Professional hard drive data recovery for clicking, beeping, and not detected drives. Our Austin lab processes HDD and SSD recoveries daily via local drop-off and nationwide mail-in. We extract files in-house with PC-3000 tools and validated clean-bench procedures. No data = no charge. Same equipment as enterprise labs at a fraction of the price.
Professional hard drive data recovery clean bench with head swap tools in Austin lab
Hard drive data recovery is the process of retrieving inaccessible data from failed, corrupted, or damaged hard disk drives (HDDs) and solid-state drives (SSDs). Also called hard drive recovery, hard disk recovery, or HDD data recovery, the goal is the same: get your files back from a drive that will not cooperate. Professional data retrieval services use specialized hardware such as the PC-3000 by ACE Lab and DeepSpar Disk Imager to recover data from hard drives when standard software solutions fail. According to Backblaze's Drive Stats data covering over 340,000 drives, the average annualized failure rate across all models is approximately 1.5–1.6%, meaning millions of drives fail each year and require professional recovery.
Recovery methods include:
  • Logical repair: Recovering corrupted partitions, formatted filesystems, and deleted files using sector-level imaging and advanced file carving. On modern SMR (Shingled Magnetic Recording) hard drives, deleted files may be permanently unrecoverable due to background UNMAP commands that function identically to solid-state TRIM, instantly returning zeroes to recovery software. Formatted SSDs also self-erase via TRIM, requiring controller-level intervention if supported.
  • Firmware repair: Restoring access to drives not detected by the system; includes ROM extraction, translator module rebuilding, and adaptive parameter correction using PC-3000-class tools
  • Mechanical repair: Clean bench head swaps and platter work for clicking or beeping drives with physical head damage, performed under ULPA-filtered laminar flow validated to 0.02 µm particle count
Last updated: March 2026
Hard drive data recovery costs $100–$2,000, depending on the failure type. Simple data copies from a functional drive cost $100. File system recovery for corrupted partitions, formatted drives, or volumes the operating system no longer recognizes starts at $250. Firmware repair, where the drive's internal software is corrupted and requires PC-3000 terminal access to rebuild translator tables, ROM data, and adaptive parameters, costs $600–$900. Mechanical failures that require a donor head swap on our laminar-flow clean bench, validated to 0.02 µm particle count, run $1,200–$1,500 and require a 50% deposit because donor parts are consumed in the procedure. The most severe tier covers platter surface damage from head crashes and starts at $2,000. Every recovery begins with a free evaluation and a firm quote before any work begins. If we cannot recover your data, you pay nothing.
Unlike labs that hide their data recovery prices or charge by capacity, our data recovery price structure is determined by the failure type and required diagnostic equipment, not by drive size.
Match Your Symptom to a Recovery Tier
The sound your drive makes (or does not make) tells us the failure type, which determines the recovery method and cost. Find your symptom below.
SymptomLikely FailureRecovery MethodPrice Range
Not detected, spins normallyFirmware / translator corruptionPC-3000 terminal, ROM rebuild$600–$900
Clicking or tickingHead failure or preamp damageDonor head swap on clean bench$1,200–$1,500
Beeping or buzzingHeads stuck to platters (stiction)Unstick + head swap$1,200–$1,500
Not spinning at allMotor seizure or PCB failurePCB repair / motor swap$600–$900 - $1,200–$1,500
Grinding or scrapingHead crash, platter contactPlatter cleaning + head swap$2,000
Watch a Real Recovery
We film our recoveries so you can see the process before sending your drive. This walkthrough covers a full head swap and PC-3000 imaging session.
Drives We Recover From
15 min read
What Hard Drive Recovery Customers Say
4.9 across 1,837+ verified Google reviews
Sent my hdd for data recovery, process was simple and I was able to pre-authorize an amount. They worked on my drive within 2 days of receiving it and the total cost was literally 1/10th of the amount of another service I got a quote from. Professional, quick, affordable. Nothing to complain about.
Andrew Hansen
My satisfaction with Rossmann Repair Group goes beyond just 5 stars. I had a hard drive die some time ago, but I had no idea where I could send it knowing it would be safe, or there being a chance I'd be ripped off.
Kyle Hartley (crazybangles)
Had a raid 0 array (windows storage pool) (failed 2tb Seagate, and a working 1tb wd blue) recovered last year, it was much cheaper than the $1500 to $3500 Canadian dollars i was quoted by a Canadian data recovery service. the price while expensive was a comparatively reasonable $900USD (about $1100 CAD at the time).
ChristopolisSeagate
Walked in with my wife's dead hard drive, walked out 20 minutes later with it fixed. They were friendly, professional, did the work in a snap, and saved me the hefty repair prices for other (mail in) hard drive recovery services!
Patrick Dughi
What's Happening to Your Drive?
Select your symptom for a free diagnosis
In most cases, yes. A "dead" hard drive usually means one of three things: the PCB has failed (power surge, shorted TVS diode), the firmware is corrupted (drive not detected, shows wrong capacity), or the read/write heads have failed (clicking, beeping). None of these conditions destroy the data stored on the platters. The data is magnetic; it persists even when the drive electronics cannot read it.
For PCB failures, we transfer the ROM chip (or extract ROM data via PC-3000) to a compatible donor board. For firmware corruption, we access the drive's terminal interface and rebuild translator modules and adaptive parameters. For head failures, we perform a donor head swap on our clean bench. Each of these scenarios has a different cost tier, but the data itself remains intact on the platters throughout.
The only scenario where data is permanently gone: the platter surfaces themselves are physically destroyed. This happens when a head crash scrapes the magnetic coating off the platters, or when someone runs a clicking drive long enough that the heads grind through the recording layer. If your drive stopped working after a crash or sudden failure, power it off immediately. Every second of contact removes data.
That depends on what is on the drive. If the files are irreplaceable (family photos, business records, legal documents, research data), the value of recovery exceeds the cost. If the files exist in backups or cloud storage, recovery is unnecessary.
The risk calculation is straightforward: you pay $0 to find out whether recovery is possible, and you only pay if we deliver your files. Compare that to national labs where a head swap can run $3,000 to $7,000 for the same procedure we perform at $1,200–$1,500.
Recovery time depends on the failure type and drive capacity. A healthy 1TB drive images in a few hours. Light bad sectors add one to three days as PC-3000 retries weak areas. Firmware corruption (drive not detected, wrong capacity) takes about a week, including terminal diagnostics and translator rebuilding.
Head swaps take one to three weeks because we need to source an exact-match donor drive with the correct firmware revision, head map, and manufacturing batch. Donor availability varies by model. Severe platter damage cases may be unrecoverable; we will tell you before spending your money. We provide a time estimate alongside the price quote after the free evaluation.
At a Glance
  • $Cost: From $100 for simple copies, $250–$2,000 for recovery (firm quote after free evaluation)
  • Equipment: PC-3000 Portable III + ULPA-filtered clean bench (ISO 14644-1 Class 4 equivalent) for mechanical failures
Estimate Your Recovery Cost
Select the symptoms your hard drive is showing to get an estimated cost range and recovery outlook. This is a starting point; we provide a firm quote after evaluating your drive for free.
No Hidden Fees — Transparent Flat-Rate Pricing
Select all symptoms that apply. This tool gives a rough estimate; your actual quote comes after our free evaluation.
Select symptoms above to see your estimated cost range and recovery likelihood.
15+ Years Experience
No Data = No Charge
In-House Austin Lab
Why Choose Our Austin Lab
We are not a middleman. We do not ship your drive to a mystery warehouse. Our certified techniciansrecover your data on-site in Austin using the same class of equipment as national labs: PC-3000, DeepSpar, laminar-flow clean benches, donor inventory, and microscopes. Visit our Austin lab page. You speak directly with the technician handling your case. No scripts. No sales team.
Local and Nationwide
All data recovery performed in our Austin lab. Mail-in accepted from all 50 states.
No Data, No Charge
If we cannot recover your data, you pay $0 (optional return shipping only).
Same Equipment, Lower Price
PC-3000 imaging, validated clean bench; without ad budgets or affiliate kickbacks.
Transparent Pricing
Clear ranges up-front; final quote after free evaluation; no surprise fees.
Direct Communication
Talk to your engineer, not a salesperson. Get straight answers.
Real Proof
2.49M+ YouTube subscribers and hundreds of hour-long recoveries on camera.
How We Compare to National Labs
All four companies listed below use PC-3000 hardware for firmware-level recovery. The difference between us and the national labs is overhead, not capability. Our pricing reflects engineering time and donor parts; theirs reflects advertising budgets, cleanroom real estate, and certification fees.
FeatureRossmann GroupDriveSaversOntrackGeek Squad
Average Cost$100–$2,000$2,000-$7,000$800-$3,000+$600-$2,500 (outsourced)
Work LocationIn-house Austin labNovato, CA facilityMultiple global labsOutsourced to partner labs
EquipmentPC-3000, DeepSpar, ULPA-filtered benchPC-3000, proprietary toolsPC-3000, proprietary toolsVaries by partner
No Data = No ChargeYes, alwaysDiagnostic fee may applyYesVaries
Direct Technician ContactYes, talk to your engineerThrough account managerThrough account managerStore staff only
Free EvaluationYesYesYes$50+ diagnostic fee
Proof of Work2.49M+ YouTube subscribers, hundreds of filmed recoveriesClient testimonials35+ year track recordBest Buy brand reputation
Data compiled from publicly available pricing and service information as of January 2026. Read our full comparison guide.
Drive Repair vs. Data Recovery
Many clients ask: "Can you repair my hard drive so I can use it again?"
Example: A Seagate ST2000LM007 arrived clicking after a 3-foot drop. We replaced all four read/write heads from a matched donor, imaged 1.87TB through PC-3000 using a head map to bypass damaged Head 2, and recovered 99.4% of the file structure. The original drive was recycled; data was returned on a new external drive.
Failure Types We Handle
Clicking hard drive →
Beeping drive →
Drive not detected →
Drive not spinning →
Logical and Mixed Failures
File system corruption →
Accidentally deleted files or formatted a conventional hard drive? If SMART is clean and reads are fast, DIY tools work. (Note: DIY software cannot recover deleted files on modern SSDs due to the TRIM command permanently wiping unmapped blocks). If reads slow or drop, stop and let us image with pro hardware before it degrades.
Bad sectors / SMART errors →
If SMART reports reallocated or pending sectors, the drive is physically degrading. We fast-pass good regions, then revisit weak areas with head-maps and conservative retries (DeepSpar/PC-3000). Goal: maximum image with minimum stress on the heads.
RAID and NAS recovery →
Enterprise Services →
Time-Critical Data Emergency?
Emergency Services →
Supported Models & Systems
Operating Systems
  • • MacOS (APFS, HFS+)
  • • Server / VMware (VMFS)
Computers
  • Laptop hard drives (Dell, HP, Lenovo, ASUS)
  • • Apple MacBooks (Pro, Air)
  • • All-in-One PCs
External Drives
  • • WD Passport / Elements
  • • Seagate Backup Plus
  • • LaCie Rugged
Storage Types
  • • 3.5" Desktop HDD
  • • 2.5" Laptop HDD
  • • USB Flash & SD Cards
External Hard Drive Recovery
Common external drive models we recover include Seagate Backup Plus Slim (Rosewood ST2000LM007), WD My Passport (SMR-based WD20SMZW), LaCie Rugged (often containing Seagate Barracuda mechanisms), and G-Technology G-DRIVE. External hard drive recovery pricing follows the same five tiers as internal drives: $100 to $2,000 depending on failure type.
Listen to Your Drive
The sound a failing hard drive makes reveals the failure type. Play each clip below and compare it to what your drive sounds like. If yours matches a mechanical failure (clicking, beeping, grinding), power it off immediately and contact us for a free evaluation.
Recovery by Manufacturer
Different manufacturers have different failure patterns. We track real reliability data from Backblaze's fleet of 340,000+ drives to understand model-specific issues and tailor our approach for each brand.
Seagate Recovery
Higher AFR
F3 terminal access, ROM extraction, and model-specific diagnostics. Rosewood slim drives and Barracuda models are our most frequent cases.
View Seagate reliability data →
Western Digital Recovery
Low AFR
Industry-leading failure rates. The PC-3000 WD module handles ROM/module repair and Ultrastar enterprise drives. My Passport and Elements external drives are frequent mail-in cases, often requiring specialized firmware patching.
View WD reliability data →
Toshiba Recovery
Canvio external drives and MQ/MG internal series. Toshiba drives use a unique head parking mechanism that frequently fails after drops. PC-3000 Toshiba module for firmware and translator repair.
View Toshiba recovery details →
Hitachi / HGST Recovery
Samsung Recovery
Maxtor Recovery
DiamondMax, OneTouch, MaxLine. Legacy Maxtor firmware and Seagate-era rebadges (STM models) require different PC-3000 modules. We maintain donor stock for legacy mechanisms out of production since 2006.
View Maxtor recovery details →
Fujitsu Recovery
MHW, MHZ, MHY laptop drives and MAP/MBA enterprise SCSI/SAS. Fujitsu exited the HDD market in 2009 (sold to Toshiba). The Toshiba MJA transitional series also uses Fujitsu firmware internally.
View Fujitsu recovery details →
Advanced Failure Modes by Drive Family
Each drive family has distinct firmware architecture and mechanical design. The failure mode dictates the recovery procedure. Generic "data recovery" approaches applied blindly to the wrong family can cause permanent data loss. Below is what we see on the bench, organized by the families that generate the most cases.
The Rosewood platform (ST500LM030, ST1000LM035, ST2000LM007, ST2000LM015) is Seagate's 2.5-inch slim portable drive. It weighs 90 grams. The top magnet is integrated into the lid via silver foil, making clean disassembly for head swaps harder than older Seagate designs. Rosewood drives are our single most common incoming case type.
The signature Rosewood failure is the LED error. When firmware corruption occurs, the drive outputs a continuous stream of LED status codes (such as LED:000000CC) over the serial terminal instead of reaching the F3 T> command prompt. Standard Seagate F3 terminal commands cannot execute while the LED error is active. The PC-3000 Seagate module includes a "Disable Subsystem" ROM function to suppress the LED output, but timing is critical: the unlock sequence must be sent (Ctrl+Z simultaneously with the unlock key) before the LED error stream begins, or the terminal session fails.
A third Rosewood-specific issue is media cache corruption. Rosewood drives use a media cache region on the platters to buffer writes before committing them to the final LBA locations. If power is lost during a cache flush, the mapping between cache sectors and their destination LBAs can become inconsistent. PC-3000's Seagate module can read and reconstruct the media cache map, but only if the heads are stable enough to read the cache zone without further degradation.
The recovery trap: WD SMR drives have a secondary translator in addition to the primary one. If a technician applies conventional (non-SMR) WD firmware repair procedures, the secondary translator can be altered or destroyed. The drive will then appear to function normally during diagnostics but will produce zeroed data on every read. This is permanent and unrecoverable. We use PC-3000's WD module with SMR-aware procedures that preserve both translator layers before any firmware manipulation begins.
WD Blue and WD Red SMR models released around 2020 (2TB, 3TB, 4TB, 6TB capacities) have shown elevated failure rates reported by multiple European data recovery labs. Western Digital has acknowledged an investigation into these failures. The most common failure pattern on these drives is Module 190 translator corruption, where the SMR-specific firmware module that maps logical sectors to shingled bands becomes partially written after a power loss or cache overflow.
Helium-Sealed Drives: One Shot at Recovery
Enterprise drives above 10TB (Seagate Exos X series, WD Ultrastar DC HC series, Toshiba MG series) are hermetically sealed and filled with helium gas. Helium has one-seventh the density of air, which reduces aerodynamic drag on the platters and allows the heads to fly at a lower height with tighter tolerances. This enables manufacturers to fit more platters (up to 10) into a standard 3.5-inch form factor.
Once a helium drive is opened, the helium escapes permanently. The heads were designed to fly in helium's lower-density environment. In normal air, the increased drag changes the fly height, and the heads can contact the platters within minutes to hours. There is no way to reseal a helium drive to factory specification outside the manufacturer's production line.
This means a head swap on a helium drive is a one-shot procedure. The donor drive must also be a helium drive of the same model family and firmware revision, because air-environment heads will not fly correctly in any remaining helium, and helium-spec heads will not fly correctly in air. We open the patient drive on our clean bench, install the donor heads, connect to PC-3000 immediately, and begin imaging. There is no "test fit" or second attempt; the imaging window closes as helium diffuses out.
Seagate's F3 firmware architecture covers the Barracuda 7200.11 through 7200.14, Barracuda LP, and the Momentus families. Each generation has distinct failure patterns. The 7200.11 (firmware SD15, SD1A) was notorious for a firmware bug that caused drives to brick on power-up; Seagate issued a firmware patch, but millions of unpatched drives remain in circulation. The 7200.14 (firmware CC46, CC4H) has a different problem: gradual system area degradation.
The system area (also called the service area or SA) is a reserved region on the platters that stores the drive's operating firmware, defect lists (P-list and G-list), SMART logs, and adaptive parameters. When the SA degrades due to weak heads or media defects in the service zone, the drive loses access to its own operating instructions. It may spin up but fail to identify, or identify with a BSY (busy) state that never resolves.
Recovery requires PC-3000's Seagate F3 module to access the terminal (Ctrl+Z to reach the T> prompt), read whatever SA modules remain, patch corrupted modules from a known-good donor, and rebuild the translator. On 7200.14 drives specifically, the P-list (primary defect list from manufacturing) and G-list (grown defect list from use) can become corrupted independently. If the G-list is lost, the drive attempts to read sectors that it had previously remapped, causing read errors across the image. We back up the original SA before any modification, reconstruct the defect lists, and image with head maps to work around weak heads reading the service zone.
When a WD drive suffers a PCB failure (power surge, shorted TVS diode, blown motor driver), a simple board swap will not work. The replacement PCB has its own ROM data that does not match the patient drive's platter calibration. On boards that have a separate 8-pin ROM chip (typically numbered 25Pxx or 25Qxx), we desolder the chip from the dead board and transfer it to the donor board. On boards where the ROM is integrated into the Marvell controller, we use PC-3000's WD module to read the ROM from the service area of the platters (which requires at least a partially functional PCB) and write it to the replacement board.
WD My Passport and Elements external drives add another layer: hardware encryption. Even when the drive inside is a standard WD Blue or WD Green, the USB-SATA bridge board encrypts all data before it reaches the platters. Losing or damaging that bridge board means the encryption key is gone. We preserve and transplant the original bridge board electronics whenever possible. If the bridge board is destroyed, recovery depends on whether the encryption implementation allows key extraction from the board's controller chip.
A decade ago, a 2TB desktop drive used five platters and ten heads. Current 2TB drives use one or two platters. The platters are thinner, the tracks are narrower, and the heads fly closer to the surface. This means tighter mechanical tolerances and less margin for error during head swaps.
Donor matching for modern high-capacity drives requires more variables than older models. Matching the model number alone is insufficient. We match by firmware revision, head map configuration (which heads are active), manufacturing site code, and platter count. A 4TB WD Red manufactured in Thailand with firmware revision 82.00A82 will not accept heads from the same model manufactured in Malaysia with firmware 83.00A83. The adaptive parameters stored in the ROM are calibrated to the specific platter surfaces in each individual drive.
Head Swap Donor Matching and PC-3000 Imaging
Donor Selection Criteria
  • Model family and firmware revision. A Seagate ST2000LM007 with firmware SBK2 will not accept heads from the same model running firmware SDM1. The firmware calibrates head fly height and write current to the specific head stack installed at the factory.
  • Head count and platter count. Manufacturers ship the same model number with different internal configurations depending on production run. A 2TB drive may use one platter with two heads or two platters with four heads. Installing a two-head stack into a four-head chassis leaves half the platters unreadable.
  • Manufacturing site and date code. Seagate drives manufactured in Wuxi (China) versus Korat (Thailand) can have different head stack assembly suppliers. The head geometry is nominally identical, but adaptive parameters written during factory calibration differ enough to cause read instability on marginal tracks.
  • Adaptive parameters. Each drive stores calibration data (fly height offsets, write current per head, and servo tuning values) in the system area of the platters and in the PCB ROM. On Western Digital drives with Marvell controllers, these parameters are partially stored in the controller IC itself. After a head swap, the new heads read the patient drive's adaptive parameters from the service area and attempt to operate with calibration data written for different physical heads. The closer the donor match, the smaller the gap between stored calibration and actual head behavior.
  • Preamplifier revision and micro-jog tolerance. The preamplifier chip on the head stack assembly (manufactured by Texas Instruments or Broadcom, depending on family) amplifies microvolt signals from the MR read elements into higher-amplitude analog signals for the read channel. Donor and patient drives must share the same preamp vendor and revision. Beyond the preamp, each head has a factory-calibrated MR Head Differential Micro-Jog value that defines the physical offset between the read and write elements on that specific slider. If the micro-jog values between donor and patient heads diverge outside a ~200 to 300 count tolerance, the drive will click on power-up because the read channel cannot lock onto the servo track. We check micro-jog compatibility in PC-3000's ROM editor before committing to the physical swap.
Pre-Swap Platter Inspection
Removing and installing the head stack assembly requires separating the heads from each other without letting them contact platter surfaces. We use duralumin head combs, CNC-machined to sub-0.01mm tolerances, sized specifically for each drive family. Duralumin (an aluminum-copper alloy) holds dimensional accuracy under the mechanical stress of separating spring-loaded heads. Plastic head separation tools, common in consumer data recovery kits, suffer from plastic deformation: they flex under load, allow heads to shift during extraction, and can cause the slider to contact and score the platter during what should be a non-contact procedure.
PC-3000's Data Extractor uses the head map to prioritize imaging. Stable heads read their zones first while the donor stack is freshest. Degraded heads are deferred to later passes with adjusted read timeouts and retry counts. If a head begins failing mid-image, the task skips to the next head rather than hammering the failing one until it scores the platter. This selective approach recovers the maximum amount of data within the limited lifespan of the donor heads.
Not every clicking drive needs a full mechanical head swap. When one head in a multi-head stack fails, PC-3000 can disable the failed head in the drive's MCU RAM so the remaining healthy heads continue reading their assigned platter surfaces. We build a head map first to identify which specific head is degrading. If heads 0, 1, and 3 are stable but head 2 produces read errors or triggers drive resets, we disable head 2 in firmware and image the data accessible to the three surviving heads.
Seagate Rosewood (2.5-inch portable drives): These single-platter, two-head drives are a high-volume head swap case for any data recovery lab. The top magnet is bonded to the lid with a foil seal, which must be separated without bending the lid or contaminating the platter. Rosewood drives have low motor torque, so stiction (heads stuck to platter) is a frequent co-occurring failure. If the heads are stuck, we free them manually before assessing whether the original heads can image or if a donor swap is necessary.
When an exact donor match cannot be sourced and the donor heads click on the patient drive, the micro-jog values stored in WD ROM Module 47 are the first thing we check. Module 47 stores per-head fly height offsets and read/write positioning parameters. If the patient's original micro-jog values and the donor's values are both known (extracted before the swap via PC-3000's WD ROM editor), we calculate an averaged configuration: splitting the difference between each parameter pair. Writing the averaged Module 47 back to the drive's service area can stabilize the read channel enough for the donor heads to track the patient's servo patterns. This procedure does not work on every drive; it depends on how far apart the two head stacks are in their factory calibration. But when the alternative is sourcing another donor and performing a second mechanical swap, parameter averaging is the lower-risk first attempt.
Helium drives (8TB+ enterprise): Head swaps on helium-sealed drives are single-attempt procedures. Once the hermetic seal is broken, the helium escapes and the heads lose their designed fly-height environment. The donor must also be a helium drive of the same family. We connect to PC-3000 immediately after installation and begin imaging at maximum throughput. There is no pause for head map testing on helium drives; the map is built live during the first imaging pass because every minute of exposure to air degrades head performance.
External portable hard drives from Western Digital (My Passport, Elements, Easystore) ship with PCBs that have a native USB interface soldered directly to the board. There is no SATA connector. While the PC-3000 Portable III can send vendor-specific commands over USB through its dedicated host port, a SATA conversion provides the timing stability needed for head map generation and selective imaging on a degraded drive after a head swap. Seagate portable externals (Backup Plus, One Touch) use a different design: the internal drive has a standard SATA connector attached to a detachable USB bridge board, so SATA access requires only removing the bridge.
For WD native USB drives, we convert the PCB to a SATA interface before any clean bench work. This requires desoldering the ROM chip (U12) from the USB board and transplanting it onto a compatible SATA donor PCB using a hot-air rework station. The ROM chip carries the drive's unique adaptive parameters; without it, the SATA board cannot initialize the motor or read the service area. Once SATA access is established, the standard head swap and PC-3000 imaging workflow proceeds as described above.
Start Your Free Estimate
Professional Recovery
Get a Free Estimate
FREE
DIY Recovery
Try Free DIY Guide
Mail-In Service
Mail-In Instructions
Transit Time
1 Business Day
Major Origins
  • New York City 1 Business Day
  • Los Angeles 1 Business Day
  • Chicago 1 Business Day
  • Seattle 1 Business Day
  • Denver 1 Business Day
Nationwide Hard Drive Recovery Service
Searching for hard drive recovery near you? Unless you live in Austin, TX, the closest qualified lab with PC-3000 equipment and clean bench capability may be hundreds of miles away. Most cities have zero professional HDD data recovery labs. The shops that advertise locally often ship your drive to a third-party lab anyway, adding a middleman, a markup, and a week of transit time.
Our mail-in hard drive recovery service eliminates the middleman. You ship directly to our Austin lab, your drive goes straight onto the bench, and you talk to the engineer doing the work. Turnaround is faster than most local options because there is no broker delay.
We process mail-in recoveries from all 50 states. The shipping process takes 1-2 business days via USPS Priority or FedEx. Pack your drive in an anti-static bag inside a padded box (no bubble wrap directly on the drive). We provide status updates from intake through delivery.
Why Mail-In Beats Local
  • Direct access to PC-3000, DeepSpar, and ULPA-filtered clean bench
  • No middleman markup; your invoice reflects lab time, not a broker's margin
  • Same $100–$2,000 pricing whether you are in New York, Los Angeles, or Austin
How to Ship Your Drive
Our Recovery Process
    Evaluate & Protect
    Stabilize Access
    Clean-Bench Mechanics
    For clicking, beeping, or stuck heads: exact-match donor head swap on a validated laminar-flow bench.
    Image First, Always
  5. 5
    Recover from Image
  6. 6
    Deliver & Purge
Typical timing: Healthy 1 TB images in a few hours; light bad sectors add days; "not detected"/firmware about a week; head swaps with donor parts 1-3 weeks. Severe platter damage may be unrecoverable; we will tell you when to save your money.
Before You Ship: What to Tell Us
A few details at intake save days of diagnostic time. When you contact us for a free estimate, include whatever you know from the list below. If you only know the symptom, that is enough to start.
Drive Details
Failure Context
Hard Drive Data Recovery Pricing
Hard drive data recovery costs $100–$2,000, depending on the failure type. Simple copies start at $100. File system recovery starts at $250. Firmware repair is $600–$900. Head swaps are $1,200–$1,500. Surface damage is $2,000. We provide a firm quote after a free evaluation.
Honest ranges so you can budget without a sales call. See our detailed pricing breakdown. After a free evaluation we give you a firm quote and honest assessment. If it turns out easier than expected, you pay less; not a flat "worst-case" tier. If we cannot get your data, you pay $0 (optional return shipping only). See all service pricing.
High complexityMost Common
Your drive is clicking, beeping, or won't spin. The internal read/write heads have failed
Target drive: The destination drive we copy recovered data onto. You can supply your own or we provide one at cost. For larger capacities (8TB, 10TB, 16TB and above), target drives cost $400+ extra. All prices are plus applicable tax.
Pricing Comparison
ScenarioRossmannDriveSavers / Big Labs
"Not detected" firmware issue$600-$900$1,000-$2,500
Head swap (exact donor, clean bench)$1,200-$1,500$2,000-$7,000+
Logical recovery (fast reads)$100-$500$500-$1,500
Evaluation feeNoneFree eval, but fees common elsewhere
Marketing Overhead$0 (Word of Mouth)Thousands [Read Analysis]
Why the difference? We do not bankroll PPC ads, affiliate kickbacks, or vanity certificates. Your invoice reflects engineering time, donor parts, and imaging hours; not marketing overhead. Read our analysis of DriveSavers pricing.
Clean Rooms vs. Clean Benches
Competitors advertise multi-million-dollar “ISO Class 5 certified clean rooms” populated by technicians in full spacesuits. Clean room classifications are defined by ISO 14644-1, which specifies maximum allowable airborne particle concentrations. For data recovery, that level of whole-room infrastructure is marketing theater, not a technical requirement. What actually protects your platters is a validated laminar-flow clean bench with proper ULPA particle filtration and an image-first workflow.
StandardMax Particles ≥0.5µm per ft³Filtration LevelRequired For HDD Work?
ISO 14644-1 Class 5 (Class 100)100 particles0.3µm HEPAIndustry marketing standard
ISO 14644-1 Class 4 (Class 10)10 particles0.1µm ULPASemiconductor manufacturing
Our Laminar BenchNear-zero particles (validated)0.02 µm particle count Localized ISO 14644-1 Class 4 equivalent
Our ULPA-filtered laminar-flow clean bench achieves zero particle count at 0.02 µm during validation. ULPA filters are rated 99.999% efficient at the most-penetrating particle size (0.1-0.3 µm); the 0.02 µm reading comes from our TSI P-Trak 8525 particle counter. We validate our bench before every open-drive procedure and publish the results. The reading: localized ISO 14644-1 Class 4 equivalent conditions.
Particle counter showing localized ISO 14644-1 Class 4 equivalent conditions during clean bench validation for data recovery
Our particle counter reading during validation: localized ISO 14644-1 Class 4 equivalent conditions at 0.02 µm sensitivity
Why You Don't Need a $1M Cleanroom
Competitors charge $3,000+ and justify it with photos of technicians in full cleanroom suits. In this video, Louis demonstrates our laminar flow bench particle test side-by-side with a competitor's marketed cleanroom. The bench validates to localized ISO 14644-1 Class 4 equivalent conditions at 0.02 µm sensitivity. The cleanroom is designed for semiconductor fabs, not 30-minute head swaps. The difference in your invoice is real estate and marketing, not science.
Full article: Do You Really Need a Clean Room for Hard Drive Data Recovery?
Real Recovery Cases
Recovery outcomes depend on the condition of the drive when it arrives. If you stopped using it immediately, success rates remain high. If someone ran software on it, tried to open it, or kept powering it on, odds drop. Watch our documented recovery cases and judge for yourself.
Seagate ST2000LM007
Beeping after drop
Heads parked on platters. Unstick in clean bench, PC-3000 image with head map. 847GB Lightroom catalog recovered.
$400
Watch similar case →
WD Blue 1TB
Clicking on startup
Firmware translator corrupt. Rebuilt with PC-3000, selective head imaging. QuickBooks DB verified, zero corruption.
$350
Watch process →
LaCie Mobile 4TB
Not detected after surge
PCB damage. ROM/adaptives transfer to donor board. Full image, 3.2TB video files delivered.
$500
Recovered After Failed Attempt
Seagate Barracuda 2TB
Returned "unrecoverable" by another lab
Previous shop opened the drive in an uncontrolled environment and contaminated the platters. We cleaned the platters, swapped heads from an exact-match donor, and recovered 1.8TB of family photos spanning 15 years.
$1,200
Watch difficult case →
WD Ultrastar 8TB
Head swap recovery
Failed read/write heads on a WD enterprise drive. Donor heads sourced from matching firmware revision, swapped in clean bench, full 8TB image completed.
$1,200
Watch head swap case →
Seagate Barracuda 1TB
Green light, no detection
Drive powers on with green LED but not recognized by any system. Firmware module corruption diagnosed via PC-3000 terminal. Modules rebuilt, full image extracted.
$600
Watch this case →
Evidence Locker
Verified recovery cases from our lab. Filter by device type or failure mode.
133 verified recovery cases · Verify on Google Maps
Watch Our Engineers Work
We believe in total transparency. That is why we film our work. Watch Louis Rossmann and the team perform real data recovery procedures, from head swaps to firmware rebuilds, so you know exactly what happens to your drive.
Got an SSD instead? NVMe, M.2, SATA; different tech, same lab. We do controller repair, firmware fixes, and chip-off on unencrypted drives.
SSD Recovery →
Safe to Try at Home
  • Try a different cable or port. USB cables fail more often than drives. Test with a known-good SATA or USB cable before assuming the drive is dead.
  • Check Disk Management (Windows) or Disk Utility (Mac). If the drive appears but has no letter, it often just needs a drive letter assigned, not recovery.
  • Use ddrescue to clone a readable drive. If the drive spins normally and reads (even slowly), you can safely image it with our free ddrescue guide before attempting file recovery.
Do NOT Do This
  • Do not open the hard drive. Exposing platters to unfiltered air introduces particles that cause permanent scratches. This is the #1 way people destroy their own data.
  • Do not put it in the freezer. The freezer trick is a myth that causes condensation damage and corrodes electronics.
  • Do not run CHKDSK or Disk Utility on a clicking/beeping drive. These tools attempt writes that can destroy weakened heads and turn a $400 recovery into a $1,500+ job or total loss.
  • Do not keep power-cycling a failing drive. Each spin-up attempt on a mechanically damaged drive worsens the damage. If it clicks, beeps, or grinds, power it off immediately.
When to Call a Professional
We do not publish a single success rate because it varies by failure type. Logical failures and firmware faults have very high recovery rates. Single-head replacements are also highly successful, while multi-platter or severe damage cases are more challenging. We publish raw, anonymized outcomes so you can see the reality by device type and failure mode.
Hard drive data recovery typically costs $100 to $2,000, depending on the failure type. Simple copies cost $100. File system recovery starts from $250. Firmware repairs (drive not detected, ROM corruption) cost $600 to $900. Head swaps for clicking or beeping drives run $1,200 to $1,500. Surface/platter damage starts at $2,000. By comparison, corporate labs like DriveSavers typically charge $2,000 to $7,000 for similar work. Price is driven by three factors: the device (HDD vs SSD), the problem (logical vs mechanical), and the company's overhead (in-house lab vs outsourced middlemen with ad budgets). We do all work on-site in Austin using PC-3000 tools (manufactured by ACE Lab) and do not buy ads, which keeps our pricing at $100 to $2,000 across 5 published tiers.
On a healthy 1 TB HDD, a full image reads in about 3-4 hours; with verification and copy-out, most standard jobs finish in 1-2 business days. Light bad sectors can add a few days. 'Not detected' or firmware issues often take around a week. Head swaps that require donor parts run 1-3 weeks. Severe platter damage can take weeks and may be unrecoverable.
Do you have HIPAA or SOC 2 certification?
No. SOC 2 audits cost $50,000+/year and get passed to customers as $3,000+ invoices. We invest in capability instead: PC-3000 tools, clean bench validated to 0.02 µm particle count, encrypted storage, and chain-of-custody documentation. We sign NDAs on request. Your device never leaves our Austin lab; access is limited to your assigned technician; we securely purge working copies after delivery.
No; and that's a feature, not a bug. Being 'authorized' usually means agreeing to price minimums and sending complex work to third-party labs. Our reputation was built on being UNAUTHORIZED while fixing problems the 'authorized' shops couldn't. We do the work here, talk to you directly, and charge you for the work done; not for a logo on our wall.
Often, yes. If you DON'T power it on wet, DON'T bake it with heat, and get it to us quickly, success can be 70-80%. Salt water is worse than fresh; fire cases usually include corrosive residue from suppression. Once in-lab, we address PCB corrosion/shorts, transfer ROM/adaptives, and image with controlled timeouts.
Logical failure: the hardware works but the file system doesn't; deleted files, bad partition table, light bad sectors. Physical failure: the hardware is damaged; stuck heads, seized spindle, shorted PCB, platter scratches. Logical jobs are cheaper ($100-$500) with near-certain odds; physical jobs need clean-bench/donor parts ($1,200-$2,000) and success depends on damage severity.
Professional hard drive data recovery follows an image-first workflow using industry-standard tools like the PC-3000 Portable III (manufactured by ACE Lab) and DeepSpar Disk Imager. The six steps: (1) Evaluate symptoms safely and protect the media; never run CHKDSK or Disk Utility on a failing disk. (2) If the drive is not detected, correct firmware or translator issues; this involves ROM extraction, service area module repair, and adaptive parameter correction. (3) Acquire a sector-level image with write-blocking and controlled retries using DeepSpar or ddrescue. (4) If heads are stuck or weak, unstick or replace them on a laminar-flow clean bench using exact-match donor parts, then resume imaging. (5) Rebuild the file system from the clone image and extract files; this works across NTFS, HFS+, APFS, ext4, XFS, and ZFS. (6) Verify file integrity and deliver the data on a new device. Typical turnaround is 5 to 10 business days for standard cases.
Can HDD be repaired?
Yes; often enough to recover your data, but a repaired hard drive shouldn't be reused. In professional hard drive data recovery we stabilize the drive with PC-3000-class tools, correct firmware/PCB issues or replace stuck/bad heads on a clean bench using an exact-match donor, then acquire a write-blocked sector-by-sector image. Files are recovered from the image, verified, and delivered on a new drive; the old failing HDD is retired.
No. Removing a drive from a computer does not erase it. Data remains on the platters (HDD) or NAND (SSD) until it is securely overwritten or cryptographically erased. If you need a wipe, request a verified secure-erase with certificate.
Yes, but most complex work (head swaps, clean-bench cases) is outsourced to partner labs rather than done in-store, which adds time, cost, and a middleman. We perform all recovery in-house in Austin with clean-bench procedures, PC-3000 imaging, direct technician communication, and transparent pricing.
The read/write heads are stuck on the platter surface, preventing the spindle motor from starting. On most Seagate 2.5-inch external drives (including Rosewood), this is a mechanical fault, not a cable or power issue. Power-cycling, tapping the drive, opening the HDA, or running repair utilities can scratch platters and turn a $1,200-$1,500 head swap into a $2,000+ surface-damage case. If the data matters, stop powering it.
The read/write heads are stuck on the platters, preventing the motor from spinning. Most LaCie external drives contain a Seagate HDD inside, and this stiction failure is common after a drop on 2.5-inch models. Do not power-cycle, tap, or open the drive; those moves turn a $1,200-$1,500 head swap into a $2,000+ surface-damage case.
Use software if: the drive spins up normally, appears in Disk Management/Disk Utility, and has no clicking or grinding sounds. Try ddrescue or R-Studio on a clone. Use a lab if: the drive clicks, beeps, grinds, isn't detected, or shows S.M.A.R.T. errors. Running software on a physically failing drive can destroy the heads and turn a $600 firmware job into a $1,500 head swap or total loss.
We use the same PC-3000 equipment and achieve comparable results for $100-$2,000 across 5 published tiers, compared to DriveSavers' typical $2,000-$7,000. DriveSavers has 40+ years of experience and SOC 2 certification. We keep pricing lower by performing all work in-house at our Austin lab and not buying ads.
Can you recover data from a dead hard drive?
Yes. A 'dead' hard drive usually means one of three things: not powering on (PCB failure), not spinning (seized motor or stuck heads), or not detected (firmware corruption). All three are recoverable. PCB failures need ROM chip transplant to a donor board. Stuck heads need clean bench unstick or head swap. Firmware corruption needs PC-3000 module repair. The platters holding your data are rarely damaged; the access mechanism is. Stop powering it and ship it for evaluation.
Yes; clicking drives are one of the most common data recovery cases. The clicking sound (sometimes called 'click of death') occurs when the read/write heads cannot locate their servo tracks on the platter surface. Servo tracks are pre-written positioning data embedded in each platter during manufacturing; they guide the heads to the correct cylinder. When the head assembly or preamplifier is damaged, the heads repeatedly seek and fail to lock onto the servo pattern, producing the rhythmic clicking. Common causes include physical shock (dropped drives), age-related head degradation, and preamplifier failure. We stabilize access using PC-3000, create a head map to disable failing heads while imaging from healthy heads, and use controlled retry parameters to recover sectors in weak zones. In severe cases, we perform an exact-match donor head swap on our laminar-flow clean bench validated to 0.02 µm particle count. Recovery success depends on whether the damaged heads caused platter scoring before the drive was powered off. The sooner you stop powering a clicking drive, the better the recovery odds.
Yes. External hard drives (WD Passport, Seagate Backup Plus, LaCie Rugged, G-Technology) contain regular HDDs or SSDs inside a USB enclosure. We remove the drive from the enclosure and connect directly via SATA, bypassing potential USB controller issues. The recovery process is identical to internal drives: logical, firmware, or mechanical repair depending on the failure. Common external drive failures include dropped drives (head damage), beeping 2.5-inch Seagates (stuck heads), and PCB damage from power surges.
Yes, when the data is irreplaceable. For businesses, lost client records, financial data, or intellectual property often justifies $600-$2,000 in recovery fees. For individuals, irreplaceable family photos, years of creative work, or graduate research are typically worth the investment. Our no-data-no-charge policy removes financial risk; you only pay if we successfully recover your files. We provide a free evaluation and will honestly tell you if recovery is unlikely to succeed, saving you from spending money on a lost cause.
What causes hard drive failure?
Hard drives fail from four main causes: (1) Mechanical wear; head crashes, bearing seizure, and motor failure increase with age and physical shock. (2) Electronic damage; power surges, PCB shorts, and controller failure from unstable power supply. (3) Firmware corruption; ROM errors, translator bugs, and service area module damage that prevent the drive from identifying correctly. (4) Logical errors; file system corruption, accidental deletion, and partition table damage from software issues or improper shutdowns. According to Backblaze's Drive Stats data covering 340,000+ drives, the average annualized failure rate is approximately 1.5-1.6%, with individual models ranging from under 1% to over 8% for certain older Seagate enterprise models. External factors like overheating, moisture, and sudden physical impacts accelerate all types of failure.
We desolder the encryption chip from the failed USB bridge board and pair it with a working PCB, or use PC-3000 Portable to work through the bridge directly. WD My Passport drives are 2.5-inch portable drives that commonly fail from drops and cable yanks. Recent models use hardware encryption on the USB bridge board; if the bridge fails, the drive data is encrypted and unreadable even over SATA. Older My Passport models without encryption are more straightforward: we remove the drive from the enclosure and image via SATA. Common failures include stuck heads from drops and PCB shorts from cheap USB cables.
Toshiba (now Kioxia for enterprise) drives have unique firmware architecture that requires Toshiba-specific modules in PC-3000. The MQ/MG series laptop drives are common in older laptops and frequently fail from head parking failures after years of use. Canvio external drives contain standard Toshiba 2.5-inch mechanisms. We maintain Toshiba donor stock and PC-3000 Toshiba modules for firmware repair. Recovery success rates are comparable to Seagate and WD; the main challenge is donor availability for less common models.
A drive that won't spin has either a seized spindle motor, stuck heads preventing rotation, or a dead PCB. We diagnose by listening and testing electrically. Stuck heads: we unstick or replace them on a clean bench ($1,200-$1,500). Seized motor: we can sometimes free it or transplant the platters to a donor chassis ($2,000). Dead PCB: we transplant the ROM chip to a compatible donor board ($250-$900). The platters hold your data regardless of why the motor isn't spinning.
It depends on the extent of the damage. Light platter scratches from brief head contact: we can often recover 80-95% of data by imaging around damaged zones with controlled retries. Severe scoring from prolonged operation with damaged heads: recovery drops, sometimes to 50% or less of files. Circular scoring (ring of death): data in the scored zone is typically unrecoverable, but data on undamaged tracks can often be saved. The earlier you stop powering a clicking drive, the less platter damage accumulates.
Often yes, depending on temperature exposure. Hard drive platters store data as magnetic orientation in a cobalt-chromium-platinum alloy layer. The Curie temperature of cobalt alloy is approximately 1,115 degrees Celsius (source: CRC Handbook of Chemistry and Physics); below that threshold, the magnetic orientation that encodes your data remains stable. Most residential fires reach 600 to 800 degrees Celsius at the ceiling (per NFPA fire dynamics research), and the aluminum drive chassis and platter substrate provide thermal insulation, so the interior of the drive often stays below the critical threshold. The bigger threat is water from fire suppression systems, which causes PCB corrosion, connector oxidation, and head contamination. We clean and inspect fire-damaged drives on our clean bench, transplant ROM chips to donor PCBs, and image the platters. Success varies: smoke-exposed drives recover well; drives from the fire's epicenter are more challenging.
Yes. Bad sectors are one of the most common and most recoverable failure types. We use PC-3000 and DeepSpar to image the drive with controlled read retries, timeouts, and head disabling to work around bad areas. A drive with scattered bad sectors typically yields 95-100% data recovery. A drive with a growing bad sector zone may indicate degrading heads, in which case we image aggressively before the heads fail completely. Do not run CHKDSK or fsck on a drive with growing bad sectors. These tools make write operations that can worsen head damage.
It depends on the encryption type. Hardware-encrypted drives (WD My Passport, some Seagate externals): we can recover data if the encryption chip is functional, since the key is stored on the USB bridge PCB. We transplant the chip to a working board. Software-encrypted drives (BitLocker, FileVault, VeraCrypt): we can recover the encrypted volume, but you need the password or recovery key to decrypt it. We cannot bypass encryption without the key. Full-disk encryption with a working key: we image the drive, then you decrypt the image. The encryption itself doesn't affect our ability to recover the raw data; it's the decryption step that requires your key.
What is the difference between HDD and SSD data recovery?
HDD recovery focuses on mechanical repair (head swaps, spindle motor work, platter transplants) and firmware correction, while SSD recovery focuses on controller repair, firmware reconstruction, and flash translation layer (FTL) rebuilding. On unencrypted drives where the controller is beyond repair, chip-off NAND reading is a last resort; this does not apply to Apple T2/M-series devices or other hardware-encrypted drives, where the AES-256 keys reside in the SoC and desoldered NAND yields only ciphertext. The underlying storage is different: HDDs store data magnetically on spinning platters; SSDs store data electrically in NAND flash memory by trapping electrons in each memory cell. Modern 3D NAND, used in virtually all current SSDs, employs charge trap technology, storing electrons in an insulating silicon nitride layer. Legacy planar NAND used conductive floating gates; both approaches are non-volatile, retaining data without power. HDDs are generally more recoverable from physical damage because the magnetic data persists on platters independent of electronics. SSDs with controller failure can be harder because the data is scrambled across multiple NAND chips using wear leveling algorithms, and recovering it requires the controller's mapping table or reverse-engineering the data layout. We use the PC-3000 Portable III for HDD recovery and PC-3000 SSD for solid-state drive cases.
Both provide adequate particle control for data recovery when properly validated; the difference is scope, not recovery outcome. A clean room is an entire room maintained at ISO 14644-1 Class 5, allowing a maximum of 3,520 particles (0.5 microns or larger) per cubic meter. A clean bench (laminar flow hood) creates a localized clean zone at the workstation using HEPA or ULPA filtration with unidirectional airflow. For head swaps and platter work, the critical area is the 12-inch zone directly above the open drive, not the entire room. Our laminar-flow bench uses ULPA filtration and is validated to zero particle count at 0.02 µm using a TSI P-Trak 8525 particle counter, achieving localized ISO 14644-1 Class 4 equivalent conditions before every open-drive procedure. Large corporate labs use clean rooms partly as marketing ('ISO 14644-1 Class 5 cleanroom'), but recovery success rates are determined by technician skill and tooling, not room size or facility overhead.
PC-3000 is professional data recovery hardware and software manufactured by ACE Lab. It is the industry-standard tool used by virtually every legitimate data recovery lab worldwide, including DriveSavers, Ontrack, and independent labs. PC-3000 communicates directly with a hard drive's firmware through vendor-specific terminal commands (Seagate F3, WD ATA, Toshiba UART); it can repair corrupted service area modules, extract and rewrite ROM data, disable failing heads via head maps, control read timeouts at the sector level, and bypass drive-level security locks. Without PC-3000-class tools, a recovery lab is limited to software-only approaches that cannot fix firmware corruption, translator failure, or mechanical issues. We use the PC-3000 Portable III (the current generation) along with DeepSpar Disk Imager for controlled sector-level imaging with configurable retry and timeout parameters.
Three factors inflate data recovery pricing: (1) Advertising: companies spending $50-100K/month on Google Ads pass that cost to customers. (2) Outsourcing: middleman companies accept drives, ship them to a partner lab, and add their markup. (3) Certification overhead: SOC 2 audits ($50K+/year), ISO cleanroom maintenance, and enterprise sales teams all get factored into per-job pricing. We keep costs at $100-$2,000 across 5 published tiers because we do all work in-house in Austin, don't buy ads, and invest in equipment rather than certifications. Same PC-3000 tools, same clean bench procedures, lower overhead.
Your drive never leaves our Austin lab. Only your assigned technician accesses your data. We work on encrypted workstations and recovered data is stored on encrypted drives. We sign NDAs on request. After you confirm receipt of your recovered data, we securely wipe all working copies from our systems. We don't subcontract, outsource, or ship drives to partner labs. Chain-of-custody documentation is available for legal and compliance cases.
These tiers describe recovery complexity: Level 1 (Logical, $100-$500): The drive works physically but data is lost from deletion, formatting, or corruption. Recovery is software-based from a cloned image. Level 2 (Firmware, $600-$900): The drive spins but isn't detected or misidentifies. Requires PC-3000 firmware repair to restore access, then imaging. Level 3 (Mechanical, $1,200-$2,000): The drive has physical damage: stuck/failed heads, seized motor, PCB failure. Requires clean bench work, donor parts, and specialized imaging. Most companies use similar tiers but charge 2-3x more at each level.
We use the same class of tools (PC-3000, DeepSpar) and achieve comparable results on consumer and small business drives for $100-$2,000, compared to Ontrack's typical $800-$3,000+. Key differences: we offer direct technician communication (Ontrack uses account managers), transparent upfront pricing (vs quote-based), and YouTube-documented processes. Ontrack (Kroll Ontrack) has 35+ years of experience and may be better suited for complex enterprise RAID arrays; we are a better fit for individual drives and small business recoveries where cost transparency matters.
We perform comparable recovery work for $100-$2,000 versus SecureData's typical $500-$3,000+. Key differences: SecureData has multiple locations (we are Austin-only with mail-in nationwide), SecureData emphasizes certifications like ISO 4 cleanroom (we emphasize transparent pricing and YouTube-documented work), and SecureData uses account managers (we connect you directly with your technician). Both companies do legitimate in-house recovery work.
Most local computer repair shops don't have PC-3000 tools or clean bench facilities. They either attempt software-only recovery (which fails on firmware and mechanical issues) or ship your drive to a partner lab and add their markup. Questions to ask any local shop: Do you have PC-3000 equipment? Do you do head swaps in-house? Can I speak to the technician? If the answers are no, they're middlemen. We do all work in-house in Austin with PC-3000 Portable III and a validated clean bench. Mail-in takes 2-3 days transit and we provide prepaid return shipping.
For most HDD recoveries, yes, typically 50-70% less. A clicking drive head swap that DriveSavers quotes at $2,500-$7,000, we typically complete for $1,200-$1,500. A firmware repair they quote at $1,500-$2,000, we handle for $600-$900. The work is the same: PC-3000 diagnosis, clean bench head swaps, sector-level imaging. The price difference comes from overhead: DriveSavers spends heavily on advertising, maintains an ISO 14644-1 Class 5 cleanroom (vs our localized ISO 14644-1 Class 4 equivalent bench), has SOC 2 certification ($50K+/year), and employs a larger support staff. We invest in tools and keep overhead low.
Can data be recovered from an SSD after TRIM?
No, once TRIM has been processed by the controller. TRIM (defined in the ATA Command Set as 'Data Set Management') tells the SSD controller to erase blocks that no longer contain valid data. Once the controller processes the TRIM command, it zeroes or unmaps those NAND flash pages, making recovery of trimmed files impossible. However, TRIM only affects deleted files on a healthy, powered-on SSD. If your SSD has a controller failure, firmware corruption, or will not power on, the TRIM queue has not executed and the raw NAND data remains intact. We can recover data from failed SSDs by repairing the controller firmware with the PC-3000 SSD tool from ACE Lab, or on unencrypted drives, by reading NAND chips directly (chip-off). Chip-off does not apply to Apple T2/M-series hardware or other drives with hardware-bound encryption, where the decryption keys never leave the SoC. If files were accidentally deleted on a working SSD, time is critical. Modern operating systems issue TRIM commands promptly to unmap deleted data, and most modern SSD controllers return zeroes for trimmed addresses immediately. However, a sudden power-loss or hardware failure occurring before the controller's background garbage collection physically erases the NAND cells can occasionally leave raw data intact at the silicon level.
On modern high-density drives, no. Once data is overwritten, the original magnetic pattern is destroyed. The myth that overwritten data can be recovered with an electron microscope originates from Peter Gutmann's 1996 paper 'Secure Deletion of Data from Magnetic and Solid-State Memory,' which studied low-density MFM/RLL drives. Modern drives use perpendicular magnetic recording (PMR) at track densities exceeding 500,000 tracks per inch; at this density, a single overwrite pass is sufficient to make the original data unrecoverable. NIST Special Publication 800-88 ('Guidelines for Media Sanitization') confirms that a single-pass overwrite is adequate for modern magnetic media. This means: if you deleted files and then wrote new data to the same sectors, those files are gone. Files in sectors that have not yet been overwritten can still be recovered via file carving techniques.
Grinding (as opposed to clicking) usually means the spindle motor bearing has seized or the heads are dragging across the platter surface. Power off immediately. Do not attempt to power it on again. Grinding with heads on platters causes progressive surface damage that destroys data zones. This is a clean bench case requiring either head replacement, motor/platter transplant, or both. Ship the drive to us unpowered with padding. Grinding drives have lower recovery rates than clicking drives because surface damage is typically more extensive, but recovery is often still possible for data outside the damaged zones.
Yes. Mac HDDs use HFS+ or APFS file systems, both of which we fully support. Fusion Drives combine an SSD and HDD into a single logical volume managed by macOS Core Storage; we image both components and reconstruct the Fusion volume. T2-chip Macs with hardware encryption require your Mac login password or recovery key to decrypt after imaging. For older Macs (pre-late 2017 without T2), recovery is straightforward; same HDD recovery process regardless of whether it was in a Mac or PC. We also recover data from failed Mac SSDs (soldered NAND on 2016+ MacBooks).
HDD data recovery addresses mechanical and firmware failures in spinning-platter drives: head replacements, motor repairs, ROM extraction, and translator module rebuilding using PC-3000 UDMA. SSD data recovery targets controller failures and NAND corruption in solid-state drives: PC-3000 SSD terminal commands, controller chip replacement, or direct NAND chip-off reads using a BGA rework station and flash reader. HDDs store data magnetically on platters; the data persists even when the drive is powered off and mechanically failed. SSDs store data as electrical charges in NAND cells; if the controller fails, the data is intact but inaccessible without bypassing or replacing the controller. HDD recovery costs $100 to $2,000. SSD recovery costs $200 to $1,500.
You can mail in your drive from anywhere in the United States. Most cities do not have a qualified data recovery lab with PC-3000 equipment and clean bench capability. Local shops that advertise hard drive recovery often ship your drive to a third-party lab, adding cost, transit time, and a middleman. Our mail-in service cuts that out: you ship directly to our Austin, TX lab via USPS Priority or FedEx (1-2 business days), we diagnose and recover in-house, and ship your data back on a new drive. Pricing is $100 to $2,000 regardless of where you are located. Pack your drive in an anti-static bag with 2+ inches of padding.
Look for three things. First, verify the lab owns PC-3000 by ACE Lab and a laminar-flow clean bench; these are the baseline tools for professional HDD data recovery. Ask to see equipment photos or videos. Second, check for published pricing. If a company will not quote a range before you ship your drive, the final bill will surprise you. Our five tiers run from $100 (simple copy) to $2,000 (platter damage), posted publicly on our site. Third, ask who does the work. If the company outsources to a partner lab, you are paying a markup for a middleman. We perform all recovery in-house at our Austin lab and you speak directly with the engineer handling your case.
Hard drive data recovery costs $100 to $2,000 across five published tiers. A simple data copy from a working drive costs $100. File system recovery (corrupted partitions, formatted volumes) starts at $250. Firmware repair for drives that spin but are not detected costs $600 to $900; this requires PC-3000 terminal access to rebuild translator tables and adaptive parameters. Clicking or beeping drives that need a donor head swap on our clean bench run $1,200 to $1,500 and require a 50% deposit because the donor drive is consumed. Platter surface damage starts at $2,000. Corporate labs like DriveSavers charge $2,000 to $7,000 for the same procedures. We keep pricing lower by performing all work in-house in Austin and not buying ads. Every recovery starts with a free evaluation and a firm quote; if we cannot recover your data, you pay nothing.
The hard drive recovery price is determined by the failure type, not the storage capacity. A 500GB drive and a 10TB drive cost the same if they both need a head swap ($1,200 to $1,500). The five pricing tiers map directly to the severity of the problem. Tier 1: the drive works and you need a copy ($100). Tier 2: file system damage, drive accessible with professional tools ($250+). Tier 3: firmware corruption, drive not recognized by any computer ($600 to $900). Tier 4: mechanical failure requiring donor parts and clean bench work ($1,200 to $1,500). Tier 5: platter scoring from a head crash ($2,000). Larger capacity drives take longer to image once stabilized, but the imaging time does not change the price tier. We quote a fixed price after a free evaluation so there are no surprises.
Hard disk data recovery cost varies by failure category. Logical failures (accidental deletion, formatting, partition corruption) cost $100 to $500. On older PMR hard drives, deleted files are usually recoverable through sector-level imaging and file carving. On modern SMR drives, deleted files may be permanently gone because the drive zeros mapped sectors via background UNMAP commands, functioning identically to SSD TRIM. Firmware failures (drive spins but is not detected, shows 0 GB, or identifies with the wrong model number) cost $600 to $900 and require PC-3000 terminal-level repair. Mechanical failures (clicking, beeping, grinding, no spin) cost $1,200 to $2,000 and require donor parts, clean bench procedures, and sector-level imaging with head maps.
No. Hard drive data recovery prices for external drives follow the same $100 to $2,000 tier structure as internal drives. An external drive is a standard 2.5-inch or 3.5-inch mechanism inside a USB enclosure. If only the enclosure electronics (USB bridge board) failed and the internal drive is healthy, the recovery falls into the lowest tiers. If the drive was dropped while running, causing head damage inside the enclosure, it needs a $1,200 to $1,500 head swap. One complication specific to external drives: recent WD My Passport models use hardware encryption on the USB bridge board. If that board is destroyed, we must transplant the encryption chip to a working board to access the data. This does not change the pricing tier but does add complexity to the diagnosis.
Recovering data from a clicking hard drive costs $1,200 to $1,500. Clicking means the read/write heads are damaged and cannot lock onto the servo tracks embedded in the platters. Recovery requires opening the drive on a laminar-flow clean bench validated to 0.02 micron particle count, removing the failed head stack assembly, and installing matched donor heads from a compatible drive with the same firmware revision and head map. The donor drive is destroyed in this process, which is why this tier requires a 50% upfront deposit for parts. After the head swap, we image the drive through PC-3000 using head maps to route around any weak or damaged heads. If the clicking drive ran for an extended period before being powered off, the heads may have scored the platters, pushing the case into the $2,000 platter damage tier.
Clicking indicates the read/write heads are failing, not the circuit board. Heads click when they cannot lock onto the servo tracks and repeatedly reset to the park position. A new PCB will not fix damaged heads. Separately, even when the PCB itself is the problem (shorted TVS diode, damaged motor driver), swapping boards requires transferring the ROM chip from the original PCB to the donor. The ROM stores factory-calibrated adaptive parameters unique to the internal head stack and motor. A donor PCB without the original ROM will power the drive but fail to read data because the calibration values do not match the installed components.
Professional data recovery labs do not charge per gigabyte. The cost is determined by the failure type and the equipment required to fix it, not by how much data is on the platters. Repairing a corrupted translator table on a 500GB drive and a 10TB drive both require the same PC-3000 terminal session and the same diagnostic labor; the price for both is $600 to $900. A head swap on our 0.02 micron ULPA-filtered clean bench costs $1,200 to $1,500 whether the drive holds 250GB or 8TB, because the donor parts and bench time are identical. Some competitors advertise per-gigabyte or capacity-based pricing (e.g., charging $300 for drives under 2TB and $600 for drives over 8TB for the same failure type). That model penalizes customers with larger drives for no technical reason. Our five published tiers run from $100 to $2,000 based strictly on failure severity: simple copy, file system recovery, firmware repair, head swap, or surface damage.
Seagate data recovery costs $100 to $2,000 depending on the failure mode, not the specific model. Seagate Barracuda desktop drives (ST1000DM010, ST2000DM008, ST4000DM004) most commonly fail from firmware corruption or gradual head degradation. Firmware repairs requiring PC-3000 F3 terminal access to patch corrupted System Area modules cost $600 to $900. The Seagate Rosewood family (ST1000LM035, ST2000LM007) is our single most common incoming case. These 2.5-inch portable drives have low motor torque; after a drop, the heads stick to the platter surface and the drive beeps instead of spinning. Releasing stiction and performing a donor head swap places the recovery in the $1,200 to $1,500 tier because the donor drive is consumed. Seagate Exos and IronWolf enterprise drives use the same pricing tiers; the added complexity of high-capacity helium-filled mechanisms does not change the tier structure.
Laptop data recovery costs $100 to $2,000 using the same five tiers as desktop drives. Older laptops (Dell Latitude, HP ProBook, Lenovo ThinkPad, ASUS VivoBook manufactured before 2018) typically contain 2.5-inch mechanical hard drives from Seagate, Western Digital, or Toshiba. If the laptop was dropped while the drive was spinning, the read/write heads likely crashed into the platters. That impact bypasses the $100 and $250 logical tiers and requires a $1,200 to $1,500 donor head swap on our clean bench. If the heads scored the platter surface during the crash, the case escalates to the $2,000 surface damage tier. Laptops that sat on a desk and simply stopped being recognized usually have firmware corruption ($600 to $900) or file system damage ($250). Modern laptops with soldered NVMe SSDs follow SSD recovery pricing instead; those start at $200.
Sources & References
  1. Backblaze Hard Drive Stats: Annualized failure rate data from a fleet of 340,000+ drives. Model-level reliability observations referenced for general manufacturer trends.
  2. ACE Lab PC-3000 Portable III: Industry-standard data recovery hardware and software used by professional labs worldwide. Manufacturer specifications referenced for tool capabilities.
  3. DeepSpar Disk Imager: Professional sector-level imaging tool with controlled retry and timeout features. Used in conjunction with PC-3000 for forensic imaging.
  4. Magnuson-Moss Warranty Act (15 U.S.C. 2302): Federal law referenced regarding independent repair and warranty rights. Manufacturers cannot void warranty for using an independent service provider.
  5. ISO 14644-1:2015: Classification of air cleanliness for cleanrooms and clean zones. ISO 14644-1 Class 5 (formerly Fed Std 209E Class 100) and ISO 14644-1 Class 4 (formerly Class 10) standards referenced in the clean bench comparison table.
  6. Pricing comparisons are based on publicly available information from competitor websites, verified as of January 2026. DriveSavers, Ontrack, and Geek Squad pricing ranges reflect published quotes and customer-reported data.
Free return shipping
