Why the difference? We do not bankroll PPC ads, affiliate kickbacks, or vanity certificates. Your invoice reflects engineering time, donor parts, and imaging hours; not marketing overhead. Read our analysis of DriveSavers pricing.
Clean Rooms vs. Clean Benches
Competitors advertise multi-million-dollar “ISO Class 5 certified clean rooms” populated by technicians in full spacesuits. Clean room classifications are defined by ISO 14644-1, which specifies maximum allowable airborne particle concentrations. For data recovery, that level of whole-room infrastructure is marketing theater, not a technical requirement. What actually protects your platters is a validated laminar-flow clean bench with proper ULPA particle filtration and an image-first workflow.
| Standard | Max Particles ≥0.5µm per ft³ | Filtration Level | Required For HDD Work? |
| ISO 14644-1 Class 5 (Class 100) | 100 particles | 0.3µm HEPA | Industry marketing standard |
| ISO 14644-1 Class 4 (Class 10) | 10 particles | 0.1µm ULPA | Semiconductor manufacturing |
| Our Laminar Bench | Near-zero particles (validated) | 0.02 µm particle count | Localized ISO 14644-1 Class 4 equivalent |
Our ULPA-filtered laminar-flow clean bench achieves zero particle count at 0.02 µm during validation. ULPA filters are rated 99.999% efficient at the most-penetrating particle size (0.1-0.3 µm); the 0.02 µm reading comes from our TSI P-Trak 8525 particle counter. We validate our bench before every open-drive procedure and publish the results. The reading: localized ISO 14644-1 Class 4 equivalent conditions.
Why You Don't Need a $1M Cleanroom
Competitors charge $3,000+ and justify it with photos of technicians in full cleanroom suits. In this video, Louis demonstrates our laminar flow bench particle test side-by-side with a competitor's marketed cleanroom. The bench validates to localized ISO 14644-1 Class 4 equivalent conditions at 0.02 µm sensitivity. The cleanroom is designed for semiconductor fabs, not 30-minute head swaps. The difference in your invoice is real estate and marketing, not science.
Full article: Do You Really Need a Clean Room for Hard Drive Data Recovery?
Real Recovery Cases
Recovery outcomes depend on the condition of the drive when it arrives. If you stopped using it immediately, success rates remain high. If someone ran software on it, tried to open it, or kept powering it on, odds drop. Watch our documented recovery cases and judge for yourself.
Seagate ST2000LM007
Beeping after drop
Heads parked on platters. Unstick in clean bench, PC-3000 image with head map. 847GB Lightroom catalog recovered.
$400
Watch similar case →WD Blue 1TB
Clicking on startup
Firmware translator corrupt. Rebuilt with PC-3000, selective head imaging. QuickBooks DB verified, zero corruption.
$350
Watch process →LaCie Mobile 4TB
Not detected after surge
PCB damage. ROM/adaptives transfer to donor board. Full image, 3.2TB video files delivered.
$500
Watch similar case →Recovered After Failed Attempt
Seagate Barracuda 2TB
Returned "unrecoverable" by another lab
Previous shop opened the drive in an uncontrolled environment and contaminated the platters. We cleaned the platters, swapped heads from an exact-match donor, and recovered 1.8TB of family photos spanning 15 years.
$1,200
Watch difficult case →WD Ultrastar 8TB
Head swap recovery
Failed read/write heads on a WD enterprise drive. Donor heads sourced from matching firmware revision, swapped in clean bench, full 8TB image completed.
$1,200
Watch head swap case →Seagate Barracuda 1TB
Green light, no detection
Drive powers on with green LED but not recognized by any system. Firmware module corruption diagnosed via PC-3000 terminal. Modules rebuilt, full image extracted.
$600
Watch this case →Evidence Locker
Verified recovery cases from our lab. Filter by device type or failure mode.
133 verified recovery cases · Verify on Google Maps
Watch Our Engineers Work
We believe in total transparency. That is why we film our work. Watch Louis Rossmann and the team perform real data recovery procedures, from head swaps to firmware rebuilds, so you know exactly what happens to your drive.
Got an SSD instead? NVMe, M.2, SATA; different tech, same lab. We do controller repair, firmware fixes, and chip-off on unencrypted drives.
Safe to Try at Home
- ✓Try a different cable or port. USB cables fail more often than drives. Test with a known-good SATA or USB cable before assuming the drive is dead.
- ✓Check Disk Management (Windows) or Disk Utility (Mac). If the drive appears but has no letter, it often just needs a drive letter assigned, not recovery.
- ✓Use ddrescue to clone a readable drive. If the drive spins normally and reads (even slowly), you can safely image it with our free ddrescue guide before attempting file recovery.
Do NOT Do This
- ✗Do not open the hard drive. Exposing platters to unfiltered air introduces particles that cause permanent scratches. This is the #1 way people destroy their own data.
- ✗Do not put it in the freezer. The freezer trick is a myth that causes condensation damage and corrodes electronics.
- ✗Do not run CHKDSK or Disk Utility on a clicking/beeping drive. These tools attempt writes that can destroy weakened heads and turn a $400 recovery into a $1,500+ job or total loss.
- ✗Do not keep power-cycling a failing drive. Each spin-up attempt on a mechanically damaged drive worsens the damage. If it clicks, beeps, or grinds, power it off immediately.
When to Call a Professional
Do you have HIPAA or SOC 2 certification?
Can HDD be repaired?
Can you recover data from a dead hard drive?
What causes hard drive failure?
What is the difference between HDD and SSD data recovery?
Can data be recovered from an SSD after TRIM?
Guides & Resources
Research your options before making a decision. These guides help you understand when to DIY, when to hire a pro, and how to choose the right service.
Complete guide: DIY methods, when to use software, when to call a pro
Decision guide: Which approach is right for your situation?
How to Choose a Recovery Service
What to look for, red flags to avoid, questions to ask
Hard Drive Recovery Near Me
Nationwide mail-in service: Local vs. specialized labs
Emergency Recovery Service
Rush service for time-critical situations
Step-by-step ddrescue guide for drives that still read
Locations We Serve
NVMe, M.2, SATA solid state drives
RAID 0, 1, 5, 6, 10 arrays
The advertising tax explained
Labs we recommend by name
T2/M-series soldered SSDs
iMac/Mac Mini SSD+HDD hybrid volumes
Hikvision, Dahua, proprietary file systems
View complete catalog
Sources & References
- Backblaze Hard Drive Stats: Annualized failure rate data from a fleet of 340,000+ drives. Model-level reliability observations referenced for general manufacturer trends.
- ACE Lab PC-3000 Portable III: Industry-standard data recovery hardware and software used by professional labs worldwide. Manufacturer specifications referenced for tool capabilities.
- DeepSpar Disk Imager: Professional sector-level imaging tool with controlled retry and timeout features. Used in conjunction with PC-3000 for forensic imaging.
- Magnuson-Moss Warranty Act (15 U.S.C. 2302): Federal law referenced regarding independent repair and warranty rights. Manufacturers cannot void warranty for using an independent service provider.
- ISO 14644-1:2015: Classification of air cleanliness for cleanrooms and clean zones. ISO 14644-1 Class 5 (formerly Fed Std 209E Class 100) and ISO 14644-1 Class 4 (formerly Class 10) standards referenced in the clean bench comparison table.
- Pricing comparisons are based on publicly available information from competitor websites, verified as of January 2026. DriveSavers, Ontrack, and Geek Squad pricing ranges reflect published quotes and customer-reported data.
